path: root/drivers/dma
2013-10-04dmaengine: imx-dma: fix callback path in taskletMichael Grzeschik
We need to free the ld_active list head before jumping into the callback routine. Otherwise the callback could run into issue_pending and change our ld_active list head we just going to free. This will run the channel list into an currupted and undefined state. Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-10-04dmaengine: imx-dma: fix lockdep issue between irqhandler and taskletMichael Grzeschik
The tasklet and irqhandler are using spin_lock while other routines are using spin_lock_irqsave/restore. This leads to lockdep issues as described bellow. This patch is changing the code to use spinlock_irq_save/restore in both code pathes. As imxdma_xfer_desc always gets called with spin_lock_irqsave lock held, this patch also removes the spare call inside the routine to avoid double locking. [ 403.358162] ================================= [ 403.362549] [ INFO: inconsistent lock state ] [ 403.366945] 3.10.0-20130823+ #904 Not tainted [ 403.371331] --------------------------------- [ 403.375721] inconsistent {IN-HARDIRQ-W} -> {HARDIRQ-ON-W} usage. [ 403.381769] swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes: [ 403.386762] (&(&imxdma->lock)->rlock){?.-...}, at: [<c019d77c>] imxdma_tasklet+0x20/0x134 [ 403.395201] {IN-HARDIRQ-W} state was registered at: [ 403.400108] [<c004b264>] mark_lock+0x2a0/0x6b4 [ 403.404798] [<c004d7c8>] __lock_acquire+0x650/0x1a64 [ 403.410004] [<c004f15c>] lock_acquire+0x94/0xa8 [ 403.414773] [<c02f74e4>] _raw_spin_lock+0x54/0x8c [ 403.419720] [<c019d094>] dma_irq_handler+0x78/0x254 [ 403.424845] [<c0061124>] handle_irq_event_percpu+0x38/0x1b4 [ 403.430670] [<c00612e4>] handle_irq_event+0x44/0x64 [ 403.435789] [<c0063a70>] handle_level_irq+0xd8/0xf0 [ 403.440903] [<c0060a20>] generic_handle_irq+0x28/0x38 [ 403.446194] [<c0009cc4>] handle_IRQ+0x68/0x8c [ 403.450789] [<c0008714>] avic_handle_irq+0x3c/0x48 [ 403.455811] [<c0008f84>] __irq_svc+0x44/0x74 [ 403.460314] [<c0040b04>] cpu_startup_entry+0x88/0xf4 [ 403.465525] [<c02f00d0>] rest_init+0xb8/0xe0 [ 403.470045] [<c03e07dc>] start_kernel+0x28c/0x2d4 [ 403.474986] [<a0008040>] 0xa0008040 [ 403.478709] irq event stamp: 50854 [ 403.482140] hardirqs last enabled at (50854): [<c001c6b8>] tasklet_action+0x38/0xdc [ 403.489954] hardirqs last disabled at (50853): [<c001c6a0>] tasklet_action+0x20/0xdc [ 403.497761] softirqs last enabled at (50850): [<c001bc64>] _local_bh_enable+0x14/0x18 [ 403.505741] softirqs last disabled at (50851): [<c001c268>] irq_exit+0x88/0xdc [ 403.513026] [ 403.513026] other info that might help us debug this: [ 403.519593] Possible unsafe locking scenario: [ 403.519593] [ 403.525548] CPU0 [ 403.528020] ---- [ 403.530491] lock(&(&imxdma->lock)->rlock); [ 403.534828] <Interrupt> [ 403.537474] lock(&(&imxdma->lock)->rlock); [ 403.541983] [ 403.541983] *** DEADLOCK *** [ 403.541983] [ 403.547951] no locks held by swapper/0. [ 403.551813] [ 403.551813] stack backtrace: [ 403.556222] CPU: 0 PID: 0 Comm: swapper Not tainted 3.10.0-20130823+ #904 [ 403.563039] Backtrace: [ 403.565581] [<c000b98c>] (dump_backtrace+0x0/0x10c) from [<c000bb28>] (show_stack+0x18/0x1c) [ 403.574054] r6:00000000 r5:c05c51d8 r4:c040bd58 r3:00200000 [ 403.579872] [<c000bb10>] (show_stack+0x0/0x1c) from [<c02f398c>] (dump_stack+0x20/0x28) [ 403.587955] [<c02f396c>] (dump_stack+0x0/0x28) from [<c02f29c8>] (print_usage_bug.part.28+0x224/0x28c) [ 403.597340] [<c02f27a4>] (print_usage_bug.part.28+0x0/0x28c) from [<c004b404>] (mark_lock+0x440/0x6b4) [ 403.606682] r8:c004a41c r7:00000000 r6:c040bd58 r5:c040c040 r4:00000002 [ 403.613566] [<c004afc4>] (mark_lock+0x0/0x6b4) from [<c004d844>] (__lock_acquire+0x6cc/0x1a64) [ 403.622244] [<c004d178>] (__lock_acquire+0x0/0x1a64) from [<c004f15c>] (lock_acquire+0x94/0xa8) [ 403.631010] [<c004f0c8>] (lock_acquire+0x0/0xa8) from [<c02f74e4>] (_raw_spin_lock+0x54/0x8c) [ 403.639614] [<c02f7490>] (_raw_spin_lock+0x0/0x8c) from [<c019d77c>] (imxdma_tasklet+0x20/0x134) [ 403.648434] r6:c3847010 r5:c040e890 r4:c38470d4 [ 403.653194] [<c019d75c>] (imxdma_tasklet+0x0/0x134) from [<c001c70c>] (tasklet_action+0x8c/0xdc) [ 403.662013] r8:c0599160 r7:00000000 r6:00000000 r5:c040e890 r4:c3847114 r3:c019d75c [ 403.670042] [<c001c680>] (tasklet_action+0x0/0xdc) from [<c001bd4c>] (__do_softirq+0xe4/0x1f0) [ 403.678687] r7:00000101 r6:c0402000 r5:c059919c r4:00000001 [ 403.684498] [<c001bc68>] (__do_softirq+0x0/0x1f0) from [<c001c268>] (irq_exit+0x88/0xdc) [ 403.692652] [<c001c1e0>] (irq_exit+0x0/0xdc) from [<c0009cc8>] (handle_IRQ+0x6c/0x8c) [ 403.700514] r4:00000030 r3:00000110 [ 403.704192] [<c0009c5c>] (handle_IRQ+0x0/0x8c) from [<c0008714>] (avic_handle_irq+0x3c/0x48) [ 403.712664] r5:c0403f28 r4:c0593ebc [ 403.716343] [<c00086d8>] (avic_handle_irq+0x0/0x48) from [<c0008f84>] (__irq_svc+0x44/0x74) [ 403.724733] Exception stack(0xc0403f28 to 0xc0403f70) [ 403.729841] 3f20: 00000001 00000004 00000000 20000013 c0402000 c04104a8 [ 403.738078] 3f40: 00000002 c0b69620 a0004000 41069264 a03fb5f4 c0403f7c c0403f40 c0403f70 [ 403.746301] 3f60: c004b92c c0009e74 20000013 ffffffff [ 403.751383] r6:ffffffff r5:20000013 r4:c0009e74 r3:c004b92c [ 403.757210] [<c0009e30>] (arch_cpu_idle+0x0/0x4c) from [<c0040b04>] (cpu_startup_entry+0x88/0xf4) [ 403.766161] [<c0040a7c>] (cpu_startup_entry+0x0/0xf4) from [<c02f00d0>] (rest_init+0xb8/0xe0) [ 403.774753] [<c02f0018>] (rest_init+0x0/0xe0) from [<c03e07dc>] (start_kernel+0x28c/0x2d4) [ 403.783051] r6:c03fc484 r5:ffffffff r4:c040a0e0 [ 403.787797] [<c03e0550>] (start_kernel+0x0/0x2d4) from [<a0008040>] (0xa0008040) Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-10-04dmaengine: imx-dma: fix slow path issue in prep_dma_cyclicMichael Grzeschik
When perparing cyclic_dma buffers by the sound layer, it will dump the following lockdep trace. The leading snd_pcm_action_single get called with read_lock_irq called. To fix this, we change the kcalloc call from GFP_KERNEL to GFP_ATOMIC. WARNING: at kernel/lockdep.c:2740 lockdep_trace_alloc+0xcc/0x114() DEBUG_LOCKS_WARN_ON(irqs_disabled_flags(flags)) Modules linked in: CPU: 0 PID: 832 Comm: aplay Not tainted 3.11.0-20130823+ #903 Backtrace: [<c000b98c>] (dump_backtrace+0x0/0x10c) from [<c000bb28>] (show_stack+0x18/0x1c) r6:c004c090 r5:00000009 r4:c2e0bd18 r3:00404000 [<c000bb10>] (show_stack+0x0/0x1c) from [<c02f397c>] (dump_stack+0x20/0x28) [<c02f395c>] (dump_stack+0x0/0x28) from [<c001531c>] (warn_slowpath_common+0x54/0x70) [<c00152c8>] (warn_slowpath_common+0x0/0x70) from [<c00153dc>] (warn_slowpath_fmt+0x38/0x40) r8:00004000 r7:a3b90000 r6:000080d0 r5:60000093 r4:c2e0a000 r3:00000009 [<c00153a4>] (warn_slowpath_fmt+0x0/0x40) from [<c004c090>] (lockdep_trace_alloc+0xcc/0x114) r3:c03955d8 r2:c03907db [<c004bfc4>] (lockdep_trace_alloc+0x0/0x114) from [<c008f16c>] (__kmalloc+0x34/0x118) r6:000080d0 r5:c3800120 r4:000080d0 r3:c040a0f8 [<c008f138>] (__kmalloc+0x0/0x118) from [<c019c95c>] (imxdma_prep_dma_cyclic+0x64/0x168) r7:a3b90000 r6:00000004 r5:c39d8420 r4:c3847150 [<c019c8f8>] (imxdma_prep_dma_cyclic+0x0/0x168) from [<c024618c>] (snd_dmaengine_pcm_trigger+0xa8/0x160) [<c02460e4>] (snd_dmaengine_pcm_trigger+0x0/0x160) from [<c0241fa8>] (soc_pcm_trigger+0x90/0xb4) r8:c058c7b0 r7:c3b8140c r6:c39da560 r5:00000001 r4:c3b81000 [<c0241f18>] (soc_pcm_trigger+0x0/0xb4) from [<c022ece4>] (snd_pcm_do_start+0x2c/0x38) r7:00000000 r6:00000003 r5:c058c7b0 r4:c3b81000 [<c022ecb8>] (snd_pcm_do_start+0x0/0x38) from [<c022e958>] (snd_pcm_action_single+0x40/0x6c) [<c022e918>] (snd_pcm_action_single+0x0/0x6c) from [<c022ea64>] (snd_pcm_action_lock_irq+0x7c/0x9c) r7:00000003 r6:c3b810f0 r5:c3b810f0 r4:c3b81000 [<c022e9e8>] (snd_pcm_action_lock_irq+0x0/0x9c) from [<c023009c>] (snd_pcm_common_ioctl1+0x7f8/0xfd0) r8:c3b7f888 r7:005407b8 r6:c2c991c0 r5:c3b81000 r4:c3b81000 r3:00004142 [<c022f8a4>] (snd_pcm_common_ioctl1+0x0/0xfd0) from [<c023117c>] (snd_pcm_playback_ioctl1+0x464/0x488) [<c0230d18>] (snd_pcm_playback_ioctl1+0x0/0x488) from [<c02311d4>] (snd_pcm_playback_ioctl+0x34/0x40) r8:c3b7f888 r7:00004142 r6:00000004 r5:c2c991c0 r4:005407b8 [<c02311a0>] (snd_pcm_playback_ioctl+0x0/0x40) from [<c00a14a4>] (vfs_ioctl+0x30/0x44) [<c00a1474>] (vfs_ioctl+0x0/0x44) from [<c00a1fe8>] (do_vfs_ioctl+0x55c/0x5c0) [<c00a1a8c>] (do_vfs_ioctl+0x0/0x5c0) from [<c00a208c>] (SyS_ioctl+0x40/0x68) [<c00a204c>] (SyS_ioctl+0x0/0x68) from [<c0009380>] (ret_fast_syscall+0x0/0x44) r8:c0009544 r7:00000036 r6:bedeaa58 r5:00000000 r4:000000c0 Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-17dma/Kconfig: Make TI_EDMA select TI_PRIV_EDMAJosh Boyer
The TI_EDMA driver unconditionally calls functions provided by the TI_PRIV_EDMA code, but it doesn't force that to be built-in. If that isn't otherwise enabled somewhere, you can get build errors like: linux-3.12.0-0.rc0.git1.1.fc21.armv7hl/drivers/dma/edma.c:593: undefined reference to `edma_free_slot' drivers/built-in.o: In function `edma_terminate_all': linux-3.12.0-0.rc0.git1.1.fc21.armv7hl/drivers/dma/edma.c:169: undefined reference to `edma_stop' drivers/built-in.o: In function `edma_execute': linux-3.12.0-0.rc0.git1.1.fc21.armv7hl/drivers/dma/edma.c:122: undefined reference to `edma_write_slot' linux-3.12.0-0.rc0.git1.1.fc21.armv7hl/drivers/dma/edma.c:149: undefined reference to `edma_link' linux-3.12.0-0.rc0.git1.1.fc21.armv7hl/drivers/dma/edma.c:152: undefined reference to `edma_start' Make TI_EDMA select TI_PRIV_EDMA to avoid this. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Acked-by: Matt Porter <matt.porter@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-17edma: Update author email addressJosh Boyer
Matt's @ti.com address bounces. Update the MODULE_AUTHOR information in edma.c to his Linaro address. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Acked-by: Matt Porter <matt.porter@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-10Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "This pull brings: - Andy's DW driver updates - Guennadi's sh driver updates - Pl08x driver fixes from Tomasz & Alban - Improvements to mmp_pdma by Daniel - TI EDMA fixes by Joel - New drivers: - Hisilicon k3dma driver - Renesas rcar dma driver - New API for publishing slave driver capablities - Various fixes across the subsystem by Andy, Jingoo, Sachin etc..." * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (94 commits) dma: edma: Remove limits on number of slots dma: edma: Leave linked to Null slot instead of DUMMY slot dma: edma: Find missed events and issue them ARM: edma: Add function to manually trigger an EDMA channel dma: edma: Write out and handle MAX_NR_SG at a given time dma: edma: Setup parameters to DMA MAX_NR_SG at a time dmaengine: pl330: use dma_set_max_seg_size to set the sg limit dmaengine: dma_slave_caps: remove sg entries dma: replace devm_request_and_ioremap by devm_ioremap_resource dma: ste_dma40: Fix potential null pointer dereference dma: ste_dma40: Remove duplicate const dma: imx-dma: Remove redundant NULL check dma: dmagengine: fix function names in comments dma: add driver for R-Car HPB-DMAC dma: k3dma: use devm_ioremap_resource() instead of devm_request_and_ioremap() dma: imx-sdma: Staticize sdma_driver_data structures pch_dma: Add MODULE_DEVICE_TABLE dmaengine: PL08x: Add cyclic transfer support dmaengine: PL08x: Fix reading the byte count in cctl dmaengine: PL08x: Add support for different maximum transfer size ...
2013-09-09Merge tag 'dmaengine-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine update from Dan Williams: "Collection of random updates to the core and some end-driver fixups for ioatdma and mv_xor: - NUMA aware channel allocation - Cleanup dmatest debugfs interface - ioat: make raid-support Atom only - mv_xor: big endian Aside from the top three commits these have all had some soak time in -next. The top commit fixes a recent build breakage. It has been a long while since my last pull request, hopefully it does not show. Thanks to Vinod for keeping an eye on drivers/dma/ this past year" * tag 'dmaengine-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: dmaengine: dma_sync_wait and dma_find_channel undefined MAINTAINERS: update email for Dan Williams dma: mv_xor: Fix incorrect error path ioatdma: silence GCC warnings dmaengine: make dma_channel_rebalance() NUMA aware dmaengine: make dma_submit_error() return an error code ioatdma: disable RAID on non-Atom platforms and reenable unaligned copies mv_xor: support big endian systems using descriptor swap feature mv_xor: use {readl, writel}_relaxed instead of __raw_{readl, writel} dmatest: print message on debug level in case of no error dmatest: remove IS_ERR_OR_NULL checks of debugfs calls dmatest: make module parameters writable
2013-09-09Merge tag 'late-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late changes from Kevin Hilman: "These are changes that arrived a little late before the merge window, or had dependencies on previous branches. Highlights: - ux500: misc. cleanup, fixup I2C devices - exynos: DT updates for RTC; PM updates - at91: DT updates for NAND; new platforms added to generic defconfig - sunxi: DT updates: cubieboard2, pinctrl driver, gated clocks - highbank: LPAE fixes, select necessary ARM errata - omap: PM fixes and improvements; OMAP5 mailbox support - omap: basic support for new DRA7xx SoCs" * tag 'late-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits) ARM: dts: vexpress: Add CCI node to TC2 device-tree ARM: EXYNOS: Skip C1 cpuidle state for exynos5440 ARM: EXYNOS: always enable PM domains support for EXYNOS4X12 ARM: highbank: clean-up some unused includes ARM: sun7i: Enable the A20 clocks in the DTSI ARM: sun6i: Enable clock support in the DTSI ARM: sun5i: dt: Use the A10s gates in the DTSI ARM: at91: at91_dt_defconfig: enable rm9200 support ARM: dts: add ADC device tree node for exynos5420/5250 ARM: dts: Add RTC DT node to Exynos5420 SoC ARM: dts: Update the "status" property of RTC DT node for Exynos5250 SoC ARM: dts: Fix the RTC DT node name for Exynos5250 irqchip: mmp: avoid to include irqs head file ARM: mmp: avoid to include head file in mach-mmp irqchip: mmp: support irqchip irqchip: move mmp irq driver ARM: OMAP: AM33xx: clock: Add RNG clock data ARM: OMAP: TI81XX: add always-on powerdomain for TI81XX ARM: OMAP4: clock: Lock PLLs in the right sequence ARM: OMAP: AM33XX: hwmod: Add hwmod data for debugSS ...
2013-09-09dma: mv_xor: Fix incorrect error pathSachin Kamat
Return directly if memory allocation fails. There is no need of dma_free_coherent(). Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Saeed Bishara <saeed@marvell.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "Unfortunately, this merge window it'll have a be a lot of small piles - my fault, actually, for not keeping #for-next in anything that would resemble a sane shape ;-/ This pile: assorted fixes (the first 3 are -stable fodder, IMO) and cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last components) + several long-standing patches from various folks. There definitely will be a lot more (starting with Miklos' check_submount_and_drop() series)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits) direct-io: Handle O_(D)SYNC AIO direct-io: Implement generic deferred AIO completions add formats for dentry/file pathnames kvm eventfd: switch to fdget powerpc kvm: use fdget switch fchmod() to fdget switch epoll_ctl() to fdget switch copy_module_from_fd() to fdget git simplify nilfs check for busy subtree ibmasmfs: don't bother passing superblock when not needed don't pass superblock to hypfs_{mkdir,create*} don't pass superblock to hypfs_diag_create_files don't pass superblock to hypfs_vm_create_files() oprofile: get rid of pointless forward declarations of struct super_block oprofilefs_create_...() do not need superblock argument oprofilefs_mkdir() doesn't need superblock argument don't bother with passing superblock to oprofile_create_stats_files() oprofile: don't bother with passing superblock to ->create_files() don't bother passing sb to oprofile_create_files() coh901318: don't open-code simple_read_from_buffer() ...
2013-09-04dma: edma: Remove limits on number of slotsJoel Fernandes
With this series, this check is no longer required and we shouldn't need to reject drivers DMA'ing more than the MAX number of slots. Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-04dma: edma: Leave linked to Null slot instead of DUMMY slotJoel Fernandes
Dummy slot has been used as a way for missed-events not to be reported as missing. This has been particularly troublesome for cases where we might want to temporarily pause all incoming events. For EDMA DMAC, there is no way to do any such pausing of events as the occurence of the "next" event is not software controlled. Using "edma_pause" in IRQ handlers doesn't help as by then the event in concern from the slave is already missed. Linking a dummy slot, is seen to absorb these events which we didn't want to miss. So we don't link to dummy, but instead leave it linked to NULL set, allow an error condition and detect the channel that missed it. Consider the case where we have a scatter-list like: SG1->SG2->SG3->SG4->SG5->SG6->Null For ex, for a MAX_NR_SG of 2, earlier we were splitting this as: SG1->SG2->Null SG3->SG4->Null SG5->SG6->Null Now we split it as SG1->SG2->Null SG3->SG4->Null SG5->SG6->Dummy This approach results in lesser unwanted interrupts that occur for the last list split. The Dummy slot has the property of not raising an error condition if events are missed unlike the Null slot. We are OK with this as we're done with processing the whole list once we reach Dummy. Signed-off-by: Joel Fernandes <joelf@ti.com> [modifed duplicate s-o-b & patch title] Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-04dma: edma: Find missed events and issue themJoel Fernandes
In an effort to move to using Scatter gather lists of any size with EDMA as discussed at [1] instead of placing limitations on the driver, we work through the limitations of the EDMAC hardware to find missed events and issue them. The sequence of events that require this are: For the scenario where MAX slots for an EDMA channel is 3: SG1 -> SG2 -> SG3 -> SG4 -> SG5 -> SG6 -> Null The above SG list will have to be DMA'd in 2 sets: (1) SG1 -> SG2 -> SG3 -> Null (2) SG4 -> SG5 -> SG6 -> Null After (1) is succesfully transferred, the events from the MMC controller donot stop coming and are missed by the time we have setup the transfer for (2). So here, we catch the events missed as an error condition and issue them manually. In the second part of the patch, we make handle the NULL slot cases: For crypto IP, we continue to receive events even continuously in NULL slot, the setup of the next set of SG elements happens after the error handler executes. This is results in some recursion problems. Due to this, we continously receive error interrupts when we manually trigger an event from the error handler. We fix this, by first detecting if the Channel is currently transferring from a NULL slot or not, that's where the edma_read_slot in the error callback from interrupt handler comes in. With this we can determine if the set up of the next SG list has completed, and we manually trigger only in this case. If the setup has _not_ completed, we are still in NULL so we just set a missed flag and allow the manual triggerring to happen in edma_execute which will be eventually called. This fixes the above mentioned race conditions seen with the crypto drivers. [1] http://marc.info/?l=linux-omap&m=137416733628831&w=2 Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-04dma: edma: Write out and handle MAX_NR_SG at a given timeJoel Fernandes
Process SG-elements in batches of MAX_NR_SG if they are greater than MAX_NR_SG. Due to this, at any given time only those many slots will be used in the given channel no matter how long the scatter list is. We keep track of how much has been written inorder to process the next batch of elements in the scatter-list and detect completion. For such intermediate transfer completions (one batch of MAX_NR_SG), make use of pause and resume functions instead of start and stop when such intermediate transfer is in progress or completed as we donot want to clear any pending events. Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-04dma: edma: Setup parameters to DMA MAX_NR_SG at a timeJoel Fernandes
Changes are made here for configuring existing parameters to support DMA'ing them out in batches as needed. Also allocate as many as slots as needed by the SG list, but not more than MAX_NR_SG. Then these slots will be reused accordingly. For ex, if MAX_NR_SG=10, and number of SG entries is 40, still only 10 slots will be allocated to DMA the entire SG list of size 40. Also enable TC interrupts for slots that are a last in a current iteration, or that fall on a MAX_NR_SG boundary. Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-04Merge branch 'topic/api_caps' into for-linusVinod Koul
2013-09-03coh901318: don't open-code simple_read_from_buffer()Al Viro
... and BTW, failing copy_to_user() means EFAULT, not EINVAL Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-03Merge tag 'driver-core-3.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg KH: "Here's the big driver core pull request for 3.12-rc1. Lots of tiny changes here fixing up the way sysfs attributes are created, to try to make drivers simpler, and fix a whole class race conditions with creations of device attributes after the device was announced to userspace. All the various pieces are acked by the different subsystem maintainers" * tag 'driver-core-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (119 commits) firmware loader: fix pending_fw_head list corruption drivers/base/memory.c: introduce help macro to_memory_block dynamic debug: line queries failing due to uninitialized local variable sysfs: sysfs_create_groups returns a value. debugfs: provide debugfs_create_x64() when disabled rbd: convert bus code to use bus_groups firmware: dcdbas: use binary attribute groups sysfs: add sysfs_create/remove_groups for when SYSFS is not enabled driver core: add #include <linux/sysfs.h> to core files. HID: convert bus code to use dev_groups Input: serio: convert bus code to use drv_groups Input: gameport: convert bus code to use drv_groups driver core: firmware: use __ATTR_RW() driver core: core: use DEVICE_ATTR_RO driver core: bus: use DRIVER_ATTR_WO() driver core: create write-only attribute macros for devices and drivers sysfs: create __ATTR_WO() driver-core: platform: convert bus code to use dev_groups workqueue: convert bus code to use dev_groups MEI: convert bus code to use dev_groups ...
2013-09-03Merge tag 'usb-3.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg KH: "Here's the big USB driver pull request for 3.12-rc1 Lots of USB driver fixes and updates. Nothing major, just the normal xhci, gadget, and other driver changes. Full details in the shortlog" * tag 'usb-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (352 commits) usbcore: fix incorrect type in assignment in descriptors_changed() usbcore: compare and release one bos descriptor in usb_reset_and_verify_device() ehci: remove debugging statement with ehci statistics in ehci_stop() ehci: remove duplicate debug_async_open() prototype in ehci-dbg.c ehci: enable debugging code when CONFIG_DYNAMIC_DEBUG is set ehci: remove ehci_vdbg() verbose debugging statements Documentation sysfs-bus-usb: Document which files are used by libusb Documentation sysfs-bus-usb: Document the speed file used by libusb Documentation sysfs-bus-usb: Move files with known users to stable USB: fix build error when CONFIG_PM_SLEEP isn't enabled usb: r8a66597-hcd: use platform_{get,set}_drvdata() usb: phy-tegra-usb: use platform_{get,set}_drvdata() usb: acm gadget: Null termintate strings table dma: cppi41: off by one in desc_to_chan() xhci: Fix warning introduced by disabling runtime PM. dev-core: fix build break when DEBUG is enabled USB: OHCI: Allow runtime PM without system sleep usb: ohci-at91: remove unnecessary dev_set_drvdata() usb: renesas_usbhs: use platform_{get,set}_drvdata() usb: fotg210-udc: use platform_{get,set}_drvdata() ...
2013-09-03dmaengine: pl330: use dma_set_max_seg_size to set the sg limitVinod Koul
2013-09-02Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dma fix from Vinod Koul: "A fix for resolving TI_EDMA driver's build error in allmodconfig to have filter function built in"" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dma/Kconfig: TI_EDMA needs to be boolean
2013-09-02Merge branch 'topic/sh' into for-linusVinod Koul
Conflicts: drivers/dma/sh/Kconfig drivers/dma/sh/shdmac.c Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02Merge branch 'topic/of' into for-linusVinod Koul
2013-09-02Merge branch 'topic/api_caps' into for-linusVinod Koul
2013-09-02dma: replace devm_request_and_ioremap by devm_ioremap_resourceJulia Lawall
Use devm_ioremap_resource instead of devm_request_and_ioremap. This was done using the semantic patch scripts/coccinelle/api/devm_ioremap_resource.cocci The relevant call to platform_get_resource was manually moved down to the call to devm_ioremap_resource. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dma: ste_dma40: Fix potential null pointer dereferenceSachin Kamat
kcalloc can return NULL. Check the pointer before dereferencing. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dma: ste_dma40: Remove duplicate constSachin Kamat
'const' was added twice. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dma: imx-dma: Remove redundant NULL checkSachin Kamat
kfree on a NULL pointer is a no-op. Null pointer check is not necessary. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dma: dmagengine: fix function names in commentsDaniel Mack
Trivial fix for function name mismatches I stumbled over. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dma: add driver for R-Car HPB-DMACMax Filippov
Add support for HPB-DMAC found in Renesas R-Car SoCs, using 'shdma-base' DMA driver framework. Based on the original patch by Phil Edworthy <phil.edworthy@renesas.com>. Signed-off-by: Max Filippov <max.filippov@cogentembedded.com> [Sergei: removed useless #include, sorted #include's, fixed HPB_DMA_TCR_MAX, fixed formats and removed line breaks in the dev_dbg() calls, rephrased and added IRQ # to the shdma_request_irq() failure message, added MODULE_AUTHOR(), removed '__init'/'__exit' annotations from the probe()/remove() methods, removed '__initdata' annotation from 'hpb_dmae_driver', fixed guard macro name in the header file, fixed #define ASYNCRSTR_ASRST20, added #define ASYNCRSTR_ASRST24, added the necessary runtime PM calls to the probe() and remove() methods, handled errors returned by dma_async_device_register(), beautified comments and #define's.] Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dma: k3dma: use devm_ioremap_resource() instead of devm_request_and_ioremap()Jingoo Han
Use devm_ioremap_resource() because devm_request_and_ioremap() is obsoleted by devm_ioremap_resource(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dma: imx-sdma: Staticize sdma_driver_data structuresFabio Estevam
Sparse report the following warnings: drivers/dma/imx-sdma.c:330:25: warning: symbol 'sdma_imx31' was not declared. Should it be static? drivers/dma/imx-sdma.c:351:25: warning: symbol 'sdma_imx25' was not declared. Should it be static? drivers/dma/imx-sdma.c:357:25: warning: symbol 'sdma_imx35' was not declared. Should it be static? drivers/dma/imx-sdma.c:375:25: warning: symbol 'sdma_imx51' was not declared. Should it be static? drivers/dma/imx-sdma.c:395:25: warning: symbol 'sdma_imx53' was not declared. Should it be static? drivers/dma/imx-sdma.c:414:25: warning: symbol 'sdma_imx6q' was not declared. Should it be static? Make the sdma_driver_data structures static. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02pch_dma: Add MODULE_DEVICE_TABLEBen Hutchings
pch_dma currently isn't auto-loaded if built as a module. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dmaengine: PL08x: Add cyclic transfer supportAlban Bedel
Many audio interface drivers require support of cyclic transfers to work correctly, for example Samsung ASoC DMA driver. This patch adds support for cyclic transfers to the amba-pl08x driver. Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> [tfiga: Rebase and slightly beautify the original patch.] Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dmaengine: PL08x: Fix reading the byte count in cctlAlban Bedel
There are more fields than just SWIDTH in CH_CONTROL register, so read register value must be masked in addition to shifting. Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dmaengine: PL08x: Add support for different maximum transfer sizeTomasz Figa
PL080S has separate register to store transfer size in, allowing single transfer to be much larger than in standard PL080. This patch makes the amba-pl08x driver aware of this and removes writing transfer size to reserved bits of CH_CONTROL register on PL080S, which was not a problem witn transfer sizes fitting the original bitfield of PL080, but now would overwrite other fields. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dmaengine: PL08x: Add support for PL080S variantTomasz Figa
PL080S is a modified version of PL080 that can be found on Samsung SoCs, such as S3C6400 and S3C6410. It has different offset of CONFIG register, separate CONTROL1 register that holds transfer size and larger maximum transfer size. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dmaengine: PL08x: Move LLI dumping code into separate functionTomasz Figa
This patch refactors debugging code that dumps LLI entries by moving it into separate function, which is stubbed when VERBOSE_DEBUG is not selected. This allows us to get rid of the ugly ifdef from the body of pl08x_fill_llis_for_desc(). No functional change is introduced by this patch. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dmaengine: PL08x: Rework LLI handling to be less fragileTomasz Figa
Currently memory allocated for LLIs is casted to an array of structs, which is fragile and also limits the driver to a single, predefined LLI layout, while there are some variants of PL08x, which have more fields in LLI (namely PL080S with its extra CCTL2). This patch makes LLIs a sequence of 32-bit words, which is just filled with appropriate values in appropriate order and padded with required amount of dummy words (currently zero, but PL080S will make better use of this). Suggested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dmaengine: PL08x: Add support for different offset of CONFIG registerTomasz Figa
Some variants of PL08x (namely PL080S, found in Samsung S3C64xx SoCs) have CONFIG register at different offset. This patch makes the driver use offset from vendor data struct. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-02dmaengine: PL08x: Refactor pl08x_getbytes_chan() to lower indentationTomasz Figa
Further patch will introduce support for PL080S, which requires some things to be done conditionally, thus increasing indentation level of some functions even more. This patch reduces indentation level of pl08x_getbytes_chan() function by inverting several conditions and returning from function wherever possible. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-08-28dma: cppi41: off by one in desc_to_chan()Dan Carpenter
The test here should be ">=" instead of ">". The cdd->chan_busy[] array has "ALLOC_DECS_NUM" elements. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-28dma: pl330: Fix handling of TERMINATE_ALL while processing completed descriptorsLars-Peter Clausen
The pl330 DMA driver is broken in regard to handling a terminate all request while it is processing the list of completed descriptors. This is most visible when calling dmaengine_terminate_all() from within the descriptors callback for cyclic transfers. In this case the TERMINATE_ALL transfer will clear the work_list and stop the transfer. But after all callbacks for all completed descriptors have been handled the descriptors will be re-enqueued into the (now empty) work_list. So the next time dma_async_issue_pending() is called for the channel these descriptors will be transferred again which will cause data corruption. Similar issues can occur if dmaengine_terminate_all() is not called from within the descriptor callback but runs on a different CPU at the same time as the completed descriptor list is processed. This patch introduces a new per channel list which will hold the completed descriptors. While processing the list the channel's lock will be held to avoid racing against dmaengine_terminate_all(). The lock will be released when calling the descriptors callback though. Since the list of completed descriptors might be modified (e.g. by calling dmaengine_terminate_all() from the callback) we can not use the normal list iterator macros. Instead we'll need to check for each loop iteration again if there are still items in the list. The drivers TERMINATE_ALL implementation is updated to move descriptors from both the work_list as well the new completed_list back to the descriptor pool. This makes sure that none of the descripts finds its way back into the work list and also that we do not call any futher complete callbacks after dmaengine_terminate_all() has been called. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-08-28dmaengine: Add hisilicon k3 DMA engine driverZhangfei Gao
Add dmaengine driver for hisilicon k3 platform based on virt_dma Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Tested-by: Kai Yang <jean.yangkai@huawei.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-08-27dma: cpp41: enable pm_runtime during initSebastian Andrzej Siewior
With enabled pm_runtime in the kernel the device won't work because it is not "on" during the probe function. This patch enables the device via pm_runtime on probe so it remains activated. Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-08-27dma: cpp41: make it compile with CONFIG_BUG=nSebastian Andrzej Siewior
Before Randy figures out that this does not compile with CONFIG_BUG=n here is a fix for it. Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-08-27DMA: shdma: fix a bad merge - remove free_irq()Guennadi Liakhovetski
A bad merge resulted in a left-over free_irq() call. This patch removes it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-08-27dma: sh: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-08-27DMA: shdma: add r8a73a4 DMAC data to the device ID tableGuennadi Liakhovetski
This configuration data will be used, when DMAC DT support is added to r8a73a4. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
