path: root/drivers/edac/amd76x_edac.c
2006-03-26[PATCH] EDAC: formatting cleanupDave Peterson
Cosmetic indentation/formatting cleanup for EDAC code. Make sure we are using tabs rather than spaces to indent, etc. Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: protect memory controller listDave Peterson
- Fix code so we always hold mem_ctls_mutex while we are stepping through the list of mem_ctl_info structures. Otherwise bad things may happen if one task is stepping through the list while another task is modifying it. We may eventually want to use reference counting to manage the mem_ctl_info structures. In the meantime we may as well fix this bug. - Don't disable interrupts while we are walking the list of mem_ctl_info structures in check_mc_devices(). This is unnecessary. Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: cleanup code for clearing initial errorsDave Peterson
Fix xxx_probe1() functions so they call xxx_get_error_info() functions to clear initial errors. This is simpler and cleaner than duplicating the low-level code for accessing PCI config space. Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: amd76x pci_dev_get/pci_dev_put fixesDave Peterson
Eliminate unnecessary calls to pci_dev_get() and pci_dev_put() from amd76x driver. Signed-off-by: David S. Peterson <dsp@llnl.gov> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: name cleanupDave Peterson
Perform the following name substitutions on all source files: sed 's/BS_MOD_STR/EDAC_MOD_STR/g' sed 's/bs_thread_info/edac_thread_info/g' sed 's/bs_thread/edac_thread/g' sed 's/bs_xstr/edac_xstr/g' sed 's/bs_str/edac_str/g' The names that start with BS_ or bs_ are artifacts of when the code was called "bluesmoke". Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: printk cleanupDave Peterson
This implements the following idea: On Monday 30 January 2006 19:22, Eric W. Biederman wrote: > One piece missing from this conversation is the issue that we need errors > in a uniform format. That is why edac_mc has helper functions. > > However there will always be errors that don't fit any particular model. > Could we add a edac_printk(dev, ); That is similar to dev_printk but > prints out an EDAC header and the device on which the error was found? > Letting the rest of the string be user specified. > > For actual control that interface may be to blunt, but at least for people > looking in the logs it allows all of the errors to be detected and > harvested. Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] EDAC: core EDAC support codeAlan Cox
This is a subset of the bluesmoke project core code, stripped of the NMI work which isn't ready to merge and some of the "interesting" proc functionality that needs reworking or just has no place in kernel. It requires no core kernel changes except the added scrub functions already posted. The goal is to merge further functionality only after the core code is accepted and proven in the base kernel, and only at the point the upstream extras are really ready to merge. From: doug thompson <norsk5@xmission.com> This converts EDAC to sysfs and is the final chunk neccessary before EDAC has a stable user space API and can be considered for submission into the base kernel. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: doug thompson <norsk5@xmission.com> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] EDAC: drivers for AMD 76x and Intel E750x, E752xAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
