commit c419fcfd071cf34ba00f9f65282583772d2655e7 upstream.
When providers get blocked unregister_dca_providers() is called ending up
with dca_providers and dca_domain lists emptied. Dca should be prevented from
trying to unregister any provider if dca_domain list is found empty.
Reported-by: Jiang Liu <jiang.liu@huawei.com>
Tested-by: Gaohuai Han <hangaohuai@huawei.com>
Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Signed-off-by: Dan Williams <djbw@fb.com>
This file really needs the full module.h header file present, but
was just getting it implicitly before. Call it out in advance so
that we don't get future build failures on this.
The dca_lock can be taken in atomic context:
[ 25.607536] Call Trace:
[ 25.607557] [<ffffffff820078a1>] try_stack_unwind+0x151/0x1a0
[ 25.607566] [<ffffffff820062c2>] dump_trace+0x92/0x370
[ 25.607573] [<ffffffff8200731c>] show_trace_log_lvl+0x5c/0x80
[ 25.607578] [<ffffffff82007355>] show_trace+0x15/0x20
[ 25.607587] [<ffffffff823f4588>] dump_stack+0x77/0x8f
[ 25.607595] [<ffffffff82043f2a>] __might_sleep+0x11a/0x130
[ 25.607602] [<ffffffff823f7b93>] rt_spin_lock+0x83/0x90
[ 25.607611] [<ffffffffa0209138>] dca_common_get_tag+0x28/0x80 [dca]
[ 25.607622] [<ffffffffa02091c8>] dca3_get_tag+0x18/0x20 [dca]
[ 25.607634] [<ffffffffa0244e71>] igb_update_dca+0xb1/0x1d0 [igb]
[ 25.607649] [<ffffffffa0244ff5>] igb_setup_dca+0x65/0x80 [igb]
[ 25.607663] [<ffffffffa02535a6>] igb_probe+0x946/0xe4d [igb]
[ 25.607678] [<ffffffff82247517>] local_pci_probe+0x17/0x20
[ 25.607686] [<ffffffff82248661>] pci_device_probe+0x121/0x130
[ 25.607699] [<ffffffff822e4832>] driver_probe_device+0xd2/0x2e0
[ 25.607707] [<ffffffff822e4adb>] __driver_attach+0x9b/0xa0
[ 25.607714] [<ffffffff822e3d1b>] bus_for_each_dev+0x6b/0xa0
[ 25.607720] [<ffffffff822e4591>] driver_attach+0x21/0x30
[ 25.607727] [<ffffffff822e3425>] bus_add_driver+0x1e5/0x350
[ 25.607734] [<ffffffff822e4e41>] driver_register+0x81/0x160
[ 25.607742] [<ffffffff8224890f>] __pci_register_driver+0x6f/0xf0
[ 25.607752] [<ffffffffa011505b>] igb_init_module+0x5b/0x5d [igb]
[ 25.607769] [<ffffffff820001dd>] do_one_initcall+0x3d/0x1a0
[ 25.607778] [<ffffffff820961f6>] sys_init_module+0xe6/0x270
[ 25.607786] [<ffffffff82003232>] system_call_fastpath+0x16/0x1b
[ 25.607794] [<00007f84d6783f4a>] 0x7f84d6783f4a
and thus must not be preempted on -rt.
In mainline this change documents the low level nature of
the lock - otherwise there's no functional difference. Lockdep
and Sparse checking will work as usual.
Signed-off-by: Mike Galbraith <efault@gmx.de>
[ Fixed the domain allocation which was calling kzalloc from the irq disabled section ]
combination
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Maciej Sosnowski <maciej.sosnowski@intel.com>
The return here doesn't release the locks or re-enable IRQs. But as
Andrew Morton points out, domain is never NULL. list_first_entry()
essentially never returns NULL and also we already verified that the list
is not empty.
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Direct Cache Access is not supported on IOAT ver.3.0 multiple-IOH platforms.
This patch blocks registering of dca providers when multiple IOH detected with IOAT ver.3.0.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The message (if it must exist) should not be an error message.
IMHO such messages are useless.
This patch enables DCA support on multiple-IOH/multiple-IIO architectures.
It modifies dca module by replacing single dca_providers list
with dca_domains list, each domain containing separate list of providers.
This approach lets dca driver manage multiple domains, i.e. sets of providers
and requesters mapped back to the same PCI root complex device.
The driver takes care to register each requester to a provider
from the same domain.
Together with new fixes update driver version
and extend copyright dates ranges.
Signed-off-by: Shannon Nelson <shannon.nelson@intel.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Change spin_locks to irqsave to prevent dead-locks.
Protect adding and deleting to/from dca_providers list.
Drop the lock during dca_sysfs_add_req() and dca_sysfs_remove_req() calls
as they might sleep (use GFP_KERNEL allocation).
There are dmaengine users that would like to register dma devices at
subsys_initcall time to ensure channels are available by device_initcall
time.
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Mark dca_init as a subsys_initcall since it needs to be ready to go
before dependent drivers start registering themselves.
Cc: <stable@kernel.org>
Reported-and-tested-by: Mark Rustad <mark_rustad@Xiotech.com>
This patch adds to ioatdma and dca modules
support for Intel I/OAT DMA engine ver.3 (aka CB3 device).
The main features of I/OAT ver.3 are:
* 8 single channel DMA devices (8 channels total)
* 8 DCA providers, each can accept 2 requesters
* 8-bit TAG values and 32-bit extended APIC IDs
Direct Cache Access (DCA) is a method for warming the CPU cache before data
is used, with the intent of lessening the impact of cache misses. This
patch adds a manager and interface for matching up client requests for DCA
services with devices that offer DCA services.
In order to use DCA, a module must do bus writes with the appropriate tag
bits set to trigger a cache read for a specific CPU. However, different
CPUs and chipsets can require different sets of tag bits, and the methods
for determining the correct bits may be simple hardcoding or may be a
hardware specific magic incantation. This interface is a way for DCA
clients to find the correct tag bits for the targeted CPU without needing
to know the specifics.
[Dave Miller] use DEFINE_SPINLOCK()
