path: root/drivers/edac/e7xxx_edac.c
2012-03-19EDAC: Make pci_device_id tables __devinitconst.Lionel Debroux
These const tables are currently marked __devinitdata, but Documentation/PCI/pci.txt says: "o The ID table array should be marked __devinitconst; this is done automatically if the table is declared with DEFINE_PCI_DEVICE_TABLE()." So use DEFINE_PCI_DEVICE_TABLE(x). Based on PaX and earlier work by Andi Kleen. Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-04-19edac: Drop __DATE__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Cc: Doug Thompson <dougthompson@xmission.com> Cc: bluesmoke-devel@lists.sourceforge.net Cc: linux-edac@vger.kernel.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-04-29edac: fix module initialization on several modules 2nd timeHitoshi Mitake
I implemented opstate_init() as a inline function in linux/edac.h. added calling opstate_init() to: i82443bxgx_edac.c i82860_edac.c i82875p_edac.c i82975x_edac.c I wrote a fixed patch of edac-fix-module-initialization-on-several-modules.patch, and tested building 2.6.25-rc7 with applying this. It was succeed. I think the patch is now correct. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Hitoshi Mitake <h.mitake@gmail.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: fix edac_mc init apisDoug Thompson
Refactoring of sysfs code necessitated the refactoring of the edac_mc_alloc() and edac_mc_add_mc() apis, of moving the index value to the alloc() function. This patch alters the in tree drivers to utilize this new api signature. Having the index value performed later created a chicken-and-the-egg issue. Moving it to the alloc() function allows for creating the necessary sysfs entries with the proper index number Cc: Alan Cox alan@lxorguk.ukuu.org.uk Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: cleanup spaces-gotos after Lindent messupDouglas Thompson
This patch fixes some remnant spaces inserted by the use of Lindent. Seems Lindent adds some spaces when it shoulded. These have been fixed. In addition, goto targets have issues, these have been fixed in this patch. Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: drivers to use new PCI operationDave Jiang
Move x86 drivers to new pci controller setup Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: Lindent e7xxxDave Jiang
Lindent cleanup of e7xxx_edac driver Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: add dev_name getter functionDave Jiang
Move dev_name() macro to a more generic interface since it's not possible to determine whether a device is pci, platform, or of_device easily. Now each low level driver sets the name into the control structure, and the EDAC core references the control structure for the information. Better abstraction. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: mod use edac_core.hDouglas Thompson
In the refactoring of edac_mc.c into several subsystem files, the header file edac_mc.h became meaningless. A new header file edac_core.h was created. All the files that previously included "edac_mc.h" are changed to include "edac_core.h". Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: add new nmi rescanDave Jiang
Provides a way for NMI reported errors on x86 to notify the EDAC subsystem pending ECC errors by writing to a software state variable. Here's the reworked patch. I added an EDAC stub to the kernel so we can have variables that are in the kernel even if EDAC is a module. I also implemented the idea of using the chip driver to select error detection mode via module parameter and eliminate the kernel compile option. Please review/test. Thx! Also, I only made changes to some of the chipset drivers since I am unfamiliar with the other ones. We can add similar changes as we go. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-01[PATCH] EDAC: fix module names quoted in sysfsDoug Thompson
Fix the quoted module name in the sysfs for EDAC modules and reported by several people. Instead of ../_edac_e752x_/ now the following will be presented, like other modules: ../edac_e752x/ Signed-off-by: Doug Thompson <norsk5@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Remove obsolete #include <linux/config.h> remove obsolete swsusp_encrypt arch/arm26/Kconfig typos Documentation/IPMI typos Kconfig: Typos in net/sched/Kconfig v9fs: do not include linux/version.h Documentation/DocBook/mtdnand.tmpl: typo fixes typo fixes: specfic -> specific typo fixes in Documentation/networking/pktgen.txt typo fixes: occuring -> occurring typo fixes: infomation -> information typo fixes: disadvantadge -> disadvantage typo fixes: aquire -> acquire typo fixes: mecanism -> mechanism typo fixes: bandwith -> bandwidth fix a typo in the RTC_CLASS help text smb is no longer maintained Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
2006-06-30[PATCH] EDAC: probe1 cleanup 1-of-2Doug Thompson
- Add lower-level functions that handle various parts of the initialization done by the xxx_probe1() functions. Some of the xxx_probe1() functions are much too long and complicated (see "Chapter 5: Functions" in Documentation/CodingStyle). - Cleanup of probe1() functions in EDAC Signed-off-by: Doug Thompson <norsk5@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] EDAC: mc numbers refactor 1-of-2Doug Thompson
Remove add_mc_to_global_list(). In next patch, this function will be reimplemented with different semantics. 1 Reimplement add_mc_to_global_list() with semantics that allow the caller to determine the ID number for a mem_ctl_info structure. Then modify edac_mc_add_mc() so that the caller specifies the ID number for the new mem_ctl_info structure. Platform-specific code should be able to assign the ID numbers in a platform-specific manner. For instance, on Opteron it makes sense to have the ID of the mem_ctl_info structure match the ID of the node that the memory controller belongs to. 2 Modify callers of edac_mc_add_mc() so they use the new semantics. Signed-off-by: Doug Thompson <norsk5@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] EDAC: PCI device to DEVICE cleanupDoug Thompson
Change MC drivers from using CVS revision strings for their version number, Now each driver has its own local string. Remove some PCI dependencies from the core EDAC module. Made the code 'struct device' centric instead of 'struct pci_dev' Most of the code changes here are from a patch by Dave Jiang. It may be best to eventually move the PCI-specific code into a separate source file. Signed-off-by: Doug Thompson <norsk5@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: formatting cleanupDave Peterson
Cosmetic indentation/formatting cleanup for EDAC code. Make sure we are using tabs rather than spaces to indent, etc. Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: protect memory controller listDave Peterson
- Fix code so we always hold mem_ctls_mutex while we are stepping through the list of mem_ctl_info structures. Otherwise bad things may happen if one task is stepping through the list while another task is modifying it. We may eventually want to use reference counting to manage the mem_ctl_info structures. In the meantime we may as well fix this bug. - Don't disable interrupts while we are walking the list of mem_ctl_info structures in check_mc_devices(). This is unnecessary. Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: cleanup code for clearing initial errorsDave Peterson
Fix xxx_probe1() functions so they call xxx_get_error_info() functions to clear initial errors. This is simpler and cleaner than duplicating the low-level code for accessing PCI config space. Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: e7xxx fix minor logic bugDave Peterson
Fix minor logic bug in e7xxx_remove_one(). Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: name cleanupDave Peterson
Perform the following name substitutions on all source files: sed 's/BS_MOD_STR/EDAC_MOD_STR/g' sed 's/bs_thread_info/edac_thread_info/g' sed 's/bs_thread/edac_thread/g' sed 's/bs_xstr/edac_xstr/g' sed 's/bs_str/edac_str/g' The names that start with BS_ or bs_ are artifacts of when the code was called "bluesmoke". Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EDAC: printk cleanupDave Peterson
This implements the following idea: On Monday 30 January 2006 19:22, Eric W. Biederman wrote: > One piece missing from this conversation is the issue that we need errors > in a uniform format. That is why edac_mc has helper functions. > > However there will always be errors that don't fit any particular model. > Could we add a edac_printk(dev, ); That is similar to dev_printk but > prints out an EDAC header and the device on which the error was found? > Letting the rest of the string be user specified. > > For actual control that interface may be to blunt, but at least for people > looking in the logs it allows all of the errors to be detected and > harvested. Signed-off-by: David S. Peterson <dsp@llnl.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] EDAC: core EDAC support codeAlan Cox
This is a subset of the bluesmoke project core code, stripped of the NMI work which isn't ready to merge and some of the "interesting" proc functionality that needs reworking or just has no place in kernel. It requires no core kernel changes except the added scrub functions already posted. The goal is to merge further functionality only after the core code is accepted and proven in the base kernel, and only at the point the upstream extras are really ready to merge. From: doug thompson <norsk5@xmission.com> This converts EDAC to sysfs and is the final chunk neccessary before EDAC has a stable user space API and can be considered for submission into the base kernel. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: doug thompson <norsk5@xmission.com> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] EDAC: drivers for AMD 76x and Intel E750x, E752xAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
