commit a6d52d70677e99bdb89b6921c265d0a58c22e597 upstream.
Put the ioat2 and ioat3 state machines in the halted state with all
errors cleared.
The ioat1 init path is not disturbed for stability, there are no
reported ioat1 initiaization issues.
Reported-by: Roland Dreier <rdreier@cisco.com>
Tested-by: Roland Dreier <rdreier@cisco.com>
Acked-by: Simon Horman <horms@verge.net.au>
crypto/async_tx/async_xor.c
drivers/dma/ioat/dma_v2.h
drivers/dma/ioat/pci.c
drivers/md/raid5.c
Drop ioatdma's use of tx_list from struct dma_async_tx_descriptor in
preparation for removal of this field.
Cc: Maciej Sosnowski <maciej.sosnowski@intel.com>
This adds a hardware specific self test to be called from ioat_probe.
In the ioat3 case we will have tests for all the different raid
operations, while ioat1 and ioat2 will continue to just test memcpy.
Export driver attributes for diagnostic purposes:
'ring_size': total number of descriptors available to the engine
'ring_active': number of descriptors in-flight
'capabilities': supported operation types for this channel
'version': Intel(R) QuickData specfication revision
This also allows some chattiness to be removed from the driver startup
as this information is now available via sysfs.
Up until this point the driver for Intel(R) QuickData Technology
engines, specification versions 2 and 3, were mostly identical save for
a few quirks. Version 3.2 hardware adds many new capabilities (like
raid offload support) requiring some infrastructure that is not relevant
for v2. For better code organization of the new funcionality move v3
and v3.2 support to its own file dma_v3.c, and export some routines from
the base files (dma.c and dma_v2.c) that can be reused directly.
The first new capability included in this code reorganization is support
for v3.2 memset operations.
In order to support dynamic resizing of the descriptor ring or polling
for a descriptor in the presence of a hung channel the reset handler
needs to make progress while in a non-preemptible context. The current
workqueue implementation precludes polling channel reset completion
under spin_lock().
This conversion also allows us to return to opportunistic cleanup in the
ioat2 case as the timer implementation guarantees at least one cleanup
after every descriptor is submitted. This means the worst case
completion latency becomes the timer frequency (for exceptional
circumstances), but with the benefit of avoiding busy waiting when the
lock is contended.
Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Save 4 bytes per software descriptor by transmitting tx_cnt in an unused
portion of the hardware descriptor.
Mark all single use initialization routines with __devinit.
The register write in ioat_dma_cleanup_tasklet is unfortunate in two
ways:
1/ It clears the extra 'enable' bits that we set at alloc_chan_resources time
2/ It gives the impression that it disables interrupts when it is in
fact re-arming interrupts
[ Impact: fix, persist the value of the chanctrl register when re-arming ]
Don't trust that the reserved bits are always zero, also sanity check
the returned value.
The cleanup path makes an effort to only perform an atomic read of the
64-bit completion address. However in the 32-bit case it does not
matter if we read the upper-32 and lower-32 non-atomically because the
upper-32 will always be zero.
Provide some output for debugging the driver.
The unified ioat1/ioat2 ioat_dma_unmap() implementation derives the
source and dest addresses from the unmap descriptor. There is no longer
a need to track this information in struct ioat_desc_sw.
Replace the current linked list munged into a ring with a native ring
buffer implementation. The benefit of this approach is reduced overhead
as many parameters can be derived from ring position with simple pointer
comparisons and descriptor allocation/freeing becomes just a
manipulation of head/tail pointers.
It requires a contiguous allocation for the software descriptor
information.
Since this arrangement is significantly different from the ioat1 chain,
move ioat2,3 support into its own file and header. Common routines are
exported from driver/dma/ioat/dma.[ch].
Prepare the code for the conversion of the ioat2 linked-list-ring into a
native ring buffer. After this conversion ioat2 channels will share
less of the ioat1 infrastructure, but there will still be places where
sharing is possible. struct ioat_chan_common is created to house the
channel attributes that will remain common between ioat1 and ioat2
channels.
For every routine that accesses both common and hardware specific fields
the old unified 'ioat_chan' pointer is split into an 'ioat' and 'chan'
pointer. Where 'chan' references common fields and 'ioat' the
hardware/version specific.
[ Impact: pure structure member movement/variable renames, no logic changes ]
If a callback is to be attached to a descriptor the channel needs to
know at ->prep time so it can set the interrupt enable bit. This is in
preparation for moving descriptor ioat2 descriptor preparation from
->submit to ->prep.
The async_tx api assumes that after a successful ->prep a subsequent
->submit will not fail due to a lack of resources.
This also fixes a bug in the allocation failure case. Previously the
descriptors allocated prior to the allocation failure would not be
returned to the free list.
This cleans up a mess of and'ing and or'ing bit definitions, and allows
simple assignments from the specified dma_ctrl_flags parameter.
Towards the removal of ioatdma_device.version split the initialization
path into distinct versions. This conversion:
1/ moves version specific probe code to version specific routines
2/ removes the need for ioat_device
3/ turns off the ioat1 msi quirk if the device is reinitialized for intx
* reduce device->common. to dma-> in ioat_dma_{probe,remove,selftest}
* ioat_lookup_chan_by_index to ioat_chan_by_index
* multi-line function definitions
* ioat_desc_sw.async_tx to ioat_desc_sw.txd
* desc->txd. to tx-> in cleanup routine
The driver currently duplicates much of what these routines offer, so
just use the common code. For example ->irq_mode tracks what interrupt
mode was initialized, which duplicates the ->msix_enabled and
->msi_enabled handling in pcim_release.
This also adds a check to the return value of dma_async_device_register,
which can fail.
Some of these defines may be useful outside of dma.c and the header is
private so there are no namespace pollution concerns.
When first created the ioat driver was the only inhabitant of
drivers/dma/. Now, it is the only multi-file (more than a .c and a .h)
driver in the directory. Moving it to an ioat/ subdirectory allows the
naming convention to be cleaned up, and allows for future splitting of
the source files by hardware version (v1, v2, and v3).
