[ Upstream commit 7088e29e0423d3195e09079b4f849ec4837e5a75 ]
The current code to convert a physical address mask to a grain
(defined as granularity in bytes) is:
e->grain = ~(mem_err->physical_addr_mask & ~PAGE_MASK);
This is broken in several ways:
1) It calculates to wrong grain values. E.g., a physical address mask
of ~0xfff should give a grain of 0x1000. Without considering
PAGE_MASK, there is an off-by-one. Things are worse when also
filtering it with ~PAGE_MASK. This will calculate to a grain with the
upper bits set. In the example it even calculates to ~0.
2) The grain does not depend on and is unrelated to the kernel's
page-size. The page-size only matters when unmapping memory in
memory_failure(). Smaller grains are wrongly rounded up to the
page-size, on architectures with a configurable page-size (e.g. arm64)
this could round up to the even bigger page-size of the hypervisor.
Fix this with:
e->grain = ~mem_err->physical_addr_mask + 1;
The grain_bits are defined as:
grain = 1 << grain_bits;
Change also the grain_bits calculation accordingly, it is the same
formula as in edac_mc.c now and the code can be unified.
The value in ->physical_addr_mask coming from firmware is assumed to
be contiguous, but this is not sanity-checked. However, in case the
mask is non-contiguous, a conversion to grain_bits effectively
converts the grain bit mask to a power of 2 by rounding it up.
Suggested-by: James Morse <james.morse@arm.com>
Signed-off-by: Robert Richter <rrichter@marvell.com>
Reviewed-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Cc: "linux-edac@vger.kernel.org" <linux-edac@vger.kernel.org>
Link: https://lkml.kernel.org/r/20191106093239.25517-11-rrichter@marvell.com
[ Upstream commit d8c27ba86a2fd806d3957e5a9b30e66dfca2a61d ]
Fix memory leak in L2c threaded interrupt handler.
[ bp: Rewrite commit message. ]
Fixes: 41003396f932 ("EDAC, thunderx: Add Cavium ThunderX EDAC driver")
CC: David Daney <david.daney@cavium.com>
CC: Jan Glauber <jglauber@cavium.com>
CC: Mauro Carvalho Chehab <mchehab@kernel.org>
CC: Sergey Temerkhanov <s.temerkhanov@gmail.com>
CC: linux-edac <linux-edac@vger.kernel.org>
Link: http://lkml.kernel.org/r/20181013102843.GG16086@mwanda
[ Upstream commit dcc960b225ceb2bd66c45e0845d03e577f7010f9 ]
Users of the mce_register_decode_chain() are called for every logged
error. EDAC drivers should check:
1) Is this a memory error? [bit 7 in status register]
2) Is there a valid address? [bit 58 in status register]
3) Is the address a system address? [bitfield 8:6 in misc register]
The sb_edac driver performed test "1" twice. Waited far too long to
perform check "2". Didn't do check "3" at all.
Fix it by moving the test for valid address from
sbridge_mce_output_error() into sbridge_mce_check_error() and add a test
for the type immediately after. Delete the redundant check for the type
of the error from sbridge_mce_output_error().
Signed-off-by: Qiuxu Zhuo <qiuxu.zhuo@intel.com>
Cc: Aristeu Rozanski <aris@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
Cc: Qiuxu Zhuo <qiuxu.zhuo@intel.com>
Cc: linux-edac <linux-edac@vger.kernel.org>
Link: http://lkml.kernel.org/r/20180907230828.13901-2-tony.luck@intel.com
[ Re-word commit message. ]
Signed-off-by: Tony Luck <tony.luck@intel.com>
[ Upstream commit 8a2eaab7daf03b23ac902481218034ae2fae5e16 ]
AMD Family 17h systems currently require address translation in order to
report the system address of a DRAM ECC error. This is currently done
before decoding the syndrome information. The syndrome information does
not depend on the address translation, so the proper EDAC csrow/channel
reporting can function without the address. However, the syndrome
information will not be decoded if the address translation fails.
Decode the syndrome information before doing the address translation.
The syndrome information is architecturally defined in MCA_SYND and can
be considered robust. The address translation is system-specific and may
fail on newer systems without proper updates to the translation
algorithm.
Fixes: 713ad54675fd ("EDAC, amd64: Define and register UMC error decode function")
Signed-off-by: Yazen Ghannam <yazen.ghannam@amd.com>
Cc: James Morse <james.morse@arm.com>
Link: https://lkml.kernel.org/r/20190821235938.118710-6-Yazen.Ghannam@amd.com
[ Upstream commit f8be8e5680225ac9caf07d4545f8529b7395327f ]
AMD Family 17h systems support x4 and x16 DRAM devices. However, the
device type is not checked when setting mci.edac_ctl_cap.
Set the appropriate capability flag based on the device type.
Default to x8 DRAM device when neither the x4 or x16 bits are set.
[ bp: reverse cpk_en check to save an indentation level. ]
Fixes: 2d09d8f301f5 ("EDAC, amd64: Determine EDAC MC capabilities on Fam17h")
Link: https://lkml.kernel.org/r/20190821235938.118710-3-Yazen.Ghannam@amd.com
[ Upstream commit 29a3388bfcce7a6d087051376ea02bf8326a957b ]
Depending on how BIOS has marked the reserved region containing the 32KB
MCHBAR you can get warnings like:
resource sanity check: requesting [mem 0xfed10000-0xfed1ffff], which spans more than reserved [mem 0xfed10000-0xfed17fff]
caller dnv_rd_reg+0xc8/0x240 [pnd2_edac] mapping multiple BARs
Not all of the mmio regions used in dnv_rd_reg() are the same size. The
MCHBAR window is 32KB and the sideband ports are 64KB. Pass the correct
size to ioremap() depending on which resource we're reading from.
Signed-off-by: Stephen Douthit <stephend@silicom-usa.com>
[ Upstream commit 8faa1cf6ed82f33009f63986c3776cc48af1b7b2 ]
Smatch complains about the cast of a u32 pointer to unsigned long:
drivers/edac/altera_edac.c:1878 altr_edac_a10_irq_handler()
warn: passing casted pointer '&irq_status' to 'find_first_bit()'
This code wouldn't work on a 64 bit big endian system because it would
read past the end of &irq_status.
[ bp: massage. ]
Fixes: 13ab8448d2c9 ("EDAC, altera: Add ECC Manager IRQ controller support")
Reviewed-by: Thor Thayer <thor.thayer@linux.intel.com>
Cc: kernel-janitors@vger.kernel.org
Link: https://lkml.kernel.org/r/20190624134717.GA1754@mwanda
[ Upstream commit 3724ace582d9f675134985727fd5e9811f23c059 ]
The grain in EDAC is defined as "minimum granularity for an error
report, in bytes". The following calculation of the grain_bits in
edac_mc is wrong:
grain_bits = fls_long(e->grain) + 1;
Where grain_bits is defined as:
Example:
grain = 8 # 64 bit (8 bytes)
grain_bits = fls_long(8) + 1
grain_bits = 4 + 1 = 5
grain = 1 << 5 = 32
Replace it with the correct calculation:
grain_bits = fls_long(e->grain - 1);
The example gives now:
grain_bits = fls_long(8 - 1)
grain_bits = fls_long(7)
grain_bits = 3
grain = 1 << 3 = 8
Also, check if the hardware reports a reasonable grain != 0 and fallback
with a warning to 1 byte granularity otherwise.
[ bp: massage a bit. ]
Link: https://lkml.kernel.org/r/20190624150758.6695-2-rrichter@marvell.com
[ Upstream commit d8655e7630dafa88bc37f101640e39c736399771 ]
Commit 9da21b1509d8 ("EDAC: Poll timeout cannot be zero, p2") assumes
edac_mc_poll_msec to be unsigned long, but the type of the variable still
remained as int. Setting edac_mc_poll_msec can trigger out-of-bounds
write.
Reproducer:
# echo 1001 > /sys/module/edac_core/parameters/edac_mc_poll_msec
KASAN report:
BUG: KASAN: global-out-of-bounds in edac_set_poll_msec+0x140/0x150
Write of size 8 at addr ffffffffb91b2d00 by task bash/1996
CPU: 1 PID: 1996 Comm: bash Not tainted 5.2.0-rc6+ #23
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-2.fc30 04/01/2014
Call Trace:
dump_stack+0xca/0x13e
print_address_description.cold+0x5/0x246
__kasan_report.cold+0x75/0x9a
? edac_set_poll_msec+0x140/0x150
kasan_report+0xe/0x20
? dimmdev_location_show+0x30/0x30
? vfs_lock_file+0xe0/0xe0
? _raw_spin_lock+0x87/0xe0
param_attr_store+0x1b5/0x310
? param_array_set+0x4f0/0x4f0
module_attr_store+0x58/0x80
? module_attr_show+0x80/0x80
sysfs_kf_write+0x13d/0x1a0
kernfs_fop_write+0x2bc/0x460
? sysfs_kf_bin_read+0x270/0x270
? kernfs_notify+0x1f0/0x1f0
__vfs_write+0x81/0x100
vfs_write+0x1e1/0x560
ksys_write+0x126/0x250
? __ia32_sys_read+0xb0/0xb0
? do_syscall_64+0x1f/0x390
do_syscall_64+0xc1/0x390
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x7fa7caa5e970
Code: 73 01 c3 48 8b 0d 28 d5 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 0f 1f 44 00 00 83 3d 99 2d 2c 00 00 75 10 b8 01 00 00 00 04
RSP: 002b:00007fff6acfdfe8 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 00007fa7caa5e970
RDX: 0000000000000005 RSI: 0000000000e95c08 RDI: 0000000000000001
RBP: 0000000000e95c08 R08: 00007fa7cad1e760 R09: 00007fa7cb36a700
R10: 0000000000000073 R11: 0000000000000246 R12: 0000000000000005
R13: 0000000000000001 R14: 00007fa7cad1d600 R15: 0000000000000005
The buggy address belongs to the variable:
edac_mc_poll_msec+0x0/0x40
Memory state around the buggy address:
ffffffffb91b2c00: 00 00 00 00 fa fa fa fa 00 00 00 00 fa fa fa fa
ffffffffb91b2c80: 00 00 00 00 fa fa fa fa 00 00 00 00 fa fa fa fa
>ffffffffb91b2d00: 04 fa fa fa fa fa fa fa 04 fa fa fa fa fa fa fa
ffffffffb91b2d80: 04 fa fa fa fa fa fa fa 00 00 00 00 00 00 00 00
ffffffffb91b2e00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Fix it by changing the type of edac_mc_poll_msec to unsigned int.
The reason why this patch adopts unsigned int rather than unsigned long
is msecs_to_jiffies() assumes arg to be unsigned int. We can avoid
integer conversion bugs and unsigned int will be large enough for
edac_mc_poll_msec.
Reviewed-by: James Morse <james.morse@arm.com>
Fixes: 9da21b1509d8 ("EDAC: Poll timeout cannot be zero, p2")
Signed-off-by: Eiichi Tsukata <devel@etsukata.com>
[ Upstream commit 585fb3d93d32dbe89e718b85009f9c322cc554cd ]
In edac_create_csrow_object(), the reference to the object is not
released when adding the device to the device hierarchy fails
(device_add()). This may result in a memory leak.
Signed-off-by: Pan Bian <bianpan2016@163.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Link: https://lkml.kernel.org/r/1555554438-103953-1-git-send-email-bianpan2016@163.com
[ Upstream commit 2b8358a951b1e2a534a54924cd8245e58a1c5fb8 ]
The mpc85xx EDAC driver can be configured as a module but then fails to
build because it uses two unexported symbols:
ERROR: ".pci_find_hose_for_OF_device" [drivers/edac/mpc85xx_edac_mod.ko] undefined!
ERROR: ".early_find_capability" [drivers/edac/mpc85xx_edac_mod.ko] undefined!
We don't want to export those symbols just for this driver, so make the
driver only configurable as a built-in.
This seems to have been broken since at least
c92132f59806 ("edac/85xx: Add PCIe error interrupt edac support")
(Nov 2013).
[ bp: make it depend on EDAC=y so that the EDAC core doesn't get built
as a module. ]
Acked-by: Johannes Thumshirn <jth@kernel.org>
Cc: linuxppc-dev@ozlabs.org
Cc: morbidrsa@gmail.com
Link: https://lkml.kernel.org/r/20190502141941.12927-1-mpe@ellerman.id.au
commit f2c4db1bd80720cd8cb2a5aa220d9bc9f374f04e upstream
Going primarily by:
https://en.wikipedia.org/wiki/List_of_Intel_Atom_microprocessors
with additional information gleaned from other related pages; notably:
- Bonnell shrink was called Saltwell
- Moorefield is the Merriefield refresh which makes it Airmont
The general naming scheme is: FAM6_ATOM_UARCH_SOCTYPE
for i in `git grep -l FAM6_ATOM` ; do
sed -i -e 's/ATOM_PINEVIEW/ATOM_BONNELL/g' \
-e 's/ATOM_LINCROFT/ATOM_BONNELL_MID/' \
-e 's/ATOM_PENWELL/ATOM_SALTWELL_MID/g' \
-e 's/ATOM_CLOVERVIEW/ATOM_SALTWELL_TABLET/g' \
-e 's/ATOM_CEDARVIEW/ATOM_SALTWELL/g' \
-e 's/ATOM_SILVERMONT1/ATOM_SILVERMONT/g' \
-e 's/ATOM_SILVERMONT2/ATOM_SILVERMONT_X/g' \
-e 's/ATOM_MERRIFIELD/ATOM_SILVERMONT_MID/g' \
-e 's/ATOM_MOOREFIELD/ATOM_AIRMONT_MID/g' \
-e 's/ATOM_DENVERTON/ATOM_GOLDMONT_X/g' \
-e 's/ATOM_GEMINI_LAKE/ATOM_GOLDMONT_PLUS/g' ${i}
done
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: dave.hansen@linux.intel.com
Cc: len.brown@intel.com
commit 8f18973877204dc8ca4ce1004a5d28683b9a7086 upstream.
The code "lchan = (lchan << 1) | ~lchan" for logical channel
intermediate decoding is wrong. The wrong intermediate decoding
result is {0xffffffff, 0xfffffffe}.
Fix it by replacing '~' with '!'. The correct intermediate
decoding result is {0x1, 0x2}.
CC: Aristeu Rozanski <aris@redhat.com>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/20181009172025.18594-1-tony.luck@intel.com
commit 432de7fd7630c84ad24f1c2acd1e3bb4ce3741ca upstream.
The count of errors is picked up from bits 52:38 of the machine check
bank status register. But this is the count of *corrected* errors. If an
uncorrected error is being logged, the h/w sets this field to 0. Which
means that when edac_mc_handle_error() is called, the EDAC core will
carefully add zero to the appropriate uncorrected error counts.
[ Massage commit message. ]
Link: http://lkml.kernel.org/r/20180928213934.19890-1-tony.luck@intel.com
commit 8960de4a5ca7980ed1e19e7ca5a774d3b7a55c38 upstream.
Add new device IDs for family 17h, models 10h-2fh.
This is required by amd64_edac_mod in order to properly detect PCI
device functions 0 and 6.
Signed-off-by: Michael Jin <mikhail.jin@gmail.com>
Reviewed-by: Yazen Ghannam <Yazen.Ghannam@amd.com>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/20180816192840.31166-1-mikhail.jin@gmail.com
[ Upstream commit 4708aa85d50cc6e962dfa8acf5ad4e0d290a21db ]
Make sure to use put_device() to free the initialised struct device so
that resources managed by driver core also gets released in the event of
a registration failure.
Signed-off-by: Johan Hovold <johan@kernel.org>
Cc: Denis Kirjanov <kirjanov@gmail.com>
Fixes: 2d56b109e3a5 ("EDAC: Handle error path in edac_mc_sysfs_init() properly")
Link: http://lkml.kernel.org/r/20180612124335.6420-1-johan@kernel.org
[ Upstream commit 6c974d4dfafe5e9ee754f2a6fba0eb1864f1649e ]
Make sure to free and deregister the addrmatch and chancounts devices
allocated during probe in all error paths. Also fix use-after-free in a
probe error path and in the remove success path where the devices were
being put before before deregistration.
Fixes: 356f0a30860d ("i7core_edac: change the mem allocation scheme to make Documentation/kobject.txt happy")
Link: http://lkml.kernel.org/r/20180612124335.6420-2-johan@kernel.org
commit b748f2de4b2f578599f46c6000683a8da755bf68 upstream.
The edac_mem_types[] array misses a MEM_LRDDR4 entry, which leads to
NULL pointer dereference when accessed via sysfs or such.
Cc: Yazen Ghannam <Yazen.Ghannam@amd.com>
Link: http://lkml.kernel.org/r/20180810141426.8918-1-tiwai@suse.de
Fixes: 1e8096bb2031 ("EDAC: Add LRDDR4 DRAM type")
[ Upstream commit 9ef20753e044f7468c4113e5aecd785419b0b3cc ]
The kbuild test robot reported the following warning:
drivers/edac/altera_edac.c: In function 'ocram_free_mem':
drivers/edac/altera_edac.c:1410:42: warning: cast from pointer to integer
of different size [-Wpointer-to-int-cast]
gen_pool_free((struct gen_pool *)other, (u32)p, size);
After adding support for ARM64 architectures, the unsigned long
parameter is 64 bits and causes a build warning on 64-bit configs. Fix
by casting to the correct size (unsigned long) instead of u32.
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Thor Thayer <thor.thayer@linux.intel.com>
Fixes: c3eea1942a16 ("EDAC, altera: Add Altera L2 cache and OCRAM support")
Link: http://lkml.kernel.org/r/1526317441-4996-1-git-send-email-thor.thayer@linux.intel.com
commit 68627a697c195937672ce07683094c72b1174786 upstream.
Currently, bank 4 is reserved on Fam17h, so we chose not to initialize
bank 4 in the smca_banks array. This means that when we check if a bank
is initialized, like during boot or resume, we will see that bank 4 is
not initialized and try to initialize it.
This will cause a call trace, when resuming from suspend, due to
rdmsr_*on_cpu() calls in the init path. The rdmsr_*on_cpu() calls issue
an IPI but we're running with interrupts disabled. This triggers:
WARNING: CPU: 0 PID: 11523 at kernel/smp.c:291 smp_call_function_single+0xdc/0xe0
Reserved banks will be read-as-zero, so their MCA_IPID register will be
zero. So, like the smca_banks array, the threshold_banks array will not
have an entry for a reserved bank since all its MCA_MISC* registers will
be zero.
Enumerate a "Reserved" bank type that matches on a HWID_MCATYPE of 0,0.
Use the "Reserved" type when checking if a bank is reserved. It's
possible that other bank numbers may be reserved on future systems.
Don't try to find the block address on reserved banks.
Cc: <stable@vger.kernel.org> # 4.14.x
Link: http://lkml.kernel.org/r/20180221101900.10326-7-bp@alien8.de
[ Upstream commit 68fa24f9121c04ef146b5158f538c8b32f285be5 ]
We should not call edac_mc_del_mc() if a corresponding call to
edac_mc_add_mc() has not been performed yet.
So here, we should go to err instead of err2 to branch at the right
place of the error handling path.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Link: http://lkml.kernel.org/r/20180107205400.14068-1-christophe.jaillet@wanadoo.fr
commit bf8486709ac7fad99e4040dea73fe466c57a4ae1 upstream.
Commit
3286d3eb906c ("EDAC, sb_edac: Drop NUM_CHANNELS from 8 back to 4")
decreased NUM_CHANNELS from 8 to 4, but this is not enough for Knights
Landing which supports up to 6 channels.
This caused out-of-bounds writes to pvt->mirror_mode and pvt->tolm
variables which don't pay critical role on KNL code path, so the memory
corruption wasn't causing any visible driver failures.
The easiest way of fixing it is to change NUM_CHANNELS to 6. Do that.
An alternative solution would be to restructure the KNL part of the
driver to 2MC/3channel representation.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Anna Karbownik <anna.karbownik@intel.com>
Cc: jim.m.snow@intel.com
Cc: krzysztof.paliswiat@intel.com
Cc: lukasz.odzioba@intel.com
Cc: qiuxu.zhuo@intel.com
Fixes: 3286d3eb906c ("EDAC, sb_edac: Drop NUM_CHANNELS from 8 back to 4")
Link: http://lkml.kernel.org/r/1519312693-4789-1-git-send-email-anna.karbownik@intel.com
commit b399151cb48db30ad1e0e93dd40d68c6d007b637 upstream.
x86_mask is a confusing name which is hard to associate with the
processor's stepping.
Additionally, correct an indent issue in lib/cpu.c.
Signed-off-by: Jia Zhang <qianyue.zj@alibaba-inc.com>
[ Updated it to more recent kernels. ]
Cc: bp@alien8.de
Cc: tony.luck@intel.com
Link: http://lkml.kernel.org/r/1514771530-70829-1-git-send-email-qianyue.zj@alibaba-inc.com
commit 544e92581a2ac44607d7cc602c6b54d18656f56d upstream.
Fix an uninitialized variable warning in the Octeon EDAC driver, as seen
in MIPS cavium_octeon_defconfig builds since v4.14 with Codescape GNU
Tools 2016.05-03:
drivers/edac/octeon_edac-lmc.c In function ‘octeon_lmc_edac_poll_o2’:
drivers/edac/octeon_edac-lmc.c:87:24: warning: ‘((long unsigned int*)&int_reg)[1]’ may \
be used uninitialized in this function [-Wmaybe-uninitialized]
if (int_reg.s.sec_err || int_reg.s.ded_err) {
Iinitialise the whole int_reg variable to zero before the conditional
assignments in the error injection case.
Signed-off-by: James Hogan <jhogan@kernel.org>
Acked-by: David Daney <david.daney@cavium.com>
Cc: linux-mips@linux-mips.org
Fixes: 1bc021e81565 ("EDAC: Octeon: Add error injection support")
Link: http://lkml.kernel.org/r/20171113161206.20990-1-james.hogan@mips.com
[ Upstream commit a8e9b186f153a44690ad0363a56716e7077ad28c ]
Add missing break statement in order to prevent the code from falling
through.
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Link: http://lkml.kernel.org/r/20171016174029.GA19757@embeddedor.com
commit 15cc3ae001873845b5d842e212478a6570c7d938 upstream.
Yi Zhang reported the following failure on a 2-socket Haswell (E5-2603v3)
server (DELL PowerEdge 730xd):
EDAC sbridge: Some needed devices are missing
EDAC MC: Removed device 0 for sb_edac.c Haswell SrcID#0_Ha#0: DEV 0000:7f:12.0
EDAC MC: Removed device 1 for sb_edac.c Haswell SrcID#1_Ha#0: DEV 0000:ff:12.0
EDAC sbridge: Couldn't find mci handler
EDAC sbridge: Failed to register device with error -19.
The refactored sb_edac driver creates the IMC1 (the 2nd memory
controller) if any IMC1 device is present. In this case only
HA1_TA of IMC1 was present, but the driver expected to find
HA1/HA1_TM/HA1_TAD[0-3] devices too, leading to the above failure.
The document [1] says the 'E5-2603 v3' CPU has 4 memory channels max. Yi
Zhang inserted one DIMM per channel for each CPU, and did random error
address injection test with this patch:
4024 addresses fell in TOLM hole area
12715 addresses fell in CPU_SrcID#0_Ha#0_Chan#0_DIMM#0
12774 addresses fell in CPU_SrcID#0_Ha#0_Chan#1_DIMM#0
12798 addresses fell in CPU_SrcID#0_Ha#0_Chan#2_DIMM#0
12913 addresses fell in CPU_SrcID#0_Ha#0_Chan#3_DIMM#0
12674 addresses fell in CPU_SrcID#1_Ha#0_Chan#0_DIMM#0
12686 addresses fell in CPU_SrcID#1_Ha#0_Chan#1_DIMM#0
12882 addresses fell in CPU_SrcID#1_Ha#0_Chan#2_DIMM#0
12934 addresses fell in CPU_SrcID#1_Ha#0_Chan#3_DIMM#0
106400 addresses were injected totally.
The test result shows that all the 4 channels belong to IMC0 per CPU, so
the server really only has one IMC per CPU.
In the 1st page of chapter 2 in datasheet [2], it also says 'E5-2600 v3'
implements either one or two IMCs. For CPUs with one IMC, IMC1 is not
used and should be ignored.
Thus, do not create a second memory controller if the key HA1 is absent.
[1] http://ark.intel.com/products/83349/Intel-Xeon-Processor-E5-2603-v3-15M-Cache-1_60-GHz
[2] https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/xeon-e5-v3-datasheet-vol-2.pdf
Reported-and-tested-by: Yi Zhang <yizhan@redhat.com>
Link: http://lkml.kernel.org/r/20170913104214.7325-1-qiuxu.zhuo@intel.com
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
... and use the macro for that.
No functionality change.
struct mce.cpuid contains CPUID(1).EAX which contains family, model and
stepping and thus has enough information for our purposes. Thus get rid
of some external dependencies which are not really needed.
Singular fits better because it decodes a single error.
Make these const as they are only stored in the type field of a device
structure, which is const.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
Link: http://lkml.kernel.org/r/1503130946-2854-2-git-send-email-bhumirks@gmail.com
Properly handle hidden state of P2SB PCI device (DEV:D, FUN:0) for
Apollo Lake.
Link: http://lkml.kernel.org/r/20170814154905.21707-1-qiuxu.zhuo@intel.com
On Deverton server, the P2SB PCI device (DEV:1F, FUN:1) is used by multiple
device drivers.
If it's hidden by some device driver (e.g. with the i801 I2C driver,
the commit
9424693035a5 ("i2c: i801: Create iTCO device on newer Intel PCHs")
unconditionally hid the P2SB PCI device wrongly) it will make the
pnd2_edac driver read out an invalid BAR value of 0xffffffff and then
fail on ioremap().
Therefore, store the presence state of P2SB PCI device before unhiding
it for reading BAR and restore the presence state after reading BAR.
Cc: linux-i2c@vger.kernel.org
Link: http://lkml.kernel.org/r/20170814154845.21663-1-qiuxu.zhuo@intel.com
Bit[0] of BAR is always zero. Bit[2:1] and bit[3] of BAR contain the
information of 'type' and the 'prefetchable' accordingly. Therefore,
mask the lower four bits to retrieve the actual base address of a BAR.
Link: http://lkml.kernel.org/r/20170814154813.21619-1-qiuxu.zhuo@intel.com
Return the proper error value if ioremap() fails (and not 0).
Cc: David Daney <david.daney@cavium.com>
Link: http://lkml.kernel.org/r/20170816045821.14165-1-christophe.jaillet@wanadoo.fr
[ Massage commit message, remove newline. ]
Return the proper error value if devm_ioremap() fails (and not 0).
Acked-by: Thor Thayer <thor.thayer@linux.intel.com>
Link: http://lkml.kernel.org/r/20170816050506.14541-1-christophe.jaillet@wanadoo.fr
I've been waing a long time for the generic sideband driver to
appear. Patience has run out, so include the minimum here to
just read registers.
Cc: Aristeu Rozanski <arozansk@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: Patrick Geary <patrickg@supermicro.com>
Link: http://lkml.kernel.org/r/20170803210536.5662-1-tony.luck@intel.com
Basically, there are full memory mirroring and address range partial
memory mirroring (supported by Haswell EX and Broadwell EX) modes.
a) In full memory mirroring, the memory behind each memory controller
is mirrored, i.e. the memory is split into two identical mirrors
(primary and secondary), half of the memory is reserved for redundancy.
b) In address range partial memory mirroring, the memory size (range)
of primary and secondary behind each memory controller can be user
defined by the TAD0 register. The rest of memory ranges defined by
TAD1/TAD2/... in that memory controller are non-mirrored.
For more detail on memory mirroring, see the following link written by Tony Luck:
https://01.org/lkp/blogs/tonyluck/2016/address-range-partial-memory-mirroring-linux
Currently the sb_edac driver only supports address decoding in full
memory mirroring and non-mirroring modes. In address range partial
memory mirroring mode, it may fail to decode an address that falls in a
non-mirroring area (the following was one of this kind of failed logs).
mce: Uncorrected hardware memory error in user-access at 566d53a400
Memory failure: 0x566d53a: Killing einj_mem_uc:4647 due to hardware memory corruption
Memory failure: 0x566d53a: recovery action for dirty LRU page: Recovered
mce: [Hardware Error]: Machine check events logged
EDAC sbridge MC1: HANDLING MCE MEMORY ERROR
EDAC sbridge MC1: CPU 48: Machine Check Event: 0 Bank 7: ec00000000010090
EDAC sbridge MC1: TSC 4b914aa5a99dab
EDAC sbridge MC1: ADDR 566d53a400
EDAC sbridge MC1: MISC 1443a0c86
EDAC sbridge MC1: PROCESSOR 0:406f1 TIME 1499712764 SOCKET 2 APIC 80
EDAC MC1: 0 UE Can't discover the memory rank for ch addr 0x7fb54e900 on any memory ( page:0x0 offset:0x0 grain:32)
Therefore, classify memory mirroring modes and make the address decoding
in address range partial memory mode correct.
Link: http://lkml.kernel.org/r/20170730180651.30060-1-qiuxu.zhuo@intel.com
Now that we have a custom printf format specifier, convert users of
full_name to use %pOF instead. This is preparation to remove storing of
the full path string for each node.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: devicetree@vger.kernel.org
Link: http://lkml.kernel.org/r/20170718214339.7774-19-robh@kernel.org
It is a write-only variable so get rid of it.
Acked-by: Robert Richter <rric@kernel.org>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: Mark Gross <mark.gross@intel.com>
Cc: Tim Small <tim@buttersideup.com>
Cc: Ranganathan Desikan <ravi@jetztechnologies.com>
Cc: "Arvind R." <arvino55@gmail.com>
Cc: Jason Baron <jbaron@akamai.com>
Cc: "Sören Brinkmann" <soren.brinkmann@xilinx.com>
Cc: Loc Ho <lho@apm.com>
Cc: linux-edac@vger.kernel.org
attribute_groups are not supposed to change at runtime. All functions
working with attribute_groups provided by <linux/sysfs.h> work with
const attribute_group. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
CC: linux-edac@vger.kernel.org
Link: http://lkml.kernel.org/r/776cb8265509054abd01b0b551624cc0da3b88e7.1499078335.git.arvind.yadav.cs@gmail.com
Using the homegrown amd_get_nb_id() to find a node ID on AMD was fine
while the L3 to node mapping was 1:1. And Zen topology broke this. So
let's start slowly moving away from it and use the topology interfaces
instead.
Cc: x86-ml <x86@kernel.org>
Link: http://lkml.kernel.org/r/1490041614-90057-2-git-send-email-Yazen.Ghannam@amd.com
Non-existent or empty DIMM slots result in error return from
RD_REGP(). But we shouldn't give up on failure.
So long as we find at least one DIMM we can continue.
Link: http://lkml.kernel.org/r/20170628234407.21521-1-tony.luck@intel.com
In the i5000 and i5400 drivers, the NRECMEMB register is defined as a
16-bit value, which results in wrong shifts in the code, as reported by
sparse.
In the datasheets ([1], section 3.9.22.20 and [2], section 3.9.22.21),
this register is a 32-bit register. A u32 value for the register fixes
the wrong shifts warnings and matches the datasheet.
Also fix the mask to access to the CAS bits [27:16] in the i5000 driver.
[1]: https://www.intel.com/content/dam/doc/datasheet/5000p-5000v-5000z-chipset-memory-controller-hub-datasheet.pdf
[2]: https://www.intel.se/content/dam/doc/datasheet/5400-chipset-memory-controller-hub-datasheet.pdf
Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr>
Link: http://lkml.kernel.org/r/20170629005729.8478-1-jeremy.lefaure@lse.epita.fr
The function sbi_send() is local to just pnd2_edac.c and does not need
to be in global scope, so make it static.
Link: http://lkml.kernel.org/r/20170623084855.9197-1-colin.king@canonical.com
Add code comment to make it clear that the fall-through is intentional
and, OR ret with its previous value to avoid overwriting it so that
callers can check the correct return value.
Link: http://lkml.kernel.org/r/20170622220535.GA4896@embeddedgus
[ Massage a bit. ]
Use of_address_to_resource() and resource_size() instead of manually
parsing the "reg" property from the "memory" node(s).
Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Thor Thayer <thor.thayer@linux.intel.com>
Link: http://lkml.kernel.org/r/20170606235500.22772-3-chris.packham@alliedtelesis.co.nz
Xiaolong Ye reported the following failure on Broadwell D server:
EDAC MC: Removed device 0 for sbridge_edac.c Broadwell SrcID#0_Ha#0: DEV 0000:ff:12.0
Broadwell D (only IMC0 per socket) and Broadwell X (IMC0 and IMC1 per
socket) use the same PCI device IDs for IMC0 per socket, then they
share pci_dev_descr_broadwell_table (n_imcs_per_sock=2). In this case,
Broadwell D wrongly creates the nonexistent SOCK EDAC memory controller
and reports above error messages, since it has no IMC1 per socket.
Avoid creating the nonexistent SOCK memory controller.
Reported-and-tested-by: Xiaolong Ye <xiaolong.ye@intel.com>
Link: http://lkml.kernel.org/r/20170608113351.25323-1-qiuxu.zhuo@intel.com
[ Massage. ]
Fix typo in "poison consumption" error description.
Link: http://lkml.kernel.org/r/1497286703-62853-1-git-send-email-Yazen.Ghannam@amd.com
edac_op_state is a module parameter which affects the behaviour of
the driver probe which can potentially be invoked as soon as the
platform driver registration happens. Because of this we need to
ensure that we sanity check the module parameter before calling
platform_register_drivers().
Link: http://lkml.kernel.org/r/20170607215530.8604-1-chris.packham@alliedtelesis.co.nz
