path: root/drivers/edac/edac_module.h
2010-10-21EDAC: Export edac sysfs class to users.Borislav Petkov
Move toplevel sysfs class to the stub and make it available to non-modularized code too. Add proper refcounting of its users and move the registration functionality into the reference counting routines. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2008-04-29edac: remove unneeded functions and add static accessorAdrian Bunk
Collection of patches, merged into one, from Adrian that do the following: 1) This patch makes the following needlessly global functions static: - edac_pci_get_log_pe() - edac_pci_get_log_npe() - edac_pci_get_panic_on_pe() - edac_pci_unregister_sysfs_instance_kobj() - edac_pci_main_kobj_setup() 2) Remove unneeded function edac_device_find() 3) Added #if 0 around function edac_pci_find() 4) make the needlessly global edac_pci_generic_check() static 5) Removed function edac_check_mc_devices() Doug Thompson modified Adrian's patches, to bettern represent the direction of EDAC, and make them one patch. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26drivers/edac: fix edac_pci sysfsDoug Thompson
This patch fixes sysfs exit code for the EDAC PCI device in a similiar manner and the previous fixes for EDAC_MC and EDAC_DEVICE. It removes the old (and incorrect) completion model and uses reference counts on per instance kobjects and on the edac core module. This pattern was applied to the edac_mc and edac_device code, but the EDAC PCI code was missed. In addition, this fixes a system hang after a low level driver was unloaded. (A cleanup function was called twice, which really screwed things up) Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26drivers/edac: fix reset edac_mc pollmsecDoug Thompson
This fixes a deadlock that could occur on a 'setup' and 'teardown' sequence of the workq for a edac_mc control structure instance. A similiar fix was previously implemented for the edac_device code. In addition, the edac_mc device code there was missing code to allow the workq period valu to be altered via sysfs control. This patch adds that fix on the code, and allows for the changing of the period value as well. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: fix edac_device sysfs completion codeDouglas Thompson
With feedback, this patch corrects operation of the kobject release operation on kobjects, attributes and controls for the edac_device. Cc: Alan Cox alan@lxorguk.ukuu.org.uk Signed-off-by: Doug Thompson <dougthompson@xmission.com> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: fix edac_mc sysfs completion codeDoug Thompson
This patch refactors the 'releasing' of kobjects for the edac_mc type of device. The correct pattern of kobject release is followed. As internal kobjs are allocated they bump a ref count on the top level kobj. It in turn has a module ref count on the edac_core module. When internal kobjects are released, they dec the ref count on the top level kobj. When the top level kobj reaches zero, it decrements the ref count on the edac_core object, allow it to be unloaded, as all resources have all now been released. Cc: Alan Cox alan@lxorguk.ukuu.org.uk Signed-off-by: Doug Thompson <dougthompson@xmission.com> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: mod edac_align_ptr functionDouglas Thompson
Refactor the edac_align_ptr() function to reduce the noise of casting the aligned pointer to the various types of data objects and modified its callers to its new signature Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: core Lindent cleanupDouglas Thompson
Run the EDAC CORE files through Lindent for cleanup Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: mod PCI poll namesDave Jiang
Fixup poll values for MC and PCI. Also make mc function names unique to mc. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmissin.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: mod MC to use workq instead of kthreadDave Jiang
Move the memory controller object to work queue based implementation from the kernel thread based. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: add edac_device classDouglas Thompson
This patch adds the new 'class' of object to be managed, named: 'edac_device'. As a peer of the 'edac_mc' class of object, it provides a non-memory centric view of an ERROR DETECTING device in hardware. It provides a sysfs interface and an abstraction for varioius EDAC type devices. Multiple 'instances' within the class are possible, with each 'instance' able to have multiple 'blocks', and each 'block' having 'attributes'. At the 'block' level there are the 'ce_count' and 'ue_count' fields which the device driver can update and/or call edac_device_handle_XX() functions. At each higher level are additional 'total' count fields, which are a summation of counts below that level. This 'edac_device' has been used to capture and present ECC errors which are found in a a L1 and L2 system on a per CORE/CPU basis. Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: split out functions to unique filesDouglas Thompson
This is a large patch to refactor the original EDAC module in the kernel and to break it up into better file granularity, such that each source file contains a given subsystem of the EDAC CORE. Originally, the EDAC 'core' was contained in one source file: edac_mc.c with it corresponding edac_mc.h file. Now, there are the following files: edac_module.c The main module init/exit function and other overhead edac_mc.c Code handling the edac_mc class of object edac_mc_sysfs.c Code handling for sysfs presentation edac_pci_sysfs.c Code handling for PCI sysfs presentation edac_core.h CORE .h include file for 'edac_mc' and 'edac_device' drivers edac_module.h Internal CORE .h include file This forms a foundation upon which a later patch can create the 'edac_device' class of object code in a new file 'edac_device.c'. Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
