path: root/drivers/dma/Makefile
2011-03-22Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (66 commits) avr32: at32ap700x: fix typo in DMA master configuration dmaengine/dmatest: Pass timeout via module params dma: let IMX_DMA depend on IMX_HAVE_DMA_V1 instead of an explicit list of SoCs fsldma: make halt behave nicely on all supported controllers fsldma: reduce locking during descriptor cleanup fsldma: support async_tx dependencies and automatic unmapping fsldma: fix controller lockups fsldma: minor codingstyle and consistency fixes fsldma: improve link descriptor debugging fsldma: use channel name in printk output fsldma: move related helper functions near each other dmatest: fix automatic buffer unmap type drivers, pch_dma: Fix warning when CONFIG_PM=n. dmaengine/dw_dmac fix: use readl & writel instead of __raw_readl & __raw_writel avr32: at32ap700x: Specify DMA Flow Controller, Src and Dst msize dw_dmac: Setting Default Burst length for transfers as 16. dw_dmac: Allow src/dst msize & flow controller to be configured at runtime dw_dmac: Changing type of src_master and dest_master to u8. dw_dmac: Pass Channel Priority from platform_data dw_dmac: Pass Channel Allocation Order from platform_data ...
2011-03-17dma: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-02dmaengine: mxs-dma: add dma support for i.MX23/28Shawn Guo
This patch adds dma support for Freescale MXS-based SoC i.MX23/28, including apbh-dma and apbx-dma. * apbh-dma and apbx-dma are supported in the driver as two mxs-dma instances. * apbh-dma is different between mx23 and mx28, hardware version register is used to differentiate. * mxs-dma supports pio function besides data transfer. The driver uses dma_data_direction DMA_NONE to identify the pio mode, and steals sgl and sg_len to get pio words and numbers from clients. * mxs dmaengine has some very specific features, like sense function and the special NAND support (nand_lock, nand_wait4ready). These are too specific to implemented in generic dmaengine driver. * The driver refers to imx-sdma and only a single descriptor is statically assigned to each channel. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2010-12-03drivers/dma/: Use the ccflag-y instead of EXTRA_CFLAGSTracey Dent
Use the ccflag-y flag instead of EXTRA_CFLAGS because EXTRA_CFLAGS is deprecated and should now be switched. According to (documentation/kbuild/makefiles.txt). Signed-off-by: Tracey Dent <tdent48227@gmail.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-07Merge branches 'dma40', 'pl08x', 'fsldma', 'imx' and 'intel-mid' into dmaengineDan Williams
2010-10-07dmaengine: Add Freescale i.MX1/21/27 DMA driverSascha Hauer
This driver is currently implemented as a user to the old i.MX DMA API. This allows us to convert each user of the old API to the dmaengine API one by one. Once this is done the old DMA driver can be merged into the i.MX dmaengine driver. V2: remove some debug leftovers and unused variables Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-05dmaengine: Add Freescale i.MX SDMA supportSascha Hauer
This patch adds support for the Freescale i.MX SDMA engine. The SDMA engine is a scatter/gather DMA engine which is implemented as a seperate coprocessor. SDMA needs its own firmware which is requested using the standard request_firmware mechanism. The firmware has different entry points for each peripheral type, so drivers have to pass the peripheral type to the DMA engine which in turn picks the correct firmware entry point from a table contained in the firmware image itself. The original Freescale code also supports support for transfering data to the internal SRAM which needs different entry points to the firmware. Support for this is currently not implemented. Also, support for the ASRC (asymmetric sample rate converter) is skipped. I took a very simple approach to implement dmaengine support. Only a single descriptor is statically assigned to a each channel. This means that transfers can't be queued up but only a single transfer is in progress. This simplifies implementation a lot and is sufficient for the usual device/memory transfers. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Linus Walleij <linus.ml.walleij@gmail.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-09-29dmaengine: driver for the ARM PL080/PL081 PrimeCells v5Linus Walleij
This creates a DMAengine driver for the ARM PL080/PL081 PrimeCells based on the implementation earlier submitted by Peter Pearse. This is working like a charm for memcpy and slave DMA to the PL011 PrimeCell on the PB11MPCore. This DMA controller is used in mostly unmodified form in the ARM RealView and Versatile platforms, in the ST-Ericsson Nomadik, and in the ST SPEAr platform. It has been converted to use the header from the Samsung PL080 derivate instead of its own defintions. The Samsungs have a custom driver in their mach-* folders though, atleast we can share the register definitions. Cc: Peter Pearse <peter.pearse@arm.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> [GFP_KERNEL to GFP_NOWAIT in pl08x_prep_dma_memcpy] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-08-04dmaengine: Driver for Topcliff PCH DMA controllerYong Wang
Topcliff PCH is the platform controller hub that is going to be used in Intel's upcoming general embedded platforms. This adds the driver for Topcliff PCH DMA controller. The DMA channels are strictly for device to host or host to device transfers and cannot be used for generic memcpy. Signed-off-by: Yong Wang <yong.y.wang@intel.com> [kill GFP_ATOMIC, kill __raw_{read|write}l, locking fixlet] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-07-27intel_mid: Add Mrst & Mfld DMA DriversVinod Koul
This patch add DMA drivers for DMA controllers in Langwell chipset of Intel(R) Moorestown platform and DMA controllers in Penwell of Intel(R) Medfield platfrom This patch adds support for Moorestown DMAC1 and DMAC2 controllers. It also add support for Medfiled GP DMA and DMAC1 controllers. These controllers supports memory to peripheral and peripheral to memory transfers. It support only single block transfers. This driver is based on Kernel DMA engine Anyone who wishes to use this controller should use DMA engine APIs This controller exposes DMA_SLAVE capabilities and notifies the client drivers of DMA transaction completion Config option required to be enabled CONFIG_INTEL_MID_DMAC=y Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-23DMA: PL330: Add dma api driverJassi Brar
Add DMA Engine API driver for the PL330 DMAC. This driver is supposed to be reusable by various platforms that have one or more PL330 DMACs. Atm, DMA_SLAVE and DMA_MEMCPY capabilities have been implemented. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Reviewed-by: Linus Walleij <linus.walleij@stericsson.com> [dan.j.williams@intel.com: missing slab.h and ->device_control() fixups] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-04-14DMAENGINE: Support for ST-Ericssons DMA40 block v3Linus Walleij
This is a straightforward driver for the ST-Ericsson DMA40 DMA controller found in U8500, implemented akin to the existing COH 901 318 driver. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidh Kasagar <srinidhi.kasagar@stericsson.com> Cc: STEricsson_nomadik_linux@list.st.com Cc: Alessandro Rubini <rubini@unipv.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-25dma: Add timb-dmaRichard Röjfors
Adds the support for the DMA engine withing the timberdale FPGA. The DMA channels are strict device to host, or host to device and can not be used for generic memcpy. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-01dma: Add MPC512x DMA driverPiotr Ziecik
Adds initial version of MPC512x DMA driver. Only memory to memory transfers are currenly supported. Signed-off-by: Piotr Ziecik <kosmo@semihalf.com> Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: John Rigby <jcrigby@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-01Debugging options for the DMA engine subsystemLinus Walleij
This adds Kconfig options for DEBUG and VERBOSE_DEBUG to the DMA engine subsystem, I got tired of editing the Makefile manually each time I want to debug things in here, modelled this on the debug switches for other subsystems and works like a charm when working on our DMA engines. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-12-11ppc440spe-adma: adds updated ppc440spe adma driverAnatolij Gustschin
This patch adds new version of the PPC440SPe ADMA driver. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-11-19Add COH 901 318 DMA block driver v5Linus Walleij
This patch adds support for the ST-Ericsson COH 901 318 DMA block, found in the U300 series platforms. It registers a DMA slave for device I/O and also a memcpy slave for memcpy. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08dmaengine: sh: Add Support SuperH DMA Engine driverNobuhiro Iwamatsu
This supported all DMA channels, and it was tested in SH7722, SH7780, SH7785 and SH7763. This can not use with SH DMA API. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Reviewed-by: Matt Fleming <matt@console-pimps.org> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08Merge branch 'ioat' into dmaengineDan Williams
2009-09-08Merge commit 'v2.6.31-rc1' into dmaengineDan Williams
2009-07-28ioat: move to drivers/dma/ioat/Dan Williams
When first created the ioat driver was the only inhabitant of drivers/dma/. Now, it is the only multi-file (more than a .c and a .h) driver in the directory. Moving it to an ioat/ subdirectory allows the naming convention to be cleaned up, and allows for future splitting of the source files by hardware version (v1, v2, and v3). Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-07-22dmaengine: at_hdmac: new driver for the Atmel AHB DMA ControllerNicolas Ferre
This AHB DMA Controller (aka HDMA or DMAC on AT91 systems) is availlable on at91sam9rl chip. It will be used on other products in the future. This first release covers only the memory-to-memory tranfer type. This is the only tranfer type supported by this chip. On other products, it will be used also for peripheral DMA transfer (slave API support to come). I used dmatest client without problem in different configurations to test it. Full documentation for this controller can be found in the SAM9RL datasheet: http://www.atmel.com/dyn/products/product_card.asp?part_id=4243 Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-06-17DMA: TXx9 Soc DMA Controller driverAtsushi Nemoto
This patch adds support for the integrated DMAC of the TXx9 family. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-19i.MX31: Image Processing Unit DMA and IRQ driversGuennadi Liakhovetski
i.MX3x SoCs contain an Image Processing Unit, consisting of a Control Module (CM), Display Interface (DI), Synchronous Display Controller (SDC), Asynchronous Display Controller (ADC), Image Converter (IC), Post-Filter (PF), Camera Sensor Interface (CSI), and an Image DMA Controller (IDMAC). CM contains, among other blocks, an Interrupt Generator (IG) and a Clock and Reset Control Unit (CRCU). This driver serves IDMAC and IG. They are supported over dmaengine and irq-chip APIs respectively. IDMAC is a specialised DMA controller, its DMA channels cannot be used for general-purpose operations, even though it might be possible to configure a memory-to-memory channel for memcpy operation. This driver will not work with generic dmaengine clients, clients, wishing to use it must use respective wrapper structures, they also must specify which channels they require, as channels are hard-wired to specific IPU functions. Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-08dmaengine: Driver for the Synopsys DesignWare DMA controllerHaavard Skinnemoen
This adds a driver for the Synopsys DesignWare DMA controller (aka DMACA on AVR32 systems.) This DMA controller can be found integrated on the AT32AP7000 chip and is primarily meant for peripheral DMA transfer, but can also be used for memory-to-memory transfers. This patch is based on a driver from David Brownell which was based on an older version of the DMA Engine framework. It also implements the proposed extensions to the DMA Engine API for slave DMA operations. The dmatest client shows no problems, but there may still be room for improvement performance-wise. DMA slave transfer performance is definitely "good enough"; reading 100 MiB from an SD card running at ~20 MHz yields ~7.2 MiB/s average transfer rate. Full documentation for this controller can be found in the Synopsys DW AHB DMAC Databook: http://www.synopsys.com/designware/docs/iip/DW_ahb_dmac/latest/doc/dw_ahb_dmac_db.pdf The controller has lots of implementation options, so it's usually a good idea to check the data sheet of the chip it's intergrated on as well. The AT32AP7000 data sheet can be found here: http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 Changes since v4: * Use client_count instead of dma_chan_is_in_use() * Add missing include * Unmap buffers unless client told us not to Changes since v3: * Update to latest DMA engine and DMA slave APIs * Embed the hw descriptor into the sw descriptor * Clean up and update MODULE_DESCRIPTION, copyright date, etc. Changes since v2: * Dequeue all pending transfers in terminate_all() * Rename dw_dmac.h -> dw_dmac_regs.h * Define and use controller-specific dma_slave data * Fix up a few outdated comments * Define hardware registers as structs (doesn't generate better code, unfortunately, but it looks nicer.) * Get number of channels from platform_data instead of hardcoding it based on CONFIG_WHATEVER_CPU. * Give slave clients exclusive access to the channel Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>, Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-08dmatest: Simple DMA memcpy test clientHaavard Skinnemoen
This client tests DMA memcpy using various lengths and various offsets into the source and destination buffers. It will initialize both buffers with a repeatable pattern and verify that the DMA engine copies the requested region and nothing more. It will also verify that the bytes aren't swapped around, and that the source buffer isn't modified. The dmatest module can be configured to test a specific device, a specific channel. It can also test multiple channels at the same time, and it can start multiple threads competing for the same channel. Changes since v2: * Support testing multiple channels at the same time * Support testing with multiple threads competing for the same channel * Use counting test patterns in order to catch byte ordering issues Changes since v1: * Remove extra dashes around "help" * Remove "default n" from Kconfig * Turn TEST_BUF_SIZE into a module parameter * Return DMA_NAK instead of DMA_DUP * Print unhandled events * Support testing specific channels and devices * Move to the end of the Makefile Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-08dmaengine: DMA engine driver for Marvell XOR engineSaeed Bishara
The XOR engine found in Marvell's SoCs and system controllers provides XOR and DMA operation, iSCSI CRC32C calculation, memory initialization, and memory ECC error cleanup operation support. This driver implements the DMA engine API and supports the following capabilities: - memcpy - xor - memset The XOR engine can be used by DMA engine clients implemented in the kernel, one of those clients is the RAID module. In that case, I observed 20% improvement in the raid5 write throughput, and 40% decrease in the CPU utilization when doing array construction, those results obtained on an 5182 running at 500Mhz. When enabling the NET DMA client, the performance decreased, so meanwhile it is recommended to keep this client off. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-03-04dmaengine: add driver for Freescale MPC85xx DMA controllerZhang Wei
The driver implements DMA engine API for Freescale MPC85xx DMA controller, which could be used by devices in the silicon. The driver supports the Basic mode of Freescale MPC85xx DMA controller. The MPC85xx processors supported include MPC8540/60, MPC8555, MPC8548, MPC8641 and so on. The MPC83xx(MPC8349, MPC8360) are also supported. [kamalesh@linux.vnet.ibm.com: build fix] [dan.j.williams@intel.com: merge mm fixes, rebase on async_tx-2.6.25] Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com> Acked-by: Kumar Gala <galak@gate.crashing.org> Cc: Shannon Nelson <shannon.nelson@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2007-10-16I/OAT: Add DCA servicesShannon Nelson
Add code to connect to the DCA driver and provide cpu tags for use by drivers that would like to use Direct Cache Access hints. [Adrian Bunk] Several Kconfig cleanup items [Andrew Morten, Chris Leech] Fix for using cpu_physical_id() even when built for uni-processor Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16I/OAT: Split PCI startup from DMA handling codeShannon Nelson
Split the general PCI startup from the DMA handling code in order to prepare for adding support for DCA services and future versions of the ioatdma device. [Rusty Russell] Removal of __unsafe() usage. Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16I/OAT: Rename the source fileShannon Nelson
Rename the ioatdma.c file in preparation for splitting into multiple files, which will allow for easier adding new functionality. Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-13dmaengine: driver for the iop32x, iop33x, and iop13xx raid enginesDan Williams
The Intel(R) IOP series of i/o processors integrate an Xscale core with raid acceleration engines. The capabilities per platform are: iop219: (2) copy engines iop321: (2) copy engines (1) xor and block fill engine iop33x: (2) copy and crc32c engines (1) xor, xor zero sum, pq, pq zero sum, and block fill engine iop34x (iop13xx): (2) copy, crc32c, xor, xor zero sum, and block fill engines (1) copy, crc32c, xor, xor zero sum, pq, pq zero sum, and block fill engine The driver supports the features of the async_tx api: * asynchronous notification of operation completion * implicit (interupt triggered) handling of inter-channel transaction dependencies The driver adapts to the platform it is running by two methods. 1/ #include <asm/arch/adma.h> which defines the hardware specific iop_chan_* and iop_desc_* routines as a series of static inline functions 2/ The private platform data attached to the platform_device defines the capabilities of the channels 20070626: Callbacks are run in a tasklet. Given the recent discussion on LKML about killing tasklets in favor of workqueues I did a quick conversion of the driver. Raid5 resync performance dropped from 50MB/s to 30MB/s, so the tasklet implementation remains until a generic softirq interface is available. Changelog: * fixed a slot allocation bug in do_iop13xx_adma_xor that caused too few slots to be requested eventually leading to data corruption * enabled the slot allocation routine to attempt to free slots before returning -ENOMEM * switched the cleanup routine to solely use the software chain and the status register to determine if a descriptor is complete. This is necessary to support other IOP engines that do not have status writeback capability * make the driver iop generic * modified the allocation routines to understand allocating a group of slots for a single operation * added a null xor initialization operation for the xor only channel on iop3xx * support xor operations on buffers larger than the hardware maximum * split the do_* routines into separate prep, src/dest set, submit stages * added async_tx support (dependent operations initiation at cleanup time) * simplified group handling * added interrupt support (callbacks via tasklets) * brought the pending depth inline with ioat (i.e. 4 descriptors) * drop dma mapping methods, suggested by Chris Leech * don't use inline in C files, Adrian Bunk * remove static tasklet declarations * make iop_adma_alloc_slots easier to read and remove chances for a corrupted descriptor chain * fix locking bug in iop_adma_alloc_chan_resources, Benjamin Herrenschmidt * convert capabilities over to dma_cap_mask_t * fixup sparse warnings * add descriptor flush before iop_chan_enable * checkpatch.pl fixes * gpl v2 only correction * move set_src, set_dest, submit to async_tx methods * move group_list and phys to async_tx Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2006-06-17[I/OAT]: Utility functions for offloading sk_buff to iovec copiesChris Leech
Provides for pinning user space pages in memory, copying to iovecs, and copying from sk_buffs including fragmented and chained sk_buffs. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: Driver for the Intel(R) I/OAT DMA engineChris Leech
Adds a new ioatdma driver Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: DMA memcpy subsystemChris Leech
Provides an API for offloading memory copies to DMA devices Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
