path: root/drivers/dma/fsldma.h
2015-01-13dmaengine: fsldma: declare slave capabilities for the generic codeKevin Hao
Since commit ecc19d17868b ("dmaengine: Add a warning for drivers not using the generic slave caps retrieval"), the dma drivers are required to fill the caps infos in order to support generic slaves caps retrieval. Otherwise we will get a warning like this: WARNING: at drivers/dma/dmaengine.c:830 Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.19.0-rc2-next-20150106-dirty #271 task: c0000001f70a0000 ti: c0000001f7044000 task.ti: c0000001f7044000 NIP: c00000000032b238 LR: c00000000032b234 CTR: c00000000001d258 REGS: c0000001f7047330 TRAP: 0700 Tainted: G W (3.19.0-rc2-next-20150106-dirty) MSR: 0000000080029000 <CE,EE,ME> CR: 24adbe22 XER: 20000000 SOFTE: 1 GPR00: c00000000032b234 c0000001f70475b0 c0000000009b4848 0000000000000040 GPR04: 0000000000000001 0000000000000001 0000000000000000 000000000000000f GPR08: 0000000000000000 c000000000902988 c000000000902988 00000000000052c8 GPR12: 0000000024adbe22 c00000000fff4000 c000000000002038 0000000000000000 GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000 GPR20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000 GPR24: 0000000000000000 0000000000000000 c000000000972dc8 c0000000007e6fd0 GPR28: c0000001f76d1d30 c0000001f76d1c10 c0000001f76d1c00 0000000000000000 NIP [c00000000032b238] .dma_async_device_register+0x3f8/0x5b8 LR [c00000000032b234] .dma_async_device_register+0x3f4/0x5b8 Call Trace: [c0000001f70475b0] [c00000000032b234] .dma_async_device_register+0x3f4/0x5b8 (unreliable) [c0000001f70476a0] [c00000000032ca78] .fsldma_of_probe+0x298/0x438 [c0000001f7047750] [c00000000037080c] .platform_drv_probe+0x50/0x9c [c0000001f70477d0] [c00000000036e74c] .really_probe+0xa4/0x29c [c0000001f7047870] [c00000000036eae4] .__driver_attach+0x100/0x104 [c0000001f7047900] [c00000000036c1f0] .bus_for_each_dev+0x84/0xe4 [c0000001f70479a0] [c00000000036e164] .driver_attach+0x24/0x38 [c0000001f7047a10] [c00000000036dcc8] .bus_add_driver+0x1c8/0x2ac [c0000001f7047ab0] [c00000000036f14c] .driver_register+0x8c/0x158 [c0000001f7047b30] [c0000000003707a8] .__platform_driver_register+0x6c/0x80 [c0000001f7047ba0] [c000000000898a3c] .fsldma_init+0x2c/0x40 [c0000001f7047c10] [c000000000001818] .do_one_initcall+0xb8/0x234 [c0000001f7047d00] [c000000000878e2c] .kernel_init_freeable+0x188/0x268 [c0000001f7047db0] [c000000000002054] .kernel_init+0x1c/0xfc8 [c0000001f7047e30] [c000000000000884] .ret_from_kernel_thread+0x58/0xd4 Instruction dump: 7fb9f840 3bffffe0 409effac 7f54d378 48000060 813d0050 2f890000 40befdd0 3c62ffe3 38632450 482f0aa9 60000000 <0fe00000> 4bfffdb8 7f03c378 482ed465 Signed-off-by: Kevin Hao <haokexin@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-07-14dmaengine: Freescale: change descriptor release process for supporting async_txHongbo Zhang
Fix the potential risk when enable config NET_DMA and ASYNC_TX. Async_tx is lack of support in current release process of dma descriptor, all descriptors will be released whatever is acked or no-acked by async_tx, so there is a potential race condition when dma engine is uesd by others clients (e.g. when enable NET_DMA to offload TCP). In our case, a race condition which is raised when use both of talitos and dmaengine to offload xor is because napi scheduler will sync all pending requests in dma channels, it affects the process of raid operations due to ack_tx is not checked in fsl dma. The no-acked descriptor is freed which is submitted just now, as a dependent tx, this freed descriptor trigger BUG_ON(async_tx_test_ack(depend_tx)) in async_tx_submit(). TASK = ee1a94a0[1390] 'md0_raid5' THREAD: ecf40000 CPU: 0 GPR00: 00000001 ecf41ca0 ee44/921a94a0 0000003f 00000001 c00593e4 00000000 00000001 GPR08: 00000000 a7a7a7a7 00000001 045/920000002 42028042 100a38d4 ed576d98 00000000 GPR16: ed5a11b0 00000000 2b162000 00000200 046/920000000 2d555000 ed3015e8 c15a7aa0 GPR24: 00000000 c155fc40 00000000 ecb63220 ecf41d28 e47/92f640bb0 ef640c30 ecf41ca0 NIP [c02b048c] async_tx_submit+0x6c/0x2b4 LR [c02b068c] async_tx_submit+0x26c/0x2b4 Call Trace: [ecf41ca0] [c02b068c] async_tx_submit+0x26c/0x2b448/92 (unreliable) [ecf41cd0] [c02b0a4c] async_memcpy+0x240/0x25c [ecf41d20] [c0421064] async_copy_data+0xa0/0x17c [ecf41d70] [c0421cf4] __raid_run_ops+0x874/0xe10 [ecf41df0] [c0426ee4] handle_stripe+0x820/0x25e8 [ecf41e90] [c0429080] raid5d+0x3d4/0x5b4 [ecf41f40] [c04329b8] md_thread+0x138/0x16c [ecf41f90] [c008277c] kthread+0x8c/0x90 [ecf41ff0] [c0011630] kernel_thread+0x4c/0x68 Another modification in this patch is the change of completed descriptors, there is a potential risk which caused by exception interrupt, all descriptors in ld_running list are seemed completed when an interrupt raised, it works fine under normal condition, but if there is an exception occured, it cannot work as our excepted. Hardware should not be depend on s/w list, the right way is to read current descriptor address register to find the last completed descriptor. If an interrupt is raised by an error, all descriptors in ld_running should not be seemed finished, or these unfinished descriptors in ld_running will be released wrongly. A simple way to reproduce: Enable dmatest first, then insert some bad descriptors which can trigger Programming Error interrupts before the good descriptors. Last, the good descriptors will be freed before they are processsed because of the exception intrerrupt. Note: the bad descriptors are only for simulating an exception interrupt. This case can illustrate the potential risk in current fsl-dma very well. Signed-off-by: Hongbo Zhang <hongbo.zhang@freescale.com> Signed-off-by: Qiang Liu <qiang.liu@freescale.com> Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-07-14dmaengine: Freescale: add suspend resume functions for DMA driverHongbo Zhang
This patch adds suspend and resume functions for Freescale DMA driver. Signed-off-by: Hongbo Zhang <hongbo.zhang@freescale.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20DMA: Freescale: change BWC from 256 bytes to 1024 bytesHongbo Zhang
Freescale DMA has a feature of BandWidth Control (ab. BWC), which is currently 256 bytes and should be changed to 1024 bytes for best DMA throughput. Changing BWC from 256 to 1024 will improve DMA performance much, in cases whatever one channel is running or multi channels are running simultanously, large or small buffers are copied. And this change doesn't impact memory access performance remarkably, lmbench tests show that for some cases the memory performance are decreased very slightly, while the others are even better. Tested on T4240. Signed-off-by: Hongbo Zhang <hongbo.zhang@freescale.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-11-13DMA: Freescale: update driver to support 8-channel DMA engineHongbo Zhang
This patch adds support to 8-channel DMA engine, thus the driver works for both the new 8-channel and the legacy 4-channel DMA engines. Signed-off-by: Hongbo Zhang <hongbo.zhang@freescale.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2012-03-13dmaengine: move last completed cookie into generic dma_chan structureRussell King - ARM Linux
Every DMA engine implementation declares a last completed dma cookie in their private dma channel structures. This is pointless, and forces driver specific code. Move this out into the common dma_chan structure. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> [imx-sdma.c & mxs-dma.c] Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2011-03-11fsldma: fix controller lockupsIra Snyder
Enabling poisoning in the dmapool API quickly showed that the DMA controller was fetching descriptors that should not have been in use. This has caused intermittent controller lockups during testing. I have been unable to figure out the exact set of conditions which cause this to happen. However, I believe it is related to the driver using the hardware registers to track whether the controller is busy or not. The code can incorrectly decide that the hardware is idle due to lag between register writes and the hardware actually becoming busy. To fix this, the driver has been reworked to explicitly track the state of the hardware, rather than try to guess what it is doing based on the register values. This has passed dmatest with 10 threads per channel, 100000 iterations per thread several times without error. Previously, this would fail within a few seconds. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11fsldma: minor codingstyle and consistency fixesIra Snyder
This fixes some minor violations of the coding style. It also changes the style of the device_prep_dma_*() function definitions so they are identical. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-11fsldma: use channel name in printk outputIra Snyder
This makes debugging the driver much easier when multiple channels are running concurrently. In addition, you can see how much descriptor memory each channel has allocated via the dmapool API in sysfs. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-12-13fsldma: fix issue of slow dmaForrest Shi
Fixed fsl dma slow issue by initializing dma mode register with bandwidth control. It boosts dma performance and should works with 85xx board. Signed-off-by: Forrest Shi <b29237@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-02-02fsldma: major cleanups and fixesIra Snyder
Fix locking. Use two queues in the driver, one for pending transacions, and one for transactions which are actually running on the hardware. Call dma_run_dependencies() on descriptor cleanup so that the async_tx API works correctly. There are a number of places throughout the code where lists of descriptors are freed in a loop. Create functions to handle this, and use them instead of open-coding the loop each time. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-02-02fsldma: clean up the OF subsystem routinesIra Snyder
This fixes some errors in the cleanup paths of the OF subsystem, including missing checks for ioremap failing. Also, some variables were renamed for brevity. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-02-02fsldma: rename dest to dst for uniformityIra Snyder
Most functions in the standard library use "dst" as a parameter, rather than "dest". This renames all use of "dest" to "dst" to match the usual convention. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-02-02fsldma: rename struct fsl_dma_chan to struct fsldma_chanIra Snyder
This is the beginning of a cleanup which will change all instances of "fsl_dma" to "fsldma" to match the name of the driver itself. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-02-02fsldma: remove unused structure membersIra Snyder
Remove some unused members from the fsldma data structures. A few trivial uses of struct resource were converted to use the stack rather than keeping the memory allocated for the lifetime of the driver. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08fsldma: split apart external pause and request count featuresIra Snyder
When using the Freescale DMA controller in external control mode, both the request count and external pause bits need to be setup correctly. This was being done with the same function. The 83xx controller lacks the external pause feature, but has a similar feature called external start. This feature requires that the request count bits be setup correctly. Split the function into two parts, to make it possible to use the external start feature on the 83xx controller. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-08fsldma: implement a private tx_listDan Williams
Drop fsldma's use of tx_list from struct dma_async_tx_descriptor in preparation for removal of this field. Cc: Li Yang <leoli@freescale.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-06-16fsldma: use PCI Read Multiple commandIra W. Snyder
By default, the Freescale 83xx DMA controller uses the PCI Read Line command when reading data over the PCI bus. Setting the controller to use the PCI Read Multiple command instead allows the controller to read much larger bursts of data, which provides a drastic speed increase. The slowdown due to using PCI Read Line was only observed when a PCI-to-PCI bridge was between the devices trying to communicate. A simple test driver showed an increase from 4MB/sec to 116MB/sec when performing DMA over the PCI bus. Using DMA to transfer between blocks of local SDRAM showed no change in performance with this patch. The dmatest driver was also used to verify the correctness of the transfers, and showed no errors. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Acked-by: Timur Tabi <timur@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-09-26fsldma: allow Freescale Elo DMA driver to be compiled as a moduleTimur Tabi
Modify the Freescale Elo / Elo Plus DMA driver so that it can be compiled as a module. The primary change is to stop treating the DMA controller as a bus, and the DMA channels as devices on the bus. This is because the Open Firmware (OF) kernel code does not allow busses to be removed, so although we can call of_platform_bus_probe() to probe the DMA channels, there is no of_platform_bus_remove(). Instead, the DMA channels are manually probed, similar to what fsl_elbc_nand.c does. Cc: Scott Wood <scottwood@freescale.com> Acked-by: Li Yang <leoli@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-03-30fix the broken annotations in fsldmaAl Viro
a) every bitwise declaration will give a unique type; use typedefs. b) no need to bother with the stuff pointed to by iomem pointers, unless it's accessed directly. noderef will force us to use helpers anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-18fsldma: Fix the DMA halt when using DMA_INTERRUPT async_tx transfer.Zhang Wei
The DMA_INTERRUPT async_tx is a NULL transfer, thus the BCR(count register) is 0. When the transfer started with a byte count of zero, the DMA controller will triger a PE(programming error) event and halt, not a normal interrupt. I add special codes for PE event and DMA_INTERRUPT async_tx testing. Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-03-04dmaengine: add driver for Freescale MPC85xx DMA controllerZhang Wei
The driver implements DMA engine API for Freescale MPC85xx DMA controller, which could be used by devices in the silicon. The driver supports the Basic mode of Freescale MPC85xx DMA controller. The MPC85xx processors supported include MPC8540/60, MPC8555, MPC8548, MPC8641 and so on. The MPC83xx(MPC8349, MPC8360) are also supported. [kamalesh@linux.vnet.ibm.com: build fix] [dan.j.williams@intel.com: merge mm fixes, rebase on async_tx-2.6.25] Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com> Acked-by: Kumar Gala <galak@gate.crashing.org> Cc: Shannon Nelson <shannon.nelson@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
