commit 5fc194ea6d34dfad9833d3043ce41d6c52aff39a upstream.
Add missing break statement in order to prevent the code from falling
through to case CRYPTO_ALG_TYPE_AHASH.
Fixes: aeb4c132f33d ("crypto: talitos - Convert to new AEAD interface")
Cc: stable@vger.kernel.org
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Reviewed-by: Christophe Leroy <christophe.leroy@c-s.fr>
commit 4bbfb839259a9c96a0be872e16f7471b7136aee5 upstream.
In that mode, hardware ICV verification is not supported.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Fixes: 7405c8d7ff97 ("crypto: talitos - templates for AEAD using HMAC_SNOOP_NO_AFEU")
commit 7ede4c36cf7c6516986ee9d75b197c8bf73ea96f upstream.
For decrypt, req->cryptlen includes the size of the authentication
part while all functions of the driver expect cryptlen to be
the size of the encrypted data.
As it is not expected to change req->cryptlen, this patch
implements local calculation of cryptlen.
Fixes: 9c4a79653b35 ("crypto: talitos - Freescale integrated security engine (SEC) driver")
commit d84cc9c9524ec5973a337533e6d8ccd3e5f05f2b upstream.
ECB's ivsize must be 0.
Fixes: 5e75ae1b3cef ("crypto: talitos - add new crypto modes")
commit ee483d32ee1a1a7f7d7e918fbc350c790a5af64a upstream.
When data size is not a multiple of the alg's block size,
the SEC generates an error interrupt and dumps the registers.
And for NULL size, the SEC does just nothing and the interrupt
is awaited forever.
This patch ensures the data size is correct before submitting
the request to the SEC engine.
Fixes: 4de9d0b547b9 ("crypto: talitos - Add ablkcipher algorithms")
commit b9a05b6041cb9810a291315569b2af0d63c3680a upstream.
CTR has a blocksize of 1.
commit 1ba34e71e9e56ac29a52e0d42b6290f3dc5bfd90 upstream.
Although the HW accepts any size and silently truncates
it to the correct length, the extra tests expects EINVAL
to be returned when the key size is not valid.
[ Upstream commit c9cca7034b34a2d82e9a03b757de2485c294851c ]
The MPC885 reference manual states:
SEC Lite-initiated 8xx writes can occur only on 32-bit-word boundaries, but
reads can occur on any byte boundary. Writing back a header read from a
non-32-bit-word boundary will yield unpredictable results.
In order to ensure that, cra_alignmask is set to 3 for SEC1.
[ Upstream commit eae55a586c3c8b50982bad3c3426e9c9dd7a0075 ]
The driver assumes that the ICV is as a single piece in the last
element of the scatterlist. This assumption is wrong.
This patch ensures that the ICV is properly handled regardless of
the scatterlist layout.
[ Upstream commit 3e03e792865ae48b8cfc69a0b4d65f02f467389f ]
Selftests report the following:
[ 2.984845] alg: skcipher: cbc-aes-talitos encryption test failed (wrong output IV) on test vector 0, cfg="in-place"
[ 2.995377] 00000000: 3d af ba 42 9d 9e b4 30 b4 22 da 80 2c 9f ac 41
[ 3.032673] alg: skcipher: cbc-des-talitos encryption test failed (wrong output IV) on test vector 0, cfg="in-place"
[ 3.043185] 00000000: fe dc ba 98 76 54 32 10
[ 3.063238] alg: skcipher: cbc-3des-talitos encryption test failed (wrong output IV) on test vector 0, cfg="in-place"
[ 3.073818] 00000000: 7d 33 88 93 0f 93 b2 42
This above dumps show that the actual output IV is indeed the input IV.
This is due to the IV not being copied back into the request.
This patch fixes that.
Reviewed-by: Horia Geantă <horia.geanta@nxp.com>
commit a1a42f84011fae6ff08441a91aefeb7febc984fc upstream.
The talitos driver has two ways to perform AEAD depending on the
HW capability. Some HW support both. It is needed to give them
different names to distingish which one it is for instance when
a test fails.
commit 1bea445b0a022ee126ca328b3705cd4df18ebc14 upstream.
[ 2.364486] WARNING: CPU: 0 PID: 60 at ./arch/powerpc/include/asm/io.h:837 dma_nommu_map_page+0x44/0xd4
[ 2.373579] CPU: 0 PID: 60 Comm: cryptomgr_test Tainted: G W 4.20.0-rc5-00560-g6bfb52e23a00-dirty #531
[ 2.384740] NIP: c000c540 LR: c000c584 CTR: 00000000
[ 2.389743] REGS: c95abab0 TRAP: 0700 Tainted: G W (4.20.0-rc5-00560-g6bfb52e23a00-dirty)
[ 2.400042] MSR: 00029032 <EE,ME,IR,DR,RI> CR: 24042204 XER: 00000000
[ 2.406669]
[ 2.406669] GPR00: c02f2244 c95abb60 c6262990 c95abd80 0000256a 00000001 00000001 00000001
[ 2.406669] GPR08: 00000000 00002000 00000010 00000010 24042202 00000000 00000100 c95abd88
[ 2.406669] GPR16: 00000000 c05569d4 00000001 00000010 c95abc88 c0615664 00000004 00000000
[ 2.406669] GPR24: 00000010 c95abc88 c95abc88 00000000 c61ae210 c7ff6d40 c61ae210 00003d68
[ 2.441559] NIP [c000c540] dma_nommu_map_page+0x44/0xd4
[ 2.446720] LR [c000c584] dma_nommu_map_page+0x88/0xd4
[ 2.451762] Call Trace:
[ 2.454195] [c95abb60] [82000808] 0x82000808 (unreliable)
[ 2.459572] [c95abb80] [c02f2244] talitos_edesc_alloc+0xbc/0x3c8
[ 2.465493] [c95abbb0] [c02f2600] ablkcipher_edesc_alloc+0x4c/0x5c
[ 2.471606] [c95abbd0] [c02f4ed0] ablkcipher_encrypt+0x20/0x64
[ 2.477389] [c95abbe0] [c02023b0] __test_skcipher+0x4bc/0xa08
[ 2.483049] [c95abe00] [c0204b60] test_skcipher+0x2c/0xcc
[ 2.488385] [c95abe20] [c0204c48] alg_test_skcipher+0x48/0xbc
[ 2.494064] [c95abe40] [c0205cec] alg_test+0x164/0x2e8
[ 2.499142] [c95abf00] [c0200dec] cryptomgr_test+0x48/0x50
[ 2.504558] [c95abf10] [c0039ff4] kthread+0xe4/0x110
[ 2.509471] [c95abf40] [c000e1d0] ret_from_kernel_thread+0x14/0x1c
[ 2.515532] Instruction dump:
[ 2.518468] 7c7e1b78 7c9d2378 7cbf2b78 41820054 3d20c076 8089c200 3d20c076 7c84e850
[ 2.526127] 8129c204 7c842e70 7f844840 419c0008 <0fe00000> 2f9e0000 54847022 7c84fa14
[ 2.533960] ---[ end trace bf78d94af73fe3b8 ]---
[ 2.539123] talitos ff020000.crypto: master data transfer error
[ 2.544775] talitos ff020000.crypto: TEA error: ISR 0x20000000_00000040
[ 2.551625] alg: skcipher: encryption failed on test 1 for ecb-aes-talitos: ret=22
IV cannot be on stack when CONFIG_VMAP_STACK is selected because the stack
cannot be DMA mapped anymore.
This patch copies the IV into the extended descriptor.
commit c56c2e173773097a248fd3bace91ac8f6fc5386d upstream.
This patch moves the mapping of IV after the kmalloc(). This
avoids having to unmap in case kmalloc() fails.
commit 2b1227301a8e4729409694e323b72c064c47cb6b upstream.
For SEC 2.x+, cipher in length must contain only the ciphertext length.
In case of using hardware ICV checking, the ICV length is provided via
the "extent" field of the descriptor pointer.
Cc: <stable@vger.kernel.org> # 4.8+
Fixes: 549bd8bc5987 ("crypto: talitos - Implement AEAD for SEC1 using HMAC_SNOOP_NO_AFEU")
Reported-by: Horia Geantă <horia.geanta@nxp.com>
Tested-by: Horia Geantă <horia.geanta@nxp.com>
[backported to 4.9.y, 4.14.y]
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit 87a81dce53b1ea61acaeefa5191a0376a2d1d721 upstream.
Performing the hash of an empty file leads to a kernel Oops
[ 44.504600] Unable to handle kernel paging request for data at address 0x0000000c
[ 44.512819] Faulting instruction address: 0xc02d2be8
[ 44.524088] Oops: Kernel access of bad area, sig: 11 [#1]
[ 44.529171] BE PREEMPT CMPC885
[ 44.532232] CPU: 0 PID: 491 Comm: md5sum Not tainted 4.15.0-rc8-00211-g3a968610b6ea #81
[ 44.540814] NIP: c02d2be8 LR: c02d2984 CTR: 00000000
[ 44.545812] REGS: c6813c90 TRAP: 0300 Not tainted (4.15.0-rc8-00211-g3a968610b6ea)
[ 44.554223] MSR: 00009032 <EE,ME,IR,DR,RI> CR: 48222822 XER: 20000000
[ 44.560855] DAR: 0000000c DSISR: c0000000
[ 44.560855] GPR00: c02d28fc c6813d40 c6828000 c646fa40 00000001 00000001 00000001 00000000
[ 44.560855] GPR08: 0000004c 00000000 c000bfcc 00000000 28222822 100280d4 00000000 10020008
[ 44.560855] GPR16: 00000000 00000020 00000000 00000000 10024008 00000000 c646f9f0 c6179a10
[ 44.560855] GPR24: 00000000 00000001 c62f0018 c6179a10 00000000 c6367a30 c62f0000 c646f9c0
[ 44.598542] NIP [c02d2be8] ahash_process_req+0x448/0x700
[ 44.603751] LR [c02d2984] ahash_process_req+0x1e4/0x700
[ 44.608868] Call Trace:
[ 44.611329] [c6813d40] [c02d28fc] ahash_process_req+0x15c/0x700 (unreliable)
[ 44.618302] [c6813d90] [c02060c4] hash_recvmsg+0x11c/0x210
[ 44.623716] [c6813db0] [c0331354] ___sys_recvmsg+0x98/0x138
[ 44.629226] [c6813eb0] [c03332c0] __sys_recvmsg+0x40/0x84
[ 44.634562] [c6813f10] [c03336c0] SyS_socketcall+0xb8/0x1d4
[ 44.640073] [c6813f40] [c000d1ac] ret_from_syscall+0x0/0x38
[ 44.645530] Instruction dump:
[ 44.648465] 38c00001 7f63db78 4e800421 7c791b78 54690ffe 0f090000 80ff0190 2f870000
[ 44.656122] 40befe50 2f990001 409e0210 813f01bc <8129000c> b39e003a 7d29c214 913e003c
This patch fixes that Oops by checking if src is NULL.
Fixes: 6a1e8d14156d4 ("crypto: talitos - making mapping helpers more generic")
commit 70d355ccea899dad47dc22d3a4406998f55143fd upstream.
ctr-aes-talitos test fails as follows on SEC2
[ 0.837427] alg: skcipher: Test 1 failed (invalid result) on encryption for ctr-aes-talitos
[ 0.845763] 00000000: 16 36 d5 ee 34 f8 06 25 d7 7f 8e 56 ca 88 43 45
[ 0.852345] 00000010: f9 3f f7 17 2a b2 12 23 30 43 09 15 82 dd e1 97
[ 0.858940] 00000020: a7 f7 32 b5 eb 25 06 13 9a ec f5 29 25 f8 4d 66
[ 0.865366] 00000030: b0 03 5b 8e aa 9a 42 b6 19 33 8a e2 9d 65 96 95
This patch fixes the descriptor type which is special for CTR AES
Fixes: 5e75ae1b3cef6 ("crypto: talitos - add new crypto modes")
commit fbb22137c4d9bab536958b152d096fb3f98020ea upstream.
sg_link_tbl_len shall be used instead of cryptlen, otherwise
SECs which perform HW CICV verification will fail.
commit 6cda075aff67a1b9b5ba1b2818091dc939643b6c upstream.
sha224 AEAD test fails with:
[ 2.803125] talitos ff020000.crypto: DEUISR 0x00000000_00000000
[ 2.808743] talitos ff020000.crypto: MDEUISR 0x80100000_00000000
[ 2.814678] talitos ff020000.crypto: DESCBUF 0x20731f21_00000018
[ 2.820616] talitos ff020000.crypto: DESCBUF 0x0628d64c_00000010
[ 2.826554] talitos ff020000.crypto: DESCBUF 0x0631005c_00000018
[ 2.832492] talitos ff020000.crypto: DESCBUF 0x0628d664_00000008
[ 2.838430] talitos ff020000.crypto: DESCBUF 0x061b13a0_00000080
[ 2.844369] talitos ff020000.crypto: DESCBUF 0x0631006c_00000080
[ 2.850307] talitos ff020000.crypto: DESCBUF 0x0631006c_00000018
[ 2.856245] talitos ff020000.crypto: DESCBUF 0x063100ec_00000000
[ 2.884972] talitos ff020000.crypto: failed to reset channel 0
[ 2.890503] talitos ff020000.crypto: done overflow, internal time out, or rngu error: ISR 0x20000000_00020000
[ 2.900652] alg: aead: encryption failed on test 1 for authenc-hmac-sha224-cbc-3des-talitos: ret=22
This is due to SHA224 not being supported by the HW. Allthough for
hash we are able to init the hash context by SW, it is not
possible for AEAD. Therefore SHA224 AEAD has to be deactivated.
commit f384cdc4faf350fdb6ad93c5f26952b9ba7c7566 upstream.
Crypto manager test report the following failures:
[ 3.061081] alg: skcipher: setkey failed on test 5 for ecb-des-talitos: flags=100
[ 3.069342] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-talitos: flags=100
[ 3.077754] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-talitos: flags=100
This is due to setkey being expected to detect weak keys.
commit e04a61bebc5da1535b6f194b464295b8d558e2fc upstream.
On SEC2, when using the old descriptors type (hmac snoop no afeu)
for doing IPsec, the CICV out pointeur points out of the allocated
memory.
[ 2.502554] =============================================================================
[ 2.510740] BUG dma-kmalloc-256 (Not tainted): Redzone overwritten
[ 2.516907] -----------------------------------------------------------------------------
[ 2.516907]
[ 2.526535] Disabling lock debugging due to kernel taint
[ 2.531845] INFO: 0xde858108-0xde85810b. First byte 0xf8 instead of 0xcc
[ 2.538549] INFO: Allocated in 0x806181a9 age=0 cpu=0 pid=58
[ 2.544229] __kmalloc+0x374/0x564
[ 2.547649] talitos_edesc_alloc+0x17c/0x48c
[ 2.551929] aead_edesc_alloc+0x80/0x154
[ 2.555863] aead_encrypt+0x30/0xe0
[ 2.559368] __test_aead+0x5a0/0x1f3c
[ 2.563042] test_aead+0x2c/0x110
[ 2.566371] alg_test_aead+0x5c/0xf4
[ 2.569958] alg_test+0x1dc/0x5a0
[ 2.573305] cryptomgr_test+0x50/0x70
[ 2.576984] kthread+0xd8/0x134
[ 2.580155] ret_from_kernel_thread+0x5c/0x64
[ 2.584534] INFO: Freed in ipsec_esp_encrypt_done+0x130/0x240 age=6 cpu=0 pid=0
[ 2.591839] ipsec_esp_encrypt_done+0x130/0x240
[ 2.596395] flush_channel+0x1dc/0x488
[ 2.600161] talitos2_done_4ch+0x30/0x200
[ 2.604185] tasklet_action+0xa0/0x13c
[ 2.607948] __do_softirq+0x148/0x6cc
[ 2.611623] irq_exit+0xc0/0x124
[ 2.614869] call_do_irq+0x24/0x3c
[ 2.618292] do_IRQ+0x78/0x108
[ 2.621369] ret_from_except+0x0/0x14
[ 2.625055] finish_task_switch+0x58/0x350
[ 2.629165] schedule+0x80/0x134
[ 2.632409] schedule_preempt_disabled+0x38/0xc8
[ 2.637042] cpu_startup_entry+0xe4/0x190
[ 2.641074] start_kernel+0x3f4/0x408
[ 2.644741] 0x3438
[ 2.646857] INFO: Slab 0xdffbdb00 objects=9 used=1 fp=0xde8581c0 flags=0x0080
[ 2.653978] INFO: Object 0xde858008 @offset=8 fp=0xca4395df
[ 2.653978]
[ 2.661032] Redzone de858000: cc cc cc cc cc cc cc cc ........
[ 2.669029] Object de858008: 00 00 00 02 00 00 00 02 00 6b 6b 6b 1e 83 ea 28 .........kkk...(
[ 2.677628] Object de858018: 00 00 00 70 1e 85 80 64 ff 73 1d 21 6b 6b 6b 6b ...p...d.s.!kkkk
[ 2.686228] Object de858028: 00 20 00 00 1e 84 17 24 00 10 00 00 1e 85 70 00 . .....$......p.
[ 2.694829] Object de858038: 00 18 00 00 1e 84 17 44 00 08 00 00 1e 83 ea 28 .......D.......(
[ 2.703430] Object de858048: 00 80 00 00 1e 84 f0 00 00 80 00 00 1e 85 70 10 ..............p.
[ 2.712030] Object de858058: 00 20 6b 00 1e 85 80 f4 6b 6b 6b 6b 00 80 02 00 . k.....kkkk....
[ 2.720629] Object de858068: 1e 84 f0 00 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b ....kkkkkkkkkkkk
[ 2.729230] Object de858078: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
[ 2.737830] Object de858088: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
[ 2.746429] Object de858098: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
[ 2.755029] Object de8580a8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
[ 2.763628] Object de8580b8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
[ 2.772229] Object de8580c8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
[ 2.780829] Object de8580d8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
[ 2.789430] Object de8580e8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 73 b0 ea 9f kkkkkkkkkkkks...
[ 2.798030] Object de8580f8: e8 18 80 d6 56 38 44 c0 db e3 4f 71 f7 ce d1 d3 ....V8D...Oq....
[ 2.806629] Redzone de858108: f8 bd 3e 4f ..>O
[ 2.814279] Padding de8581b0: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ
[ 2.822283] CPU: 0 PID: 0 Comm: swapper Tainted: G B 4.9.50-g995be12679 #179
[ 2.831819] Call Trace:
[ 2.834301] [dffefd20] [c01aa9a8] check_bytes_and_report+0x100/0x194 (unreliable)
[ 2.841801] [dffefd50] [c01aac3c] check_object+0x200/0x530
[ 2.847306] [dffefd80] [c01ae584] free_debug_processing+0x290/0x690
[ 2.853585] [dffefde0] [c01aec8c] __slab_free+0x308/0x628
[ 2.859000] [dffefe80] [c05057f4] ipsec_esp_encrypt_done+0x130/0x240
[ 2.865378] [dffefeb0] [c05002c4] flush_channel+0x1dc/0x488
[ 2.870968] [dffeff10] [c05007a8] talitos2_done_4ch+0x30/0x200
[ 2.876814] [dffeff30] [c002fe38] tasklet_action+0xa0/0x13c
[ 2.882399] [dffeff60] [c002f118] __do_softirq+0x148/0x6cc
[ 2.887896] [dffeffd0] [c002f954] irq_exit+0xc0/0x124
[ 2.892968] [dffefff0] [c0013adc] call_do_irq+0x24/0x3c
[ 2.898213] [c0d4be00] [c000757c] do_IRQ+0x78/0x108
[ 2.903113] [c0d4be30] [c0015c08] ret_from_except+0x0/0x14
[ 2.908634] --- interrupt: 501 at finish_task_switch+0x70/0x350
[ 2.908634] LR = finish_task_switch+0x58/0x350
[ 2.919327] [c0d4bf20] [c085e1d4] schedule+0x80/0x134
[ 2.924398] [c0d4bf50] [c085e2c0] schedule_preempt_disabled+0x38/0xc8
[ 2.930853] [c0d4bf60] [c007f064] cpu_startup_entry+0xe4/0x190
[ 2.936707] [c0d4bfb0] [c096c434] start_kernel+0x3f4/0x408
[ 2.942198] [c0d4bff0] [00003438] 0x3438
[ 2.946137] FIX dma-kmalloc-256: Restoring 0xde858108-0xde85810b=0xcc
[ 2.946137]
[ 2.954158] FIX dma-kmalloc-256: Object at 0xde858008 not freed
This patch reworks the handling of the CICV out in order
to properly handle all cases.
commit ec8c7d14acc0a477429d3a6fade5dab72c996c82 upstream.
AEAD tests fail when destination SG list has more than 1 element.
[ 2.058752] alg: aead: Test 1 failed on encryption for authenc-hmac-sha1-cbc-aes-talitos
[ 2.066965] 00000000: 53 69 6e 67 6c 65 20 62 6c 6f 63 6b 20 6d 73 67
00000010: c0 43 ff 74 c0 43 ff e0 de 83 d1 20 de 84 8e 54
00000020: de 83 d7 c4
[ 2.082138] alg: aead: Test 1 failed on encryption for authenc-hmac-sha1-cbc-aes-talitos
[ 2.090435] 00000000: 53 69 6e 67 6c 65 20 62 6c 6f 63 6b 20 6d 73 67
00000010: de 84 ea 58 c0 93 1a 24 de 84 e8 59 de 84 f1 20
00000020: 00 00 00 00
[ 2.105721] alg: aead: Test 1 failed on encryption for authenc-hmac-sha1-cbc-3des-talitos
[ 2.114259] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74
00000010: 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 74 65
00000020: 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72
00000030: 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63
00000040: 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65
00000050: 65 72 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53
00000060: 72 63 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20
00000070: 63 65 65 72 73 74 54 20 6f 6f 4d 20 6e 61 0a 79
00000080: c0 50 f1 ac c0 50 f3 38 c0 50 f3 94 c0 50 f5 30
00000090: c0 99 74 3c
[ 2.166410] alg: aead: Test 1 failed on encryption for authenc-hmac-sha1-cbc-3des-talitos
[ 2.174794] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74
[ 2.226486] alg: No test for authenc(hmac(sha224),cbc(aes)) (authenc-hmac-sha224-cbc-aes-talitos)
[ 2.236459] alg: No test for authenc(hmac(sha224),cbc(aes)) (authenc-hmac-sha224-cbc-aes-talitos)
[ 2.247196] alg: aead: Test 1 failed on encryption for authenc-hmac-sha224-cbc-3des-talitos
[ 2.255555] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74
00000090: c0 99 74 3c c0 96 e5 b8
[ 2.309004] alg: aead: Test 1 failed on encryption for authenc-hmac-sha224-cbc-3des-talitos
[ 2.317562] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74
[ 2.370710] alg: aead: Test 1 failed on encryption for authenc-hmac-sha256-cbc-aes-talitos
[ 2.379177] 00000000: 53 69 6e 67 6c 65 20 62 6c 6f 63 6b 20 6d 73 67
[ 2.397863] alg: aead: Test 1 failed on encryption for authenc-hmac-sha256-cbc-aes-talitos
[ 2.406134] 00000000: 53 69 6e 67 6c 65 20 62 6c 6f 63 6b 20 6d 73 67
[ 2.424789] alg: aead: Test 1 failed on encryption for authenc-hmac-sha256-cbc-3des-talitos
[ 2.433491] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74
00000090: c0 99 74 3c c0 96 e5 b8 c0 96 e9 20 c0 00 3d dc
[ 2.488832] alg: aead: Test 1 failed on encryption for authenc-hmac-sha256-cbc-3des-talitos
[ 2.497387] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74
commit 886a27c0fc8a34633aadb0986dba11d8c150ae2e upstream.
md5sum on some files gives wrong result
Exemple:
With the md5sum from libkcapi:
c15115c05bad51113f81bdaee735dd09 test
With the original md5sum:
bbdf41d80ba7e8b2b7be3a0772be76cb test
This patch fixes this issue
commit afd62fa26343be6445479e75de9f07092a061459 upstream.
Kernel crypto tests report the following error at startup
[ 2.752626] alg: hash: Test 4 failed for sha224-talitos
[ 2.757907] 00000000: 30 e2 86 e2 e7 8a dd 0d d7 eb 9f d5 83 fe f1 b0
00000010: 2d 5a 6c a5 f9 55 ea fd 0e 72 05 22
This patch fixes it
commit 56136631573baa537a15e0012055ffe8cfec1a33 upstream.
Today, md5sum fails with error -ENOKEY because a setkey
function is set for non hmac hashing algs, see strace output below:
mmap(NULL, 378880, PROT_READ, MAP_SHARED, 6, 0) = 0x77f50000
accept(3, 0, NULL) = 7
vmsplice(5, [{"bin/\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 378880}], 1, SPLICE_F_MORE|SPLICE_F_GIFT) = 262144
splice(4, NULL, 7, NULL, 262144, SPLICE_F_MORE) = -1 ENOKEY (Required key not available)
write(2, "Generation of hash for file kcap"..., 50) = 50
munmap(0x77f50000, 378880) = 0
This patch ensures that setkey() function is set only
for hmac hashing.
commit 03d2c5114c95797c0aa7d9f463348b171a274fd4 upstream.
An updated patch that also handles the additional key length requirements
for the AEAD algorithms.
The max keysize is not 96. For SHA384/512 it's 128, and for the AEAD
algorithms it's longer still. Extend the max keysize for the
AEAD size for AES256 + HMAC(SHA512).
Fixes: 357fb60502ede ("crypto: talitos - add sha224, sha384 and sha512 to existing AEAD algorithms")
Signed-off-by: Martin Hicks <mort@bork.org>
Acked-by: Horia Geantă <horia.geanta@nxp.com>
This will allow IPSEC on SEC1
SEC1 doesn't have IPSEC_ESP descriptor type but it is able to perform
IPSEC using HMAC_SNOOP_NO_AFEU, which is also existing on SEC2
In order to be able to define descriptors templates for SEC1 without
breaking SEC2+, we have to give lower priority to HMAC_SNOOP_NO_AFEU
so that SEC2+ selects IPSEC_ESP and not HMAC_SNOOP_NO_AFEU which is
less performant.
This is done by adding a priority field in the template. If the field
is 0, we use the default priority, otherwise we used the one in the
field.
This patchs enhances the IPSEC_ESP related functions for them to
also supports the same operations with descriptor type
HMAC_SNOOP_NO_AFEU.
The differences between the two descriptor types are:
* pointeurs 2 and 3 are swaped (Confidentiality key and
Primary EU Context IN)
* HMAC_SNOOP_NO_AFEU has CICV out in pointer 6
* HMAC_SNOOP_NO_AFEU has no primary EU context out so we get it
from the end of data out
In preparation of IPSEC for SEC1, first step is to make the mapping
helpers more generic so that they can also be used by AEAD functions.
First, the functions are moved before IPSEC functions in talitos.c
talitos_sg_unmap() and unmap_sg_talitos_ptr() are merged as they
are quite similar, the second one handling the SEC1 case an calling
the first one for SEC2
map_sg_in_talitos_ptr() and map_sg_out_talitos_ptr() are merged
into talitos_sg_map() and enhenced to support offseted zones
as used for AEAD. The actual mapping is now performed outside that
helper. The DMA sync is also done outside to not make it several
times.
talitos_edesc_alloc() size calculation are fixed to also take into
account AEAD specific parts also for SEC1
In order to be able to use the mapping/unmapping helpers for IPSEC
it needs to be move upper in the file
Use helper for all modifications to talitos_ptr in preparation to
the implementation of AEAD for SEC1
to_talitos_ptr_extent_clear() has been removed in favor of
to_talitos_ptr_ext_set() to set any value and
to_talitos_ptr_ext_or() to or the extent field with a value
name has been shorten to help keeping single lines of 80 chars
Merge the crypto tree to pull in the qat adf_init_pf_wq change.
Provide hardware state import/export functionality, as mandated by
commit 8996eafdcbad ("crypto: ahash - ensure statesize is non-zero")
Cc: <stable@vger.kernel.org> # 4.3+
Reported-by: Jonas Eymann <J.Eymann@gmx.net>
Signed-off-by: Horia Geant? <horia.geanta@nxp.com>
After conversion to new AEAD interface, tcrypt tests fail as follows:
[ 1.145414] alg: aead: Test 1 failed on encryption for authenc-hmac-sha1-cbc-aes-talitos
[ 1.153564] 00000000: 53 69 6e 67 6c 65 20 62 6c 6f 63 6b 20 6d 73 67
[ 1.160041] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1.166509] 00000020: 00 00 00 00
Fix them by providing the correct cipher in & cipher out pointers,
i.e. must skip over associated data in src and dst S/G.
While here, fix a problem with the HW S/G table index usage:
tbl_off must be updated after the pointer to the table entries is set.
Conversion of talitos driver to the new AEAD interface
hasn't been properly tested.
AEAD algorithms crash in talitos_cra_init as follows:
[ 1.141095] talitos ffe30000.crypto: hwrng
[ 1.145381] Unable to handle kernel paging request for data at address 0x00000058
[ 1.152913] Faulting instruction address: 0xc02accc0
[ 1.157910] Oops: Kernel access of bad area, sig: 11 [#1]
[ 1.163315] SMP NR_CPUS=2 P1020 RDB
[ 1.166810] Modules linked in:
[ 1.169875] CPU: 0 PID: 1007 Comm: cryptomgr_test Not tainted 4.4.6 #1
[ 1.176415] task: db5ec200 ti: db4d6000 task.ti: db4d6000
[ 1.181821] NIP: c02accc0 LR: c02acd18 CTR: c02acd04
[ 1.186793] REGS: db4d7d30 TRAP: 0300 Not tainted (4.4.6)
[ 1.192457] MSR: 00029000 <CE,EE,ME> CR: 95009359 XER: e0000000
[ 1.198585] DEAR: 00000058 ESR: 00000000
GPR00: c017bdc0 db4d7de0 db5ec200 df424b48 00000000 00000000 df424bfc db75a600
GPR08: df424b48 00000000 db75a628 db4d6000 00000149 00000000 c0044cac db5acda0
GPR16: 00000000 00000000 00000000 00000000 00000000 00000000 00000400 df424940
GPR24: df424900 00003083 00000400 c0180000 db75a640 c03e9f84 df424b40 df424b48
[ 1.230978] NIP [c02accc0] talitos_cra_init+0x28/0x6c
[ 1.236039] LR [c02acd18] talitos_cra_init_aead+0x14/0x28
[ 1.241443] Call Trace:
[ 1.243894] [db4d7de0] [c03e9f84] 0xc03e9f84 (unreliable)
[ 1.249322] [db4d7df0] [c017bdc0] crypto_create_tfm+0x5c/0xf0
[ 1.255083] [db4d7e10] [c017beec] crypto_alloc_tfm+0x98/0xf8
[ 1.260769] [db4d7e40] [c0186a20] alg_test_aead+0x28/0xc8
[ 1.266181] [db4d7e60] [c0186718] alg_test+0x260/0x2e0
[ 1.271333] [db4d7ee0] [c0183860] cryptomgr_test+0x30/0x54
[ 1.276843] [db4d7ef0] [c0044d80] kthread+0xd4/0xd8
[ 1.281741] [db4d7f40] [c000e4a4] ret_from_kernel_thread+0x5c/0x64
[ 1.287930] Instruction dump:
[ 1.290902] 38600000 4e800020 81230028 7c681b78 81490010 38e9ffc0 3929ffe8 554a073e
[ 1.298691] 2b8a000a 7d474f9e 812a0008 91230030 <80e90058> 39270060 7c0004ac 7cc04828
Signed-off-by: Jonas Eymann <J.Eymann@gmx.net>
Fix typo - replaced parameter of __crypto_ahash_alg(): s/tfm/alg
Remove checkpatch warnings.
Add commit message.
This patch adds the following algorithms to the talitos driver:
* ecb(aes)
* ctr(aes)
* ecb(des)
* cbc(des)
* ecb(des3_ede)
The sg_nents_for_len() function could fail, this patch add a check for
its return value.
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
Using non-constant time memcmp() makes the verification of the authentication
tag in the decrypt path vulnerable to timing attacks. Fix this by using
crypto_memneq() instead.
Signed-off-by: David Gstir <david@sigma-star.at>
The talitos driver use two dma_map_sg path
according to SG are chained or not.
Since dma_map_sg can handle both case, clean the code with all
references to sg chained.
Thus removing talitos_map_sg, talitos_unmap_sg_chain
and sg_count functions.
Pull SG updates from Jens Axboe:
"This contains a set of scatter-gather related changes/fixes for 4.3:
- Add support for limited chaining of sg tables even for
architectures that do not set ARCH_HAS_SG_CHAIN. From Christoph.
- Add sg chain support to target_rd. From Christoph.
- Fixup open coded sg->page_link in crypto/omap-sham. From
Christoph.
- Fixup open coded crypto ->page_link manipulation. From Dan.
- Also from Dan, automated fixup of manual sg_unmark_end()
manipulations.
- Also from Dan, automated fixup of open coded sg_phys()
implementations.
- From Robert Jarzmik, addition of an sg table splitting helper that
drivers can use"
* 'for-4.3/sg' of git://git.kernel.dk/linux-block:
lib: scatterlist: add sg splitting function
scatterlist: use sg_phys()
crypto/omap-sham: remove an open coded access to ->page_link
scatterlist: remove open coded sg_unmark_end instances
crypto: replace scatterwalk_sg_chain with sg_chain
target/rd: always chain S/G list
scatterlist: allow limited chaining without ARCH_HAS_SG_CHAIN
[hch: split from a larger patch by Dan]
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Jens Axboe <axboe@fb.com>
This patch removes the CRYPTO_ALG_AEAD_NEW flag now that everyone
has been converted.
The probe error path for this driver, for all intents and purposes,
is the talitos_remove() function due to the common "goto err_out".
Without this patch applied, talitos_remove() will panic under these
two conditions:
1. If the RNG device hasn't been registered via
talitos_register_rng() prior to entry into talitos_remove(),
then the attempt to unregister the RNG "device" will cause a panic.
2. If the priv->chan array has not been allocated prior to entry
into talitos_remove(), then the per-channel FIFO cleanup will panic
because of the dereference of that NULL "array".
Both of the above scenarios occur if talitos_probe_irq() fails.
This patch resolves issue #1 by introducing a boolean to mask the
hwrng_unregister() call in talitos_unregister_rng() if RNG device
registration was unsuccessful.
It resolves issue #2 by checking that priv->chan is not NULL in the
per-channel FIFO cleanup for loop.
Signed-off-by: Aaron Sierra <asierra@xes-inc.com>
This patch converts talitos to the new AEAD interface. IV generation
has been removed since it's equivalent to a software implementation.
-change req_ctx->nbuf from u64 to unsigned int to silence checker
warnings; this is safe since nbuf value is <= HASH_MAX_BLOCK_SIZE
-remove unused value read from TALITOS_CCPSR; there is no requirement
to read upper 32b before reading lower 32b of a 64b register;
SEC RM mentions: "reads can always be done by byte, word, or dword"
-remove unused return value of sg_to_link_tbl()
-change "len" parameter of map_single_talitos_ptr() and
to_talitos_ptr_len() to unsigned int; later, cpu_to_be16 will __force
downcast the value to unsigned short without any checker warning
Signed-off-by: Horia Geanta <horia.geanta@freescale.com>
Check return value of scatterlist_sg_next(), i.e. don't rely solely
on number of bytes to be processed or number of scatterlist entries.
This reverts commit 7291a932c6e27d9768e374e9d648086636daf61c.
The conversion to be16_add_cpu() is incorrect in case cryptlen is
negative due to premature (i.e. before addition / subtraction)
implicit conversion of cryptlen (int -> u16) leading to sign loss.
Cc: <stable@vger.kernel.org> # 3.10+
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: <stable@vger.kernel.org> # 3.2+
Fixes: 1d11911a8c57 ("crypto: talitos - fix warning: 'alg' may be used uninitialized in this function")
The + operation has higher precedence than ?: so we need parentheses
here. Otherwise we may end up allocating a max of only one "cryptlen"
instead of two.
Fixes: 6f65f6ac5fb3 ('crypto: talitos - implement scatter/gather copy for SEC1')
Acked-by: Christophe Leroy <christophe.leroy@c-s.fr>
