path: root/drivers/crypto
2018-02-25crypto: s5p-sss - Fix kernel Oops in AES-ECB modeKamil Konieczny
commit c927b080c67e3e97193c81fc1d27f4251bf4e036 upstream. In AES-ECB mode crypt is done with key only, so any use of IV can cause kernel Oops. Use IV only in AES-CBC and AES-CTR. Signed-off-by: Kamil Konieczny <k.konieczny@partner.samsung.com> Reported-by: Anand Moon <linux.amoon@gmail.com> Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org> Tested-by: Anand Moon <linux.amoon@gmail.com> Cc: stable@vger.kernel.org # can be applied after commit 8f9702aad138 Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25crypto: talitos - fix Kernel Oops on hashing an empty fileLEROY Christophe
commit 87a81dce53b1ea61acaeefa5191a0376a2d1d721 upstream. Performing the hash of an empty file leads to a kernel Oops [ 44.504600] Unable to handle kernel paging request for data at address 0x0000000c [ 44.512819] Faulting instruction address: 0xc02d2be8 [ 44.524088] Oops: Kernel access of bad area, sig: 11 [#1] [ 44.529171] BE PREEMPT CMPC885 [ 44.532232] CPU: 0 PID: 491 Comm: md5sum Not tainted 4.15.0-rc8-00211-g3a968610b6ea #81 [ 44.540814] NIP: c02d2be8 LR: c02d2984 CTR: 00000000 [ 44.545812] REGS: c6813c90 TRAP: 0300 Not tainted (4.15.0-rc8-00211-g3a968610b6ea) [ 44.554223] MSR: 00009032 <EE,ME,IR,DR,RI> CR: 48222822 XER: 20000000 [ 44.560855] DAR: 0000000c DSISR: c0000000 [ 44.560855] GPR00: c02d28fc c6813d40 c6828000 c646fa40 00000001 00000001 00000001 00000000 [ 44.560855] GPR08: 0000004c 00000000 c000bfcc 00000000 28222822 100280d4 00000000 10020008 [ 44.560855] GPR16: 00000000 00000020 00000000 00000000 10024008 00000000 c646f9f0 c6179a10 [ 44.560855] GPR24: 00000000 00000001 c62f0018 c6179a10 00000000 c6367a30 c62f0000 c646f9c0 [ 44.598542] NIP [c02d2be8] ahash_process_req+0x448/0x700 [ 44.603751] LR [c02d2984] ahash_process_req+0x1e4/0x700 [ 44.608868] Call Trace: [ 44.611329] [c6813d40] [c02d28fc] ahash_process_req+0x15c/0x700 (unreliable) [ 44.618302] [c6813d90] [c02060c4] hash_recvmsg+0x11c/0x210 [ 44.623716] [c6813db0] [c0331354] ___sys_recvmsg+0x98/0x138 [ 44.629226] [c6813eb0] [c03332c0] __sys_recvmsg+0x40/0x84 [ 44.634562] [c6813f10] [c03336c0] SyS_socketcall+0xb8/0x1d4 [ 44.640073] [c6813f40] [c000d1ac] ret_from_syscall+0x0/0x38 [ 44.645530] Instruction dump: [ 44.648465] 38c00001 7f63db78 4e800421 7c791b78 54690ffe 0f090000 80ff0190 2f870000 [ 44.656122] 40befe50 2f990001 409e0210 813f01bc <8129000c> b39e003a 7d29c214 913e003c This patch fixes that Oops by checking if src is NULL. Fixes: 6a1e8d14156d4 ("crypto: talitos - making mapping helpers more generic") Cc: <stable@vger.kernel.org> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25crypto: hash - annotate algorithms taking optional keyEric Biggers
commit a208fa8f33031b9e0aba44c7d1b7e68eb0cbd29e upstream. We need to consistently enforce that keyed hashes cannot be used without setting the key. To do this we need a reliable way to determine whether a given hash algorithm is keyed or not. AF_ALG currently does this by checking for the presence of a ->setkey() method. However, this is actually slightly broken because the CRC-32 algorithms implement ->setkey() but can also be used without a key. (The CRC-32 "key" is not actually a cryptographic key but rather represents the initial state. If not overridden, then a default initial state is used.) Prepare to fix this by introducing a flag CRYPTO_ALG_OPTIONAL_KEY which indicates that the algorithm has a ->setkey() method, but it is not required to be called. Then set it on all the CRC-32 algorithms. The same also applies to the Adler-32 implementation in Lustre. Also, the cryptd and mcryptd templates have to pass through the flag from their underlying algorithm. Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22x86/cpu: Rename cpu_data.x86_mask to cpu_data.x86_steppingJia Zhang
commit b399151cb48db30ad1e0e93dd40d68c6d007b637 upstream. x86_mask is a confusing name which is hard to associate with the processor's stepping. Additionally, correct an indent issue in lib/cpu.c. Signed-off-by: Jia Zhang <qianyue.zj@alibaba-inc.com> [ Updated it to more recent kernels. ] Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: bp@alien8.de Cc: tony.luck@intel.com Link: http://lkml.kernel.org/r/1514771530-70829-1-git-send-email-qianyue.zj@alibaba-inc.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17crypto: caam - fix endless loop when DECO acquire failsHoria Geantă
commit 225ece3e7dad4cfc44cca38ce7a3a80f255ea8f1 upstream. In case DECO0 cannot be acquired - i.e. run_descriptor_deco0() fails with -ENODEV, caam_probe() enters an endless loop: run_descriptor_deco0 ret -ENODEV -> instantiate_rng -ENODEV, overwritten by -EAGAIN ret -EAGAIN -> caam_probe -EAGAIN results in endless loop It turns out the error path in instantiate_rng() is incorrect, the checks are done in the wrong order. Fixes: 1005bccd7a4a6 ("crypto: caam - enable instantiation of all RNG4 state handles") Reported-by: Bryan O'Donoghue <pure.logic@nexus-software.ie> Suggested-by: Auer Lukas <lukas.auer@aisec.fraunhofer.de> Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10crypto: n2 - cure use after freeJan Engelhardt
commit 203f45003a3d03eea8fa28d74cfc74c354416fdb upstream. queue_cache_init is first called for the Control Word Queue (n2_crypto_probe). At that time, queue_cache[0] is NULL and a new kmem_cache will be allocated. If the subsequent n2_register_algs call fails, the kmem_cache will be released in queue_cache_destroy, but queue_cache_init[0] is not set back to NULL. So when the Module Arithmetic Unit gets probed next (n2_mau_probe), queue_cache_init will not allocate a kmem_cache again, but leave it as its bogus value, causing a BUG() to trigger when queue_cache[0] is eventually passed to kmem_cache_zalloc: n2_crypto: Found N2CP at /virtual-devices@100/n2cp@7 n2_crypto: Registered NCS HVAPI version 2.0 called queue_cache_init n2_crypto: md5 alg registration failed n2cp f028687c: /virtual-devices@100/n2cp@7: Unable to register algorithms. called queue_cache_destroy n2cp: probe of f028687c failed with error -22 n2_crypto: Found NCP at /virtual-devices@100/ncp@6 n2_crypto: Registered NCS HVAPI version 2.0 called queue_cache_init kernel BUG at mm/slab.c:2993! Call Trace: [0000000000604488] kmem_cache_alloc+0x1a8/0x1e0 (inlined) kmem_cache_zalloc (inlined) new_queue (inlined) spu_queue_setup (inlined) handle_exec_unit [0000000010c61eb4] spu_mdesc_scan+0x1f4/0x460 [n2_crypto] [0000000010c62b80] n2_mau_probe+0x100/0x220 [n2_crypto] [000000000084b174] platform_drv_probe+0x34/0xc0 Signed-off-by: Jan Engelhardt <jengelh@inai.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25crypto: crypto4xx - increase context and scatter ring buffer elementsChristian Lamparter
[ Upstream commit 778f81d6cdb7d25360f082ac0384d5103f04eca5 ] If crypto4xx is used in conjunction with dm-crypt, the available ring buffer elements are not enough to handle the load properly. On an aes-cbc-essiv:sha256 encrypted swap partition the read performance is abyssal: (tested with hdparm -t) /dev/mapper/swap_crypt: Timing buffered disk reads: 14 MB in 3.68 seconds = 3.81 MB/sec The patch increases both PPC4XX_NUM_SD and PPC4XX_NUM_PD to 256. This improves the performance considerably: /dev/mapper/swap_crypt: Timing buffered disk reads: 104 MB in 3.03 seconds = 34.31 MB/sec Furthermore, PPC4XX_LAST_SD, PPC4XX_LAST_GD and PPC4XX_LAST_PD can be easily calculated from their respective PPC4XX_NUM_* constant. Signed-off-by: Christian Lamparter <chunkeey@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14crypto: s5p-sss - Fix completing crypto request in IRQ handlerKrzysztof Kozlowski
[ Upstream commit 07de4bc88ce6a4d898cad9aa4c99c1df7e87702d ] In a regular interrupt handler driver was finishing the crypt/decrypt request by calling complete on crypto request. This is disallowed since converting to skcipher in commit b286d8b1a690 ("crypto: skcipher - Add skcipher walk interface") and causes a warning: WARNING: CPU: 0 PID: 0 at crypto/skcipher.c:430 skcipher_walk_first+0x13c/0x14c The interrupt is marked shared but in fact there are no other users sharing it. Thus the simplest solution seems to be to just use a threaded interrupt handler, after converting it to oneshot. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14crypto: talitos - fix ctr-aes-talitosLEROY Christophe
commit 70d355ccea899dad47dc22d3a4406998f55143fd upstream. ctr-aes-talitos test fails as follows on SEC2 [ 0.837427] alg: skcipher: Test 1 failed (invalid result) on encryption for ctr-aes-talitos [ 0.845763] 00000000: 16 36 d5 ee 34 f8 06 25 d7 7f 8e 56 ca 88 43 45 [ 0.852345] 00000010: f9 3f f7 17 2a b2 12 23 30 43 09 15 82 dd e1 97 [ 0.858940] 00000020: a7 f7 32 b5 eb 25 06 13 9a ec f5 29 25 f8 4d 66 [ 0.865366] 00000030: b0 03 5b 8e aa 9a 42 b6 19 33 8a e2 9d 65 96 95 This patch fixes the descriptor type which is special for CTR AES Fixes: 5e75ae1b3cef6 ("crypto: talitos - add new crypto modes") Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14crypto: talitos - fix use of sg_link_tbl_lenLEROY Christophe
commit fbb22137c4d9bab536958b152d096fb3f98020ea upstream. sg_link_tbl_len shall be used instead of cryptlen, otherwise SECs which perform HW CICV verification will fail. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14crypto: talitos - fix AEAD for sha224 on non sha224 capable chipsLEROY Christophe
commit 6cda075aff67a1b9b5ba1b2818091dc939643b6c upstream. sha224 AEAD test fails with: [ 2.803125] talitos ff020000.crypto: DEUISR 0x00000000_00000000 [ 2.808743] talitos ff020000.crypto: MDEUISR 0x80100000_00000000 [ 2.814678] talitos ff020000.crypto: DESCBUF 0x20731f21_00000018 [ 2.820616] talitos ff020000.crypto: DESCBUF 0x0628d64c_00000010 [ 2.826554] talitos ff020000.crypto: DESCBUF 0x0631005c_00000018 [ 2.832492] talitos ff020000.crypto: DESCBUF 0x0628d664_00000008 [ 2.838430] talitos ff020000.crypto: DESCBUF 0x061b13a0_00000080 [ 2.844369] talitos ff020000.crypto: DESCBUF 0x0631006c_00000080 [ 2.850307] talitos ff020000.crypto: DESCBUF 0x0631006c_00000018 [ 2.856245] talitos ff020000.crypto: DESCBUF 0x063100ec_00000000 [ 2.884972] talitos ff020000.crypto: failed to reset channel 0 [ 2.890503] talitos ff020000.crypto: done overflow, internal time out, or rngu error: ISR 0x20000000_00020000 [ 2.900652] alg: aead: encryption failed on test 1 for authenc-hmac-sha224-cbc-3des-talitos: ret=22 This is due to SHA224 not being supported by the HW. Allthough for hash we are able to init the hash context by SW, it is not possible for AEAD. Therefore SHA224 AEAD has to be deactivated. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14crypto: talitos - fix setkey to check key weaknessLEROY Christophe
commit f384cdc4faf350fdb6ad93c5f26952b9ba7c7566 upstream. Crypto manager test report the following failures: [ 3.061081] alg: skcipher: setkey failed on test 5 for ecb-des-talitos: flags=100 [ 3.069342] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-talitos: flags=100 [ 3.077754] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-talitos: flags=100 This is due to setkey being expected to detect weak keys. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14crypto: talitos - fix memory corruption on SEC2LEROY Christophe
commit e04a61bebc5da1535b6f194b464295b8d558e2fc upstream. On SEC2, when using the old descriptors type (hmac snoop no afeu) for doing IPsec, the CICV out pointeur points out of the allocated memory. [ 2.502554] ============================================================================= [ 2.510740] BUG dma-kmalloc-256 (Not tainted): Redzone overwritten [ 2.516907] ----------------------------------------------------------------------------- [ 2.516907] [ 2.526535] Disabling lock debugging due to kernel taint [ 2.531845] INFO: 0xde858108-0xde85810b. First byte 0xf8 instead of 0xcc [ 2.538549] INFO: Allocated in 0x806181a9 age=0 cpu=0 pid=58 [ 2.544229] __kmalloc+0x374/0x564 [ 2.547649] talitos_edesc_alloc+0x17c/0x48c [ 2.551929] aead_edesc_alloc+0x80/0x154 [ 2.555863] aead_encrypt+0x30/0xe0 [ 2.559368] __test_aead+0x5a0/0x1f3c [ 2.563042] test_aead+0x2c/0x110 [ 2.566371] alg_test_aead+0x5c/0xf4 [ 2.569958] alg_test+0x1dc/0x5a0 [ 2.573305] cryptomgr_test+0x50/0x70 [ 2.576984] kthread+0xd8/0x134 [ 2.580155] ret_from_kernel_thread+0x5c/0x64 [ 2.584534] INFO: Freed in ipsec_esp_encrypt_done+0x130/0x240 age=6 cpu=0 pid=0 [ 2.591839] ipsec_esp_encrypt_done+0x130/0x240 [ 2.596395] flush_channel+0x1dc/0x488 [ 2.600161] talitos2_done_4ch+0x30/0x200 [ 2.604185] tasklet_action+0xa0/0x13c [ 2.607948] __do_softirq+0x148/0x6cc [ 2.611623] irq_exit+0xc0/0x124 [ 2.614869] call_do_irq+0x24/0x3c [ 2.618292] do_IRQ+0x78/0x108 [ 2.621369] ret_from_except+0x0/0x14 [ 2.625055] finish_task_switch+0x58/0x350 [ 2.629165] schedule+0x80/0x134 [ 2.632409] schedule_preempt_disabled+0x38/0xc8 [ 2.637042] cpu_startup_entry+0xe4/0x190 [ 2.641074] start_kernel+0x3f4/0x408 [ 2.644741] 0x3438 [ 2.646857] INFO: Slab 0xdffbdb00 objects=9 used=1 fp=0xde8581c0 flags=0x0080 [ 2.653978] INFO: Object 0xde858008 @offset=8 fp=0xca4395df [ 2.653978] [ 2.661032] Redzone de858000: cc cc cc cc cc cc cc cc ........ [ 2.669029] Object de858008: 00 00 00 02 00 00 00 02 00 6b 6b 6b 1e 83 ea 28 .........kkk...( [ 2.677628] Object de858018: 00 00 00 70 1e 85 80 64 ff 73 1d 21 6b 6b 6b 6b ...p...d.s.!kkkk [ 2.686228] Object de858028: 00 20 00 00 1e 84 17 24 00 10 00 00 1e 85 70 00 . .....$......p. [ 2.694829] Object de858038: 00 18 00 00 1e 84 17 44 00 08 00 00 1e 83 ea 28 .......D.......( [ 2.703430] Object de858048: 00 80 00 00 1e 84 f0 00 00 80 00 00 1e 85 70 10 ..............p. [ 2.712030] Object de858058: 00 20 6b 00 1e 85 80 f4 6b 6b 6b 6b 00 80 02 00 . k.....kkkk.... [ 2.720629] Object de858068: 1e 84 f0 00 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b ....kkkkkkkkkkkk [ 2.729230] Object de858078: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk [ 2.737830] Object de858088: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk [ 2.746429] Object de858098: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk [ 2.755029] Object de8580a8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk [ 2.763628] Object de8580b8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk [ 2.772229] Object de8580c8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk [ 2.780829] Object de8580d8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk [ 2.789430] Object de8580e8: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 73 b0 ea 9f kkkkkkkkkkkks... [ 2.798030] Object de8580f8: e8 18 80 d6 56 38 44 c0 db e3 4f 71 f7 ce d1 d3 ....V8D...Oq.... [ 2.806629] Redzone de858108: f8 bd 3e 4f ..>O [ 2.814279] Padding de8581b0: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ [ 2.822283] CPU: 0 PID: 0 Comm: swapper Tainted: G B 4.9.50-g995be12679 #179 [ 2.831819] Call Trace: [ 2.834301] [dffefd20] [c01aa9a8] check_bytes_and_report+0x100/0x194 (unreliable) [ 2.841801] [dffefd50] [c01aac3c] check_object+0x200/0x530 [ 2.847306] [dffefd80] [c01ae584] free_debug_processing+0x290/0x690 [ 2.853585] [dffefde0] [c01aec8c] __slab_free+0x308/0x628 [ 2.859000] [dffefe80] [c05057f4] ipsec_esp_encrypt_done+0x130/0x240 [ 2.865378] [dffefeb0] [c05002c4] flush_channel+0x1dc/0x488 [ 2.870968] [dffeff10] [c05007a8] talitos2_done_4ch+0x30/0x200 [ 2.876814] [dffeff30] [c002fe38] tasklet_action+0xa0/0x13c [ 2.882399] [dffeff60] [c002f118] __do_softirq+0x148/0x6cc [ 2.887896] [dffeffd0] [c002f954] irq_exit+0xc0/0x124 [ 2.892968] [dffefff0] [c0013adc] call_do_irq+0x24/0x3c [ 2.898213] [c0d4be00] [c000757c] do_IRQ+0x78/0x108 [ 2.903113] [c0d4be30] [c0015c08] ret_from_except+0x0/0x14 [ 2.908634] --- interrupt: 501 at finish_task_switch+0x70/0x350 [ 2.908634] LR = finish_task_switch+0x58/0x350 [ 2.919327] [c0d4bf20] [c085e1d4] schedule+0x80/0x134 [ 2.924398] [c0d4bf50] [c085e2c0] schedule_preempt_disabled+0x38/0xc8 [ 2.930853] [c0d4bf60] [c007f064] cpu_startup_entry+0xe4/0x190 [ 2.936707] [c0d4bfb0] [c096c434] start_kernel+0x3f4/0x408 [ 2.942198] [c0d4bff0] [00003438] 0x3438 [ 2.946137] FIX dma-kmalloc-256: Restoring 0xde858108-0xde85810b=0xcc [ 2.946137] [ 2.954158] FIX dma-kmalloc-256: Object at 0xde858008 not freed This patch reworks the handling of the CICV out in order to properly handle all cases. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14crypto: talitos - fix AEAD test failuresLEROY Christophe
commit ec8c7d14acc0a477429d3a6fade5dab72c996c82 upstream. AEAD tests fail when destination SG list has more than 1 element. [ 2.058752] alg: aead: Test 1 failed on encryption for authenc-hmac-sha1-cbc-aes-talitos [ 2.066965] 00000000: 53 69 6e 67 6c 65 20 62 6c 6f 63 6b 20 6d 73 67 00000010: c0 43 ff 74 c0 43 ff e0 de 83 d1 20 de 84 8e 54 00000020: de 83 d7 c4 [ 2.082138] alg: aead: Test 1 failed on encryption for authenc-hmac-sha1-cbc-aes-talitos [ 2.090435] 00000000: 53 69 6e 67 6c 65 20 62 6c 6f 63 6b 20 6d 73 67 00000010: de 84 ea 58 c0 93 1a 24 de 84 e8 59 de 84 f1 20 00000020: 00 00 00 00 [ 2.105721] alg: aead: Test 1 failed on encryption for authenc-hmac-sha1-cbc-3des-talitos [ 2.114259] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74 00000010: 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 74 65 00000020: 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 00000030: 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 00000040: 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 00000050: 65 72 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 00000060: 72 63 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 00000070: 63 65 65 72 73 74 54 20 6f 6f 4d 20 6e 61 0a 79 00000080: c0 50 f1 ac c0 50 f3 38 c0 50 f3 94 c0 50 f5 30 00000090: c0 99 74 3c [ 2.166410] alg: aead: Test 1 failed on encryption for authenc-hmac-sha1-cbc-3des-talitos [ 2.174794] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74 00000010: 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 74 65 00000020: 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 00000030: 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 00000040: 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 00000050: 65 72 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 00000060: 72 63 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 00000070: 63 65 65 72 73 74 54 20 6f 6f 4d 20 6e 61 0a 79 00000080: c0 50 f1 ac c0 50 f3 38 c0 50 f3 94 c0 50 f5 30 00000090: c0 99 74 3c [ 2.226486] alg: No test for authenc(hmac(sha224),cbc(aes)) (authenc-hmac-sha224-cbc-aes-talitos) [ 2.236459] alg: No test for authenc(hmac(sha224),cbc(aes)) (authenc-hmac-sha224-cbc-aes-talitos) [ 2.247196] alg: aead: Test 1 failed on encryption for authenc-hmac-sha224-cbc-3des-talitos [ 2.255555] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74 00000010: 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 74 65 00000020: 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 00000030: 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 00000040: 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 00000050: 65 72 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 00000060: 72 63 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 00000070: 63 65 65 72 73 74 54 20 6f 6f 4d 20 6e 61 0a 79 00000080: c0 50 f1 ac c0 50 f3 38 c0 50 f3 94 c0 50 f5 30 00000090: c0 99 74 3c c0 96 e5 b8 [ 2.309004] alg: aead: Test 1 failed on encryption for authenc-hmac-sha224-cbc-3des-talitos [ 2.317562] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74 00000010: 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 74 65 00000020: 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 00000030: 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 00000040: 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 00000050: 65 72 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 00000060: 72 63 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 00000070: 63 65 65 72 73 74 54 20 6f 6f 4d 20 6e 61 0a 79 00000080: c0 50 f1 ac c0 50 f3 38 c0 50 f3 94 c0 50 f5 30 00000090: c0 99 74 3c c0 96 e5 b8 [ 2.370710] alg: aead: Test 1 failed on encryption for authenc-hmac-sha256-cbc-aes-talitos [ 2.379177] 00000000: 53 69 6e 67 6c 65 20 62 6c 6f 63 6b 20 6d 73 67 00000010: 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 74 65 00000020: 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 [ 2.397863] alg: aead: Test 1 failed on encryption for authenc-hmac-sha256-cbc-aes-talitos [ 2.406134] 00000000: 53 69 6e 67 6c 65 20 62 6c 6f 63 6b 20 6d 73 67 00000010: 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 74 65 00000020: 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 [ 2.424789] alg: aead: Test 1 failed on encryption for authenc-hmac-sha256-cbc-3des-talitos [ 2.433491] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74 00000010: 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 74 65 00000020: 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 00000030: 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 00000040: 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 00000050: 65 72 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 00000060: 72 63 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 00000070: 63 65 65 72 73 74 54 20 6f 6f 4d 20 6e 61 0a 79 00000080: c0 50 f1 ac c0 50 f3 38 c0 50 f3 94 c0 50 f5 30 00000090: c0 99 74 3c c0 96 e5 b8 c0 96 e9 20 c0 00 3d dc [ 2.488832] alg: aead: Test 1 failed on encryption for authenc-hmac-sha256-cbc-3des-talitos [ 2.497387] 00000000: 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 73 74 00000010: 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 74 65 00000020: 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 65 72 00000030: 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 72 63 00000040: 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 63 65 00000050: 65 72 73 74 54 20 6f 6f 4d 20 6e 61 20 79 65 53 00000060: 72 63 74 65 20 73 6f 54 20 6f 61 4d 79 6e 53 20 00000070: 63 65 65 72 73 74 54 20 6f 6f 4d 20 6e 61 0a 79 00000080: c0 50 f1 ac c0 50 f3 38 c0 50 f3 94 c0 50 f5 30 00000090: c0 99 74 3c c0 96 e5 b8 c0 96 e9 20 c0 00 3d dc This patch fixes that. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09Revert "crypto: caam - get rid of tasklet"Horia Geantă
commit 2b163b5bce04546da72617bfb6c8bf07a45c4b17 upstream. This reverts commit 66d2e2028091a074aa1290d2eeda5ddb1a6c329c. Quoting from Russell's findings: https://www.mail-archive.com/linux-crypto@vger.kernel.org/msg21136.html [quote] Okay, I've re-tested, using a different way of measuring, because using openssl speed is impractical for off-loaded engines. I've decided to use this way to measure the performance: dd if=/dev/zero bs=1048576 count=128 | /usr/bin/time openssl dgst -md5 For the threaded IRQs case gives: 0.05user 2.74system 0:05.30elapsed 52%CPU (0avgtext+0avgdata 2400maxresident)k 0.06user 2.52system 0:05.18elapsed 49%CPU (0avgtext+0avgdata 2404maxresident)k 0.12user 2.60system 0:05.61elapsed 48%CPU (0avgtext+0avgdata 2460maxresident)k => 5.36s => 25.0MB/s and the tasklet case: 0.08user 2.53system 0:04.83elapsed 54%CPU (0avgtext+0avgdata 2468maxresident)k 0.09user 2.47system 0:05.16elapsed 49%CPU (0avgtext+0avgdata 2368maxresident)k 0.10user 2.51system 0:04.87elapsed 53%CPU (0avgtext+0avgdata 2460maxresident)k => 4.95 => 27.1MB/s which corresponds to an 8% slowdown for the threaded IRQ case. So, tasklets are indeed faster than threaded IRQs. [...] I think I've proven from the above that this patch needs to be reverted due to the performance regression, and that there _is_ most definitely a deterimental effect of switching from tasklets to threaded IRQs. [/quote] Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30crypto: marvell - Copy IVDIG before launching partial DMA ahash requestsRomain Perier
[ Upstream commit 8759fec4af222f338d08f8f1a7ad6a77ca6cb301 ] Currently, inner IV/DIGEST data are only copied once into the hash engines and not set explicitly before launching a request that is not a first frag. This is an issue especially when multiple ahash reqs are computed in parallel or chained with cipher request, as the state of the request being computed is not updated into the hash engine. It leads to non-deterministic corrupted digest results. Fixes: commit 2786cee8e50b ("crypto: marvell - Move SRAM I/O operations to step functions") Signed-off-by: Romain Perier <romain.perier@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: <stable@vger.kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15crypto: vmx - disable preemption to enable vsx in aes_ctr.cLi Zhong
[ Upstream commit 7dede913fc2ab9c0d3bff3a49e26fa9e858b0c13 ] Some preemptible check warnings were reported from enable_kernel_vsx(). This patch disables preemption in aes_ctr.c before enabling vsx, and they are now consistent with other files in the same directory. Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08crypto: ccp - Set the AES size field for all modesGary R Hook
[ Upstream commit f7cc02b3c3a33a10dd5bb9e5dfd22e47e09503a2 ] Ensure that the size field is correctly populated for all AES modes. Signed-off-by: Gary R Hook <gary.hook@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05crypto: talitos - fix hashingLEROY Christophe
commit 886a27c0fc8a34633aadb0986dba11d8c150ae2e upstream. md5sum on some files gives wrong result Exemple: With the md5sum from libkcapi: c15115c05bad51113f81bdaee735dd09 test With the original md5sum: bbdf41d80ba7e8b2b7be3a0772be76cb test This patch fixes this issue Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05crypto: talitos - fix sha224LEROY Christophe
commit afd62fa26343be6445479e75de9f07092a061459 upstream. Kernel crypto tests report the following error at startup [ 2.752626] alg: hash: Test 4 failed for sha224-talitos [ 2.757907] 00000000: 30 e2 86 e2 e7 8a dd 0d d7 eb 9f d5 83 fe f1 b0 00000010: 2d 5a 6c a5 f9 55 ea fd 0e 72 05 22 This patch fixes it Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05crypto: talitos - Don't provide setkey for non hmac hashing algs.LEROY Christophe
commit 56136631573baa537a15e0012055ffe8cfec1a33 upstream. Today, md5sum fails with error -ENOKEY because a setkey function is set for non hmac hashing algs, see strace output below: mmap(NULL, 378880, PROT_READ, MAP_SHARED, 6, 0) = 0x77f50000 accept(3, 0, NULL) = 7 vmsplice(5, [{"bin/\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 378880}], 1, SPLICE_F_MORE|SPLICE_F_GIFT) = 262144 splice(4, NULL, 7, NULL, 262144, SPLICE_F_MORE) = -1 ENOKEY (Required key not available) write(2, "Generation of hash for file kcap"..., 50) = 50 munmap(0x77f50000, 378880) = 0 This patch ensures that setkey() function is set only for hmac hashing. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27crypto: ccp - Fix XTS-AES-128 support on v5 CCPsGary R Hook
commit e652399edba99a5497f0d80f240c9075d3b43493 upstream. Version 5 CCPs have some new requirements for XTS-AES: the type field must be specified, and the key requires 512 bits, with each part occupying 256 bits and padded with zeroes. Signed-off-by: Gary R Hook <ghook@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24crypto: ixp4xx - Fix error handling path in 'aead_perform()'Herbert Xu
commit 28389575a8cf933a5f3c378556b9f4d3cce0efd2 upstream. In commit 0f987e25cb8a, the source processing has been moved in front of the destination processing, but the error handling path has not been modified accordingly. Free resources in the correct order to avoid some leaks. Fixes: 0f987e25cb8a ("crypto: ixp4xx - Fix false lastlen uninitialised warning") Reported-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21crypto: caam - fix signals handlingHoria Geantă
commit 7459e1d25ffefa2b1be799477fcc1f6c62f6cec7 upstream. Driver does not properly handle the case when signals interrupt wait_for_completion_interruptible(): -it does not check for return value -completion structure is allocated on stack; in case a signal interrupts the sleep, it will go out of scope, causing the worker thread (caam_jr_dequeue) to fail when it accesses it wait_for_completion_interruptible() is replaced with uninterruptable wait_for_completion(). We choose to block all signals while waiting for I/O (device executing the split key generation job descriptor) since the alternative - in order to have a deterministic device state - would be to flush the job ring (aborting *all* in-progress jobs). Fixes: 045e36780f115 ("crypto: caam - ahash hmac support") Fixes: 4c1ec1f930154 ("crypto: caam - refactor key_gen, sg") Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21crypto: caam - properly set IV after {en,de}cryptDavid Gstir
commit 854b06f768794cd664886ec3ba3a5b1c58d42167 upstream. Certain cipher modes like CTS expect the IV (req->info) of ablkcipher_request (or equivalently req->iv of skcipher_request) to contain the last ciphertext block when the {en,de}crypt operation is done. This is currently not the case for the CAAM driver which in turn breaks e.g. cts(cbc(aes)) when the CAAM driver is enabled. This patch fixes the CAAM driver to properly set the IV after the {en,de}crypt operation of ablkcipher finishes. This issue was revealed by the changes in the SW CTS mode in commit 0605c41cc53ca ("crypto: cts - Convert to skcipher") Signed-off-by: David Gstir <david@sigma-star.at> Reviewed-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21crypto: atmel - only treat EBUSY as transient if backlogGilad Ben-Yossef
commit 1606043f214f912a52195293614935811a6e3e53 upstream. The Atmel SHA driver was treating -EBUSY as indication of queueing to backlog without checking that backlog is enabled for the request. Fix it by checking request flags. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21crypto: talitos - Extend max key length for SHA384/512-HMAC and AEADMartin Hicks
commit 03d2c5114c95797c0aa7d9f463348b171a274fd4 upstream. An updated patch that also handles the additional key length requirements for the AEAD algorithms. The max keysize is not 96. For SHA384/512 it's 128, and for the AEAD algorithms it's longer still. Extend the max keysize for the AEAD size for AES256 + HMAC(SHA512). Fixes: 357fb60502ede ("crypto: talitos - add sha224, sha384 and sha512 to existing AEAD algorithms") Signed-off-by: Martin Hicks <mort@bork.org> Acked-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15crypto: caam - fix gfp allocation flags (part I)Horia Geantă
commit 42cfcafb91dabb0f9d9e08396c39824535948c67 upstream. Changes in the SW cts (ciphertext stealing) code in commit 0605c41cc53ca ("crypto: cts - Convert to skcipher") revealed a problem in the CAAM driver: when cts(cbc(aes)) is executed and cts runs in SW, cbc(aes) is offloaded in CAAM; cts encrypts the last block in atomic context and CAAM incorrectly decides to use GFP_KERNEL for memory allocation. Fix this by allowing GFP_KERNEL (sleeping) only when MAY_SLEEP flag is set, i.e. remove MAY_BACKLOG flag. We split the fix in two parts - first is sent to -stable, while the second is not (since there is no known failure case). Link: http://lkml.kernel.org/g/20170602122446.2427-1-david@sigma-star.at Reported-by: David Gstir <david@sigma-star.at> Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20crypto: ccp - Change ISR handler method for a v5 CCPGary R Hook
commit 6263b51eb3190d30351360fd168959af7e3a49a9 upstream. The CCP has the ability to perform several operations simultaneously, but only one interrupt. When implemented as a PCI device and using MSI-X/MSI interrupts, use a tasklet model to service interrupts. By disabling and enabling interrupts from the CCP, coupled with the queuing that tasklets provide, we can ensure that all events (occurring on the device) are recognized and serviced. This change fixes a problem wherein 2 or more busy queues can cause notification bits to change state while a (CCP) interrupt is being serviced, but after the queue state has been evaluated. This results in the event being 'lost' and the queue hanging, waiting to be serviced. Since the status bits are never fully de-asserted, the CCP never generates another interrupt (all bits zero -> one or more bits one), and no further CCP operations will be executed. Signed-off-by: Gary R Hook <gary.hook@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20crypto: ccp - Change ISR handler method for a v3 CCPGary R Hook
commit 7b537b24e76a1e8e6d7ea91483a45d5b1426809b upstream. The CCP has the ability to perform several operations simultaneously, but only one interrupt. When implemented as a PCI device and using MSI-X/MSI interrupts, use a tasklet model to service interrupts. By disabling and enabling interrupts from the CCP, coupled with the queuing that tasklets provide, we can ensure that all events (occurring on the device) are recognized and serviced. This change fixes a problem wherein 2 or more busy queues can cause notification bits to change state while a (CCP) interrupt is being serviced, but after the queue state has been evaluated. This results in the event being 'lost' and the queue hanging, waiting to be serviced. Since the status bits are never fully de-asserted, the CCP never generates another interrupt (all bits zero -> one or more bits one), and no further CCP operations will be executed. Signed-off-by: Gary R Hook <gary.hook@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20crypto: ccp - Disable interrupts early on unloadGary R Hook
commit 116591fe3eef11c6f06b662c9176385f13891183 upstream. Ensure that we disable interrupts first when shutting down the driver. Signed-off-by: Gary R Hook <ghook@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20crypto: ccp - Use only the relevant interrupt bitsGary R Hook
commit 56467cb11cf8ae4db9003f54b3d3425b5f07a10a upstream. Each CCP queue can product interrupts for 4 conditions: operation complete, queue empty, error, and queue stopped. This driver only works with completion and error events. Signed-off-by: Gary R Hook <gary.hook@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14crypto: caam - fix error path for ctx_dma mapping failureHoria Geantă
commit 87ec02e7409d787348c244039aa3536a812dfa8b upstream. In case ctx_dma dma mapping fails, ahash_unmap_ctx() tries to dma unmap an invalid address: map_seq_out_ptr_ctx() / ctx_map_to_sec4_sg() -> goto unmap_ctx -> -> ahash_unmap_ctx() -> dma unmap ctx_dma There is also possible to reach ahash_unmap_ctx() with ctx_dma uninitialzed or to try to unmap the same address twice. Fix these by setting ctx_dma = 0 where needed: -initialize ctx_dma in ahash_init() -clear ctx_dma in case of mapping error (instead of holding the error code returned by the dma map function) -clear ctx_dma after each unmapping Fixes: 32686d34f8fb6 ("crypto: caam - ensure that we clean up after an error") Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-18crypto: caam - fix invalid dereference in caam_rsa_init_tfm()Horia Geantă
commit 33fa46d7b310e06d2cb2ab5417c100af120bfb65 upstream. In case caam_jr_alloc() fails, ctx->dev carries the error code, thus accessing it with dev_err() is incorrect. Fixes: 8c419778ab57e ("crypto: caam - add support for RSA algorithm") Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-18crypto: caam - fix RNG deinstantiation error checkingHoria Geantă
commit 40c98cb57cdbc377456116ad4582c89e329721b0 upstream. RNG instantiation was previously fixed by commit 62743a4145bb9 ("crypto: caam - fix RNG init descriptor ret. code checking") while deinstantiation was not addressed. Since the descriptors used are similar, in the sense that they both end with a JUMP HALT command, checking for errors should be similar too, i.e. status code 7000_0000h should be considered successful. Fixes: 1005bccd7a4a6 ("crypto: caam - enable instantiation of all RNG4 state handles") Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30crypto: ccp - Assign DMA commands to the channel's CCPGary R Hook
commit 7c468447f40645fbf2a033dfdaa92b1957130d50 upstream. The CCP driver generally uses a round-robin approach when assigning operations to available CCPs. For the DMA engine, however, the DMA mappings of the SGs are associated with a specific CCP. When an IOMMU is enabled, the IOMMU is programmed based on this specific device. If the DMA operations are not performed by that specific CCP then addressing errors and I/O page faults will occur. Update the CCP driver to allow a specific CCP device to be requested for an operation and use this in the DMA engine support. Signed-off-by: Gary R Hook <gary.hook@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14crypto: ccp - Fix double add when creating new DMA commandGary R Hook
commit e5da5c5667381d2772374ee6a2967b3576c9483d upstream. Eliminate a double-add by creating a new list to manage command descriptors when created; move the descriptor to the pending list when the command is submitted. Signed-off-by: Gary R Hook <gary.hook@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14crypto: ccp - Fix DMA operations when IOMMU is enabledGary R Hook
commit 500c0106e638e08c2c661c305ed57d6b67e10908 upstream. An I/O page fault occurs when the IOMMU is enabled on a system that supports the v5 CCP. DMA operations use a Request ID value that does not match what is expected by the IOMMU, resulting in the I/O page fault. Setting the Request ID value to 0 corrects this issue. Signed-off-by: Gary R Hook <gary.hook@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14crypto: qat - zero esram only for DH85x devicesGiovanni Cabiddu
commit 685ce0626840e2673fe64ea8807684f7324fec5f upstream. Zero embedded ram in DH85x devices. This is not needed for newer generations as it is done by HW. Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14crypto: qat - fix bar discovery for c62xGiovanni Cabiddu
commit 3484ecbe0e9deb94afb0b9b6172d77e98eb72b94 upstream. Some accelerators of the c62x series have only two bars. This patch skips BAR0 if the accelerator does not have it. Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14crypto: chcr - Check device is allocated before useHarsh Jain
commit f5f7bebc91ab378dea5aad5277c4d283e46472d9 upstream. Ensure dev is allocated for crypto uld context before using the device for crypto operations. Signed-off-by: Atul Gupta <atul.gupta@chelsio.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06crypto: caam - fix AEAD givenc descriptorsAlex Porosanu
commit d128af17876d79b87edf048303f98b35f6a53dbc upstream. The AEAD givenc descriptor relies on moving the IV through the output FIFO and then back to the CTX2 for authentication. The SEQ FIFO STORE could be scheduled before the data can be read from OFIFO, especially since the SEQ FIFO LOAD needs to wait for the SEQ FIFO LOAD SKIP to finish first. The SKIP takes more time when the input is SG than when it's a contiguous buffer. If the SEQ FIFO LOAD is not scheduled before the STORE, the DECO will hang waiting for data to be available in the OFIFO so it can be transferred to C2. In order to overcome this, first force transfer of IV to C2 by starting the "cryptlen" transfer first and then starting to store data from OFIFO to the output buffer. Fixes: 1acebad3d8db8 ("crypto: caam - faster aead implementation") Signed-off-by: Alex Porosanu <alexandru.porosanu@nxp.com> Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-07crypto: caam - fix pointer size for AArch64 boot loader, AArch32 kernelHoria Geantă
Start with a clean slate before dealing with bit 16 (pointer size) of Master Configuration Register. This fixes the case of AArch64 boot loader + AArch32 kernel, when the boot loader might set MCFGR[PS] and kernel would fail to clear it. Cc: <stable@vger.kernel.org> Reported-by: Alison Wang <alison.wang@nxp.com> Signed-off-by: Horia Geantă <horia.geanta@nxp.com> Reviewed-By: Alison Wang <Alison.wang@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-12-07crypto: marvell - Don't corrupt state of an STD req for re-stepped ahashRomain Perier
mv_cesa_hash_std_step() copies the creq->state into the SRAM at each step, but this is only required on the first one. By doing that, we overwrite the engine state, and get erroneous results when the crypto request is split in several chunks to fit in the internal SRAM. This commit changes the function to copy the state only on the first step. Fixes: commit 2786cee8e50b ("crypto: marvell - Move SRAM I/O op...") Signed-off-by: Romain Perier <romain.perier@free-electrons.com> Cc: <stable@vger.kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-12-07crypto: marvell - Don't copy hash operation twice into the SRAMRomain Perier
No need to copy the template of an hash operation twice into the SRAM from the step function. Fixes: commit 85030c5168f1 ("crypto: marvell - Add support for chai...") Signed-off-by: Romain Perier <romain.perier@free-electrons.com> Cc: <stable@vger.kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-11-30crypto: chcr - Fix memory corruptionHarsh Jain
Fix memory corruption done by *((u32 *)dec_key + k) operation. Signed-off-by: Jitendra Lulla <JLULLA@chelsio.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-11-17crypto: caam - fix type mismatch warningArnd Bergmann
Building the caam driver on arm64 produces a harmless warning: drivers/crypto/caam/caamalg.c:140:139: warning: comparison of distinct pointer types lacks a cast We can use min_t to tell the compiler which type we want it to use here. Fixes: 5ecf8ef9103c ("crypto: caam - fix sg dump") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Horia Geantă <horia.geanta@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-11-13crypto: caam - do not register AES-XTS mode on LP unitsSven Ebenfeld
When using AES-XTS on a Wandboard, we receive a Mode error: caam_jr 2102000.jr1: 20001311: CCB: desc idx 19: AES: Mode error. According to the Security Reference Manual, the Low Power AES units of the i.MX6 do not support the XTS mode. Therefore we must not register XTS implementations in the Crypto API. Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com> Reviewed-by: Horia Geantă <horia.geanta@nxp.com> Cc: <stable@vger.kernel.org> # 4.4+ Fixes: c6415a6016bf "crypto: caam - add support for acipher xts(aes)" Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-10-10Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto updates from Herbert Xu: "Here is the crypto update for 4.9: API: - The crypto engine code now supports hashes. Algorithms: - Allow keys >= 2048 bits in FIPS mode for RSA. Drivers: - Memory overwrite fix for vmx ghash. - Add support for building ARM sha1-neon in Thumb2 mode. - Reenable ARM ghash-ce code by adding import/export. - Reenable img-hash by adding import/export. - Add support for multiple cores in omap-aes. - Add little-endian support for sha1-powerpc. - Add Cavium HWRNG driver for ThunderX SoC" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (137 commits) crypto: caam - treat SGT address pointer as u64 crypto: ccp - Make syslog errors human-readable crypto: ccp - clean up data structure crypto: vmx - Ensure ghash-generic is enabled crypto: testmgr - add guard to dst buffer for ahash_export crypto: caam - Unmap region obtained by of_iomap crypto: sha1-powerpc - little-endian support crypto: gcm - Fix IV buffer size in crypto_gcm_setkey crypto: vmx - Fix memory corruption caused by p8_ghash crypto: ghash-generic - move common definitions to a new header file crypto: caam - fix sg dump hwrng: omap - Only fail if pm_runtime_get_sync returns < 0 crypto: omap-sham - shrink the internal buffer size crypto: omap-sham - add support for export/import crypto: omap-sham - convert driver logic to use sgs for data xmit crypto: omap-sham - change the DMA threshold value to a define crypto: omap-sham - add support functions for sg based data handling crypto: omap-sham - rename sgl to sgl_tmp for deprecation crypto: omap-sham - align algorithms on word offset crypto: omap-sham - add context export/import stubs ...
2016-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Herbert Xu
Merge the crypto tree to pull in vmx ghash fix.
