[ Upstream commit c4c2b7644cc9a41f17a8cc8904efe3f66ae4c7ed ]
The d->chans[] array has d->dma_requests elements so the > should be
>= here.
Fixes: 8e6152bc660e ("dmaengine: Add hisilicon k3 DMA engine driver")
Signed-off-by: Vinod Koul <vkoul@kernel.org>
[ Upstream commit e3f329c600033f011a978a8bc4ddb1e2e94c4f4d ]
The reported residue is already calculated in BURST unit granularity, so
advertise this capability properly to other devices in the system.
Fixes: aee4d1fac887 ("dmaengine: pl330: improve pl330_tx_status() function")
[ Upstream commit 48d163b1aa6e7f650c0b7a4f9c61c387a6def868 ]
When Linux is master of BAM, it can directly read registers to know number
of supported channels, however when its remotely controlled reading these
registers would trigger a crash if the BAM is not yet initialized or
powered up on the remote side.
This patch allows driver to read num-channels and num-ees from Device Tree
for remotely controlled BAM.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 3e081628d510b2ddbe493371d9c574d9275da17e ]
This patch fixes an issue that a race condition happens between a client
driver and the rcar-dmac driver:
- The rcar_dmac_isr_transfer_end() is called.
- The done list appears, and desc.running is the next active list.
- rcar_dmac_chan_get_residue() is called by a client driver before
rcar_dmac_isr_channel_thread() is called.
- The rcar_dmac_chan_get_residue() will not find any descriptors.
- And, the following WARNING happens:
WARN(1, "No descriptor for cookie!");
The sh-sci driver with HSCIF (921,600bps) on R-Car H3 can cause this
situation.
So, this patch checks the done lists in rcar_dmac_chan_get_residue()
and returns zero if the done lists has the argument cookie.
Tested-by: Nguyen Viet Dung <dung.nguyen.aj@renesas.com>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
[ Upstream commit a3ca831249ca8c4c226e4ceafee04e280152e59d ]
When booting up with "threadirqs" in command line, all irq handlers of the DMA
controller pl330 will be threaded forcedly. These threads will race for the same
list, pl330->req_done.
Before the callback, the spinlock was released. And after it, the spinlock was
taken. This opened an race window where another threaded irq handler could steal
the spinlock and be permitted to delete entries of the list, pl330->req_done.
If the later deleted an entry that was still referred to by the former, there would
be a kernel panic when the former was scheduled and tried to get the next sibling
of the deleted entry.
The scenario could be depicted as below:
Thread: T1 pl330->req_done Thread: T2
| -A-B-C-D- |
Locked | |
| | Waiting
Del A | |
| -B-C-D- |
Unlocked | |
| | Locked
Waiting | |
| | Del B
| -C-D- Unlocked
Waiting | |
Locked
get C via B
- Kernel panic
The kernel panic looked like as below:
Unable to handle kernel paging request at virtual address dead000000000108
pgd = ffffff8008c9e000
[dead000000000108] *pgd=000000027fffe003, *pud=000000027fffe003, *pmd=0000000000000000
Internal error: Oops: 96000044 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 85 Comm: irq/59-66330000 Not tainted 4.8.24-WR9.0.0.12_standard #2
Hardware name: Broadcom NS2 SVK (DT)
task: ffffffc1f5cc3c00 task.stack: ffffffc1f5ce0000
PC is at pl330_irq_handler+0x27c/0x390
LR is at pl330_irq_handler+0x2a8/0x390
pc : [<ffffff80084cb694>] lr : [<ffffff80084cb6c0>] pstate: 800001c5
sp : ffffffc1f5ce3d00
x29: ffffffc1f5ce3d00 x28: 0000000000000140
x27: ffffffc1f5c530b0 x26: dead000000000100
x25: dead000000000200 x24: 0000000000418958
x23: 0000000000000001 x22: ffffffc1f5ccd668
x21: ffffffc1f5ccd590 x20: ffffffc1f5ccd418
x19: dead000000000060 x18: 0000000000000001
x17: 0000000000000007 x16: 0000000000000001
x15: ffffffffffffffff x14: ffffffffffffffff
x13: ffffffffffffffff x12: 0000000000000000
x11: 0000000000000001 x10: 0000000000000840
x9 : ffffffc1f5ce0000 x8 : ffffffc1f5cc3338
x7 : ffffff8008ce2020 x6 : 0000000000000000
x5 : 0000000000000000 x4 : 0000000000000001
x3 : dead000000000200 x2 : dead000000000100
x1 : 0000000000000140 x0 : ffffffc1f5ccd590
Process irq/59-66330000 (pid: 85, stack limit = 0xffffffc1f5ce0020)
Stack: (0xffffffc1f5ce3d00 to 0xffffffc1f5ce4000)
3d00: ffffffc1f5ce3d80 ffffff80080f09d0 ffffffc1f5ca0c00 ffffffc1f6f7c600
3d20: ffffffc1f5ce0000 ffffffc1f6f7c600 ffffffc1f5ca0c00 ffffff80080f0998
3d40: ffffffc1f5ce0000 ffffff80080f0000 0000000000000000 0000000000000000
3d60: ffffff8008ce202c ffffff8008ce2020 ffffffc1f5ccd668 ffffffc1f5c530b0
3d80: ffffffc1f5ce3db0 ffffff80080f0d70 ffffffc1f5ca0c40 0000000000000001
3da0: ffffffc1f5ce0000 ffffff80080f0cfc ffffffc1f5ce3e20 ffffff80080bf4f8
3dc0: ffffffc1f5ca0c80 ffffff8008bf3798 ffffff8008955528 ffffffc1f5ca0c00
3de0: ffffff80080f0c30 0000000000000000 0000000000000000 0000000000000000
3e00: 0000000000000000 0000000000000000 0000000000000000 ffffff80080f0b68
3e20: 0000000000000000 ffffff8008083690 ffffff80080bf420 ffffffc1f5ca0c80
3e40: 0000000000000000 0000000000000000 0000000000000000 ffffff80080cb648
3e60: ffffff8008b1c780 0000000000000000 0000000000000000 ffffffc1f5ca0c00
3e80: ffffffc100000000 ffffff8000000000 ffffffc1f5ce3e90 ffffffc1f5ce3e90
3ea0: 0000000000000000 ffffff8000000000 ffffffc1f5ce3eb0 ffffffc1f5ce3eb0
3ec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3ee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3fa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3fc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
3fe0: 0000000000000000 0000000000000000 0000000275ce3ff0 0000000275ce3ff8
Call trace:
Exception stack(0xffffffc1f5ce3b30 to 0xffffffc1f5ce3c60)
3b20: dead000000000060 0000008000000000
3b40: ffffffc1f5ce3d00 ffffff80084cb694 0000000000000008 0000000000000e88
3b60: ffffffc1f5ce3bb0 ffffff80080dac68 ffffffc1f5ce3b90 ffffff8008826fe4
3b80: 00000000000001c0 00000000000001c0 ffffffc1f5ce3bb0 ffffff800848dfcc
3ba0: 0000000000020000 ffffff8008b15ae4 ffffffc1f5ce3c00 ffffff800808f000
3bc0: 0000000000000010 ffffff80088377f0 ffffffc1f5ccd590 0000000000000140
3be0: dead000000000100 dead000000000200 0000000000000001 0000000000000000
3c00: 0000000000000000 ffffff8008ce2020 ffffffc1f5cc3338 ffffffc1f5ce0000
3c20: 0000000000000840 0000000000000001 0000000000000000 ffffffffffffffff
3c40: ffffffffffffffff ffffffffffffffff 0000000000000001 0000000000000007
[<ffffff80084cb694>] pl330_irq_handler+0x27c/0x390
[<ffffff80080f09d0>] irq_forced_thread_fn+0x38/0x88
[<ffffff80080f0d70>] irq_thread+0x140/0x200
[<ffffff80080bf4f8>] kthread+0xd8/0xf0
[<ffffff8008083690>] ret_from_fork+0x10/0x40
Code: f2a00838 f9405763 aa1c03e1 aa1503e0 (f9000443)
---[ end trace f50005726d31199c ]---
Kernel panic - not syncing: Fatal exception in interrupt
SMP: stopping secondary CPUs
SMP: failed to stop secondary CPUs 0-1
Kernel Offset: disabled
Memory Limit: none
---[ end Kernel panic - not syncing: Fatal exception in interrupt
To fix this, re-start with the list-head after dropping the lock then
re-takeing it.
Reviewed-by: Frank Mori Hess <fmh6jj@gmail.com>
Tested-by: Frank Mori Hess <fmh6jj@gmail.com>
Signed-off-by: Qi Hou <qi.hou@windriver.com>
[ Upstream commit 3cd2c313f1d618f92d1294addc6c685c17065761 ]
On the CP110 components which are present on the Armada 7K/8K SoC we need
to explicitly enable the clock for the registers. However it is not
needed for the AP8xx component, that's why this clock is optional.
With this patch both clock have now a name, but in order to be backward
compatible, the name of the first clock is not used. It allows to still
use this clock with a device tree using the old binding.
Reviewed-by: Rob Herring <robh@kernel.org>
[ Upstream commit d716d9b702bb759dd6fb50804f10a174bd156d71 ]
According to R-Car Gen3 Rev.0.80 manual, the DMATCR can be set to
16,777,215 as maximum. So, this patch fixes the max_chunk_size for
safety on all of SoCs. Otherwise, a system may hang if the DMATCR
is set to 0 on R-Car Gen3.
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
commit c5637476bbf9bb86c7f0413b8f4822a73d8d2d07 upstream.
Despite the efforts made to correctly read the NDA and CUBC registers,
the order in which the registers are read could sometimes lead to an
inconsistent state.
Re-using the timeline from the comments, this following timing of
registers reads could lead to reading NDA with value "@desc2" and
CUBC with value "MAX desc1":
INITD -------- ------------
|____________________|
_______________________ _______________
NDA @desc2 \/ @desc3
_______________________/\_______________
__________ ___________ _______________
CUBC 0 \/ MAX desc1 \/ MAX desc2
__________/\___________/\_______________
Events:(1)(2) (3)(4)
(1) check_nda = @desc2
(2) initd = 1
(3) cur_ubc = MAX desc1
(4) cur_nda = @desc2
This is allowed by the condition ((check_nda == cur_nda) && initd),
despite cur_ubc and cur_nda being in the precise state we don't want.
This error leads to incorrect residue computation.
Fix it by inversing the order in which CUBC and INITD are read. This
makes sure that NDA and CUBC are always read together either _before_
INITD goes to 0 or _after_ it is back at 1.
The case where NDA is read before INITD is at 0 and CUBC is read after
INITD is back at 1 will be rejected by check_nda and cur_nda being
different.
Fixes: 53398f488821 ("dmaengine: at_xdmac: fix residue corruption")
Cc: stable@vger.kernel.org
Signed-off-by: Maxime Jayat <maxime.jayat@mobile-devices.fr>
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
[ Upstream commit fb9caf370f4d0457789d13a1a1b110a8db846e5e ]
clk_prepare_enable() can fail here and we must check its return value.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
[ Upstream commit d087f15786021a9605b20f4c678312510be4cac1 ]
Register layout of a typical TPCC_EVT_MUX_M_N register is such that the
lowest numbered event is at the lowest byte address and highest numbered
event at highest byte address. But TPCC_EVT_MUX_60_63 register layout is
different, in that the lowest numbered event is at the highest address
and highest numbered event is at the lowest address. Therefore, modify
ti_am335x_xbar_write() to handle TPCC_EVT_MUX_60_63 register
accordingly.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
[ Upstream commit 5ba080aada5e739165e0f38d5cc3b04c82b323c8 ]
Incase of interrupt property is not present,
Driver is trying to free an invalid irq,
This patch fixes it by adding a check before freeing the irq.
Signed-off-by: Kedareswara rao Appana <appanad@xilinx.com>
[ Upstream commit 7f3ff14b7eb1ffad132117f08a1973b48e653d43 ]
sdma_disable_channel() cannot ensure dma is stopped to access
module's FIFOs. There is chance SDMA core is running and accessing
BD when disable of corresponding channel, this may cause sometimes
even after call of .sdma_disable_channel(), SDMA core still be
running and accessing module's FIFOs.
According to NXP R&D team a delay of one BD SDMA cost time (maximum
is 1ms) should be added after disable of the channel bit, to ensure
SDMA core has really been stopped after SDMA clients call
.device_terminate_all.
This patch introduces adds a new function sdma_disable_channel_with_delay()
which simply adds 1ms delay after call sdma_disable_channel(),
and set it as .device_terminate_all.
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
[ Upstream commit 2610acf46b9ed528ec2cacd717bc9d354e452b73 ]
Previously enabled clks are only disabled if clk_prepare_enable() fails.
However, there are other error paths were the previously enabled
clocks are not disabled.
To fix the problem, fsl_disable_clocks() now takes the number of clocks
that shall be disabled + unprepared. For existing calls were all clocks
were already successfully prepared + enabled, DMAMUX_NR is passed to
disable + unprepare all clocks.
In error paths were only some clocks were successfully prepared +
enabled the loop counter is passed, in order to disable + unprepare
all successfully prepared + enabled clocks.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Andreas Platschek <andreas.platschek@opentech.at>
commit 067fdeb2f391bfa071f741a2b3eb74b8ff3785cd upstream.
Fix build warning that related to PAGE_SIZE. The maximum DMA
length has nothing to do with PAGE_SIZE, just use a fix number
for the definition.
drivers/dma/zx_dma.c: In function 'zx_dma_prep_memcpy':
drivers/dma/zx_dma.c:523:8: warning: division by zero [-Wdiv-by-zero]
drivers/dma/zx_dma.c: In function 'zx_dma_prep_slave_sg':
drivers/dma/zx_dma.c:567:11: warning: division by zero [-Wdiv-by-zero]
Signed-off-by: Jun Nie <jun.nie@linaro.org>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
[ Upstream commit eb9436966fdc84cebdf222952a99898ab46d9bb0 ]
in error path of jz4740_dma_probe(), call clk_disable_unprepare() to clean
up.
Fixes: 25ce6c35fea0 MIPS: jz4740: Remove custom DMA API
Signed-off-by: Tobias Jordan <Tobias.Jordan@elektrobit.com>
atc_prep_dma_interleaved
[ Upstream commit 62a277d43d47e74972de44d33bd3763e31992414 ]
_xt_ is being dereferenced before it is null checked, hence there is a
potential null pointer dereference.
Fix this by moving the pointer dereference after _xt_ has been null
checked.
This issue was detected with the help of Coccinelle.
Fixes: 4483320e241c ("dmaengine: Use Pointer xt after NULL check.")
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
[ Upstream commit 5c9afbda911ce20b3f2181d1e440a0222e1027dd ]
If the last test in 'ioat_dma_self_test()' fails, we must release all
the allocated resources and not just part of them.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Dave Jiang <dave.jiang@intel.com>
commit 66b3bd2356e0a1531c71a3dcf96944621e25c17c upstream.
The type of arg passed to dmatest_callback is struct dmatest_done.
It refers to test_done in struct dmatest_thread, not done_wait.
Fixes: 6f6a23a213be ("dmaengine: dmatest: move callback wait ...")
Signed-off-by: Yang Shunyong <shunyong.yang@hxt-semitech.com>
Acked-by: Adam Wallis <awallis@codeaurora.org>
[ Upstream commit 288e7560e4d3e259aa28f8f58a8dfe63627a1bf6 ]
The used 0x1f mask is only valid for am335x family of SoC, different family
using this type of crossbar might have different number of electable
events. In case of am43xx family 0x3f mask should have been used for
example.
Instead of trying to handle each family's mask, just use u8 type to store
the mux value since the event offsets are aligned to byte offset.
Fixes: 42dbdcc6bf965 ("dmaengine: ti-dma-crossbar: Add support for crossbar on AM33xx/AM43xx")
[ Upstream commit 23f963e91fd81f44f6b316b1c24db563354c6be8 ]
This fixes the following warning when building with clang and
CONFIG_DMA_ENGINE_RAID=n :
drivers/dma/dmaengine.c:1102:11: error: array index 2 is past the end of the array (which contains 1 element) [-Werror,-Warray-bounds]
return &unmap_pool[2];
drivers/dma/dmaengine.c:1083:1: note: array 'unmap_pool' declared here
static struct dmaengine_unmap_pool unmap_pool[] = {
drivers/dma/dmaengine.c:1104:11: error: array index 3 is past the end of the array (which contains 1 element) [-Werror,-Warray-bounds]
return &unmap_pool[3];
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
commit 6f6a23a213be51728502b88741ba6a10cda2441d upstream.
Commit adfa543e7314 ("dmatest: don't use set_freezable_with_signal()")
introduced a bug (that is in fact documented by the patch commit text)
that leaves behind a dangling pointer. Since the done_wait structure is
allocated on the stack, future invocations to the DMATEST can produce
undesirable results (e.g., corrupted spinlocks).
Commit a9df21e34b42 ("dmaengine: dmatest: warn user when dma test times
out") attempted to WARN the user that the stack was likely corrupted but
did not fix the actual issue.
This patch fixes the issue by pushing the wait queue and callback
structs into the the thread structure. If a failure occurs due to time,
dmaengine_terminate_all will force the callback to safely call
wake_up_all() without possibility of using a freed pointer.
Bug: https://bugzilla.kernel.org/show_bug.cgi?id=197605
Fixes: adfa543e7314 ("dmatest: don't use set_freezable_with_signal()")
Reviewed-by: Sinan Kaya <okaya@codeaurora.org>
Suggested-by: Shunyong Yang <shunyong.yang@hxt-semitech.com>
Signed-off-by: Adam Wallis <awallis@codeaurora.org>
[ Upstream commit 91539eb1fda2d530d3b268eef542c5414e54bf1a ]
The static bug finder EBA (http://www.iagoabal.eu/eba/) reported the
following double-lock bug:
Double lock:
1. spin_lock_irqsave(pch->lock, flags) at pl330_free_chan_resources:2236;
2. call to function `pl330_release_channel' immediately after;
3. call to function `dma_pl330_rqcb' in line 1753;
4. spin_lock_irqsave(pch->lock, flags) at dma_pl330_rqcb:1505.
I have fixed it as suggested by Marek Szyprowski.
First, I have replaced `pch->lock' with `pl330->lock' in functions
`pl330_alloc_chan_resources' and `pl330_free_chan_resources'. This avoids
the double-lock by acquiring a different lock than `dma_pl330_rqcb'.
NOTE that, as a result, `pl330_free_chan_resources' executes
`list_splice_tail_init' on `pch->work_list' under lock `pl330->lock',
whereas in the rest of the code `pch->work_list' is protected by
`pch->lock'. I don't know if this may cause race conditions. Similarly
`pch->cyclic' is written by `pl330_alloc_chan_resources' under
`pl330->lock' but read by `pl330_tx_submit' under `pch->lock'.
Second, I have removed locking from `pl330_request_channel' and
`pl330_release_channel' functions. Function `pl330_request_channel' is
only called from `pl330_alloc_chan_resources', so the lock is already
held. Function `pl330_release_channel' is called from
`pl330_free_chan_resources', which already holds the lock, and from
`pl330_del'. Function `pl330_del' is called in an error path of
`pl330_probe' and at the end of `pl330_remove', but I assume that there
cannot be concurrent accesses to the protected data at those points.
Signed-off-by: Iago Abal <mail@iagoabal.eu>
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com>
[ Upstream commit 57b5a32135c813f2ab669039fb4ec16b30cb3305 ]
chan->desc is always set to NULL when a DMA transfer is complete.
As a DMA transfer could be complete during the call of stm32_dma_tx_status,
we need to be sure that chan->desc is not NULL before using this variable
to avoid a null pointer deference issue.
Signed-off-by: M'boumba Cedric Madianga <cedric.madianga@gmail.com>
Reviewed-by: Ludovic BARRE <ludovic.barre@st.com>
Acked-by: Pierre-Yves MORDRET <pierre-yves.mordret@st.com>
[ Upstream commit 7e96304d99477de1f70db42035071e56439da817 ]
This patch sets the right number of arguments to be used for DMA clients
which request channels from DT.
[ Upstream commit fc318d64f3d91e15babac00e08354b1beb650b57 ]
The zx_dma driver supports cyclic transfer mode. Let's set DMA_CYCLIC
cap_mask bit to make that clear, and avoid unnecessary failure when
clients request channel via dma_request_chan_by_mask() with DMA_CYCLIC
bit set in mask.
Reviewed-by: Jun Nie <jun.nie@linaro.org>
commit a9df21e34b422f79d9a9fa5c3eff8c2a53491be6 upstream.
undesirable results (e.g., corrupted spinlocks). Ideally, this would be
cleaned up in the thread handler, but at the very least, the kernel
is left in a very precarious scenario that can lead to some long debug
sessions when the crash comes later.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=197605
commit 2ccb4837c938357233a0b8818e3ca3e58242c952 upstream.
When looking for unused xbar_out lane we should also protect the set_bit()
call with the same mutex to protect against concurrent threads picking the
same ID.
Fixes: ec9bfa1e1a796 ("dmaengine: ti-dma-crossbar: dra7: Use bitops instead of idr")
commit 87a2f622cc6446c7d09ac655b7b9b04886f16a4c upstream.
Memory to Memory transfers does not have any special alignment needs
regarding to acnt array size, but if one of the areas are in memory mapped
regions (like PCIe memory), we need to make sure that the acnt array size
is aligned with the mem copy parameters.
Before "dmaengine: edma: Optimize memcpy operation" change the memcpy was set
up in a different way: acnt == number of bytes in a word based on
__ffs((src | dest | len), bcnt and ccnt for looping the necessary number of
words to comlete the trasnfer.
Instead of reverting the commit we can fix it to make sure that the ACNT size
is aligned to the traswnfer.
Fixes: df6694f80365a (dmaengine: edma: Optimize memcpy operation)
[ Upstream commit 75bdc7f31a3a6e9a12e218b31a44a1f54a91554c ]
Add some missing 'of_node_put()' in early exit error path.
[ Upstream commit 34a31f0af84158955a9747fb5c6712da5bbb5331 ]
The Skylake ioatdma is technically CBDMA 3.2+ and contains the same hardware
bits with some additional 3.3 features, but it's not really 3.3 where the
driver is concerned.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
[ Upstream commit 1594c18fd297a8edcc72bc4b161f3f52603ebb92 ]
Adding Skylake Xeon PCI device ids for ioatdma and related bits.
commit 2201ac6129fa162ac24da089a034bb0971648ebb upstream.
The code responsible for splitting periods into chunks that
can be handled by the DMA controller missed to update total_len,
the number of bytes processed in the current period, when there
are more chunks to follow.
Therefore total_len was stuck at 0 and the code didn't work at all.
This resulted in a wrong control block layout and audio issues because
the cyclic DMA callback wasn't executing on period boundaries.
Fix this by adding the missing total_len update.
Signed-off-by: Matthias Reichl <hias@horus.com>
Signed-off-by: Martin Sperl <kernel@martin.sperl.org>
Tested-by: Clive Messer <clive.messer@digitaldreamtime.co.uk>
Reviewed-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit b2d3c270f9f2fb82518ac500a9849c3aaf503852 upstream.
The XORv2 engine on Armada 7K/8K can only access the first 40 bits of
the physical address space, so the DMA mask must be set accordingly.
Fixes: 19a340b1a820 ("dmaengine: mv_xor_v2: new driver")
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
commit 9dd4f319bac25334a869d9276b19eac9e478fd33 upstream.
The current implementation of interrupt coalescing doesn't work, because
it doesn't configure the coalescing timer, which is needed to make sure
we get an interrupt at some point.
As a fix for stable, we simply remove the interrupt coalescing
functionality. It will be re-introduced properly in a future commit.
commit 44d5887a8bf1e86915c8ff647337cb138149da82 upstream.
The mv_xor_v2_tx_submit() gets the next available HW descriptor by
calling mv_xor_v2_get_desq_write_ptr(), which reads a HW register
telling the next available HW descriptor. This was working fine when HW
descriptors were issued for processing directly in tx_submit().
However, as part of the review process of the driver, a change was
requested to move the actual kick-off of HW descriptors processing to
->issue_pending(). Due to this, reading the HW register to know the next
available HW descriptor no longer works.
So instead of using this HW register, we implemented a software index
pointing to the next available HW descriptor.
commit ab2c5f0a77fe49bdb6e307b397496373cb47d2c2 upstream.
The engine was enabled prior to its configuration, which isn't
correct. This patch relocates the activation of the XOR engine, to be
after the configuration of the XOR engine.
Signed-off-by: Hanna Hawa <hannah@marvell.com>
commit bc473da1ed726c975ad47f8d7d27631de11356d8 upstream.
Descriptors that have not been acknowledged by the async_tx layer
should not be re-used, so this commit adjusts the implementation of
mv_xor_v2_prep_sw_desc() to skip descriptors for which
async_tx_test_ack() is false.
commit 2aab4e18152cd30cb5d2f4c27629fc8a04aed979 upstream.
mv_xor_v2_tasklet() is looping over completed HW descriptors. Before the
loop, it initializes 'next_pending_hw_desc' to the first HW descriptor
to handle, and then the loop simply increments this point, without
taking care of wrapping when we reach the last HW descriptor. The
'pending_ptr' index was being wrapped back to 0 at the end, but it
wasn't used in each iteration of the loop to calculate
next_pending_hw_desc.
This commit fixes that, and makes next_pending_hw_desc a variable local
to the loop itself.
commit eb8df543e444492328f506adffc7dfe94111f1bd upstream.
The mv_xor_v2_prep_sw_desc() is called from a few different places in
the driver, but we never take into account the fact that it might
return NULL. This commit fixes that, ensuring that we don't panic if
there are no more descriptors available.
commit 98f9de366fccee7572c646af226b2d4b4841e3b5 upstream.
Draining the transfers in terminate_all callback happens with IRQs disabled,
therefore induces huge latency:
irqsoff latency trace v1.1.5 on 4.11.0
latency: 39770 us, #57/57, CPU#0 | (M:preempt VP:0, KP:0, SP:0 HP:0)
| task: process-129 (uid:0 nice:0 policy:2 rt_prio:50)
=> started at: _snd_pcm_stream_lock_irqsave
=> ended at: snd_pcm_stream_unlock_irqrestore
_------=> CPU#
/ _-----=> irqs-off
| / _----=> need-resched
|| / _---=> hardirq/softirq
||| / _--=> preempt-depth
|||| / delay
cmd pid ||||| time | caller
process-129 0d.s. 3us : _snd_pcm_stream_lock_irqsave
process-129 0d.s1 9us : snd_pcm_stream_lock <-_snd_pcm_stream_lock_irqsave
process-129 0d.s1 15us : preempt_count_add <-snd_pcm_stream_lock
process-129 0d.s2 22us : preempt_count_add <-snd_pcm_stream_lock
process-129 0d.s3 32us : snd_pcm_update_hw_ptr0 <-snd_pcm_period_elapsed
process-129 0d.s3 41us : soc_pcm_pointer <-snd_pcm_update_hw_ptr0
process-129 0d.s3 50us : dmaengine_pcm_pointer <-soc_pcm_pointer
process-129 0d.s3 58us+: snd_dmaengine_pcm_pointer_no_residue <-dmaengine_pcm_pointer
process-129 0d.s3 96us : update_audio_tstamp <-snd_pcm_update_hw_ptr0
process-129 0d.s3 103us : snd_pcm_update_state <-snd_pcm_update_hw_ptr0
process-129 0d.s3 112us : xrun <-snd_pcm_update_state
process-129 0d.s3 119us : snd_pcm_stop <-xrun
process-129 0d.s3 126us : snd_pcm_action <-snd_pcm_stop
process-129 0d.s3 134us : snd_pcm_action_single <-snd_pcm_action
process-129 0d.s3 141us : snd_pcm_pre_stop <-snd_pcm_action_single
process-129 0d.s3 150us : snd_pcm_do_stop <-snd_pcm_action_single
process-129 0d.s3 157us : soc_pcm_trigger <-snd_pcm_do_stop
process-129 0d.s3 166us : snd_dmaengine_pcm_trigger <-soc_pcm_trigger
process-129 0d.s3 175us : ep93xx_dma_terminate_all <-snd_dmaengine_pcm_trigger
process-129 0d.s3 182us : preempt_count_add <-ep93xx_dma_terminate_all
process-129 0d.s4 189us*: m2p_hw_shutdown <-ep93xx_dma_terminate_all
process-129 0d.s4 39472us : m2p_hw_setup <-ep93xx_dma_terminate_all
... rest skipped...
process-129 0d.s. 40080us : <stack trace>
=> ep93xx_dma_tasklet
=> tasklet_action
=> __do_softirq
=> irq_exit
=> __handle_domain_irq
=> vic_handle_irq
=> __irq_usr
=> 0xb66c6668
Just abort the transfers and warn if the HW state is not what we expect.
Move draining into device_synchronize callback.
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
commit 0037ae47812b1f431cc602100d1d51f37d77b61e upstream.
The current buffer is being reset to zero on device_free_chan_resources()
but not on device_terminate_all(). It could happen that HW is restarted and
expects BASE0 to be used, but the driver is not synchronized and will start
from BASE1. One solution is to reset the buffer explicitly in
m2p_hw_setup().
commit 9a445bbb1607d9f14556a532453dd86d1b7e381e upstream.
This patch fixes the register definition of AE (Address Error flag) bit.
Fixes: 0c1c8ff32fa2 ("dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver")
Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
[Shimoda: add Fixes and Cc tags in the commit log]
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
allocations.
commit 21d25f6a4217e755906cb548b55ddab39d0e88b9 upstream.
On a kernel with DEBUG_LOCKS, ioat_free_chan_resources triggers an
in_interrupt() warning. With PROVE_LOCKING, it reports detecting a
SOFTIRQ-safe to SOFTIRQ-unsafe lock ordering in the same code path.
This is because dma_generic_alloc_coherent() checks if the GFP flags
permit blocking. It allocates from different subsystems if blocking is
permitted. The free path knows how to return the memory to the correct
allocator. If GFP_KERNEL is specified then the alloc and free end up
going through cma_alloc(), which uses mutexes.
Given that ioat_free_chan_resources() can be called in interrupt
context, ioat_alloc_chan_resources() must specify GFP_NOWAIT so that the
allocations do not block and instead use an allocator that uses
spinlocks.
Signed-off-by: Krister Johansen <kjlx@templeofstupid.com>
commit 85f57752b33cf12f1d583f0c10b752292de00abe upstream.
The residue calculation was taking in consideration that dma
transaction status will be always retrieved in the dma callback
used to inform that dma transfer is complete. However this is not
the case for all subsystems that use dma. Some subsystems use a
timer to check the dma status periodically.
Therefore the calculation was updated and residue is calculated
accordingly by a) update the residue calculation taking in
consideration the last used buffer index by using *buf_ptail* variable
and b) chn_real_count (number of bytes transferred) is initialized to
zero, when dma channel is created, to avoid using an uninitialized
value in residue calculation when dma status is checked without
waiting dma complete event.
Signed-off-by: Nandor Han <nandor.han@ge.com>
Acked-by: Peter Senna Tschudin <peter.senna@collabora.com>
Tested-by: Peter Senna Tschudin <peter.senna@collabora.com>
Tested-by: Marek Vasut <marex@denx.de>
Cc: Fabio Estevam <festevam@gmail.com>
commit adee40b265d7568296e218f079f478197ffa15bf upstream.
Commit 3d8cc00073d6 ("dmaengine: ipu: Consolidate duplicated irq handlers")
consolidated the two interrupts routines into one, but the remaining
interrupt routine only checks the status of the error interrupts, not the
normal interrupts.
This patch fixes that problem (tested on i.MX31 PDK board).
Fixes: 3d8cc00073d6 ("dmaengine: ipu: Consolidate duplicated irq handlers")
Cc: Vinod Koul <vinod.koul@intel.com>
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
commit 362f4562466c3b9490e733e06999025638310d4a upstream.
Commit fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support")
together with recent MUSB changes allowed USB and DMA on BeagleBone to idle
when no cable is connected. But looks like few corner case issues still
remain.
Looks like just by re-plugging USB cable about ten or so times on BeagleBone
when configured in USB peripheral mode we can get warnings and eventually
trigger an oops in cppi41 DMA:
WARNING: CPU: 0 PID: 14 at drivers/dma/cppi41.c:1154 cppi41_runtime_suspend+
x28/0x38 [cppi41]
WARNING: CPU: 0 PID: 14 at drivers/dma/cppi41.c:452
push_desc_queue+0x94/0x9c [cppi41]
Unable to handle kernel NULL pointer dereference at virtual
address 00000104
pgd = c0004000
[00000104] *pgd=00000000
Internal error: Oops: 805 [#1] SMP ARM
[<bf0d92cc>] (cppi41_runtime_resume [cppi41]) from [<c0589838>]
(__rpm_callback+0xc0/0x214)
[<c0589838>] (__rpm_callback) from [<c05899ac>] (rpm_callback+0x20/0x80)
[<c05899ac>] (rpm_callback) from [<c0589460>] (rpm_resume+0x504/0x78c)
[<c0589460>] (rpm_resume) from [<c058a1a0>] (pm_runtime_work+0x60/0xa8)
[<c058a1a0>] (pm_runtime_work) from [<c0156120>] (process_one_work+0x2b4/0x808)
This is because of a race with runtime PM and cppi41_dma_issue_pending()
as reported by Alexandre Bailon <abailon@baylibre.com> in earlier
set of patches. Based on mailing list discussions we however came to the
conclusion that a different fix from Alexandre's fix is needed in order
to guarantee that DMA is really active when we try to use it.
To fix the issue, we need to add a driver specific flag as we otherwise
can have -EINPROGRESS state set by runtime PM and can't rely on
pm_runtime_active() to tell us when we can use the DMA.
And we need to make sure the DMA transfers get triggered in the queued
order. So let's always queue the transfers, then flush the queue
from both cppi41_dma_issue_pending() and cppi41_runtime_resume()
as suggested by Grygorii Strashko <grygorii.strashko@ti.com> in an
earlier example patch.
For reference, this is also documented in Documentation/power/runtime_pm.txt
in the example at the end of the file as pointed out by Grygorii Strashko
<grygorii.strashko@ti.com>.
Based on earlier patches from Alexandre Bailon <abailon@baylibre.com>
and Grygorii Strashko <grygorii.strashko@ti.com> modified based on
testing and what was discussed on the mailing lists.
Fixes: fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support")
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Bin Liu <b-liu@ti.com>
Cc: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Kevin Hilman <khilman@baylibre.com>
Cc: Patrick Titiano <ptitiano@baylibre.com>
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Reported-by: Alexandre Bailon <abailon@baylibre.com>
Tested-by: Bin Liu <b-liu@ti.com>
commit ae4a3e028bb8b59e7cfeb0cc9ef03d885182ce8b upstream.
added runtime PM support for cppi41, but had corner case issues. Some of
the issues were fixed with commit 098de42ad670 ("dmaengine: cppi41: Fix
unpaired pm runtime when only a USB hub is connected"). That fix however
caused a new regression where we can get error -115 messages with USB on
BeagleBone when connecting a USB mass storage device to a hub.
This is because when connecting a USB mass storage device to a hub, the
initial DMA transfers can take over 200ms to complete and cppi41
autosuspend delay times out.
To fix the issue, we want to implement refcounting for chan_busy array
that contains the active dma transfers. Increasing the autosuspend delay
won't help as that the delay could be potentially seconds, and it's best
to let the USB subsystem to deal with the timeouts on errors.
The earlier attempt for runtime PM was buggy as the pm_runtime_get/put()
calls could get unpaired easily as they did not follow the state of
the chan_busy array as described in commit 098de42ad670 ("dmaengine:
cppi41: Fix unpaired pm runtime when only a USB hub is connected".
Let's fix the issue by adding pm_runtime_get() to where a new transfer
is added to the chan_busy array, and calls to pm_runtime_put() where
chan_busy array entry is cleared. This prevents any autosuspend timeouts
from happening while dma transfers are active.
Fixes: 098de42ad670 ("dmaengine: cppi41: Fix unpaired pm runtime when
commit 5c9e6c2b2ba3ec3a442e2fb5b4286498f8b4dcb7 upstream.
PL330 DMA engine driver is leaking a runtime reference after any terminated
DMA transactions. This patch fixes this issue by tracking runtime PM state
of the device and making additional call to pm_runtime_put() in terminate_all
callback if needed.
Fixes: ae43b3289186 ("ARM: 8202/1: dmaengine: pl330: Add runtime Power Management support v12")
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
commit 3139dc8ded6f27552a248d23fe9f086e3027fa12 upstream.
The slave mapping should be removed together with other channel
resources when the channel is freed. If it's not unmapped it will hang
around forever after the channel is freed.
Fixes: 9f878603dbdb7db3 ("dmaengine: rcar-dmac: add iommu support for slave transfers")
Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit 836c3ce2566fb8c1754f8d7c9534cad9bc8a6879 upstream.
The original patch did not done what it was supposed to be doing and even
worst it broke legacy boot (OMAP1).
The lch_map size should be the number of available logical channels in sDMA
and the od->dma_requests should store the number of available DMA request
lines usable in sDMA.
In legacy mode we do not have a way to get the DMA request count, in that
case we use OMAP_SDMA_REQUESTS (127), despite the fact that OMAP1510 have
only 31 DMA request line.
Fixes: 2d1a9a946fae ("dmaengine: omap-dma: Dynamically allocate memory for lch_map")
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
