path: root/drivers/dma/img-mdc-dma.c
2017-12-04dmaengine: img-mdc-dma: Use vchan_terminate_vdesc() instead of desc_freePeter Ujfalusi
To avoid race with vchan_complete, use the race free way to terminate running transfer. Implement the device_synchronize callback to make sure that the terminated descriptor is freed. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2017-10-16dmaengine: img-mdc: Add runtime PMEd Blake
Add runtime PM support to disable the clock when the h/w is not in use. The existing clock_prepare_enable is removed from probe() as the clock is no longer permanently enabled. Signed-off-by: Ed Blake <ed.blake@sondrel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2017-10-16dmaengine: img-mdc: Add suspend / resume handlingEd Blake
Add suspend / resume handling using suspend_late and resume_early, and check that all channels are idle before suspending. DMA drivers should use suspend_late / resume_early to ensure that all DMA client devices are suspended before the DMA device itself, and that client devices are resumed after the DMA device. This avoids suspending the DMA device while transactions are still active. It is the responsibility of client drivers to terminate all DMA transactions in their suspend handlers, so there should be no active transactions by the time suspend_late is called. There's no need to save and restore registers for MDC during suspend / resume, as all transactions will be terminated as a result of the suspend, and all required registers are programmed anyway at the start of any new transactions following resume. Signed-off-by: Ed Blake <ed.blake@sondrel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-12-12dmaengine: img-mdc: remove unused ‘prev_phys’Vinod Koul
In mdc_prep_dma_memcpy(), mdc_prep_dma_cyclic() and mdc_prep_slave_sg() variable ‘prev_phys’ is initialized but never used, which leads to warning with W=1 drivers/dma/img-mdc-dma.c: In function ‘mdc_prep_dma_memcpy’: drivers/dma/img-mdc-dma.c:295:24: warning: variable ‘prev_phys’ set but not used [-Wunused-but-set-variable] dma_addr_t curr_phys, prev_phys; drivers/dma/img-mdc-dma.c: In function ‘mdc_prep_dma_cyclic’: drivers/dma/img-mdc-dma.c:378:24: warning: variable ‘prev_phys’ set but not used [-Wunused-but-set-variable] dma_addr_t curr_phys, prev_phys; drivers/dma/img-mdc-dma.c: In function ‘mdc_prep_slave_sg’: drivers/dma/img-mdc-dma.c:461:24: warning: variable ‘prev_phys’ set but not used [-Wunused-but-set-variable] dma_addr_t curr_phys, prev_phys; So remove it. Cc: Damien.Horsley <Damien.Horsley@imgtec.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-08-22dmaengine: img-mdc: fix a possible NULL dereferenceLABBE Corentin
of_match_device could return NULL, and so cause a NULL pointer dereference later at line 850: mdma->soc = match->data; For fixing this problem, we use of_device_get_match_data(), this will simplify the code a little by using a standard function for getting the match data. This was reported by coverity (CID 1324134) Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-12-18dmaengine: mdc: Correct terminate_all handlingDamien.Horsley
Use of the CANCEL bit in mdc_terminate_all creates an additional 'command done' to appear in the registers (in addition to an interrupt). In addition, there is a potential race between mdc_terminate_all and the irq handler if a transfer completes at the same time as the terminate all (presently this results in an inappropriate warning). To handle these issues, any outstanding 'command done' events are cleared during mdc_terminate_all and the irq handler takes no action when there are no new 'command done' events. Signed-off-by: Damien.Horsley <Damien.Horsley@imgtec.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-12-05dmaengine: img-mdc: Remove unnecessary synchronize_irq() before devm_free_irq()Lars-Peter Clausen
Calling synchronize_irq() right before devm_free_irq() is quite useless. On one hand the IRQ can easily fire again before devm_free_irq() is entered, on the other hand devm_free_irq() itself calls synchronize_irq() internally (in a race condition free way), before any state associated with the IRQ is freed. Patch was generated using the following semantic patch: // <smpl> @@ expression irq, dev; @@ -synchronize_irq(irq); devm_free_irq(dev, irq, ...); // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-03-18dmaengine: img-mdc: remove device_alloc_chan_resources handlerVinod Koul
Now that device_alloc_chan_resources handler in not mandatory, remove dummy implementations Acked-by: Andrew Bresticker <abrestic@chromium.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-02-04dmaengine: Add driver for IMG MDCAndrew Bresticker
Add support for the IMG Multi-threaded DMA Controller (MDC) found on certain IMG SoCs. Currently this driver supports the variant present on the MIPS-based Pistachio SoC. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
