This is the 4.9.67 stable release
Resolved conflicts:
arch/arm/boot/dts/imx6sx-sdb.dts
drivers/dma/imx-sdma.c
drivers/mmc/core/host.c
drivers/usb/chipidea/otg.c
sound/soc/fsl/fsl_ssi.c
This merge also reverts commit 3a654a85932f ("dmaengine:
imx-sdma - correct the dma transfer residue calculation"). The
downstream kernel seems to use different structures and already
use buf_ptail in its calculation.
[ Upstream commit 8759fec4af222f338d08f8f1a7ad6a77ca6cb301 ]
Currently, inner IV/DIGEST data are only copied once into the hash
engines and not set explicitly before launching a request that is not a
first frag. This is an issue especially when multiple ahash reqs are
computed in parallel or chained with cipher request, as the state of the
request being computed is not updated into the hash engine. It leads to
non-deterministic corrupted digest results.
Fixes: commit 2786cee8e50b ("crypto: marvell - Move SRAM I/O operations to step functions")
Signed-off-by: Romain Perier <romain.perier@free-electrons.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: <stable@vger.kernel.org>
[ Upstream commit 7dede913fc2ab9c0d3bff3a49e26fa9e858b0c13 ]
Some preemptible check warnings were reported from enable_kernel_vsx(). This
patch disables preemption in aes_ctr.c before enabling vsx, and they are now
consistent with other files in the same directory.
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
[ Upstream commit f7cc02b3c3a33a10dd5bb9e5dfd22e47e09503a2 ]
Ensure that the size field is correctly populated for
all AES modes.
Signed-off-by: Gary R Hook <gary.hook@amd.com>
commit 886a27c0fc8a34633aadb0986dba11d8c150ae2e upstream.
md5sum on some files gives wrong result
Exemple:
With the md5sum from libkcapi:
c15115c05bad51113f81bdaee735dd09 test
With the original md5sum:
bbdf41d80ba7e8b2b7be3a0772be76cb test
This patch fixes this issue
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
commit afd62fa26343be6445479e75de9f07092a061459 upstream.
Kernel crypto tests report the following error at startup
[ 2.752626] alg: hash: Test 4 failed for sha224-talitos
[ 2.757907] 00000000: 30 e2 86 e2 e7 8a dd 0d d7 eb 9f d5 83 fe f1 b0
00000010: 2d 5a 6c a5 f9 55 ea fd 0e 72 05 22
This patch fixes it
commit 56136631573baa537a15e0012055ffe8cfec1a33 upstream.
Today, md5sum fails with error -ENOKEY because a setkey
function is set for non hmac hashing algs, see strace output below:
mmap(NULL, 378880, PROT_READ, MAP_SHARED, 6, 0) = 0x77f50000
accept(3, 0, NULL) = 7
vmsplice(5, [{"bin/\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 378880}], 1, SPLICE_F_MORE|SPLICE_F_GIFT) = 262144
splice(4, NULL, 7, NULL, 262144, SPLICE_F_MORE) = -1 ENOKEY (Required key not available)
write(2, "Generation of hash for file kcap"..., 50) = 50
munmap(0x77f50000, 378880) = 0
This patch ensures that setkey() function is set only
for hmac hashing.
commit e652399edba99a5497f0d80f240c9075d3b43493 upstream.
Version 5 CCPs have some new requirements for XTS-AES: the type field
must be specified, and the key requires 512 bits, with each part
occupying 256 bits and padded with zeroes.
Signed-off-by: Gary R Hook <ghook@amd.com>
commit 28389575a8cf933a5f3c378556b9f4d3cce0efd2 upstream.
In commit 0f987e25cb8a, the source processing has been moved in front of
the destination processing, but the error handling path has not been
modified accordingly.
Free resources in the correct order to avoid some leaks.
Fixes: 0f987e25cb8a ("crypto: ixp4xx - Fix false lastlen uninitialised warning")
Reported-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
commit 7459e1d25ffefa2b1be799477fcc1f6c62f6cec7 upstream.
Driver does not properly handle the case when signals interrupt
wait_for_completion_interruptible():
-it does not check for return value
-completion structure is allocated on stack; in case a signal interrupts
the sleep, it will go out of scope, causing the worker thread
(caam_jr_dequeue) to fail when it accesses it
wait_for_completion_interruptible() is replaced with uninterruptable
wait_for_completion().
We choose to block all signals while waiting for I/O (device executing
the split key generation job descriptor) since the alternative - in
order to have a deterministic device state - would be to flush the job
ring (aborting *all* in-progress jobs).
Fixes: 045e36780f115 ("crypto: caam - ahash hmac support")
Fixes: 4c1ec1f930154 ("crypto: caam - refactor key_gen, sg")
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit 854b06f768794cd664886ec3ba3a5b1c58d42167 upstream.
Certain cipher modes like CTS expect the IV (req->info) of
ablkcipher_request (or equivalently req->iv of skcipher_request) to
contain the last ciphertext block when the {en,de}crypt operation is done.
This is currently not the case for the CAAM driver which in turn breaks
e.g. cts(cbc(aes)) when the CAAM driver is enabled.
This patch fixes the CAAM driver to properly set the IV after the
{en,de}crypt operation of ablkcipher finishes.
This issue was revealed by the changes in the SW CTS mode in commit
0605c41cc53ca ("crypto: cts - Convert to skcipher")
Signed-off-by: David Gstir <david@sigma-star.at>
Reviewed-by: Horia Geantă <horia.geanta@nxp.com>
commit 1606043f214f912a52195293614935811a6e3e53 upstream.
The Atmel SHA driver was treating -EBUSY as indication of queueing
to backlog without checking that backlog is enabled for the request.
Fix it by checking request flags.
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
commit 03d2c5114c95797c0aa7d9f463348b171a274fd4 upstream.
An updated patch that also handles the additional key length requirements
for the AEAD algorithms.
The max keysize is not 96. For SHA384/512 it's 128, and for the AEAD
algorithms it's longer still. Extend the max keysize for the
AEAD size for AES256 + HMAC(SHA512).
Fixes: 357fb60502ede ("crypto: talitos - add sha224, sha384 and sha512 to existing AEAD algorithms")
Signed-off-by: Martin Hicks <mort@bork.org>
Acked-by: Horia Geantă <horia.geanta@nxp.com>
commit 42cfcafb91dabb0f9d9e08396c39824535948c67 upstream.
Changes in the SW cts (ciphertext stealing) code in
commit 0605c41cc53ca ("crypto: cts - Convert to skcipher")
revealed a problem in the CAAM driver:
when cts(cbc(aes)) is executed and cts runs in SW,
cbc(aes) is offloaded in CAAM; cts encrypts the last block
in atomic context and CAAM incorrectly decides to use GFP_KERNEL
for memory allocation.
Fix this by allowing GFP_KERNEL (sleeping) only when MAY_SLEEP flag is
set, i.e. remove MAY_BACKLOG flag.
We split the fix in two parts - first is sent to -stable, while the
second is not (since there is no known failure case).
Link: http://lkml.kernel.org/g/20170602122446.2427-1-david@sigma-star.at
Reported-by: David Gstir <david@sigma-star.at>
Remove variant restriction for DCP SHA workaround. All integrations of
DCP seem affected.
Signed-off-by: Radu Solea <radu.solea@nxp.com>
CAAM aes modes share descriptors, because of this CAAM requires an IV
for ECB. ECB does not need an IV and users do not have to pass valid
IV vectors. To allow correct usage with minimum impact to the driver a
zero IV is provided by the driver for ECB operations that need it.
The DCP driver does not obey cryptlen, when doing CTS this results in
passing to hardware input stream lengths which are not multiple of
block size. This causes the hw to misbehave. Also not honoring
cryptlen makes CTS fail. A check was introduced to prevent future
erroneous stream lengths from reaching the hardware. Code which is
splitting the input stream in internal DCP pages was changed to obey
cryptlen.
On imx6sl and imx6ull DCP writes at least 32 bytes in the output
buffer instead of hash length as documented. Add intermediate buffer
to prevent write out of bounds.
When requested to produce null hashes DCP fails to produce valid
output. Add software workaround to bypass hardware and return valid output.
AES is a keyed algorithm, XCBC-AES needs a key for operation,
this patch prevents the registration of AES-based transforms
as unkeyed operations.
Update ERA detection code to check 3 sources CCBVID, CAAMVID
and the device tree.
Fix bit handling of CAAMVID data to obtain correct results.
Remove default device tree values.
Update errata handling to target known affected platforms.
Current CBC mode does not return the last cyphertext block
as IV for operation chaining. CTS fails because of incorrect IV.
Missing NULL checks in CAAM sm_store and sm_test cause kernel
crashes if caam init fails.
Fixes the following lockdep message:
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.1.30-02225-g55e4b9e #8
Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[<800162b0>] (unwind_backtrace) from [<80012ba0>] (show_stack+0x10/0x14)
[<80012ba0>] (show_stack) from [<808d09d0>] (dump_stack+0xa8/0xd4)
[<808d09d0>] (dump_stack) from [<8007aed0>] (__lock_acquire+0x1eb0/0x2224)
[<8007aed0>] (__lock_acquire) from [<8007b840>] (lock_acquire+0xa4/0xd0)
[<8007b840>] (lock_acquire) from [<808dc28c>] (_raw_spin_lock+0x3c/0x4c)
[<808dc28c>] (_raw_spin_lock) from [<80666724>] (sm_keystore_slot_alloc+0x24/0x74)
[<80666724>] (sm_keystore_slot_alloc) from [<806677c8>] (caam_sm_example_init+0x1ec/0xb68)
[<806677c8>] (caam_sm_example_init) from [<80c6ff48>] (caam_sm_test_init+0x50/0x58)
[<80c6ff48>] (caam_sm_test_init) from [<80009770>] (do_one_initcall+0x8c/0x1d8)
[<80009770>] (do_one_initcall) from [<80c26dc8>] (kernel_init_freeable+0x144/0x1e4)
[<80c26dc8>] (kernel_init_freeable) from [<808cbff0>] (kernel_init+0x8/0xe8)
[<808cbff0>] (kernel_init) from [<8000f618>] (ret_from_fork+0x14/0x3c)
Signed-off-by: Octavian Purdila <octavian.purdila@nxp.com>
Reviewed-by: Dan Douglass <dan.douglass@nxp.com>
Added clock enable and disable to the probe and remove functions
where appropriate.
Signed-off-by: Dan Douglass <dan.douglass@nxp.com>
Enable DCP support for imx6 series.
commit 6263b51eb3190d30351360fd168959af7e3a49a9 upstream.
The CCP has the ability to perform several operations simultaneously,
but only one interrupt. When implemented as a PCI device and using
MSI-X/MSI interrupts, use a tasklet model to service interrupts. By
disabling and enabling interrupts from the CCP, coupled with the
queuing that tasklets provide, we can ensure that all events
(occurring on the device) are recognized and serviced.
This change fixes a problem wherein 2 or more busy queues can cause
notification bits to change state while a (CCP) interrupt is being
serviced, but after the queue state has been evaluated. This results
in the event being 'lost' and the queue hanging, waiting to be
serviced. Since the status bits are never fully de-asserted, the
CCP never generates another interrupt (all bits zero -> one or more
bits one), and no further CCP operations will be executed.
commit 7b537b24e76a1e8e6d7ea91483a45d5b1426809b upstream.
commit 116591fe3eef11c6f06b662c9176385f13891183 upstream.
Ensure that we disable interrupts first when shutting down
the driver.
commit 56467cb11cf8ae4db9003f54b3d3425b5f07a10a upstream.
Each CCP queue can product interrupts for 4 conditions:
operation complete, queue empty, error, and queue stopped.
This driver only works with completion and error events.
commit 87ec02e7409d787348c244039aa3536a812dfa8b upstream.
In case ctx_dma dma mapping fails, ahash_unmap_ctx() tries to
dma unmap an invalid address:
map_seq_out_ptr_ctx() / ctx_map_to_sec4_sg() -> goto unmap_ctx ->
-> ahash_unmap_ctx() -> dma unmap ctx_dma
There is also possible to reach ahash_unmap_ctx() with ctx_dma
uninitialzed or to try to unmap the same address twice.
Fix these by setting ctx_dma = 0 where needed:
-initialize ctx_dma in ahash_init()
-clear ctx_dma in case of mapping error (instead of holding
the error code returned by the dma map function)
-clear ctx_dma after each unmapping
Fixes: 32686d34f8fb6 ("crypto: caam - ensure that we clean up after an error")
commit 33fa46d7b310e06d2cb2ab5417c100af120bfb65 upstream.
In case caam_jr_alloc() fails, ctx->dev carries the error code,
thus accessing it with dev_err() is incorrect.
Fixes: 8c419778ab57e ("crypto: caam - add support for RSA algorithm")
commit 40c98cb57cdbc377456116ad4582c89e329721b0 upstream.
RNG instantiation was previously fixed by
commit 62743a4145bb9 ("crypto: caam - fix RNG init descriptor ret. code checking")
while deinstantiation was not addressed.
Since the descriptors used are similar, in the sense that they both end
with a JUMP HALT command, checking for errors should be similar too,
i.e. status code 7000_0000h should be considered successful.
Fixes: 1005bccd7a4a6 ("crypto: caam - enable instantiation of all RNG4 state handles")
commit 7c468447f40645fbf2a033dfdaa92b1957130d50 upstream.
The CCP driver generally uses a round-robin approach when
assigning operations to available CCPs. For the DMA engine,
however, the DMA mappings of the SGs are associated with a
specific CCP. When an IOMMU is enabled, the IOMMU is
programmed based on this specific device.
If the DMA operations are not performed by that specific
CCP then addressing errors and I/O page faults will occur.
Update the CCP driver to allow a specific CCP device to be
requested for an operation and use this in the DMA engine
support.
JTAG, DS-5 attachment causes exceptions
Added properties to device tree, in order to enable and disable
alarms. The following are the available alarms:
-JTAG active
-WatchDOG 2 reset
-Internal Boot
-External Tamper Detection pad
Fix cherry-picked from 5ec908319ab53072d3a2188e62ed2e5d7b846951
crypto: caam - only export the state we really need to export
Avoid exporting lots of state by only exporting what we really require,
which is the buffer containing the set of pending bytes to be hashed,
number of pending bytes, the context buffer, and the function pointer
state. This reduces down the exported state size to 216 bytes from
576 bytes.
There is new flag that is checked in of_platform_device_create().
The flag is cleared prior to the call now so the device creates
successfully.
caam_snvs driver involves snvs HP registers access that needs to
enable snvs clock source. The patch add the clock management.
Signed-off-by: Fugang Duan <B38611@freescale.com>
Signed-off-by: Dan Douglass <dan.douglass@freescale.com>
Added missing reserved register for caam_secure_mem_v1 struct
* Add caam_aclk clock root dependency, imx7d caam
ip module needs caam_aclk and caam_ipg clock signals
to operate add additional clock signal.
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
[Octavian: since the clk API skips NULL args use a single disable label]
There are only 3 CAAM clocks that are required for i.mx6ul. Adding
logic to enable only the required clocks based on the device tree
compatibility node.
CAAM only has a single clock in i.mx7d. Logic was added to initialize only the
single clock.
The Secure Memory registers moved in CAAM era included in i.mx7d. This required
changes to support access to two different versions of the register map. The
registers are access through a data structure that overlay the register region.
Two new Secure Memory register structures were created to support the different
versions. Logic was also added to determine which version is implemented based on
the CAAM era, and access functions were added to support register access to the
Secure Memory Command and Status registers.
Replace of_irq_to_resource() in the SECVIO module with the simpler
equivalent irq_of_parse_and_map(). Also, add error checking to
to the SECVIO and Job Ring modules. Based on upstream commit
f7578496a671a96e501f16a5104893275e32c33a.
Signed-off-by: Victoria Milhoan <vicki.milhoan@freescale.com>
This patch allows CAAM to be enabled as a wakeup source for the
Mega/Fast mix domain. If CAAM is enabled as a wakeup source, it
will continue to be powered on across Deep Sleep Mode (DSM). This
allows CAAM to be functional after the system resumes from DSM.
(cherry picked from commit 290744e3b40a563319324e234fa5a65b49fd4d82)
Add XCBC-AES support to the CAAM crypto accelerator core in
the i.MX6 family of SoC devices.
Note that CAAM also goes by sec-4.0 or sec-5.0 in other product families (such as QorIQ).
Thus the property names are often tied to the sec-4.0+ nomenclature.
Signed-off-by: Winston Hudson (b45308) <winston.h.hudson@freescale.com>
Add more CAAM era values to the CAAM driver's caam_get_era()
function. Read only 32 bits of data since the data required
to identify the IP_ID and MAJ_REV is located in the first 32
bits of the register. And, update the function for use with
ARM/Little Endian devices.
[<vicki.milhoan@freescale.com>: Edited to apply to 3.14]
(cherry picked from commit 6050d7faf2d0c063195aa9454c130548a9f8058f)
Unregister Secure Memory platform device when the Secure Memory
module is shut down. This allows the Secure Memory module to
be inserted again successfully.
(cherry picked from commit 785456f38234e64618ee9c74ab4258f39f00e73c)
i.MX6 devices have an issue wherein AXI bus transactions may not occur
in the correct order. This isn't a problem running single descriptors,
but can be if running multiple concurrent descriptors. Reworking the CAAM
driver to throttle to single requests is impractical, so this patch limits
the AXI pipeline to a depth of one (from a default of four) to preclude
this situation from occurring.
Signed-off-by: Victoria Milhoan (b42089) <vicki.milhoan@freescale.com>
Adds ARC4-ECB Mode support to the CAAM crypto accelerator core in
Adds 3DES-ECB-EDE Mode support to the CAAM crypto accelerator core in
