path: root/drivers/dma/dmatest.c
2014-03-26Add new line to test result strings produced in verbose modeJerome Blin
Prevents test result strings from being output on same line. Issue will happen with verbose and multi-iteration modes enabled. Signed-off-by: Jerome Blin <jerome.blin@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-29Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dma updates from Vinod Koul: - new driver for BCM2835 used in R-pi - new driver for MOXA ART - dma_get_any_slave_channel API for DT based systems - minor fixes and updates spread acrooss driver [ The fsl-ssi dual fifo mode support addition clashed badly with the other changes to fsl-ssi that came in through the sound merge. I did a very rough cut at fixing up the conflict, but Nicolin Chen (author of both sides) will need to verify and check things ] * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (36 commits) dmaengine: mmp_pdma: fix mismerge dma: pl08x: Export pl08x_filter_id acpi-dma: align documentation with kernel-doc format dma: fix vchan_cookie_complete() debug print DMA: dmatest: extend the "device" module parameter to 32 characters drivers/dma: fix error return code dma: omap: Set debug level to debugging messages dmaengine: fix kernel-doc style typos for few comments dma: tegra: add support for Tegra148/124 dma: dw: use %pad instead of casting dma_addr_t dma: dw: join split up messages dma: dw: fix style of multiline comment dmaengine: k3dma: fix sparse warnings dma: pl330: Use dma_get_slave_channel() in the of xlate callback dma: pl330: Differentiate between submitted and issued descriptors dmaengine: sirf: Add device_slave_caps interface DMA: Freescale: change BWC from 256 bytes to 1024 bytes dmaengine: Add MOXA ART DMA engine driver dmaengine: Add DMA_PRIVATE to BCM2835 driver dma: imx-sdma: Assign a default script number for ROM firmware cases ...
2014-01-20DMA: dmatest: extend the "device" module parameter to 32 charactersGuennadi Liakhovetski
With Device Tree a typical DMA controller device name can look like 10000000.dma-controller, which extends the current size of the string, allocated for this parameter. This patch extends its size from 20 to 32 characters. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-12dmatest: fix build warning on mipsDan Williams
drivers/dma/dmatest.c:543:11: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default] mips expects virt_to_phys() to take a pointer. Fix up the types accordingly. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-16Merge commit 'dmaengine-3.13-v2' of ↵Vinod Koul
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine changes from Dan 1/ Bartlomiej and Dan finalized a rework of the dma address unmap implementation. 2/ In the course of testing 1/ a collection of enhancements to dmatest fell out. Notably basic performance statistics, and fixed / enhanced test control through new module parameters 'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and Linus for their review. 3/ Testing the raid related corner cases of 1/ triggered bugs in the recently added 16-source operation support in the ioatdma driver. 4/ Some minor fixes / cleanups to mv_xor and ioatdma. Conflicts: drivers/dma/dmatest.c Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-11-14dmatest: verbose modeDan Williams
Verbose mode turns on test success messages, by default we only output test summaries and failure results. Also cleaned up some stray quotes, leftover from putting the result message format string all on one line. Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmatest: convert to dmaengine_unmap_dataDan Williams
Remove the open coded unmap and add coverage for this core functionality to dmatest. Also fixes up a couple places where we leaked dma mappings. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmatest: add a 'wait' parameterDan Williams
Allows for scripting test runs by module load / unload. Prevent module load from returning until 'iterations' (finite) tests have completed, or cause reads of the 'wait' parameter in sysfs to pause until the tests are done. Also killed the local waitqueue since we can just let the thread exit naturally as long as we hold a reference. Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmatest: add basic performance metricsDan Williams
Add iops and throughput to the summary output. Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmatest: add support for skipping verification and random data setupDan Williams
Towards enabling dmatest to checkout performance add a 'noverify' mode. Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmatest: use pseudo random numbersDan Williams
There is no need for dmatest to drain the entropy pool. It would be nice to one day have repeatable runs, but would need a larger rework to synchronize and order calls to the rng across test threads. Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmatest: support xor-only, or pq-only channels in testsDan Williams
Currently we only test raid channels that happen to also have 'copy' capability. Search for capable channels that do not have DMA_MEMCPY. Note the return value from run_threaded_test never really made sense because it could return errors after successfully starting tests. We already have the test results per channel so missing channels can be detected at that time. Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmatest: restore ability to start test at module load and initDan Williams
1/ move 'run' control to a module parameter so we can do: modprobe dmatest run=1. With this moved the rest of the debugfs boilerplate can go. 2/ Fix parameter initialization. Previously the test was being started without taking the parameters into account in the built-in case. Also killed off the '__' version of some routines. The new rule is just hold the lock when calling a *threaded_test() routine. Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmatest: cleanup redundant "dmatest: " prefixesDan Williams
...now that we have a common pr_fmt. Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmatest: replace stored results mechanism, with uniform messagesDan Williams
For long running tests the tracking results in a memory leak for the "ok" results, and for the failures the kernel log should be sufficient. Provide a uniform format for error messages so they can be easily parsed and remove the debugfs file. Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14Revert "dmatest: append verify result to results"Dan Williams
This reverts commit d86b2f298e6de124984f5d5817ed1e6e759b3ada. The kernel log buffer is sufficient for collecting test results. The current logging OOMs the machine on long running tests, and usually only the first error is relevant. It is better to stop on error and parse the kernel output. If output volume becomes an issue we can always investigate using trace messages. Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmaengine: remove DMA unmap flagsBartlomiej Zolnierkiewicz
Remove no longer needed DMA unmap flags: - DMA_COMPL_SKIP_SRC_UNMAP - DMA_COMPL_SKIP_DEST_UNMAP - DMA_COMPL_SRC_UNMAP_SINGLE - DMA_COMPL_DEST_UNMAP_SINGLE Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jon Mason <jon.mason@intel.com> Acked-by: Mark Brown <broonie@linaro.org> [djbw: clean up straggling skip unmap flags in ntb] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-13dmatest: make driver unmap also source buffers by itselfBartlomiej Zolnierkiewicz
Make the driver DMA unmap also source buffers by itself (currently it DMA unmaps only destination buffers) as a preparation for introducing generic 'ummap' data. Cc: Dan Williams <dan.j.williams@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-10-25dmaengine: dmatest: use DMA_COMPLETE for dma completion statusVinod Koul
Acked-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-08-22dmatest: print message on debug level in case of no errorAndy Shevchenko
Let's move the behaviour of printing no error message back to the pre v3.10 times. It means we will use debug level in the described case, and a warning level otherwise. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <djbw@fb.com>
2013-08-22dmatest: remove IS_ERR_OR_NULL checks of debugfs callsAndy Shevchenko
There is a really little chance when we are able to create a directory and are not able to create nodes under it. So, this patch just removes those checks. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Dan Williams <djbw@fb.com>
2013-08-22dmatest: make module parameters writableAndy Shevchenko
The debugfs interface brought a copy of the test case parameters. This makes different set of values under /sys/module/dmatest/parameters/ and /sys/kernel/debug/dmatest/. The user might be confused by the divergence of values. The proposed solution in this patch is to make module parameters writable and remove them from the debugfs. Though we're still using debugfs to control test runner and getting results. Documentation part is updated accordingly. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Suggested-by: Dan Williams <djbw@fb.com> Signed-off-by: Dan Williams <djbw@fb.com>
2013-06-08dmatest: do not allow to interrupt ongoing testsAndy Shevchenko
When user interrupts ongoing transfers the dmatest may end up with console lockup, oops, or data mismatch. This patch prevents user to abort any ongoing test. Documentation is updated accordingly. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reported-by: Will Deacon <will.deacon@arm.com> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: append verify result to resultsAndy Shevchenko
Comparison between buffers is stored to the dedicated structure. Note that the verify result is now accessible only via file 'results' in the debugfs. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: gather test results in the linked listAndy Shevchenko
The patch provides a storage for the test results in the linked list. The gathered data could be used after test is done. The new file 'results' represents gathered data of the in progress test. The messages collected are printed to the kernel log as well. Example of output: % cat /sys/kernel/debug/dmatest/results dma0chan0-copy0: #1: No errors with src_off=0x7bf dst_off=0x8ad len=0x3fea (0) The message format is unified across the different types of errors. A number in the parens represents additional information, e.g. error code, error counter, or status. Note that the buffer comparison is done in the old way, i.e. data is not collected and just printed out. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: define MAX_ERROR_COUNT constantAndy Shevchenko
Its meaning is to limit amount of error messages to be printed out when buffer mismatch is occured. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: return actual state in 'run' fileAndy Shevchenko
The following command should return actual state of the test. % cat /sys/kernel/debug/dmatest/run To wait for test done the user may perform a busy loop that checks the state. % while [ $(cat /sys/kernel/debug/dmatest/run) = "Y" ] > do > echo -n "." > sleep 1 > done > echo Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: run test via debugfsAndy Shevchenko
Instead of doing modprobe dmatest ... modprobe -r dmatest we allow user to run tests interactively. The dmatest could be built as module or inside kernel. Let's consider those cases. 1. When dmatest is built as a module... After mounting debugfs and loading the module, the /sys/kernel/debug/dmatest folder with nodes will be created. They are the same as module parameters with addition of the 'run' node that controls run and stop phases of the test. Note that in this case test will not run on load automatically. Example of usage: % echo dma0chan0 > /sys/kernel/debug/dmatest/channel % echo 2000 > /sys/kernel/debug/dmatest/timeout % echo 1 > /sys/kernel/debug/dmatest/iterations % echo 1 > /sys/kernel/debug/dmatest/run After a while you will start to get messages about current status or error like in the original code. Note that running a new test will stop any in progress test. 2. When built-in in the kernel... The module parameters that is supplied to the kernel command line will be used for the first performed test. After user gets a control, the test could be interrupted or re-run with same or different parameters. For the details see the above section "1. When dmatest is built as a module..." In both cases the module parameters are used as initial values for the test case. You always could check them at run-time by running % grep -H . /sys/module/dmatest/parameters/* Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: split test parameters to separate structureAndy Shevchenko
Better to keep test parameters separate from internal variables. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: move dmatest_channels and nr_channels to dmatest_infoAndy Shevchenko
We don't need to have them global and later we would like to protect access to them as well. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: create dmatest_info to keep test parametersAndy Shevchenko
The proposed change will remove usage of the module parameters as global variables. In future it helps to run different test cases sequentially. The patch introduces the run_threaded_test() and stop_threaded_test() functions that could be used later outside of dmatest_init, dmatest_exit scope. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: allocate memory for pq_coefs from heapAndy Shevchenko
This will help in future to hide a global variable usage. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmatest: cancel thread immediately when asked forAndy Shevchenko
If user have the timeout alike issues and wants to cancel the thread immediately, the current call of wait_event_freezable_timeout is preventing to this until timeout is expired. Thus, user will experience the unnecessary delays. Adding kthread_should_stop() check inside wait_event_freezable_timeout() solves that. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-01-07dmaengine/dmatest: terminate transfers only in case of errorsShiraz Hashim
dmatest erroneously terminated transfers in normal cases also leading to test failures for multiple threads over a channel. Fix this and terminate transfers only in case of errors. Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2013-01-07dmatest: Fix NULL pointer dereference on ioatJon Mason
device_control is an optional and not implemented in all DMA drivers. Any calls to these will result in a NULL pointer dereference. dmatest makes two of these calls when completing the kernel thread and removing the module. These are corrected by calling the dmaengine_device_control wrapper and checking for a non-existant device_control function pointer there. Signed-off-by: Jon Mason <jon.mason@intel.com> CC: Vinod Koul <vinod.koul@intel.com> CC: Dan Williams <djbw@fb.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2013-01-07dmatest: adjust invalid module parameters for number of source buffersAkinobu Mita
DMA Engine test module has module parameters to set the number of source buffers for xor and pq operations. We can set these values larger than the maximum number of sources that the device can support. These values are not adjusted and the unsupported number of source buffers are passed to the device. But most drivers don't check it, so unexpected results will happen. This makes an appropriate adjustment for these module parameters before use. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <djbw@fb.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-12-17dmatest: check for dma mapping errorAndy Shevchenko
The kernel emits a warning if CONFIG_DMA_API_DEBUG=y: WARNING: at lib/dma-debug.c:933 check_unmap+0x5d6/0x6ac() dw_dmac dw_dmac.0: DMA-API: device driver failed to check map error[device address=0x0000000035698305] [size=14365 bytes] [mapped as single] Fix this by adding the required checking of the dma_map_single() return value. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17dmatest: implement two helpers to unmap dma memoryAndy Shevchenko
The unmap_src() and unmap_dst() will be used later as well. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-23dmaengine: fix missing 'cnt' in ?: in dmatestDr. David Alan Gilbert
Hi, On the latest tree my compiler has started giving the warning: drivers/dma/dmatest.c:575:28: warning: the omitted middle operand in ?: will always be ?true?, suggest explicit middle operand [-Wparentheses] The following patch fixes the missing middle clause with the same fix that Nicolas Ferre used in the similar clauses. (There seems to have been a race between him fixing that and the extra clause going in a little later). I don't actually know the dmatest code/structures, nor do I own any hardware to test it on (assuming it needs a DMA engine); but this patch builds, the existing code is almost certainly wrong and the fix is the same as the corresponding lines above it. (WTH is x=y?:z legal C anyway?) Signed-off-by: Dr. David Alan Gilbert <linux@treblig.org> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-11-23dmatest: don't use set_freezable_with_signal()Tejun Heo
Commit 981ed70d8e (dmatest: make dmatest threads freezable) made dmatest kthread use set_freezable_with_signal(); however, the interface is scheduled to be removed in the next merge window. The problem is that unlike userland tasks there's no default place which handles signal pending state and it isn't clear who owns and/or is responsible for clearing TIF_SIGPENDING. For example, in the current code, try_to_freeze() clears TIF_SIGPENDING but it isn't sure whether it actually owns the TIF_SIGPENDING nor is it race-free - ie. the task may continue to run with TIF_SIGPENDING set after the freezable section. Unfortunately, we don't have wait_for_completion_freezable_timeout(). This patch open codes it and uses wait_event_freezable_timeout() instead and removes timeout reloading - wait_event_freezable_timeout() won't return across freezing events (currently racy but fix scheduled) and timer doesn't decrement while the task is in freezer. Although this does lose timer-reset-over-freezing, given that timeout is supposed to be long enough and failure to finish inside is considered irrecoverable, I don't think this is worth the complexity. While at it, move completion to outer scope and explain that we're ignoring dangling pointer problem after timeout. This should give slightly better chance at avoiding oops after timeout. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Dan Williams <dan.j.williams@intel.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-08-29dmatest: make dmatest threads freezableGuennadi Liakhovetski
Making dmatest threads freezable allows its use for system PM testing. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-08-08dmaengine/dmatest: Terminate transfers on all channels in case of error or exitViresh Kumar
In case, some error occurs while doing memcpy transfers, we must terminate all transfers physically too. This is achieved by calling device_control() routine with TERMINATE_ALL as parameter. This is also required to be done in case module is removed while we are in middle of some transfers. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-06-21net: remove mm.h inclusion from netdevice.hAlexey Dobriyan
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually). To prevent mm.h inclusion via other channels also extract "enum dma_data_direction" definition into separate header. This tiny piece is what gluing netdevice.h with mm.h via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h". Removal of mm.h from scatterlist.h was tried and was found not feasible on most archs, so the link was cutoff earlier. Hope people are OK with tiny include file. Note, that mm_types.h is still dragged in, but it is a separate story. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-18Haavard Skinnemoen has left AtmelJean Delvare
Haavard's e-mail address at Atmel is no longer valid. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-26treewide: cleanup continuations and remove logging message whitespaceJoe Perches
Using C line continuation inside format strings is error prone. Clean up the unintended whitespace introduced by misuse of \. Neaten correctly used line continations as well for consistency. drivers/scsi/arcmsr/arcmsr_hba.c has these errors as well, but arcmsr needs a lot more work and the driver should likely be moved to staging instead. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-22dmaengine/dmatest: Pass timeout via module paramsViresh Kumar
When we try to test all channels present on our controller together, some channels of lower priority may be very slow as compared to others. If number of transfers is unlimited, some channels may timeout and will not finish within 3 seconds. Thus, while doing such regress testing we may need to have higher value of timeouts. This patch adds support for passing timeout value via module parameters. Default value is 3 msec, a negative value means max timeout possible. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11dmatest: fix automatic buffer unmap typeIra Snyder
The dmatest code relies on the DMAEngine API to automatically call dma_unmap_single() on src buffers. The flags it passes are incorrect, fix them. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-08-04dma: dmatest: fix potential sign bugKulikov Vasiliy
'cnt' is unsigned, so this code may become wrong in future as dmatest_add_threads() can return error code: cnt = dmatest_add_threads(dtc, DMA_MEMCPY); thread_count += cnt > 0 ? cnt : 0; ^^^^^^^ Now it can return only -EINVAL if and only if second argument of dmatest_add_threads() is not one of DMA_MEMCPY, DMA_XOR, DMA_PQ. So, now it is not wrong but may become wrong in future. The semantic patch that finds this problem (many false-positive results): (http://coccinelle.lip6.fr/) // <smpl> @ r1 @ identifier f; @@ int f(...) { ... } @@ identifier r1.f; type T; unsigned T x; @@ *x = f(...) ... *x > 0 Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03Merge branch 'coh' into dmaengineDan Williams
