path: root/drivers/dma
2010-07-02of/dma: fix build breakage in ppc4xx adma driverDan Williams
Convert ppc4xx adma driver to use new node pointer location Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-06-02of/dma: fix build breakage in ppc4xx adma driverAnatolij Gustschin
Fixes build error caused by the OF device_node pointer being moved into struct device Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-06-02of/dma: mpc512x_dma.c: Fix build failuresAnatolij Gustschin
Fixes build errors caused by the: - OF device_node pointer being moved into struct device - removal of the match_table field from struct of_platform_driver Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-30Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: DMAENGINE: DMA40 U8500 platform configuration DMA: PL330: Add dma api driver
2010-05-25kernel-wide: replace USHORT_MAX, SHORT_MAX and SHORT_MIN with USHRT_MAX, ↵Alexey Dobriyan
SHRT_MAX and SHRT_MIN - C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not USHORT_MAX/SHORT_MAX/SHORT_MIN. - Make SHRT_MIN of type s16, not int, for consistency. [akpm@linux-foundation.org: fix drivers/dma/timb_dma.c] [akpm@linux-foundation.org: fix security/keys/keyring.c] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (25 commits) sh: fix up sh7785lcr_32bit_defconfig. arch/sh/lib/strlen.S: Checkpatch cleanup sh: fix up sh7786 dmaengine build. sh: guard cookie consistency across termination in the DMA driver sh: prevent the DMA driver from unloading, while in use sh: fix Oops in the serial SCI driver sh: allow platforms to specify SD-card supported voltages mmc: let MFD's provide supported Vdd card voltages to tmio_mmc sh: disable SD-card write-protection detection on kfr2r09 mfd: pass platform flags down to the tmio_mmc driver tmio: add a platform flag to disable card write-protection detection sh: Add SDHI DMA support to migor sh: Add SDHI DMA support to kfr2r09 sh: Add SDHI DMA support to ms7724se sh: Add SDHI DMA support to ecovec mmc: add DMA support to tmio_mmc driver, when used on SuperH sh: prepare the SDHI MFD driver to pass DMA configuration to tmio_mmc.c mmc: prepare tmio_mmc for passing of DMA configuration from the MFD cell sh: add DMA slave definitions to sh7724 sh: add DMA slaves for two SDHI controllers to sh7722 ...
2010-05-23DMA: PL330: Add dma api driverJassi Brar
Add DMA Engine API driver for the PL330 DMAC. This driver is supposed to be reusable by various platforms that have one or more PL330 DMACs. Atm, DMA_SLAVE and DMA_MEMCPY capabilities have been implemented. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Reviewed-by: Linus Walleij <linus.walleij@stericsson.com> [dan.j.williams@intel.com: missing slab.h and ->device_control() fixups] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-22sh: guard cookie consistency across termination in the DMA driverGuennadi Liakhovetski
If all descriptors on a channel are terminated or the channel is released, update the completed cookie counter to match the last cookie. This prevents inconsistency warning on resumed DMA operation. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: prevent the DMA driver from unloading, while in useGuennadi Liakhovetski
This prevents the driver from unloading, while it is in use. Unloading of the driver, while its DMA channels are held, leads to a kernel Oops. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: DMAENGINE: extend the control command to include an arg async_tx: trim dma_async_tx_descriptor in 'no channel switch' case DMAENGINE: DMA40 fix for allocation of logical channel 0 DMAENGINE: DMA40 support paused channel status dmaengine: mpc512x: Use resource_size DMA ENGINE: Do not reset 'private' of channel ioat: Remove duplicated devm_kzalloc() calls for ioatdma_device ioat3: disable cacheline-unaligned transfers for raid operations ioat2,3: convert to producer/consumer locking ioat: convert to circ_buf DMAENGINE: Support for ST-Ericssons DMA40 block v3 async_tx: use of kzalloc/kfree requires the include of slab.h dmaengine: provide helper for setting txstate DMAENGINE: generic channel status v2 DMAENGINE: generic slave control v2 dma: timb-dma: Update comment and fix compiler warning dma: Add timb-dma DMAENGINE: COH 901 318 fix bytesleft DMAENGINE: COH 901 318 rename confusing vars
2010-05-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (127 commits) sh: update defconfigs. sh: Fix up the NUMA build for recent LMB changes. sh64: provide a stub per_cpu_trap_init() definition. sh: fix up CONFIG_KEXEC=n build. sh: fixup the docbook paths for clock framework shuffling. driver core: Early dev_name() depends on slab_is_available(). sh: simplify WARN usage in SH clock driver sh: Check return value of clk_get on ms7724 sh: Check return value of clk_get on ecovec24 sh: move sh clock-cpg.c contents to drivers/sh/clk-cpg.c sh: move sh clock.c contents to drivers/sh/clk. sh: move sh asm/clock.h contents to linux/sh_clk.h V2 sh: remove unused clock lookup sh: switch boards to clkdev sh: switch sh4-202 to clkdev sh: switch shx3 to clkdev sh: switch sh7757 to clkdev sh: switch sh7763 to clkdev sh: switch sh7780 to clkdev sh: switch sh7786 to clkdev ...
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-17Merge branch 'ioat' into dmaengineDan Williams
2010-05-17DMAENGINE: extend the control command to include an argLinus Walleij
This adds an argument to the DMAengine control function, so that we can later provide control commands that need some external data passed in through an argument akin to the ioctl() operation prototype. [dan.j.williams@intel.com: fix up some missed conversions] Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-17async_tx: trim dma_async_tx_descriptor in 'no channel switch' caseDan Williams
Saves 24 bytes per descriptor (64-bit) when the channel-switching capabilities of async_tx are not required. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-17DMAENGINE: DMA40 fix for allocation of logical channel 0Marcin Mielczarczyk
Fix for allocation failure of logical channel when event line happens to be number 0. Signed-off-by: Marcin Mielczarczyk <marcin.mielczarczyk@tieto.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-17DMAENGINE: DMA40 support paused channel statusJonas Aaberg
Support determining whether a channel is paused or not using the status function. Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-17dmaengine: mpc512x: Use resource_sizeTobias Klauser
Use the resource_size function instead of manually calculating the resource size. This reduces the chance of introducing off-by-one errors. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-17DMA ENGINE: Do not reset 'private' of channelJassi Brar
The member 'private' of 'struct dma_chan' is meant for passing data between client and the controller driver. The DMA client driver may point it to platform specific stuff after acquiring the channel. So, it is the responsiblity of the same code to reset it, if it must. The DMA engine doesn't set it and hence, shouldn't reset it either. This reseting of private by DMA Engine comes in the way of implementing default channel settings during DMAC probe. That capability is useful for not having the clients to always provide platform specific data, like Rx/Tx FIFO addresses, which usually doesn't change across channel requests. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-06Merge branch 'sh/for-2.6.34' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh/for-2.6.34' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: fix a number of Oopses and leaks in SH framebuffer driver SH: fix error paths in DMA driver sh: sh7751 pci controller io port fix sh: Fix maximum number of SCIF ports in R2D defconfigs SH: fix TS field shift calculation for DMA drivers
2010-05-02ioat: Remove duplicated devm_kzalloc() calls for ioatdma_deviceMinskey Guo
The memory for ioatdma_device structure is being allocated in alloc_ioatdma() Signed-off-by: Minskey Guo <chaohong_guo@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-01ioat3: disable cacheline-unaligned transfers for raid operationsDan Williams
There are cases where cacheline-unaligned raid operations can hang the dma channel. Simply disable these operations by increasing the alignment constraints published to async_tx. The raid456 driver always issues page aligned requests, so the only in-kernel user of the ioatdma driver that is affected by this change is dmatest. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-01ioat2,3: convert to producer/consumer lockingDan Williams
Use separate locks for the descriptor prep (producer) and descriptor cleanup (consumer) paths. Allows the producer path to run concurrently with the cleanup path. Inspired by Documentation/circular-buffer.txt. Cc: David Howells <dhowells@redhat.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-01ioat: convert to circ_bufDan Williams
Use the common power-of-2 circular buffer macros. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-04-30MIPS: TXx9: Add missing MODULE_ALIAS definitions for TXx9 platform devicesGeert Uytterhoeven
This enables autoloading of the TXx9 sound driver on RBTX4927. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> To: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Linux MIPS Mailing List <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1101/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-26Merge branch 'sh/stable-updates'Paul Mundt
Conflicts: arch/sh/kernel/dwarf.c drivers/dma/shdma.c Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-04-26SH: fix error paths in DMA driverGuennadi Liakhovetski
If channel allocation is failing, mark the channel unused and give PM a chance to power down the hardware. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-04-26SH: constify multiple DMA related objects and references to themGuennadi Liakhovetski
Lists of DMA channels and slaves are not changed, make them constant. Besides, SH7724 channel and slave configuration of both DMA controllers is identical, remove the extra copy of the configuration data. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-04-14DMAENGINE: Support for ST-Ericssons DMA40 block v3Linus Walleij
This is a straightforward driver for the ST-Ericsson DMA40 DMA controller found in U8500, implemented akin to the existing COH 901 318 driver. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidh Kasagar <srinidhi.kasagar@stericsson.com> Cc: STEricsson_nomadik_linux@list.st.com Cc: Alessandro Rubini <rubini@unipv.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29async_tx: use of kzalloc/kfree requires the include of slab.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-26dmaengine: provide helper for setting txstateDan Williams
Simple conditional struct filler to cut out some duplicated code. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-26DMAENGINE: generic channel status v2Linus Walleij
Convert the device_is_tx_complete() operation on the DMA engine to a generic device_tx_status()operation which can return three states, DMA_TX_RUNNING, DMA_TX_COMPLETE, DMA_TX_PAUSED. [dan.j.williams@intel.com: update for timberdale] Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Maciej Sosnowski <maciej.sosnowski@intel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Li Yang <leoli@freescale.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Magnus Damm <damm@opensource.se> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Joe Perches <joe@perches.com> Cc: Roland Dreier <rdreier@cisco.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-26DMAENGINE: generic slave control v2Linus Walleij
Convert the device_terminate_all() operation on the DMA engine to a generic device_control() operation which can now optionally support also pausing and resuming DMA on a certain channel. Implemented for the COH 901 318 DMAC as an example. [dan.j.williams@intel.com: update for timberdale] Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Maciej Sosnowski <maciej.sosnowski@intel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Li Yang <leoli@freescale.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Magnus Damm <damm@opensource.se> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Joe Perches <joe@perches.com> Cc: Roland Dreier <rdreier@cisco.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-26dma: timb-dma: Update comment and fix compiler warningRichard Röjfors
An incremental patch which clarifies what the spinlock is used for and fixes a compiler warning. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-25dma: Add timb-dmaRichard Röjfors
Adds the support for the DMA engine withing the timberdale FPGA. The DMA channels are strict device to host, or host to device and can not be used for generic memcpy. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-24DMAENGINE: COH 901 318 fix bytesleftLinus Walleij
This makes the function to get the number of bytes left in the ongoing DMA transaction actually work: the old code did not take neither lli:s nor queued jobs into account. Also fix a missing spinlock while we're at it. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-24DMAENGINE: COH 901 318 rename confusing varsLinus Walleij
This fixes up the code with a lot of comments that make it readable, rename things with opaque names like "data" into something more appropriate, and remove some very confusing BUG() statements. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-03-23dmaengine: shdma: Introduce include/linux/sh_dma.hMagnus Damm
Create a common platform data header file for the shdma dmaengine driver. This is done by moving common structures from sh asm/dmaengine.h to linux/sh_dma.h. DMA registers are also copied from sh asm/dma-register.h to make the code architecture independent. The sh header file asm/dmaengine.h is still kept with the slave id enum. This allows us to keep the old processor specific code as is and slowly move over to slave id enums in per-processor headers. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-23dmaengine: shdma: Common SH_DMA_SLAVE_NUMBERMagnus Damm
Move SHDMA_SLAVE_NUMBER from asm/dmaengine.h to shdma.h. Set it to 256 to support a wide range of processors. The amount of memory consumed by this change is limited to 256 bits. While at it, rename to SH_DMA_SLAVE_NUMBER to match with the rest of the file. Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-23dmaengine: shdma: Remove sh_dmae_slave_chan_id enumMagnus Damm
This patch replaces the sh_dmae_slave_chan_id enum with an unsigned int. The purpose of this chainge is to make it possible to separate the slave id enums from the dmaengine header. The slave id enums varies with processor model, so in the future it makes sense to put these in the processor specific headers together with the pinmux enums. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (26 commits) sh: Convert sh to use read/update_persistent_clock sh: Move PMB debugfs entry initialization to later stage sh: Fix up flush_cache_vmap() on SMP. sh: fix up MMU reset with variable PMB mapping sizes. sh: establish PMB mappings for NUMA nodes. sh: check for existing mappings for bolted PMB entries. sh: fixed virt/phys mapping helpers for PMB. sh: make pmb iomapping configurable. sh: reworked dynamic PMB mapping. sh: Fix up cpumask_of_pcibus() for the NUMA build. serial: sh-sci: Tidy up build warnings. sh: Fix up ctrl_read/write stragglers in migor setup. serial: sh-sci: Add DMA support. dmaengine: shdma: extend .device_terminate_all() to record partial transfer sh: merge sh7722 and sh7724 DMA register definitions sh: activate runtime PM for dmaengine on sh7722 and sh7724 dmaengine: shdma: add runtime PM support. dmaengine: shdma: separate DMA headers. dmaengine: shdma: convert to platform device resources dmaengine: shdma: fix DMA error handling. ...
2010-03-06bitops: rename for_each_bit() to for_each_set_bit()Akinobu Mita
Rename for_each_bit to for_each_set_bit in the kernel source tree. To permit for_each_clear_bit(), should that ever be added. The patch includes a macro to map the old for_each_bit() onto the new for_each_set_bit(). This is a (very) temporary thing to ease the migration. [akpm@linux-foundation.org: add temporary for_each_bit()] Suggested-by: Alexey Dobriyan <adobriyan@gmail.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (28 commits) ioat: cleanup ->timer_fn() and ->cleanup_fn() prototypes ioat3: interrupt coalescing ioat: close potential BUG_ON race in the descriptor cleanup path ioat2: kill pending flag ioat3: use ioat2_quiesce() ioat3: cleanup, don't enable DCA completion writes DMAENGINE: COH 901 318 lli sg offset fix DMAENGINE: COH 901 318 configure channel direction DMAENGINE: COH 901 318 remove irq counting DMAENGINE: COH 901 318 descriptor pool refactoring DMAENGINE: COH 901 318 cleanups dma: Add MPC512x DMA driver Debugging options for the DMA engine subsystem iop-adma: redundant/wrong tests in iop_*_count()? dmatest: fix handling of an even number of xor_sources dmatest: correct raid6 PQ test fsldma: Fix cookie issues fsldma: Fix cookie issues dma: cases IPU_PIX_FMT_BGRA32, BGR32 and ABGR32 are the same in ipu_ch_param_set_size() dma: make Open Firmware device id constant ...
2010-03-03Merge branch 'coh' into dmaengineDan Williams
