fixup usage of dma direction by introducing dma_transfer_direction,
this patch moves dma/drivers/* to use new enum
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Viresh Kumar <viresh.kumar@st.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Mika Westerberg <mika.westerberg@iki.fi>
Cc: H Hartley Sweeten <hartleys@visionengravers.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Zhang Wei <zw@zh-kernel.org>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Shawn Guo <shawn.guo@freescale.com>
Cc: Yong Wang <yong.y.wang@intel.com>
Cc: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com>
Cc: Boojin Kim <boojin.kim@samsung.com>
Cc: Barry Song <Baohua.Song@csr.com>
Acked-by: Mika Westerberg <mika.westerberg@iki.fi>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (33 commits)
x86: poll waiting for I/OAT DMA channel status
maintainers: add dma engine tree details
dmaengine: add TODO items for future work on dma drivers
dmaengine: Add API documentation for slave dma usage
dmaengine/dw_dmac: Update maintainer-ship
dmaengine: move link order
dmaengine/dw_dmac: implement pause and resume in dwc_control
dmaengine/dw_dmac: Replace spin_lock* with irqsave variants and enable submission from callback
dmaengine/dw_dmac: Divide one sg to many desc, if sg len is greater than DWC_MAX_COUNT
dmaengine/dw_dmac: set residue as total len in dwc_tx_status if status is !DMA_SUCCESS
dmaengine/dw_dmac: don't call callback routine in case dmaengine_terminate_all() is called
dmaengine: at_hdmac: pause: no need to wait for FIFO empty
pch_dma: modify pci device table definition
pch_dma: Support new device ML7223 IOH
pch_dma: Support I2S for ML7213 IOH
pch_dma: Fix DMA setting issue
pch_dma: modify for checkpatch
pch_dma: fix dma direction issue for ML7213 IOH video-in
dmaengine: at_hdmac: use descriptor chaining help function
dmaengine: at_hdmac: implement pause and resume in atc_control
Fix up trivial conflict in drivers/dma/dw_dmac.c
With the addition of the "pause" feature, an active wait was introduced
to check the "FIFO empty" event. This event was not always happening and
a timout contition was needed.
But, in some cases, this event depend on the peripheral connected to the
channel that is paused: FIFO becomes empty if the peripheral consumes data.
The timeout is pretty difficult to evaluate. Moreover, this check is not
needed.
In conclusion, it seems sensible to entirely remove the checking of
"FIFO empty" status when pausing.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
[commit msg edited for grammer]
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
A little function helps to chain descriptors:
it is already used in cyclic dma operations, now use it in memcpy and slave_sg
preparation functions.
Pause and resume controls are useful for audio devices. This also returns
correct status from atc_tx_status() in case chan is paused.
Idea from dw_dmac patch by Linus Walleij.
If transfer status is !=DMA_SUCCESS, return total transfer len as residue,
instead of zero.
Idea from dw_dmac patch by Viresh Kumar.
DMA controller has two AHB interfaces on the SOC internal
matrix.
It is more efficient to specialize each interface as the
access to memory can introduce latencies that are not compatible
with peripheral accesses requirements.
There is no need to test if channel is enabled in tasklet:
- in error path, channel is disabled in interrupt routine
- in normal path, this test is performed in sub functions to report
a misuse of the engine.
Now we use Buffer Transfer Completed interrupts. If we
want a chained buffer completed information, we setup the
ATC_IEN bit in CTRLB register in the lli.
This is done by set_desc_eol() function and used by
memcpy/slave_sg functions.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (63 commits)
ARM: PL08x: cleanup comments
Update CONFIG_MD_RAID6_PQ to CONFIG_RAID6_PQ in drivers/dma/iop-adma.c
ARM: PL08x: fix a warning
Fix dmaengine_submit() return type
dmaengine: at_hdmac: fix race while monitoring channel status
dmaengine: at_hdmac: flags located in first descriptor
dmaengine: at_hdmac: use subsys_initcall instead of module_init
dmaengine: at_hdmac: no need set ACK in new descriptor
dmaengine: at_hdmac: trivial add precision to unmapping comment
dmaengine: at_hdmac: use dma_address to program DMA hardware
pch_dma: support new device ML7213 IOH
ARM: PL08x: prevent dma_set_runtime_config() reconfiguring memcpy channels
ARM: PL08x: allow dma_set_runtime_config() to return errors
ARM: PL08x: fix locking between prepare function and submit function
ARM: PL08x: introduce 'phychan_hold' to hold on to physical channels
ARM: PL08x: put txd's on the pending list in pl08x_tx_submit()
ARM: PL08x: rename 'desc_list' as 'pend_list'
ARM: PL08x: implement unmapping of memcpy buffers
ARM: PL08x: store prep_* flags in async_tx structure
ARM: PL08x: shrink srcbus/dstbus in txd structure
We were reading channel status then taking a lock. This lead to a race because
this lock may delay us and then make this channel not idle anymore.
Place flags on first descriptor of chain instead of last.
This is the one used by atc_chain_complete() function while unmapping.
Use subsys_initcall instead of module_init in order to keep DMA engine rolling
before other peripheral drivers.
Signed-off-by: Eric Xu <hong.xu@atmel.com>
Following descriptor flow in at_hdmac driver, descriptor comming from
atc_desc_get() as already DMA_CTRL_ACK flag set. No need to set it again.
In atc_prep_slave_sg() function we use dma_address field of scatterlist with
sg_dma_address() macro instead of sg_phys(). DMA address is already computed
by dma_map_sg() or another mapping function in calling driver.
Buffer transfer size is the number of transfers to be performed in
relation with the width of the _source_ interface.
So in the DMA_FROM_DEVICE case, it should be the register width that
should be taken into account.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (30 commits)
DMAENGINE: at_hdmac: locking fixlet
DMAENGINE: pch_dma: kill another usage of __raw_{read|write}l
dma: dmatest: fix potential sign bug
ioat2: catch and recover from broken vtd configurations v6
DMAENGINE: add runtime slave control to COH 901 318 v3
DMAENGINE: add runtime slave config to DMA40 v3
DMAENGINE: generic slave channel control v3
dmaengine: Driver for Topcliff PCH DMA controller
intel_mid: Add Mrst & Mfld DMA Drivers
drivers/dma: Eliminate a NULL pointer dereference
dma/timb_dma: compile warning on 32 bit
DMAENGINE: ste_dma40: support older silicon
DMAENGINE: ste_dma40: support disabling physical channels
DMAENGINE: ste_dma40: no disabled phy channels on ux500
DMAENGINE: ste_dma40: fix suspend bug
DMAENGINE: ste_dma40: add DB8500 memcpy channels
DMAENGINE: ste_dma40: no flow control on memcpy
DMAENGINE: ste_dma40: arch updates for LCLA and LCPA
DMAENGINE: ste_dma40: allocate LCLA dynamically
DMAENGINE: ste_dma40: no premature stop
Fix up trivial conflicts in arch/arm/mach-ux500/devices-db8500.c
atc_chain_complete shall be called with atchan->lock held
and bh disabled.
Signed-off-by: Yong Wang <yong.y.wang@intel.com>
This adds an argument to the DMAengine control function, so that
we can later provide control commands that need some external data
passed in through an argument akin to the ioctl() operation
prototype.
[dan.j.williams@intel.com: fix up some missed conversions]
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Simple conditional struct filler to cut out some duplicated code.
Convert the device_is_tx_complete() operation on the
DMA engine to a generic device_tx_status()operation which
can return three states, DMA_TX_RUNNING, DMA_TX_COMPLETE,
DMA_TX_PAUSED.
[dan.j.williams@intel.com: update for timberdale]
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Maciej Sosnowski <maciej.sosnowski@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Cc: Magnus Damm <damm@opensource.se>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Joe Perches <joe@perches.com>
Cc: Roland Dreier <rdreier@cisco.com>
Convert the device_terminate_all() operation on the
DMA engine to a generic device_control() operation
which can now optionally support also pausing and
resuming DMA on a certain channel. Implemented for the
COH 901 318 DMAC as an example.
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
drivers/dma: Correct use after free
drivers/dma: drop unnecesary memset
ioat2,3: put channel hardware in known state at init
async_tx: expand async raid6 test to cover ioatdma corner case
ioat3: fix p-disabled q-continuation
sh: fix DMA driver's descriptor chaining and cookie assignment
dma: at_hdmac: correct incompatible type for argument 1 of 'spin_lock_bh'
Correct a typo error in locking calls.
Cc: <stable@kernel.org>
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx into for-linus
This patch reworks platform driver power management code
for at_hdmac from legacy late/early callbacks to dev_pm_ops.
The callbacks are converted for CONFIG_SUSPEND like this:
suspend_late() -> suspend_noirq()
resume_early() -> resume_noirq()
Dan Williams wrote:
... DMA-slave clients request specific channels and know the hardware
details at a low level, so it should not be too high an expectation to
push dma mapping responsibility to the client.
Also this patch includes DMA_COMPL_{SRC,DEST}_UNMAP_SINGLE support for
dw_dmac driver.
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Drop at_hdmac's use of tx_list from struct dma_async_tx_descriptor in
preparation for removal of this field.
This patch for at_hdmac adds the slave transfers capability to the Atmel DMA
controller available on some AT91 SOCs. This allow peripheral to memory and
memory to peripheral transfers with hardware handshaking.
Slave structure for controller specific information is passed through channel
private data. This at_dma_slave structure is defined in at_hdmac.h header file
and relative hardware definition are moved to this file from at_hdmac_regs.h.
Doing this we allow the channel configuration from platform definition code.
This work is intensively based on dw_dmac and several slave implementations.
This AHB DMA Controller (aka HDMA or DMAC on AT91 systems) is availlable on
at91sam9rl chip. It will be used on other products in the future.
This first release covers only the memory-to-memory tranfer type. This is the
only tranfer type supported by this chip. On other products, it will be used
also for peripheral DMA transfer (slave API support to come).
I used dmatest client without problem in different configurations to test it.
Full documentation for this controller can be found in the SAM9RL datasheet:
http://www.atmel.com/dyn/products/product_card.asp?part_id=4243
