path: root/drivers/dma/dmatest.c
2011-06-21net: remove mm.h inclusion from netdevice.hAlexey Dobriyan
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually). To prevent mm.h inclusion via other channels also extract "enum dma_data_direction" definition into separate header. This tiny piece is what gluing netdevice.h with mm.h via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h". Removal of mm.h from scatterlist.h was tried and was found not feasible on most archs, so the link was cutoff earlier. Hope people are OK with tiny include file. Note, that mm_types.h is still dragged in, but it is a separate story. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-18Haavard Skinnemoen has left AtmelJean Delvare
Haavard's e-mail address at Atmel is no longer valid. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-26treewide: cleanup continuations and remove logging message whitespaceJoe Perches
Using C line continuation inside format strings is error prone. Clean up the unintended whitespace introduced by misuse of \. Neaten correctly used line continations as well for consistency. drivers/scsi/arcmsr/arcmsr_hba.c has these errors as well, but arcmsr needs a lot more work and the driver should likely be moved to staging instead. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-22dmaengine/dmatest: Pass timeout via module paramsViresh Kumar
When we try to test all channels present on our controller together, some channels of lower priority may be very slow as compared to others. If number of transfers is unlimited, some channels may timeout and will not finish within 3 seconds. Thus, while doing such regress testing we may need to have higher value of timeouts. This patch adds support for passing timeout value via module parameters. Default value is 3 msec, a negative value means max timeout possible. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11dmatest: fix automatic buffer unmap typeIra Snyder
The dmatest code relies on the DMAEngine API to automatically call dma_unmap_single() on src buffers. The flags it passes are incorrect, fix them. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-08-04dma: dmatest: fix potential sign bugKulikov Vasiliy
'cnt' is unsigned, so this code may become wrong in future as dmatest_add_threads() can return error code: cnt = dmatest_add_threads(dtc, DMA_MEMCPY); thread_count += cnt > 0 ? cnt : 0; ^^^^^^^ Now it can return only -EINVAL if and only if second argument of dmatest_add_threads() is not one of DMA_MEMCPY, DMA_XOR, DMA_PQ. So, now it is not wrong but may become wrong in future. The semantic patch that finds this problem (many false-positive results): (http://coccinelle.lip6.fr/) // <smpl> @ r1 @ identifier f; @@ int f(...) { ... } @@ identifier r1.f; type T; unsigned T x; @@ *x = f(...) ... *x > 0 Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03Merge branch 'coh' into dmaengineDan Williams
2010-02-28dmatest: fix handling of an even number of xor_sourcesDan Williams
Just like commit ac5d73fc, we need to be careful to use 'src_cnt' as it contains the fixed up number of xor sources (forced odd) to meet dmatest's data verification scheme. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-02-28dmatest: correct raid6 PQ testAnatolij Gustschin
The number of PQ sources specified by module parameter "pq_sources" is always forced odd to fit into dmatest's destination verificaton scheme. But number of PQ sources and coefficients as passed to the driver's prep_dma_pq() is not adjusted accordingly. Fix it now to get correct PQ testing results in the case passed "pq_sources" parameter is even. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-02-05dmaengine: correct onstack wait_queue_head declarationYong Zhang
Use DECLARE_WAIT_QUEUE_HEAD_ONSTACK to make lockdep happy Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Cc: Maciej Sosnowski <maciej.sosnowski@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-12-10dmaengine: fix dmatest to verify minimum transfer length and test buffer sizeGuennadi Liakhovetski
Transfers and the test buffer have to be at least align bytes long. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08Merge branch 'dmaengine' into async-tx-nextDan Williams
Conflicts: crypto/async_tx/async_xor.c drivers/dma/ioat/dma_v2.h drivers/dma/ioat/pci.c drivers/md/raid5.c
2009-09-08dmaengine, async_tx: support alignment checksDan Williams
Some engines have transfer size and address alignment restrictions. Add a per-operation alignment property to struct dma_device that the async routines and dmatest can use to check alignment capabilities. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08Merge branch 'md-raid6-accel' into ioat3.2Dan Williams
Conflicts: include/linux/dmaengine.h
2009-08-29dmatest: add pq supportDan Williams
Test raid6 p+q operations with a simple "always multiply by 1" q calculation to fit into dmatest's current destination verification scheme. Reviewed-by: Andre Noll <maan@systemlinux.org> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-07-22dmaengine: dmatest: correct thread_count while using multiple thread per channelNicolas Ferre
It seems that thread_count is not properly calculated in dmatest. In fact the thread count number that is returned from dmatest_add_threads() is not correctly added to the thread_count and thus not properly printed. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-07-22dmaengine: dmatest: add a maximum number of test iterationsNicolas Ferre
The dmatest usually waits for the killing of its kthreads to stop running tests. This patch adds a parameter that sets a maximum number of test iterations. This feature is quite interesting for debugging when you set a lot of traces in your dmaengine controller driver. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-07-22drivers/dma: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-04-08dmatest: fix max channels handlingDan Williams
The check for reaching max_channels is short circuited by 'continuing' after successfully adding a channel. [ Impact: make the 'max_channels' module parameter actually have an effect ] Cc: <stable@kernel.org> Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-03-25dmatest: add dma interrupts and callbacksDan Williams
Use the callback infrastructure to report driver/hardware hangs or missed interrupts. Since this makes the test threads much more aggressive (from: explicit 1ms sleep to: wait_for_completion) we set the nice value to 10 so as to not swamp legitimate tasks. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-03-25dmatest: add xor testDan Williams
Extend dmatest to launch a thread per supported operation type and add an xor test. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-03-04dmatest: fix use after free in dmatest_exitDan Williams
dmatest_cleanup_chanel will free dtc, so grab ->chan before it goes away and use it to do the release. Reported-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-01-13dmatest: Use custom map/unmap for destination bufferAtsushi Nemoto
The dmatest driver should use DMA_BIDIRECTIONAL on the destination buffer to ensure that the poison values are written to RAM and not just written to cache and discarded. Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-01-06dmaengine: add a release for dma class devices and dependent infrastructureDan Williams
Resolves: WARNING: at drivers/base/core.c:122 device_release+0x4d/0x52() Device 'dma0chan0' does not have a release() function, it is broken and must be fixed. The dma_chan_dev object is introduced to gear-match sysfs kobject and dmaengine channel lifetimes. When a channel is removed access to the sysfs entries return -ENODEV until the kobject can be released. The bulk of the change is updates to existing code to handle the extra layer of indirection between a dma_chan and its struct device. Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-01-06dmaengine: kill enum dma_state_clientDan Williams
DMA_NAK is now useless. We can just use a bool instead. Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-01-06dmatest: convert to dma_request_channelDan Williams
Replace the client registration infrastructure with a custom loop to poll for channels. Once dma_request_channel returns NULL stop asking for channels. A userspace side effect of this change if that loading the dmatest module before loading a dma driver will result in no channels being found, previously dmatest would get a callback. To facilitate testing in the built-in case dmatest_init is marked as a late_initcall. Another side effect is that channels under test can not be used for any other purpose. Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-01-06dmaengine: up-level reference counting to the module levelDan Williams
Simply, if a client wants any dmaengine channel then prevent all dmaengine modules from being removed. Once the clients are done re-enable module removal. Why?, beyond reducing complication: 1/ Tracking reference counts per-transaction in an efficient manner, as is currently done, requires a complicated scheme to avoid cache-line bouncing effects. 2/ Per-transaction ref-counting gives the false impression that a dma-driver can be gracefully removed ahead of its user (net, md, or dma-slave) 3/ None of the in-tree dma-drivers talk to hot pluggable hardware, but if such an engine were built one day we still would not need to notify clients of remove events. The driver can simply return NULL to a ->prep() request, something that is much easier for a client to handle. Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-11-11dmaengine: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-09-19drivers/dma/dmatest.c: switch a GFP_ATOMIC to GFP_KERNELAndrew Morton
It was needlessly using the unreliable GFP_ATOMIC. Cc: Timur Tabi <timur@freescale.com> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-09-19dmatest: properly handle duplicate DMA channelsTimur Tabi
Update the the dmatest driver so that it handles duplicate DMA channels properly. When a DMA client is notified of an available DMA channel, it must check if it has already allocated resources for that channel. If so, it should return DMA_DUP. This can happen, for example, if a DMA driver calls dma_async_device_register() more than once. Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-08dmatest: Simple DMA memcpy test clientHaavard Skinnemoen
This client tests DMA memcpy using various lengths and various offsets into the source and destination buffers. It will initialize both buffers with a repeatable pattern and verify that the DMA engine copies the requested region and nothing more. It will also verify that the bytes aren't swapped around, and that the source buffer isn't modified. The dmatest module can be configured to test a specific device, a specific channel. It can also test multiple channels at the same time, and it can start multiple threads competing for the same channel. Changes since v2: * Support testing multiple channels at the same time * Support testing with multiple threads competing for the same channel * Use counting test patterns in order to catch byte ordering issues Changes since v1: * Remove extra dashes around "help" * Remove "default n" from Kconfig * Turn TEST_BUF_SIZE into a module parameter * Return DMA_NAK instead of DMA_DUP * Print unhandled events * Support testing specific channels and devices * Move to the end of the Makefile Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
