path: root/drivers/edac/i5400_edac.c
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-04-19edac: Drop __DATE__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Cc: Doug Thompson <dougthompson@xmission.com> Cc: bluesmoke-devel@lists.sourceforge.net Cc: linux-edac@vger.kernel.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-11edac: i5400: improve handling of pci_enable_device() return valueKulikov Vasiliy
-EIO is not the only error code that pci_enable_device() may return, also the set of errors can be enhanced in future. We should compare return code with zero, not with concrete error value. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Jeff Roberson <jroberson@jroberson.net> Cc: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27drivers/edac: convert logging messages direct uses of __FILE__ to %s, __FILEJoe Perches
Reduces text by eliminating multiple __FILE__ uses. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joe Perches <joe@perches.com> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Tim Small <tim@buttersideup.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29edac: i5400 fix csrow mappingJeff Roberson
The i5400 EDAC driver has several bugs with chip-select row computation which most likely lead to bugs in detailed error reporting. Attempts to contact the authors have gone mostly unanswered so I am presenting my diff here. I do not subscribe to lkml and would appreciate being kept in the cc. The most egregious problem was miscalculating the addresses of MTR registers after register 0 by assuming they are 32bit rather than 16. This caused the driver to miss half of the memories. Most motherboards tend to have only 8 dimm slots and not 16, so this may not have been noticed before. Further, the row calculations multiplied the number of dimms several times, ultimately ending up with a maximum row of 32. The chipset only supports 4 dimms in each of 4 channels, so csrow could not be higher than 4 unless you use a row per-rank with dual-rank dimms. I opted to eliminate this behavior as it is confusing to the user and the error reporting works by slot and not rank. This gives a much clearer view of memory by slot and channel in /sys. Signed-off-by: Jeff Roberson <jroberson@jroberson.net> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06edac: driver for i5400 MCH (update)Mauro Carvalho Chehab
Signed-off-by: Ben Woodard <woodard@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06edac: driver for i5400 MCH (Seaburg)Mauro Carvalho Chehab
EDAC driver for i5400 MCH (Seaburg) This driver adds support for i5400 MCH chipset. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Ben Woodard <woodard@redhat.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
