path: root/drivers/crypto
2005-10-30[PATCH] CONFIG_IA32Brian Gerst
Add CONFIG_X86_32 for i386. This allows selecting options that only apply to 32-bit systems. (X86 && !X86_64) becomes X86_32 (X86 || X86_64) becomes X86 Signed-off-by: Brian Gerst <bgerst@didntduck.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-06[CRYPTO] Update IV correctly for Padlock CBC encryptionHerbert Xu
When the Padlock does CBC encryption, the memory pointed to by EAX is not updated at all. Instead, it updates the value of EAX by pointing it to the last block in the output. Therefore to maintain the correct semantics we need to copy the IV. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Ensure cit_iv is aligned correctlyHerbert Xu
This patch ensures that cit_iv is aligned according to cra_alignmask by allocating it as part of the tfm structure. As a side effect the crypto layer will also guarantee that the tfm ctx area has enough space to be aligned by cra_alignmask. This allows us to remove the extra space reservation from the Padlock driver. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[PADLOCK] Implement multi-block operationsHerbert Xu
By operating on multiple blocks at once, we expect to extract more performance out of the VIA Padlock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[PADLOCK] Move fast path work into aes_set_key and upper layerHerbert Xu
Most of the work done aes_padlock can be done in aes_set_key. This means that we only have to do it once when the key changes rather than every time we perform an encryption or decryption. This patch also sets cra_alignmask to let the upper layer ensure that the buffers fed to us are aligned correctly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
