path: root/drivers/dma/xgene-dma.c
2016-08-08dmaengine: xgene-dma: move unmap to before callbackDave Jiang
Completion callback should happen after dma_descriptor_unmap() has happened. This allow the cache invalidate to happen and ensure that the data accessed by the upper layer is in memory that was from DMA rather than stale data. On some architecture this is done by the hardware, however we should make the code consistent to not cause confusion. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Cc: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-08-08dmaengine: xgene-dma: convert callback to helper functionDave Jiang
This is in preperation of moving to a callback that provides results to the callback for the transaction. The conversion will maintain current behavior and the driver must convert to new callback mechanism at a later time in order to receive results. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-01-07dmaengine: xgene-dma: Fix double IRQ issue by setting IRQ_DISABLE_UNLAZY flagRameshwar Prasad Sahu
For interrupt controller that doesn't support irq_disable and hardware with level interrupt, an extra interrupt can be pending. This patch fixes the issue by setting IRQ_DISABLE_UNLAZY flag for the interrupt line. Reference: http://git.kernel.org/tip/e9849777d0e27cdd2902805be51da73e7c79578c Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-11-10Merge tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time we have a very typical update which is mostly fixes and updates to drivers and no new drivers. - the biggest change is coming from Peter for edma cleanup which even caused some last minute regression, things seem settled now - idma64 and dw updates - iotdma updates - module autoload fixes for various drivers - scatter gather support for hdmac" * tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (77 commits) dmaengine: edma: Add dummy driver skeleton for edma3-tptc Revert "ARM: DTS: am33xx: Use the new DT bindings for the eDMA3" Revert "ARM: DTS: am437x: Use the new DT bindings for the eDMA3" dmaengine: dw: some Intel devices has no memcpy support dmaengine: dw: platform: provide platform data for Intel dmaengine: dw: don't override platform data with autocfg dmaengine: hdmac: Add scatter-gathered memset support dmaengine: hdmac: factorise memset descriptor allocation dmaengine: virt-dma: Fix kernel-doc annotations ARM: DTS: am437x: Use the new DT bindings for the eDMA3 ARM: DTS: am33xx: Use the new DT bindings for the eDMA3 dmaengine: edma: New device tree binding dmaengine: Kconfig: edma: Select TI_DMA_CROSSBAR in case of ARCH_OMAP dmaengine: ti-dma-crossbar: Add support for crossbar on AM33xx/AM43xx dmaengine: edma: Merge the of parsing functions dmaengine: edma: Do not allocate memory for edma_rsv_info in case of DT boot dmaengine: edma: Refactor the dma device and channel struct initialization dmaengine: edma: Get qDMA channel information from HW also dmaengine: edma: Merge map_dmach_to_queue into assign_channel_eventq dmaengine: edma: Correct PaRAM access function names (_parm_ to _param_) ...
2015-10-14dmaengine: xgene-dma: Remove memcpy offload support due to performance dropRameshwar Prasad Sahu
The DMA engine supports memory copy, RAID5 XOR, RAID6 PQ, and other computations. But the bandwidth of the entire DMA engine is shared among all channels. This patch re-configures operations availability such that one can achieve maximum performance for XOR and PQ computation by removing the memory offload operations. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-30dmaengine: xgene-dma: Fix overwritting DMA tx ringRameshwar Prasad Sahu
This patch fixes an over flow issue with the TX ring descriptor. Each descriptor is 32B in size and an operation requires 2 of these descriptors. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-25dmaengine: xgene-dma: fix handling xgene_dma_get_ring_size resultAndrzej Hajda
The function can return negative value. The problem has been detected using proposed semantic patch scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1]. [1]: http://permalink.gmane.org/gmane.linux.kernel/2046107 Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-21dmaengine: xgene-dma: use dma_pool_zallocVinod Koul
We should use shiny new dma_pool_zalloc instead of dma_pool_alloc/memset Reported-by: Julia Lawall <julia.lawall@lip6.fr> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-04Merge tag 'dmaengine-4.3-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time we have aded a new capability for scatter-gathered memset using dmaengine APIs. This is supported in xdmac & hdmac drivers We have added support for reusing descriptors for examples like video buffers etc. Driver will follow The behaviour of descriptor ack has been clarified and documented New devices added are: - dma controller in sun[457]i SoCs - lpc18xx dmamux - ZTE ZX296702 dma controller - Analog Devices AXI-DMAC DMA controller - eDMA support for dma-crossbar - imx6sx support in imx-sdma driver - imx-sdma device to device support Other: - jz4780 fixes - ioatdma large refactor and cleanup for removal of ioat v1 and v2 which is deprecated and fixes - ACPI support in X-Gene DMA engine driver - ipu irq fixes - mvxor fixes - minor fixes spread thru drivers" [ The Kconfig and Makefile entries got re-sorted alphabetically, and I handled the conflict with the new Intel integrated IDMA driver by slightly mis-sorting it on purpose: "IDMA64" got sorted after "IMX" in order to keep the Intel entries together. I think it might be a good idea to just rename the IDMA64 config entry to INTEL_IDMA64 to make the sorting be a true sort, not this mismash. Also, this merge disables the COMPILE_TEST for the sun4i DMA controller, because it does not compile cleanly at all. - Linus ] * tag 'dmaengine-4.3-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (89 commits) dmaengine: ioatdma: add Broadwell EP ioatdma PCI dev IDs dmaengine :ipu: change ipu_irq_handler() to remove compile warning dmaengine: ioatdma: Fix variable array length dmaengine: ioatdma: fix sparse "error" with prep lock dmaengine: hdmac: Add memset capabilities dmaengine: sort the sh Makefile dmaengine: sort the sh Kconfig dmaengine: sort the dw Kconfig dmaengine: sort the Kconfig dmaengine: sort the makefile drivers/dma: make mv_xor.c driver explicitly non-modular dmaengine: Add support for the Analog Devices AXI-DMAC DMA controller devicetree: Add bindings documentation for Analog Devices AXI-DMAC dmaengine: xgene-dma: Fix the lock to allow client for further submission of requests dmaengine: ioatdma: fix coccinelle warning dmaengine: ioatdma: fix zero day warning on incompatible pointer type dmaengine: tegra-apb: Simplify locking for device using global pause dmaengine: tegra-apb: Remove unnecessary return statements and variables dmaengine: tegra-apb: Avoid unnecessary channel base address calculation dmaengine: tegra-apb: Remove unused variables ...
2015-08-21dmaengine: xgene-dma: Fix the lock to allow client for further submission of ↵Rameshwar Prasad Sahu
requests This patch provides the fix in the cleanup routing such that client can perform further submission by releasing the lock before calling client's callback function. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-20dmaengine: xgene-dma: Add ACPI support for X-Gene DMA engine driverRameshwar Prasad Sahu
This patch adds ACPI support for the APM X-Gene DMA engine driver. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-05dmaengine: Add an enum for the dmaengine alignment constraintsMaxime Ripard
Most drivers need to set constraints on the buffer alignment for async tx operations. However, even though it is documented, some drivers either use a defined constant that is not matching what the alignment variable expects (like DMA_BUSWIDTH_* constants) or fill the alignment in bytes instead of power of two. Add a new enum for these alignments that matches what the framework expects, and convert the drivers to it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-07-31dmaengine: xgene-dma: Fix the resource map to handle overlappingRameshwar Prasad Sahu
There is an overlap in dma ring cmd csr region due to sharing of ethernet ring cmd csr region. This patch fix the resource overlapping by mapping the entire dma ring cmd csr region. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-06-25dmaengine: xgene: fix file permissionVinod Koul
drivers/dma/xgene-dma.c has file permissions 775, which is wrong, it should be 664, so fix it Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-06-02dmaengine: xgene-dma: Fix "incorrect type in assignement" warningsRameshwar Prasad Sahu
This patch fixes sparse warnings like incorrect type in assignment (different base types), cast to restricted __le64. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-04-17dmaengine: fix platform_no_drv_owner.cocci warningskbuild test robot
drivers/dma/xgene-dma.c:2079:3-8: No need to set .owner here. The core will do it. Remove .owner field if calls are used which set it automatically Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci CC: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-04-17dmaengine: xgene: devm_ioremap() returns NULL on errorDan Carpenter
The code here is checking for IS_ERR() but devm_ioremap() returns NULL on error and not an error pointer. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-04-17dmaengine: xgene: buffer overflow in xgene_dma_init_channels()Dan Carpenter
We put 9 characters into the 8 character name[] array. Let's make the array bigger and change the sprintf() to snprintf(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-04-02dmaengine: xgene_dma_init_ring_mngr() can be statickbuild test robot
2015-04-02dmaengine: Add support for APM X-Gene SoC DMA engine driverRameshwar Prasad Sahu
This patch implements the APM X-Gene SoC DMA engine driver. The APM X-Gene SoC DMA engine consists of 4 DMA channels for performing DMA operations. These DMA operations include memory copy, scatter-gather memory copy, raid5 xor, and raid6 p+q offloading. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Loc Ho <lho@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
