path: root/drivers/edac/cell_edac.c
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-18edac: add missing __devexit_p()Mike Frysinger
The remove function uses __devexit, so the .remove assignment needs __devexit_p() to fix a build error with hotplug disabled. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24edac: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: dougthompson@xmission.com Cc: bluesmoke-devel@lists.sourceforge.net Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2009-01-28powerpc: More printing warning fixes for the l64 to ll64 conversionStephen Rothwell
These are all powerpc specific drivers. res.start in fsl_elbc_nand.c needs to be cast since it may be either 32 or 64 bit. Thanks to Scott Wood for noticing. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Arnd Bergmann <arnd@arndb.de> call_edac bits in particular Acked-by: Olof Johansson <olof@lixom.net> pasemi_nand peices Acked-by: Scott Wood <scottwood@freescale.com> fsl_elbc fixes Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-30edac: fix enabling of polling cell moduleBenjamin Herrenschmidt
The edac driver on cell turned out to be not enabled because of a missing op_state. This patch introduces it. Verified to work on top of Ben's next branch. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Osterkamp <jens@linux.vnet.ibm.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20edac cell: fix incorrect edac_modeBenjamin Herrenschmidt
The cell_edac driver is setting the edac_mode field of the csrow's to an incorrect value, causing the sysfs show routine for that field to go out of an array bound and Oopsing the kernel when used. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: <stable@kernel.org> [2.6.27.x, 2.6.26.x. 2.6.25.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22powerpc/cell/edac: Log a syndrome code in case of correctable errorMaxim Shchetynin
If correctable error occurs the syndrome code was logged as 0. This patch lets EDAC to log a correct syndrome code to make problem investigation easier. Signed-off-by: Maxim Shchetynin <maxim@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-02-07drivers-edac: add Cell MC driverBenjamin Herrenschmidt
Adds driver for the Cell memory controller when used without a Hypervisor such as on the IBM Cell blades. There might still be some improvements to do to this such as finding if it's possible to properly obtain more details about the address of the error but it's good enough already to report CE counts which is our main priority at the moment. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
