[ Upstream commit e486df39305864604b7e25f2a95d51039517ac57 ]
The dma_desc->bytes_transferred counter tracks the number of bytes
moved by the DMA channel. This is then used to calculate the information
passed back in the in the tegra_dma_tx_status callback, which is usually
fine.
When the DMA channel is configured as continous, then the bytes_transferred
counter will increase over time and eventually overflow to become negative
so the residue count will become invalid and the ALSA sound-dma code will
report invalid hardware pointer values to the application. This results in
some users becoming confused about the playout position and putting audio
data in the wrong place.
To fix this issue, always ensure the bytes_transferred field is modulo the
size of the request. We only do this for the case of the cyclic transfer
done ISR as anyone attempting to move 2GiB of DMA data in one transfer
is unlikely.
Note, we don't fix the issue that we should /never/ transfer a negative
number of bytes so we could make those fields unsigned.
Reviewed-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Acked-by: Jon Hunter <jonathanh@nvidia.com>
Signed-off-by: Vinod Koul <vkoul@kernel.org>
This allows DMA client to issue a non-flow controlled TX. In particular
it is needed for the fuse driver that reads fuse registers using APBDMA
to workaround a HW bug that results in hang when CPU and DMA perform
simultaneous access to fuse peripheral.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Reviewed-by: Jon Hunter <jonathanh@nvidia.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Commit edd3bdbe9db1 ("dmaengine: tegra-apb: Correct runtime-pm usage")
added pm_runtime_get/put() calls to the tegra-apb DMA system suspend
callbacks. Runtime PM is disabled during system suspend and so these
APIs cannot be used. Fix the suspend handling for the tegra-apb DMA by
moving the save and restore of the DMA register context into the
runtime PM suspend and resume callbacks, and then use the
pm_runtime_force_suspend/resume() APIs to invoke the runtime PM
callbacks during system suspend.
Fixes: edd3bdbe9db1 ("dmaengine: tegra-apb: Correct runtime-pm usage")
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
This is in preperation of moving to a callback that provides results to the
callback for the transaction. The conversion will maintain current behavior
and the driver must convert to new callback mechanism at a later time in
order to receive results.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
Cc: Laxman Dewangan <ldewangan@nvidia.com>
Commit 71f7e6cc5500 ('dmaengine: tegra20-apb-dma: Only calculate residue
if txstate exists') changed the tegra_dma_tx_status() function to only
calculate the residue if there is a valid 'txstate' pointer for storing
the residue. Although this makes sense, this changed the behaviour of
the function tegra_dma_tx_status() such that if the pointer 'txstate' is
not valid, then we will return whatever state is returned by
dma_cookie_status() and no longer return the state by looking up the DMA
descriptor and returning it's state.
Please note that dma_cookie_status() will either return DMA_COMPLETE or
DMA_IN_PROGRESS. However, if dma_cookie_status() returns DMA_IN_PROGRESS
the actual status could be DMA_ERROR which will only be seen from
checking the descriptor status. Therefore, even if 'txstate' is not
valid, still check to see if there is a valid descriptor for the cookie
in question and if so return the descriptor state. Finally, ensure the
residue is still not calculated if the 'txstate' is not valid.
The calculation of the DMA residue for the Tegra APB DMA is duplicated
in two places in the tegra_dma_tx_status() function. Remove this
duplicated code by moving calculation to the end of the function and
only calculating if we found a valid descriptor.
Correct the grammar in the debug message when no descriptor is found.
If kzalloc() fails it will issue it's own error message including
a dump_stack(). So remove the site specific error messages.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
There is no point calculating the residue if there is
no txstate to store the value.
There are some places where whitespace is used in very funky ways. Fix
the most serious ones to make the code easier on the eye.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Initialize default channel slave_id(req_sel) to invalid id
(i.e max supported slave id + 1) to avoid overwriting of slave_id
during tegra_dma_slave_config() with client data if slave_id
is not initialized through DT
Signed-off-by: Shardar Shariff Md <smohammed@nvidia.com>
Tested-by: Jon Hunter <jonathanh@nvidia.com>
After using the function of_device_get_match_data(), the
of_device_id table for tegra20 dma is not used by probe()
and hence moving it near to place where platform driver is
defined as this table used only on this data structure.
Use of_device_get_match_data() for getting matched data
instead of implementing this locally.
Acked-by: Thierry Reding <treding@nvidia.com>
On probe failure or driver removal, before killing any tasklets, ensure
that the channel interrupt is freed to ensure that another channel
interrupt cannot occur and schedule the tasklet again.
The tegra20-apb-dma driver currently uses the flag GFP_ATOMIC when
allocating memory for structures used in conjunction with the DMA
descriptors. It is preferred that dmaengine drivers use GFP_NOWAIT
instead and so the emergency memory pool will not be used by these
drivers.
Currently the tegra-apb DMA driver suspend/resume helpers, save and
restore the registers for all channels regardless of whether they are
in use or not. Change this so that only channels that have been
allocated and configured are saved and restored.
Newer tegra devices have a separate word count register per channel that
contains the number of words to be transferred. This register is not
saved or restored by the suspend/resume helpers for these newer devices
and so ensure that it is.
In the tegra_dma_runtime_suspend/resume functions, the pdev structure
is not needed, and so just call dev_get_drvdata() to get the device
data structure.
The tegra-apb DMA driver enables runtime-pm but never calls
pm_runtime_get/put and hence the runtime-pm callbacks are never invoked.
The driver manages the clocks by directly calling clk_prepare_enable()
and clk_unprepare_disable().
Fix this by replacing the clk_prepare_enable() and clk_disable_unprepare()
with pm_runtime_get_sync() and pm_runtime_put(), respectively. Note that
the consequence of this is that if runtime-pm is disabled, then the clocks
will remain on the entire time the driver is loaded. However, if
runtime-pm is disabled, then power is not most likely not a concern.
Sparse reports the following with regard to locking in the
tegra_dma_global_pause() and tegra_dma_global_resume() functions:
drivers/dma/tegra20-apb-dma.c:362:9: warning: context imbalance in
'tegra_dma_global_pause' - wrong count at exit
drivers/dma/tegra20-apb-dma.c:366:13: warning: context imbalance in
'tegra_dma_global_resume' - unexpected unlock
The warning is caused because tegra_dma_global_pause() acquires a lock
but does not release it. However, the lock is released by
tegra_dma_global_resume(). These pause/resume functions are called in
pairs and so it does appear to work.
This global pause is used on early tegra devices that do not have an
individual pause for each channel. The lock appears to be used to ensure
that multiple channels do not attempt to assert/de-assert the global pause
at the same time which could cause the DMA controller to be in the wrong
paused state. Rather than locking around the entire code between the pause
and resume, employ a simple counter to keep track of the global pause
requests. By using a counter, it is only necessary to hold the lock when
pausing and unpausing the DMA controller and hence, fixes the sparse
warning.
Please note that for devices that support individual channel pausing, the
DMA controller lock is not held between pausing and unpausing the channel.
Hence, this change will make the devices that use the global pause behave
in the same way, with regard to locking, as those that don't.
Some void functions have unnecessary return statements at the end
(reported by sparse) and so remove these. Also remove the return variables
from functions tegra_dma_prep_slave_sg() and tegra_dma_prep_slave_cyclic()
because the value is not used.
Everytime a DMA channel register is accessed, the channel base address
is calculated by adding the DMA base address and the channel register
offset. Avoid this calculation and simply calculate the channel base
address once at probe time for each DMA channel.
The callback and callback_param members of the tegra_dma_sg_req structure
are never used. The dma-engine structure, dma_async_tx_descriptor, defines
the same members and these are the ones used by the driver. Therefore,
remove the unused versions from the tegra_dma_sg_req structure.
The half_done member of tegra_dma_channel structure is configured but
never used and so remove it.
After commit ecc19d17868be9c9f8f00ed928791533c420f3e0 ("dmaengine: Add
a warning for drivers not using the generic slave caps retrieval"),
the Tegra APB DMA driver causes this warning during boot:
WARNING: CPU: 0 PID: 1 at drivers/dma/dmaengine.c:830 dma_async_device_register+0x294/0x538()
this driver doesn't support generic slave capabilities reporting
Fix by setting the appropriate reporting structure fields that are
passed to dma_async_device_register().
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Tested-by: Thierry Reding <treding@nvidia.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
drivers/dma/tegra20-apb-dma.c:1428:37: warning: assignment from incompatible pointer type [enabled by default]
drivers/dma/ste_dma40.c: In function 'd40_terminate_all':
The function prototype expects return type 'int' whereas these where void
Split the device_control callback of the NVidia Tegra20 APB DMA driver to make
use of the newly introduced callbacks, that will eventually be used to retrieve
slave capabilities.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Pull dmaengine updates from Vinod Koul:
"Main features this time are:
- BAM v1.3.0 support form qcom bam dma
- support for Allwinner sun8i dma
- atmels eXtended DMA Controller driver
- chancnt cleanup by Maxime
- fixes spread over drivers"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (56 commits)
dmaenegine: Delete a check before free_percpu()
dmaengine: ioatdma: fix dma mapping errors
dma: cppi41: add a delay while setting the TD bit
dma: cppi41: wait longer for the HW to return the descriptor
dmaengine: fsl-edma: fixup reg offset and hw S/G support in big-endian model
dmaengine: fsl-edma: fix calculation of remaining bytes
drivers/dma/pch_dma: declare pch_dma_id_table as static
dmaengine: ste_dma40: fix error return code
dma: imx-sdma: clarify about firmware not found error
Documentation: devicetree: Fix Xilinx VDMA specification
dmaengine: pl330: update author info
dmaengine: clarify the issue_pending expectations
dmaengine: at_xdmac: Add DMA_PRIVATE
ARM: dts: at_xdmac: fix bad value of dma-cells in documentation
dmaengine: at_xdmac: fix missing spin_unlock
dmaengine: at_xdmac: fix a bug in transfer residue computation
dmaengine: at_xdmac: fix software lockup at_xdmac_tx_status()
dmaengine: at_xdmac: remove chancnt affectation
dmaengine: at_xdmac: prefer usage of readl/writel_relaxed
dmaengine: xdmac: fix print warning on dma_addr_t variable
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks
depending on CONFIG_PM_RUNTIME may now be changed to depend on
CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM in drivers/dma/nbpfaxi.c
and drivers/dma/tegra20-apb-dma.c.
Acked-by: Vinod Koul <vinod.koul@intel.com>
There is no need to init .owner field.
Based on the patch from Peter Griffin <peter.griffin@linaro.org>
"mmc: remove .owner field for drivers using module_platform_driver"
This patch removes the superflous .owner field for drivers which
use the module_platform_driver API, as this is overriden in
platform_driver_register anyway."
Signed-off-by: Kiran Padwal <kiran.padwal@smartplayin.com>
[for nvidia]
The argument is always set to NULL and never used. Remove it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Pull slave-dma updates from Vinod Koul:
- new driver for BCM2835 used in R-pi
- new driver for MOXA ART
- dma_get_any_slave_channel API for DT based systems
- minor fixes and updates spread acrooss driver
[ The fsl-ssi dual fifo mode support addition clashed badly with the
other changes to fsl-ssi that came in through the sound merge. I did
a very rough cut at fixing up the conflict, but Nicolin Chen (author
of both sides) will need to verify and check things ]
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (36 commits)
dmaengine: mmp_pdma: fix mismerge
dma: pl08x: Export pl08x_filter_id
acpi-dma: align documentation with kernel-doc format
dma: fix vchan_cookie_complete() debug print
DMA: dmatest: extend the "device" module parameter to 32 characters
drivers/dma: fix error return code
dma: omap: Set debug level to debugging messages
dmaengine: fix kernel-doc style typos for few comments
dma: tegra: add support for Tegra148/124
dma: dw: use %pad instead of casting dma_addr_t
dma: dw: join split up messages
dma: dw: fix style of multiline comment
dmaengine: k3dma: fix sparse warnings
dma: pl330: Use dma_get_slave_channel() in the of xlate callback
dma: pl330: Differentiate between submitted and issued descriptors
dmaengine: sirf: Add device_slave_caps interface
DMA: Freescale: change BWC from 256 bytes to 1024 bytes
dmaengine: Add MOXA ART DMA engine driver
dmaengine: Add DMA_PRIVATE to BCM2835 driver
dma: imx-sdma: Assign a default script number for ROM firmware cases
Tegra148 introduces a few changes to the APB DMA HW registers. Update the
driver to cope with them. Tegra124 inherits these changes.
* The register address stride between DMA channels increases.
* A new per-channel WCOUNT register is introduced.
Signed-off-by: Kunal Agrawal <kunala@nvidia.com>
[swarren, remove .dts file change, rewrote commit description, removed
some duplicate/unused code and register IO]
Reviewed-by: Thierry Reding <treding@nvidia.com>
Call of_dma_controller_register() so that DMA clients can look up the
Tegra DMA controller using standard APIs. This requires the of_xlate()
function to save off the DMA slave ID, and for tegra_dma_slave_config()
not to over-write this information; once DMA client drivers are converted
to dma_request_slave_channel() and DT-based lookups, they won't set this
field of struct dma_slave_config anymore.
Tegra's clock driver now provides an implementation of the common
reset API (include/linux/reset.h). Use this instead of the old Tegra-
specific API; that will soon be removed.
Acked-by: Dan Williams <dan.j.williams@intel.com>
tegra_dma_prep_dma_cyclic is referenced only in this file.
Make it static.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
Accordingly to dma_cookie_status() description locking is not required.
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: linux-tegra@vger.kernel.org
Lock scenario: Channel 1 was allocated and prepared as slave_sg, used and freed.
Now preparation of cyclic dma on channel 1 will fail with err "DMA configuration
conflict" because tdc->isr_handler still setted to handle_once_dma_done.
This happens because tegra_dma_abort_all() won't be called on channel freeing
if pending list is empty and channel not busy. We need to clear isr_handler
on channel freeing to avoid locking.
Fixed err msg params order on irq request fail.
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Implement suspend/resume callbacks to store APB DMA channel's
register on suspend and restore APB DMA channel's register on
resume.
Tegra only supports, and always enables, device tree. Remove all ifdefs
and runtime checks for DT support from the driver.
Pull slave-dmaengine updates from Vinod Koul:
"This is fairly big pull by my standards as I had missed last merge
window. So we have the support for device tree for slave-dmaengine,
large updates to dw_dmac driver from Andy for reusing on different
architectures. Along with this we have fixes on bunch of the drivers"
Fix up trivial conflicts, usually due to #include line movement next to
each other.
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (111 commits)
Revert "ARM: SPEAr13xx: Pass DW DMAC platform data from DT"
ARM: dts: pl330: Add #dma-cells for generic dma binding support
DMA: PL330: Register the DMA controller with the generic DMA helpers
DMA: PL330: Add xlate function
DMA: PL330: Add new pl330 filter for DT case.
dma: tegra20-apb-dma: remove unnecessary assignment
edma: do not waste memory for dma_mask
dma: coh901318: set residue only if dma is in progress
dma: coh901318: avoid unbalanced locking
dmaengine.h: remove redundant else keyword
dma: of-dma: protect list write operation by spin_lock
dmaengine: ste_dma40: do not remove descriptors for cyclic transfers
dma: of-dma.c: fix memory leakage
dw_dmac: apply default dma_mask if needed
dmaengine: ioat - fix spare sparse complain
dmaengine: move drivers/of/dma.c -> drivers/dma/of-dma.c
ioatdma: fix race between updating ioat->head and IOAT_COMPLETION_PENDING
dw_dmac: add support for Lynxpoint DMA controllers
dw_dmac: return proper residue value
dw_dmac: fill individual length of descriptor
Pull ARM SoC-specific updates from Arnd Bergmann:
"This is a larger set of new functionality for the existing SoC
families, including:
- vt8500 gains support for new CPU cores, notably the Cortex-A9 based
wm8850
- prima2 gains support for the "marco" SoC family, its SMP based
cousin
- tegra gains support for the new Tegra4 (Tegra114) family
- socfpga now supports a newer version of the hardware including SMP
- i.mx31 and bcm2835 are now using DT probing for their clocks
- lots of updates for sh-mobile
- OMAP updates for clocks, power management and USB
- i.mx6q and tegra now support cpuidle
- kirkwood now supports PCIe hot plugging
- tegra clock support is updated
- tegra USB PHY probing gets implemented diffently"
* tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits)
ARM: prima2: remove duplicate v7_invalidate_l1
ARM: shmobile: r8a7779: Correct TMU clock support again
ARM: prima2: fix __init section for cpu hotplug
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3)
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3)
arm: socfpga: Add SMP support for actual socfpga harware
arm: Add v7_invalidate_l1 to cache-v7.S
arm: socfpga: Add entries to enable make dtbs socfpga
arm: socfpga: Add new device tree source for actual socfpga HW
ARM: tegra: sort Kconfig selects for Tegra114
ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114
ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC
ARM: tegra: Fix build error for gic update
ARM: tegra: remove empty tegra_smp_init_cpus()
ARM: shmobile: Register ARM architected timer
ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move
ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT
ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles
ARM: mxs: use apbx bus clock to drive the timers on timrotv2
There is no need to assign 0 to residue, because dma_cookie_status() does this
for us.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into next/soc
From Stephen Warren:
ARM: tegra: Common Clock Framework rework
Tegra already supports the common clock framework, but had issues:
1) The clock driver was located in arch/arm/mach-tegra/ rather than
drivers/clk/.
2) A single "Tegra clock" type was implemented, rather than separate
clock types for PLL, mux, divider, ... type in HW.
3) Clock lookups by device drivers were still driven by device name
and connection ID, rather than through device tree.
This pull request solves all three issues. This required some DT changes
to add clocks properties, and driver changes to request clocks more
"correctly". Finally, this rework allows all AUXDATA to be removed from
Tegra board files, and various duplicate clock lookup entries to be
removed from the driver.
This pull request is based on the previous pull request, with tag
tegra-for-3.9-cleanup.
* tag 'tegra-for-3.9-soc-ccf' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra: (31 commits)
clk: tegra30: remove unused TEGRA_CLK_DUPLICATE()s
clk: tegra20: remove unused TEGRA_CLK_DUPLICATE()s
ARM: tegra30: remove auxdata
ARM: tegra20: remove auxdata
ASoC: tegra: remove auxdata
staging: nvec: remove use of clk_get_sys
ARM: tegra: paz00: add clock information to DT
ARM: tegra: add clock properties to Tegra30 DT
ARM: tegra: add clock properties to Tegra20 DT
spi: tegra: do not use clock name to get clock
ARM: tegra: remove legacy clock code
ARM: tegra: migrate to new clock code
clk: tegra: add clock support for Tegra30
clk: tegra: add clock support for Tegra20
clk: tegra: add Tegra specific clocks
ARM: tegra: define Tegra30 CAR binding
ARM: tegra: define Tegra20 CAR binding
ARM: tegra: move tegra_cpu_car.h to linux/clk/tegra.h
ARM: tegra: add function to read chipid
ARM: tegra: fix compile error when disable CPU_IDLE
arch/arm/mach-tegra/board-dt-tegra20.c
arch/arm/mach-tegra/board-dt-tegra30.c
arch/arm/mach-tegra/common.c
arch/arm/mach-tegra/platsmp.c
drivers/clocksource/Makefile
Migrate Tegra clock support to drivers/clk/tegra, this involves
moving:
1. definition of tegra_cpu_car_ops to clk.c
2. definition of reset functions to clk-peripheral.c
3. change parent of cpu clock.
4. Remove legacy clock initialization.
5. Initialize clocks using DT.
6. Remove all instance of mach/clk.h
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
[swarren: use to_clk_periph_gate().]
This resolves a gpio driver merge issue pointed out in linux-next.
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Vinod Koul <vinod.koul@intel.com>
