path: root/drivers/crypto/talitos.h
2015-12-04crypto: talitos - add new crypto modesLEROY Christophe
This patch adds the following algorithms to the talitos driver: * ecb(aes) * ctr(aes) * ecb(des) * cbc(des) * ecb(des3_ede) Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-10crypto: talitos - Prevent panic in probe error pathAaron Sierra
The probe error path for this driver, for all intents and purposes, is the talitos_remove() function due to the common "goto err_out". Without this patch applied, talitos_remove() will panic under these two conditions: 1. If the RNG device hasn't been registered via talitos_register_rng() prior to entry into talitos_remove(), then the attempt to unregister the RNG "device" will cause a panic. 2. If the priv->chan array has not been allocated prior to entry into talitos_remove(), then the per-channel FIFO cleanup will panic because of the dereference of that NULL "array". Both of the above scenarios occur if talitos_probe_irq() fails. This patch resolves issue #1 by introducing a boolean to mask the hwrng_unregister() call in talitos_unregister_rng() if RNG device registration was unsuccessful. It resolves issue #2 by checking that priv->chan is not NULL in the per-channel FIFO cleanup for loop. Signed-off-by: Aaron Sierra <asierra@xes-inc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-04crypto: talitos - Remove zero_entry static initializerAaron Sierra
Compiling the talitos driver with my GCC 4.3.1 e500v2 cross-compiler resulted in a failed build due to the anonymous union/structures introduced in this commit: crypto: talitos - enhanced talitos_desc struct for SEC1 The build error was: drivers/crypto/talitos.h:56: error: unknown field 'len' specified in initializer drivers/crypto/talitos.h:56: warning: missing braces around initializer drivers/crypto/talitos.h:56: warning: (near initialization for 'zero_entry.<anonymous>') drivers/crypto/talitos.h:57: error: unknown field 'j_extent' specified in initializer drivers/crypto/talitos.h:58: error: unknown field 'eptr' specified in initializer drivers/crypto/talitos.h:58: warning: excess elements in struct initializer drivers/crypto/talitos.h:58: warning: (near initialization for 'zero_entry') make[2]: *** [drivers/crypto/talitos.o] Error 1 make[1]: *** [drivers/crypto] Error 2 make: *** [drivers] Error 2 This patch eliminates the errors by relying on the C standard's implicit assignment of zero to static variables. Signed-off-by: Aaron Sierra <asierra@xes-inc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-21crypto: talitos - implement scatter/gather copy for SEC1LEROY Christophe
SEC1 doesn't support scatter/gather, SEC1 doesn't handle link tables. Therefore, for SEC1 we have to do it by SW. For that, we reserve space at the end of the extended descriptor, in lieu of the space reserved for the link tables on SEC2, and we perform sg_copy() when preparing the descriptors We also adapt the max buffer size which is only 32k on SEC1 while it is 64k on SEC2+ Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-21crypto: talitos - adapt interrupts and reset functions to SEC1LEROY Christophe
This patch adapts the interrupts handling and reset function for SEC1. On SEC1, registers are almost similar to SEC2+, but bits are sometimes located at different places. So we need to define TALITOS1 and TALITOS2 versions of some fields, and manage according to whether it is SEC1 or SEC2. On SEC1, only one interrupt vector is dedicated to the SEC, so only interrupt_4ch is needed. On SEC1, interrupts are enabled by clearing related bits in IMR, while on SEC2, interrupts are enabled by seting the bits in IMR. SEC1 also performs parity verification in the DES Unit. We have to disable this feature because the test vectors provided in the kernel have parity errors. In reset functions, only SEC2 supports continuation after error. For SEC1, we have to reset in all cases. For errors handling, SEC2+ names have been kept, but displayed text have been amended to reflect exact meaning on SEC1. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-21crypto: talitos - base address for Execution UnitsLEROY Christophe
SEC 1.0, 1.2 and 2.x+ have different EU base addresses, so we need to define pointers for each EU in the driver private data structure. The proper address is set by the probe function depending on the SEC type, in order to provide access to the proper address. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-21crypto: talitos - adaptation of talitos_submit() for SEC1LEROY Christophe
SEC1 descriptor is a bit different to SEC2+ descriptor. talitos_submit() will have to copy hdr field into hdr1 field and send the descriptor starting at hdr1 up to next_desc. For SEC2, it remains unchanged and next_desc is just ignored. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-21crypto: talitos - Add a feature to tag SEC1LEROY Christophe
We add a new feature in the features field, to mark compatible "fsl,sec1.0" We also define a helper function called has_ftr_sec1() to help functions quickly determine if they are running on SEC1 or SEC2+. When only SEC1 or SEC2 is compiled in, has_ftr_sec1() return trivial corresponding value. If both are compiled in, feature field is checked. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-21crypto: talitos - enhanced talitos_desc struct for SEC1LEROY Christophe
This patch enhances the talitos_desc struct with fields for SEC1. SEC1 has only one header field, and has a 'next_desc' field in addition. This mixed descriptor will continue to fit SEC2, and for SEC1 we will recopy hdr value into hdr1 value in talitos_submit() Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-07-11crypto: talitos - add sha224, sha384 and sha512 to existing AEAD algorithmsHoria Geanta
With this, now all combinations of CBC: AES, 3DES-EDE with HMAC: SHA-1, SHA-224, SHA-256, SHA-384, SHA-512 are supported. Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-07-11crypto: talitos - export the talitos_submit functionHoria Geanta
This patch exports the talitos_submit function so that on need basis same can be used by other entities. Signed-off-by: Sandeep Malik <Sandeep.Malik@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-07-11crypto: talitos - move talitos structures to header fileHoria Geanta
This patch moves the talitos structure definitions from c file to its header file so that the same can be shared on need basis. Signed-off-by: Sandeep Malik <Sandeep.Malik@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-21crypto: talitos - support for channel remap and 2nd IRQKim Phillips
Some later SEC v3.x are equipped with a second IRQ line. By correctly assigning IRQ affinity, this feature can be used to increase performance on dual core parts, like the MPC8572E and P2020E. The existence of the 2nd IRQ is determined from the device node's interrupt property. If present, the driver remaps two of four channels, which in turn makes those channels trigger their interrupts on the 2nd line instead of the first. To handle single- and dual-IRQ combinations efficiently, talitos gets two new interrupt handlers and back-half workers. [includes a fix to MCR_LO's address.] Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-21crypto: talitos - prepare driver for channel remap supportKim Phillips
Add a reg member to the channel struct and use it to access channels. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-19crypto: talitos - add support for sha224Kim Phillips
SEC h/w versions 2.1 and above support sha224 via explicit instruction. Performing sha224 ahashes on earlier versions is still possible because they support sha256 (sha224 is sha256 with different initial constants and a different truncation length). We do this by overriding hardware context self-initialization, and perform it manually in s/w instead. Thanks to Lee for his fixes for correct execution on actual sec2.0 h/w. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off by: Lee Nipper <lee.nipper@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-19crypto: talitos - add hash algorithmsLee Nipper
Add the following alorithms to talitos: md5, sha1, sha256, sha384, sha512. These are all type ahash. Signed-off-by: Lee Nipper <lee.nipper@gmail.com> Acked-By: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-13crypto: talitos - add support for 36 bit addressingKim Phillips
Enabling extended addressing in the h/w requires we always assign the extended address component (eptr) of the talitos h/w pointer. This is for e500 based platforms with large memories. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: remove uses of __constant_{endian} helpersHarvey Harrison
Base versions handle constant folding just fine. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: talitos - Perform auth check in h/w if on sec 2.1 and aboveKim Phillips
SEC version 2.1 and above adds the capability to do the IPSec ICV memcmp in h/w. Results of the cmp are written back in the descriptor header, along with the done status. A new callback is added that checks these ICCR bits instead of performing the memcmp on the core, and is enabled by h/w capability. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> After testing on different parts, another condition was added before using h/w auth check because different SEC revisions require different handling. The SEC 3.0 allows a more flexible link table where the auth data can span separate link table entries. The SEC 2.4/2.1 does not support this case. So a test was added in the decrypt routine for a fragmented case; the h/w auth check is disallowed for revisions not having the extent in the link table; in this case the hw auth check is done by software. A portion of a previous change for SEC 3.0 link table handling was removed since it became dead code with the hw auth check supported. This seems to be the best compromise for using hw auth check on supporting SEC revisions; it keeps the link table logic simpler for the fragmented cases. Signed-off-by: Lee Nipper <lee.nipper@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: talitos - Implement done interrupt mitigationLee Nipper
In talitos_interrupt, upon one done interrupt, mask further done interrupts, and ack only any error interrupt. In talitos_done, unmask done interrupts after completing processing. In flush_channel, ack each done channel processed. Keep done overflow interrupts masked because even though each pkt is ack'ed, a few done overflows still occur. Signed-off-by: Lee Nipper <lee.nipper@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: talitos - Add support for 3desLee Nipper
This patch adds support for authenc(hmac(sha1),cbc(des3_ede)) to the talitos crypto driver for the Freescale Security Engine. Some adjustments were made to the scatterlist to link table conversion to make 3des work for ping -s 1439..1446. Signed-off-by: Lee Nipper <lee.nipper@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: talitos - Freescale integrated security engine (SEC) driverKim Phillips
Add support for the SEC available on a wide range of PowerQUICC devices, e.g. MPC8349E, MPC8548E. This initial version supports authenc(hmac(sha1),cbc(aes)) for use with IPsec. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
