path: root/drivers/dca
2008-02-08DCA: convert struct class_device to struct device.Kay Sievers
Thanks to Kay for keeping us honest. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Cc: "Williams, Dan J" <dan.j.williams@intel.com> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16I/OAT: Add DCA servicesShannon Nelson
Add code to connect to the DCA driver and provide cpu tags for use by drivers that would like to use Direct Cache Access hints. [Adrian Bunk] Several Kconfig cleanup items [Andrew Morten, Chris Leech] Fix for using cpu_physical_id() even when built for uni-processor Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16DCA: Add Direct Cache Access driverShannon Nelson
Direct Cache Access (DCA) is a method for warming the CPU cache before data is used, with the intent of lessening the impact of cache misses. This patch adds a manager and interface for matching up client requests for DCA services with devices that offer DCA services. In order to use DCA, a module must do bus writes with the appropriate tag bits set to trigger a cache read for a specific CPU. However, different CPUs and chipsets can require different sets of tag bits, and the methods for determining the correct bits may be simple hardcoding or may be a hardware specific magic incantation. This interface is a way for DCA clients to find the correct tag bits for the targeted CPU without needing to know the specifics. [Dave Miller] use DEFINE_SPINLOCK() Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
