[ Upstream commit 648865a79d8ee3d1aa64aab5eb2a9d12eeed14f9 ]
In 2D transfers (for the AXI DMAC), the number of frames (numf) represents
Y_LENGTH, and the length of a frame is X_LENGTH. 2D transfers are useful
for video transfers where screen resolutions ( X * Y ) are typically
aligned for X, but not for Y.
There is no requirement for Y_LENGTH to be aligned to the bus-width (or
anything), and this is also true for AXI DMAC.
Checking the Y_LENGTH for alignment causes false errors when initiating DMA
transfers. This change fixes this by checking only that the Y_LENGTH is
non-zero.
Fixes: 0e3b67b348b8 ("dmaengine: Add support for the Analog Devices AXI-DMAC DMA controller")
Signed-off-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
Signed-off-by: Vinod Koul <vkoul@kernel.org>
Return IRQ_NONE in the interrupt handler when it is called but no IRQs are
pending. This allows the system to recover in case of an interrupt storm
e.g. due to a wrong interrupt configuration setup.
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Propagate errors returned by platform_get_irq() to the driver core. This
will enable proper probe deferring for the driver in case the IRQ provider
has not been registered yet.
Add MODULE_DEVICE_TABLE() for the axi-dmac driver. This allows the driver
to be loaded on demand when built as a module.
Implement the new device_synchronize() callback to allow proper
synchronization when stopping a channel. Since the driver already makes
sure that no new complete callbacks are scheduled after the
device_terminate_all() callback has been called, all left to do in the
device_synchronize() callback is to wait for all currently running complete
callbacks to finish.
Add support for the Analog Devices AXI-DMAC DMA controller. This controller
is a soft peripheral that can be instantiated in a FPGA and is often used
in Analog Devices' reference designs for FPGA platforms.
The peripheral has various configuration options that can be selected at
synthesis time and influence the supported features of the instantiated
peripheral, those options are represented as device-tree properties to
allow the driver to behave accordingly.
The peripheral has a zero latency architecture, which means it is possible
to switch from one to the next descriptor without any delay. This is
archived by having a internal queue which can hold multiple descriptors.
The driver supports this, which means it will submit new descriptors
directly to the hardware until the queue is full and not wait for a
descriptor to complete before the next one is submitted. Interrupts are
used for the descriptor queue flow control.
Currently the driver supports SG, cyclic and interleaved slave DMA.
