commit 77e75fda94d2ebb86aa9d35fb1860f6395bf95de upstream.
of_dma_controller_free() was not called on module onloading.
This lead to a soft lockup:
watchdog: BUG: soft lockup - CPU#0 stuck for 23s!
Modules linked in: at_hdmac [last unloaded: at_hdmac]
when of_dma_request_slave_channel() tried to call ofdma->of_dma_xlate().
Cc: stable@vger.kernel.org
Fixes: bbe89c8e3d59 ("at_hdmac: move to generic DMA binding")
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Signed-off-by: Vinod Koul <vkoul@kernel.org>
commit 98f5f932254b88ce828bc8e4d1642d14e5854caa upstream.
The leak was found when opening/closing a serial port a great number of
time, increasing kmalloc-32 in slabinfo.
Each time the port was opened, dma_request_slave_channel() was called.
Then, in at_dma_xlate(), atslave was allocated with devm_kzalloc() and
never freed. (Well, it was free at module unload, but that's not what we
want).
So, here, kzalloc is more suited for the job since it has to be freed in
atc_free_chan_resources().
Reported-by: Mario Forner <m.forner@be4energy.com>
Suggested-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
atc_prep_dma_interleaved
[ Upstream commit 62a277d43d47e74972de44d33bd3763e31992414 ]
_xt_ is being dereferenced before it is null checked, hence there is a
potential null pointer dereference.
Fix this by moving the pointer dereference after _xt_ has been null
checked.
This issue was detected with the help of Coccinelle.
Fixes: 4483320e241c ("dmaengine: Use Pointer xt after NULL check.")
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
This is in preperation of moving to a callback that provides results to the
callback for the transaction. The conversion will maintain current behavior
and the driver must convert to new callback mechanism at a later time in
order to receive results.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
dma_addr_t may be defined as 32 or 64 bit depending on configuration,
so it cannot be printed using the normal format strings, as
gcc correctly warns:
drivers/dma/at_hdmac.c: In function 'atc_prep_dma_interleaved':
drivers/dma/at_hdmac.c:731:28: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'dma_addr_t {aka long long unsigned int}' [-Wformat=]
This changes the format strings to use the special "%pad" format
string that prints a dma_addr_t, and changes the arguments so we
pass the address by reference as required.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Just like memset support, the HDMAC might be used to do a memset over a
discontiguous memory area.
In such a case, we'll just build up a chain of memset descriptors over the
contiguous chunks of memory to set, in order to allow such a support.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The memset and scatter gathered memset are going to use some common logic
to create their descriptors.
Move that logic into a function of its own so that we can share it with the
future memset_sg callback.
Pull dmaengine updates from Vinod Koul:
"This time we have aded a new capability for scatter-gathered memset
using dmaengine APIs. This is supported in xdmac & hdmac drivers
We have added support for reusing descriptors for examples like video
buffers etc. Driver will follow
The behaviour of descriptor ack has been clarified and documented
New devices added are:
- dma controller in sun[457]i SoCs
- lpc18xx dmamux
- ZTE ZX296702 dma controller
- Analog Devices AXI-DMAC DMA controller
- eDMA support for dma-crossbar
- imx6sx support in imx-sdma driver
- imx-sdma device to device support
Other:
- jz4780 fixes
- ioatdma large refactor and cleanup for removal of ioat v1 and v2
which is deprecated and fixes
- ACPI support in X-Gene DMA engine driver
- ipu irq fixes
- mvxor fixes
- minor fixes spread thru drivers"
[ The Kconfig and Makefile entries got re-sorted alphabetically, and I
handled the conflict with the new Intel integrated IDMA driver by
slightly mis-sorting it on purpose: "IDMA64" got sorted after "IMX" in
order to keep the Intel entries together. I think it might be a good
idea to just rename the IDMA64 config entry to INTEL_IDMA64 to make
the sorting be a true sort, not this mismash.
Also, this merge disables the COMPILE_TEST for the sun4i DMA
controller, because it does not compile cleanly at all. - Linus ]
* tag 'dmaengine-4.3-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (89 commits)
dmaengine: ioatdma: add Broadwell EP ioatdma PCI dev IDs
dmaengine :ipu: change ipu_irq_handler() to remove compile warning
dmaengine: ioatdma: Fix variable array length
dmaengine: ioatdma: fix sparse "error" with prep lock
dmaengine: hdmac: Add memset capabilities
dmaengine: sort the sh Makefile
dmaengine: sort the sh Kconfig
dmaengine: sort the dw Kconfig
dmaengine: sort the Kconfig
dmaengine: sort the makefile
drivers/dma: make mv_xor.c driver explicitly non-modular
dmaengine: Add support for the Analog Devices AXI-DMAC DMA controller
devicetree: Add bindings documentation for Analog Devices AXI-DMAC
dmaengine: xgene-dma: Fix the lock to allow client for further submission of requests
dmaengine: ioatdma: fix coccinelle warning
dmaengine: ioatdma: fix zero day warning on incompatible pointer type
dmaengine: tegra-apb: Simplify locking for device using global pause
dmaengine: tegra-apb: Remove unnecessary return statements and variables
dmaengine: tegra-apb: Avoid unnecessary channel base address calculation
dmaengine: tegra-apb: Remove unused variables
Just like for the XDMAC, the SoCs that embed the HDMAC don't have any kind
of GPU, and need to accelerate a few framebuffer-related operations through
their DMA controller.
However, unlike the XDMAC, the HDMAC doesn't have the memset capability
built-in. That can be easily emulated though, by doing a transfer with a
fixed address on the variable that holds the value we want to set.
As claimed by the programmer datasheet and confirmed by the IP designer,
the Block Transfer Size (BTSIZE) bitfield of the Channel x Control A
Register (CTRLAx) always refers to a number of Source Width (SRC_WIDTH)
transfers.
Both the SRC_WIDTH and BTSIZE bitfields can be extacted from the CTRLAx
register to compute the DMA residue. So the 'tx_width' field is useless
and can be removed from the struct at_desc.
Before this patch, atc_prep_slave_sg() was not consistent: BTSIZE was
correctly initialized according to the SRC_WIDTH but 'tx_width' was always
set to reg_width, which was incorrect for MEM_TO_DEV transfers. It led to
bad DMA residue when 'tx_width' != SRC_WIDTH.
Also the 'tx_width' field was mostly set only in the first and last
descriptors. Depending on the kind of DMA transfer, this field remained
uninitialized for intermediate descriptors. The accurate DMA residue was
computed only when the currently processed descriptor was the first or the
last of the chain. This algorithm was a little bit odd. An accurate DMA
residue can always be computed using the SRC_WIDTH and BTSIZE bitfields
in the CTRLAx register.
Finally, the test to check whether the currently processed descriptor is
the last of the chain was wrong: for cyclic transfer, last_desc->lli.dscr
is NOT equal to zero, since set_desc_eol() is never called, but logically
equal to first_desc->txd.phys. This bug has a side effect on the
drivers/tty/serial/atmel_serial.c driver, which uses cyclic DMA transfer
to receive data. Since the DMA residue was wrong each time the DMA
transfer reaches the second (and last) period of the transfer, no more
data were received by the USART driver till the cyclic DMA transfer loops
back to the first period.
Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com>
Acked-by: Torsten Fleischer <torfl6749@gmail.com>
Tested-by: Jirí Prchal <jiri.prchal@aksignal.cz>
Removing static analysis error:-
Possible null pointer dereference: xt
Because currently xt is dereferenced before NULL check,
Thus Use it after NULL Check.
Signed-off-by: Maninder Singh <maninder1.s@samsung.com>
Reviewed-by: Vaneet Narang <v.narang@samsung.com>
The AT91 HDMAC controller supports interleaved transfers through what's
called the Picture-in-Picture mode, which allows to transfer a squared
portion of a framebuffer.
This means that this interleaved transfer only supports interleaved
transfers which have a transfer size and ICGs that are fixed across all the
chunks.
While this is a quite drastic restriction of the interleaved transfers
compared to what the dmaengine API allows, this is still useful, and our
driver will only reject transfers that do not conform to this.
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Pull slave-dmaengine updates from Vinod Koul:
- new drivers for:
- Ingenic JZ4780 controller
- APM X-Gene controller
- Freescale RaidEngine device
- Renesas USB Controller
- remove device_alloc_chan_resources dummy handlers
- sh driver cleanups for peri peri and related emmc and asoc patches
as well
- fixes and enhancements spread over the drivers
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (59 commits)
dmaengine: dw: don't prompt for DW_DMAC_CORE
dmaengine: shdmac: avoid unused variable warnings
dmaengine: fix platform_no_drv_owner.cocci warnings
dmaengine: pch_dma: fix memory leak on failure path in pch_dma_probe()
dmaengine: at_xdmac: unlock spin lock before return
dmaengine: xgene: devm_ioremap() returns NULL on error
dmaengine: xgene: buffer overflow in xgene_dma_init_channels()
dmaengine: usb-dmac: Fix dereferencing freed memory 'desc'
dmaengine: sa11x0: report slave capabilities to upper layers
dmaengine: vdma: Fix compilation warnings
dmaengine: fsl_raid: statify fsl_re_chan_probe
dmaengine: Driver support for FSL RaidEngine device.
dmaengine: xgene_dma_init_ring_mngr() can be static
Documentation: dma: Add documentation for the APM X-Gene SoC DMA device DTS binding
arm64: dts: Add APM X-Gene SoC DMA device and DMA clock DTS nodes
dmaengine: Add support for APM X-Gene SoC DMA engine driver
dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver
dmaengine: renesas,usb-dmac: Add device tree bindings documentation
dmaengine: edma: fixed wrongly initialized data parameter to the edma callback
dmaengine: ste_dma40: fix implicit conversion
This patch fixes the following issues regarding to the calculation of the
residue:
1. The residue is always calculated for the current transfer even if the
cookie is associated to a pending transfer.
2. For scatter/gather DMA the calculation of the residue for the current
transfer doesn't include the bytes of the child descriptors that are already
transferred.
It only calculates the difference between the transfer's total length minus
the number of bytes that are already transferred for the current child
descriptor.
For example: There is a scatter/gather DMA transfer with a total length of
1 MByte. Getting the residue several times while the transfer is running shows
something like that:
1: residue = 975584
2: residue = 1002766
3: residue = 992627
4: residue = 983767
5: residue = 985694
6: residue = 1008094
7: residue = 1009741
8: residue = 1011195
3. The driver stores the residue but never resets it when starting a new
transfer.
For example: If there are two subsequent DMA transfers. The first one with
a total length of 1 MByte and the second one with a total length of 1 kByte.
Getting the residue for both transfers shows something like that:
transfer 1: residue = 975584
transfer 2: residue = 1048380
Changes from V1:
* Fixed coding style of the multi-line comments.
* Improved accuracy of the residue calculation when the transfer for the
first descriptor is active.
Changes from V2:
* Member 'tx_width' of 'struct at_desc' restored, because the transfer width
can't be derived from the source width when using "slave_sg".
The transfer width is needed for the calculation of the residue if either
the transfer of the first or the last descriptor is in progress.
In the case of a "memory_to_memory_sg" transfer (part of this patch
series) the transfer width of both descriptors may differ. Thus it is
required to additionally set 'tx_width' of the last descriptor.
* Added functions for multiply used calculations.
Signed-off-by: Torsten Fleischer <torfl6749@gmail.com>
This patch adds support for memory to memory scatter-gather transfers.
Changes from V1:
Changes from V2:
* Added setup of 'desc->tx_width' that is needed to calculate the
residue.
Declare slave capabilities to suppress "this driver doesn't support generic
slave capabilities reporting" warning.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Split the device_control callback of the Atmel HDMAC driver to make use
of the newly introduced callbacks, that will eventually be used to retrieve
slave capabilities.
Found using smatch:
drivers/dma/at_hdmac.c:299 atc_get_bytes_left() warn: unsigned
'atchan->remain_desc' is never less than zero.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The argument is always set to NULL and never used. Remove it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
As discussed in [1] the tasklet_disable is not a proper function for teardown.
We need to ensure irq is disabled, followed by ensuring that don't schedule any
more tasklets and then its safe to use tasklet_kill().
Here in at_hdmac driver we use free_irq() before tasklet_kill(). The free_irq()
will ensure that the irq is disabled and also wait till all scheduled interrupts
are executed by invoking synchronize_irq(). So we need to only do tasklet_kill()
after invoking free_irq()
[1]: http://lwn.net/Articles/588457/
Reported-by: Thomas Gleixner <tglx@linutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine
Pull dmaengine changes from Dan
1/ Bartlomiej and Dan finalized a rework of the dma address unmap
implementation.
2/ In the course of testing 1/ a collection of enhancements to dmatest
fell out. Notably basic performance statistics, and fixed / enhanced
test control through new module parameters 'run', 'wait', 'noverify',
and 'verbose'. Thanks to Andriy and Linus for their review.
3/ Testing the raid related corner cases of 1/ triggered bugs in the
recently added 16-source operation support in the ioatdma driver.
4/ Some minor fixes / cleanups to mv_xor and ioatdma.
drivers/dma/dmatest.c
Remove support for DMA unmapping from drivers as it is no longer
needed (DMA core code is now handling it).
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Tomasz Figa <t.figa@samsung.com>
Cc: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[djbw: fix up chan2parent() unused warning in drivers/dma/dw/core.c]
Add a hook for a common dma unmap implementation to enable removal of
the per driver custom unmap code. (A reworked version of Bartlomiej
Zolnierkiewicz's patches to remove the custom callbacks and the size
increase of dma_async_tx_descriptor for drivers that don't care about
raid).
[bzolnier: prepare pl330 driver for adding missing unmap while at it]
Acked-by: Dan Williams <dan.j.williams@intel.com>
Replace clk_enable/disable with clk_prepare_enable/disable_unprepare to
avoid common clk framework warnings.
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
[nicolas.ferre@atmel.com: remove return code checking in at_dma_resume_noirq()]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Correct coding style following the patch:
7c407d3e54dcc0c79119553c8d5ef176c1d5bc3a (DMA: AT91:
Get residual bytes in dma buffer).
Since patch 7c407d3e54dcc0c79119553c8d5ef176c1d5bc3a (DMA: AT91:
Get residual bytes in dma buffer), the function
atc_cleanup_descriptors() is not used anymore. We remove it to prevent
warnings.
For most devices the FIFO configuration is the same i.e. when half FIFO size is
available/filled, a source/destination request is serviced. But USART devices
have to do it when there is enough space/data available to perform a single
AHB access so the ASAP configuration.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Add support for returning the residue for current transfer cookie by
reading the transfered buffer size(BTSIZE) in CTRLA register.
For a single buffer cookie, the descriptor length minus BTSIZE
can get the residue.
For a lli cookie, remain_desc will record remain descriptor length
when last descriptor finish, the remain_desc minus BTSIZE can get the
current residue.
If the cookie has completed successfully, the residue will be zero.
If the cookie is in progress, it will be the number of bytes yet to be transferred.
If get residue error, the cookie will be turn into error status.
Check dma fifo to see if data remain, let issue pending finish remain work if there is.
Signed-off-by: Elen Song <elen.song@atmel.com>
In one dma transfer, the data transfer width can be configured and it is limited by source or destination peripheral width,
tx_width will save the transfer width, but for memcpy, either source or destination transfer width is taken as tx_width.
No modification in CFG register configuration, just rearrange
bits directives to group logically and make it more readable.
Peripheral handshaking identification numbers can be bigger than 15, so new
fields have been created in the CFG register.
Add macros to take this modification into account and use them in
at_dma_xlate() function.
"This time we have dmatest improvements from Andy along with dw_dmac
fixes. He has also done support for acpi for dmanegine.
Also we have bunch of fixes going in DT support for dmanegine for
various folks. Then Haswell and other ioat changes from Dave and
SUDMAC support from Shimoda."
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits)
dma: tegra: implement suspend/resume callbacks
dma:of: Use a mutex to protect the of_dma_list
dma: of: Fix of_node reference leak
dmaengine: sirf: move driver init from module_init to subsys_initcall
sudmac: add support for SUDMAC
dma: sh: add Kconfig
ioatdma: ioat3_alloc_sed can be static
ioatdma: Adding write back descriptor error status support for ioatdma 3.3
ioatdma: S1200 platforms ioatdma channel 2 and 3 falsely advertise RAID cap
ioatdma: Adding support for 16 src PQ ops and super extended descriptors
ioatdma: Removing hw bug workaround for CB3.x .2 and earlier
dw_dmac: add ACPI support
dmaengine: call acpi_dma_request_slave_channel as well
dma: acpi-dma: introduce ACPI DMA helpers
dma: of: Remove unnecessary list_empty check
DMA: OF: Check properties value before running be32_to_cpup() on it
DMA: of: Constant names
ioatdma: skip silicon bug workaround for pq_align for cb3.3
ioatdma: Removing PQ val disable for cb3.3
Update at_hdmac driver to support generic DMA device tree binding. Devices
can still request channel with dma_request_channel() then it doesn't break
DMA for non DT boards.
The BUG_ON() directive is triggered probably due to a latency
modification following inclusion of commit c10d73671ad3 ("softirq:
reduce latencies"). This condition has not been met before 3.9-rc1 and
doesn't trigger without this patch.
We now make sure that DMA channel is idle before calling
atc_complete_all() which makes the BUG_ON() "protection" useless.
Acked-by: Vinod Koul <vinod.koul@intel.com>
Removing the annotation with __exit and referencing with __exit_p()
present in dma driver module remove hooks.
Part of the __devexit and __devexit_p() purge.
Signed-off-by: Maxin B. John <maxin.john@enea.com>
dma_transfer_direction is a normal enum. It means we can't usually use the
values as bit fields. Let's adjust this check and move it above the usage of
the direction parameter, due to the nature of the following usage of it.
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This contains pretty many small commits covering fairly large range of
files in sound/ directory. Partly because of additional API support
and partly because of constantly developed ASoC and ARM stuff.
Some highlights:
- Introduced the helper function and documentation for exposing the
channel map via control API, as discussed in Plumbers; most of PCI
drivers are covered, will follow more drivers later
- Most of drivers have been replaced with the new PM callbacks (if
the bus is supported)
- HD-audio controller got the support of runtime PM and the support
of D3 clock-stop. Also changing the power_save option in sysfs
kicks off immediately to enable / disable the power-save mode.
- Another significant code change in HD-audio is the rewrite of
firmware loading code. Other than that, most of changes in
HD-audio are continued cleanups and standardization for the generic
auto parser and bug fixes (HBR, device-specific fixups), in
addition to the support of channel-map API.
- Addition of ASoC bindings for the compressed API, used by the
mid-x86 drivers.
- Lots of cleanups and API refreshes for ASoC codec drivers and
DaVinci.
- Conversion of OMAP to dmaengine.
- New machine driver for Wolfson Microelectronics Bells.
- New CODEC driver for Wolfson Microelectronics WM0010.
- Enhancements to the ux500 and wm2000 drivers
- A new driver for DA9055 and the support for regulator bypass mode."
Fix up various arm soc header file reorg conflicts.
* tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (339 commits)
ALSA: hda - Add new codec ALC283 ALC290 support
ALSA: hda - avoid unneccesary indices on "Headphone Jack" controls
ALSA: hda - fix indices on boost volume on Conexant
ALSA: aloop - add locking to timer access
ALSA: hda - Fix hang caused by race during suspend.
sound: Remove unnecessary semicolon
ALSA: hda/realtek - Fix detection of ALC271X codec
ALSA: hda - Add inverted internal mic quirk for Lenovo IdeaPad U310
ALSA: hda - make Realtek/Sigmatel/Conexant use the generic unsol event
ALSA: hda - make a generic unsol event handler
ASoC: codecs: Add DA9055 codec driver
ASoC: eukrea-tlv320: Convert it to platform driver
ALSA: ASoC: add DT bindings for CS4271
ASoC: wm_hubs: Ensure volume updates are handled during class W startup
ASoC: wm5110: Adding missing volume update bits
ASoC: wm5110: Add OUT3R support
ASoC: wm5110: Add AEC loopback support
ASoC: wm5110: Rename EPOUT to HPOUT3
ASoC: arizona: Add more clock rates
ASoC: arizona: Add more DSP options for mixer input muxes
Pull the trivial tree from Jiri Kosina:
"Tiny usual fixes all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
doc: fix old config name of kprobetrace
fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc
btrfs: fix the commment for the action flags in delayed-ref.h
btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID
vfs: fix kerneldoc for generic_fh_to_parent()
treewide: fix comment/printk/variable typos
ipr: fix small coding style issues
doc: fix broken utf8 encoding
nfs: comment fix
platform/x86: fix asus_laptop.wled_type module parameter
mfd: printk/comment fixes
doc: getdelays.c: remember to close() socket on error in create_nl_socket()
doc: aliasing-test: close fd on write error
mmc: fix comment typos
dma: fix comments
spi: fix comment/printk typos in spi
Coccinelle: fix typo in memdup_user.cocci
tmiofb: missing NULL pointer checks
tools: perf: Fix typo in tools/perf
tools/testing: fix comment / output typos
Change the parameter list of device_prep_dma_cyclic() so the DMA drivers
can receive the flags coming from clients.
This feature can be used during audio operation to disable all audio
related interrupts when the DMA_PREP_INTERRUPT is cleared from the flags.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Avoid the construction of a malformed DMA request sent to
the DMA controller.
Log message is for debug only because this condition is unlikely to
append and may only trigger at driver development time.
Cc: Stable <stable@vger.kernel.org> [2.6.31+]
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
s/dma_memcpy/slave_sg/ and it is sg length that we are
talking about.
Correct spelling typo in drivers/dma.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
This prepares of_device_id.data becoming const. Without this change
the following warning would occur:
drivers/dma/at_hdmac.c: In function 'at_dma_get_driver_data':
drivers/dma/at_hdmac.c:1228: warning: return discards qualifiers from pointer target type
Cc: Dan Williams <dan.j.williams@intel.com>
Not all Atmel SoCs were pointed out in header comment which was bringing
confusion. Remove the truncated list of supported devices, replace by the
only one that is not supported.
Reported-by: Elen Song <elen.song@atmel.com>
The maxburst/chunk size was taken from the private slave DMA data structure.
Use the common API provided by DMA_SLAVE_CONFIG to setup src/dst maxburst
values.
The ctrla field is not needed anymore in the slave private structure nor the
header constants that were located in an architecture specific directory.
The at91sam9g45_devices.c file that was using this platform data is also
modified to remove this now useless data.
Not needed constant that was set to 0.
for cyclic dma, dont makr the descriptor as complte. Fix the remaining users of
cyclic dma which do so
Tested-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Tested-by: Mika Westerberg <mika.westerberg@iki.fi>
