[ Upstream commit 5c9afbda911ce20b3f2181d1e440a0222e1027dd ]
If the last test in 'ioat_dma_self_test()' fails, we must release all
the allocated resources and not just part of them.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 34a31f0af84158955a9747fb5c6712da5bbb5331 ]
The Skylake ioatdma is technically CBDMA 3.2+ and contains the same hardware
bits with some additional 3.3 features, but it's not really 3.3 where the
driver is concerned.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
[ Upstream commit 1594c18fd297a8edcc72bc4b161f3f52603ebb92 ]
Adding Skylake Xeon PCI device ids for ioatdma and related bits.
allocations.
commit 21d25f6a4217e755906cb548b55ddab39d0e88b9 upstream.
On a kernel with DEBUG_LOCKS, ioat_free_chan_resources triggers an
in_interrupt() warning. With PROVE_LOCKING, it reports detecting a
SOFTIRQ-safe to SOFTIRQ-unsafe lock ordering in the same code path.
This is because dma_generic_alloc_coherent() checks if the GFP flags
permit blocking. It allocates from different subsystems if blocking is
permitted. The free path knows how to return the memory to the correct
allocator. If GFP_KERNEL is specified then the alloc and free end up
going through cma_alloc(), which uses mutexes.
Given that ioat_free_chan_resources() can be called in interrupt
context, ioat_alloc_chan_resources() must specify GFP_NOWAIT so that the
allocations do not block and instead use an allocator that uses
spinlocks.
Signed-off-by: Krister Johansen <kjlx@templeofstupid.com>
Provide a mechanism to translate CHANERR bits to English strings in order
to allow user to report more concise errors.
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
Adding error handling to the ioatdma driver so that when a
read/write error occurs the error results are reported back and
all the remaining descriptors are aborted. This utilizes the new
dmaengine callback function that allows reporting of results.
This is in preperation of moving to a callback that provides results to the
callback for the transaction. The conversion will maintain current behavior
and the driver must convert to new callback mechanism at a later time in
order to receive results.
Static analysis showed that unitialized array is being used for compare.
At line 850 when a dma_mapping_error() occurs, it jumps to dma_unmap. At
this point, dma_srcs has not been initialized. However, the code after
dma_unmap label checks dma_srcs for a comparison and thus is comparing
to random garbage in the array. Given that when dest_dma is being mapped
this is the first instance of mapping DMA memory and failed, there is
really nothing to be cleaned up and thus should jump to free_resources
label instead.
Sparse warns:
drivers/dma/ioat/init.c:1215:6: warning: symbol 'ioat_resume' was not declared. Should it be static?
ioatdma by default is in snoop mode. Relaxed ordering according to spec
does not do anything in snoop mode. However, it causes hang or significant
performance degrade when tested with NTB. Disabling in the driver due to
some BIOS do not configure it correctly.
Dma_pool_zalloc combines dma_pool_alloc and memset 0. The semantic patch
that makes this transformation is as follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression d,e;
statement S;
d =
- dma_pool_alloc
+ dma_pool_zalloc
if (!d) S
- memset(d, 0, sizeof(*d));
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Pull dmaengine updates from Vinod Koul:
"This is smallish update with minor changes to core and new driver and
usual updates. Nothing super exciting here..
- We have made slave address as physical to enable driver to do the
mapping.
- We now expose the maxburst for slave dma as new capability so
clients can know this and program accordingly
- addition of device synchronize callbacks on omap and edma.
- pl330 updates to support DMAFLUSHP for Rockchip platforms.
- Updates and improved sg handling in Xilinx VDMA driver.
- New hidma qualcomm dma driver, though some bits are still in
progress"
* tag 'dmaengine-4.6-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (40 commits)
dmaengine: IOATDMA: revise channel reset workaround on CB3.3 platforms
dmaengine: add Qualcomm Technologies HIDMA channel driver
dmaengine: add Qualcomm Technologies HIDMA management driver
dmaengine: hidma: Add Device Tree binding
dmaengine: qcom_bam_dma: move to qcom directory
dmaengine: tegra: Move of_device_id table near to its user
dmaengine: xilinx_vdma: Remove unnecessary variable initializations
dmaengine: sirf: use __maybe_unused to hide pm functions
dmaengine: rcar-dmac: clear pertinence number of channels
dmaengine: sh: shdmac: don't open code of_device_get_match_data()
dmaengine: tegra: don't open code of_device_get_match_data()
dmaengine: qcom_bam_dma: Make driver work for BE
dmaengine: sun4i: support module autoloading
dma/mic_x100_dma: IS_ERR() vs PTR_ERR() typo
dmaengine: xilinx_vdma: Use readl_poll_timeout instead of do while loop's
dmaengine: xilinx_vdma: Simplify spin lock handling
dmaengine: xilinx_vdma: Fix issues with non-parking mode
dmaengine: xilinx_vdma: Improve SG engine handling
dmaengine: pl330: fix to support the burst mode
dmaengine: make slave address physical
Previously we unloaded the interrupts and reloaded in order to work around
a channel reset bug that cleared the MSIX table. This approach just isn't
practical when a reset needs to happen in the error handler that just
happens to be running in interrupt context (bottom half). It looks like we
can work around the hardware issue by just storing a shadow copy of the
MSIX table and restore it after reset.
Future IOATDMA hardware will take advantage of descriptors residing in
contiguous memory. Setting the descriptor ring in max config DMA memory
of 2MB. Each channel will need 2 of these chunks. This should provide 64k
of 64B descriptors.
Moving to contingous memory backed descriptor rings. This makes is really
difficult and complex to do reshape. Going to remove this as I don't think
we need to do it anymore.
Converting old pci_pool_* calls to "new" dma_pool_* to make everything
uniform.
idle
The timer_event() function seems to have a bug where it ends up marking the
last entry as non-responding and eventually attempts to restart the
channel. This also continuously happen when idle. What needs to happen is
for us to make sure there are no descriptors active and then handle that
case properly. We should only hit the "cleanup" stage if there are still
active descriptors.
CC [M] drivers/dma/ioat/prep.o
drivers/dma/ioat/prep.c: In function 'ioat_prep_pqxor':
drivers/dma/ioat/prep.c:682:1: warning: the frame size of 1048 bytes is larger than 1024 bytes [-Wframe-larger-than=]
drivers/dma/ioat/prep.c: In function 'ioat_prep_pqxor_val':
drivers/dma/ioat/prep.c:714:1: warning: the frame size of 1048 bytes is larger than 1024 bytes [-Wframe-larger-than=]
gcc version 5.3.1 20151219 (Ubuntu 5.3.1-4ubuntu1)
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Nicholas Mc Guire <der.herr@hofr.at>
Cc: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
The dca_ops structure is never modified, so declare it as const.
Done with the help of Coccinelle.
Acked-by: Dan Williams <dan.j.williams@intel.com>
Remove pre-3.0 channel status reads. 3.0 and later chansts register
is 64bit and can be read 64bit. This was clarified with the hardware
architects and since the driver now only support 3.0+ we don't need the
legacy support
Adding AER handlers in order to handle any PCIe errors.
The ioatdma needs to be queisced and block all additional op submission
during reboots. When NET_DMA was used, this caused issue as ops were still
being sent to ioatdma during reboots even though PCI BME has been turned
off. Even though NET_DMA has been deprecated, we need to prevent similar
situations. The shutdown handler should address that.
Adding the Broadwell Xeon ioatdma PCI device IDs and
related bits. This is still IOATDMA 3.2 based hw.
Sparse reported:
drivers/dma/ioat/prep.c:637:27: sparse: Variable length array is used.
Assigning a static value for the array.
The prep lock gets acquired in ioat_check_space_lock and released in
ioat_tx_submit_unlock. Setting the annotations so sparse does not freak out.
drivers/dma/ioat/dma.c:273:30: sparse: context imbalance in 'ioat_tx_submit_unlock' - unexpected unlock
drivers/dma/ioat/dma.c:476:5: sparse: context imbalance in 'ioat_check_space_lock' - wrong count at exit
Simplifying the end return. This existed in the original code but was
flagged when refactoring of the code made it appear it's new.
coccinelle warnings: (new ones prefixed by >>)
>> drivers/dma/ioat/init.c:1018:1-3: WARNING: end returns can be simpified
IOAT_COMPLETION_PENDING flag was deprecated for v2 and v3 drivers but was
not cleaned up. Doing that now. The commit deprecated this flag was
4dec23d7 ioatdma: fix race between updating ioat->head and
IOAT_COMPLETION_PENDING.
./scripts/kerne-doc is reporting errors on dma.h. Clean up all reported
errors.
Since we are a "single" device driver now we no longer require the function
pointers in ioatdma_device. Remove.
Moving the relevant functions to their respective .c files and removal of
dma_v3.c file. Also removed various ioat3 references when appropriate.
Move all DMA descriptor prepping functions to prep.c file. Fixup all
broken bits caused by the move.
Moving all the init routines to init.c and fixup anything broken during
the move.
Move and fixup all sysfs related bits to sysfs.c file.
Clean out dma_v2 and remove ioat2 calls since we are moving everything
to just ioat.
Changing the variable names for ioatdma_device to be consistently named
ioat_dma instead of device/dma in order to avoid confusion and distinct
from struct device. This will clearly indicate that it is an
ioatdma_device. This also make all the naming consistent that the dma
device is ioat_dma and all the channels are ioat_chan.
Kill the common ioatdma channel structure and everything that is not
dma_chan to be ioat_dma_chan. Since we don't have to worry about v1
and v2 ioatdma anymore this makes it much cleaner and obvious for
maintenance.
Removal of support for ioatdma v2 device support.
Cleaning up of ioat1 specific code as it is no longer supported
Removal of any devices that are ioatdma pre-3.0. This is the first step
in attempting to clean up the ioatdma driver and remove hw no longer
supported.
If the allocation order is 16, then the u16 count will overflow and wrap
to zero when assigned the value 1 << 16.
Change the type of 'total_descs' to int, so that it is large enough to
store a value equal or greater than 1 << 16.
Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com>
If the allocation order is 16, then the u16 index will overflow and wrap
to zero instead of being equal or greater than 1 << 16. The loop
condition will always be true, and the loop will run until all the
memory resources are depleted.
Change the type of index 'i' to u32, so that it is large enough to store
The dmaengine core assumes that async DMA devices will only be removed
when they not used anymore, or it assumes dma_async_device_unregister()
will only be called by dma driver exit routines. But this assumption is
not true for the IOAT driver, which calls dma_async_device_unregister()
from ioat_remove(). So current IOAT driver doesn't support device
hot-removal because it may cause system crash to hot-remove an inuse
IOAT device.
To support CPU socket hot-removal, all PCI devices, including IOAT
devices embedded in the socket, will be hot-removed. The idea solution
is to enhance the dmaengine core and IOAT driver to support hot-removal,
but that's too hard.
This patch implements a hack to disable IOAT devices under hotplug-capable
CPU socket so it won't break socket hot-removal.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
This allows claiming of non-RAID channels as a private channel. This
prevents breakage of MDRAID using the IOATDMA channels via
async_tx but also allows agents such as NTB to claim channels
exclusively for its usages.
Pull slave-dmaengine updates from Vinod Koul:
- new drivers for:
- Ingenic JZ4780 controller
- APM X-Gene controller
- Freescale RaidEngine device
- Renesas USB Controller
- remove device_alloc_chan_resources dummy handlers
- sh driver cleanups for peri peri and related emmc and asoc patches
as well
- fixes and enhancements spread over the drivers
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (59 commits)
dmaengine: dw: don't prompt for DW_DMAC_CORE
dmaengine: shdmac: avoid unused variable warnings
dmaengine: fix platform_no_drv_owner.cocci warnings
dmaengine: pch_dma: fix memory leak on failure path in pch_dma_probe()
dmaengine: at_xdmac: unlock spin lock before return
dmaengine: xgene: devm_ioremap() returns NULL on error
dmaengine: xgene: buffer overflow in xgene_dma_init_channels()
dmaengine: usb-dmac: Fix dereferencing freed memory 'desc'
dmaengine: sa11x0: report slave capabilities to upper layers
dmaengine: vdma: Fix compilation warnings
dmaengine: fsl_raid: statify fsl_re_chan_probe
dmaengine: Driver support for FSL RaidEngine device.
dmaengine: xgene_dma_init_ring_mngr() can be static
Documentation: dma: Add documentation for the APM X-Gene SoC DMA device DTS binding
arm64: dts: Add APM X-Gene SoC DMA device and DMA clock DTS nodes
dmaengine: Add support for APM X-Gene SoC DMA engine driver
dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver
dmaengine: renesas,usb-dmac: Add device tree bindings documentation
dmaengine: edma: fixed wrongly initialized data parameter to the edma callback
dmaengine: ste_dma40: fix implicit conversion
Free Software Foundation mailing address has been moved in the past and some
of the addresses here are outdated. Remove them from file headers since the
COPYING file in the kernel sources includes it.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
BDX-DE IOATDMA reports incorrect DMACAP register for PQ related
ops. Ignoring those bits.
wait_for_completion_timeout reaching timeout was being ignored,
fail the self-test if timeout condition occurs.
v2: fixup of coding style issues.
Signed-off-by: Nicholas Mc Guire <der.herr@hofr.at>
Reviewed-by: Prarit Bhargava <prarit@redhat.com>
Adding PCI device IDs and hooks in workarounds for Broadwell DE ioatdma.
