path: root/drivers/edac
2013-02-03EDAC: Test correct variable in ->store functionDan Carpenter
commit 8024c4c0b1057d1cd811fc9c3f88f81de9729fcd upstream. We're testing for ->show but calling ->store(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-10i7300_edac: Fix error flag testingJean Delvare
commit 7e06b7a3333f5c7a0cec12aff20d39c5c87c0795 upstream. * Right-shift the values in GET_FBD_FAT_IDX and GET_FBD_NF_IDX, so that the callers get the result they expect. * Fix definition of FERR_FAT_FBD_ERR_MASK. * Call GET_FBD_NF_IDX, not GET_FBD_FAT_IDX, when operating on register FERR_NF_FBD. We were lucky they have the same definition. This fixes kernel bug #44131: https://bugzilla.kernel.org/show_bug.cgi?id=44131 Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28amd64_edac:__amd64_set_scrub_rate(): avoid overindexing scrubrates[]Andrew Morton
commit 168bfeef7bba3f9784f7540b053e4ac72b769ce9 upstream. If none of the elements in scrubrates[] matches, this loop will cause __amd64_set_scrub_rate() to incorrectly use the n+1th element. As the function is designed to use the final scrubrates[] element in the case of no match, we can fix this bug by simply terminating the array search at the n-1th element. Boris: this code is fragile anyway, see here why: http://marc.info/?l=linux-kernel&m=135102834131236&w=2 It will be rewritten more robustly soonish. Reported-by: Denis Kirjanov <kirjanov@gmail.com> Cc: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-22edac: fix the error about memory type detection on SandyBridgeChen Gong
commit 2cbb587d3bc41a305168e91b4f3c5b6944a12566 upstream. On SandyBridge, DDRIOA(Dev: 17 Func: 0 Offset: 328) is used to detect whether DIMM is RDIMM/LRDIMM, not TA(Dev: 15 Func: 0). Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-22edac: avoid mce decoding crash after edac driver unloadedChen Gong
commit e35fca4791fcdd43dc1fd769797df40c562ab491 upstream. Some edac drivers register themselves as mce decoders via notifier_chain. But in current notifier_chain implementation logic, it doesn't accept same notifier registered twice. If so, it will be wrong when adding/removing the element from the list. For example, on one SandyBridge platform, remove module sb_edac and then trigger one error, it will hit oops because it has no mce decoder registered but related notifier_chain still points to an invalid callback function. Here is an example: Call Trace: [<ffffffff8150ef6a>] atomic_notifier_call_chain+0x1a/0x20 [<ffffffff8102b936>] mce_log+0x46/0x180 [<ffffffff8102eaea>] apei_mce_report_mem_error+0x4a/0x60 [<ffffffff812e19d2>] ghes_do_proc+0x192/0x210 [<ffffffff812e2066>] ghes_proc+0x46/0x70 [<ffffffff812e20d8>] ghes_notify_sci+0x48/0x80 [<ffffffff8150ef05>] notifier_call_chain+0x55/0x80 [<ffffffff81076f1a>] __blocking_notifier_call_chain+0x5a/0x80 [<ffffffff812aea11>] ? acpi_os_wait_events_complete+0x23/0x23 [<ffffffff81076f56>] blocking_notifier_call_chain+0x16/0x20 [<ffffffff812ddc4d>] acpi_hed_notify+0x19/0x1b [<ffffffff812b16bd>] acpi_device_notify+0x19/0x1b [<ffffffff812beb38>] acpi_ev_notify_dispatch+0x67/0x7f [<ffffffff812aea3a>] acpi_os_execute_deferred+0x29/0x36 [<ffffffff81069dc2>] process_one_work+0x132/0x450 [<ffffffff8106bbcb>] worker_thread+0x17b/0x3c0 [<ffffffff8106ba50>] ? manage_workers+0x120/0x120 [<ffffffff81070aee>] kthread+0x9e/0xb0 [<ffffffff81514724>] kernel_thread_helper+0x4/0x10 [<ffffffff81070a50>] ? kthread_freezable_should_stop+0x70/0x70 [<ffffffff81514720>] ? gs_change+0x13/0x13 Code: f3 49 89 d4 45 85 ed 4d 89 c6 48 8b 0f 74 48 48 85 c9 75 17 eb 41 0f 1f 80 00 00 00 00 41 83 ed 01 4c 89 f9 74 22 4d 85 ff 74 1d <4c> 8b 79 08 4c 89 e2 48 89 de 48 89 cf ff 11 4d 85 f6 74 04 41 RIP [<ffffffff8150eef6>] notifier_call_chain+0x46/0x80 RSP <ffff88042868fb20> CR2: ffffffffa01af838 ---[ end trace 0100930068e73e6f ]--- BUG: unable to handle kernel paging request at fffffffffffffff8 IP: [<ffffffff810705b0>] kthread_data+0x10/0x20 PGD 1a0d067 PUD 1a0e067 PMD 0 Oops: 0000 [#2] SMP Only i7core_edac and sb_edac have such issues because they have more than one memory controller which means they have to register mce decoder many times. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-06Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull arch/tile bug fixes from Chris Metcalf: "This includes Paul Gortmaker's change to fix the <asm/system.h> disintegration issues on tile, a fix to unbreak the tilepro ethernet driver, and a backlog of bugfix-only changes from internal Tilera development over the last few months. They have all been to LKML and on linux-next for the last few days. The EDAC change to MAINTAINERS is an oddity but discussion on the linux-edac list suggested I ask you to pull that change through my tree since they don't have a tree to pull edac changes from at the moment." * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (39 commits) drivers/net/ethernet/tile: fix netdev_alloc_skb() bombing MAINTAINERS: update EDAC information tilepro ethernet driver: fix a few minor issues tile-srom.c driver: minor code cleanup edac: say "TILEGx" not "TILEPro" for the tilegx edac driver arch/tile: avoid accidentally unmasking NMI-type interrupt accidentally arch/tile: remove bogus performance optimization arch/tile: return SIGBUS for addresses that are unaligned AND invalid arch/tile: fix finv_buffer_remote() for tilegx arch/tile: use atomic exchange in arch_write_unlock() arch/tile: stop mentioning the "kvm" subdirectory arch/tile: export the page_home() function. arch/tile: fix pointer cast in cacheflush.c arch/tile: fix single-stepping over swint1 instructions on tilegx arch/tile: implement panic_smp_self_stop() arch/tile: add "nop" after "nap" to help GX idle power draw arch/tile: use proper memparse() for "maxmem" options arch/tile: fix up locking in pgtable.c slightly arch/tile: don't leak kernel memory when we unload modules arch/tile: fix bug in delay_backoff() ...
2012-04-04MCE, AMD: Drop too granulary family model checksBorislav Petkov
MCA details seldom change inbetween the models of a family so don't be too conservative and enable decoding on everything starting from K8 onwards. Minor adjustments can come in later but most importantly, we have some decoding infrastructure in place for upcoming models by default. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2012-04-02edac: say "TILEGx" not "TILEPro" for the tilegx edac driverChris Metcalf
This is just an aesthetic change but it was silly to say TILEPro when booting up on the tilegx architecture. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-03-28Merge branch 'linux_next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac Pull EDAC fixes from Mauro Carvalho Chehab: "A series of EDAC driver fixes. It also has one core fix at the documentation, and a rename patch, fixing the name of the struct that contains the rank information." * 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac: edac: rename channel_info to rank_info i5400_edac: Avoid calling pci_put_device() twice edac: i5100 ack error detection register after each read edac: i5100 fix erroneous define for M1Err edac: sb_edac: Fix a wrong value setting for the previous value edac: sb_edac: Fix a INTERLEAVE_MODE() misuse edac: sb_edac: Let the driver depend on PCI_MMCONFIG edac: Improve the comments to better describe the memory concepts edac/ppc4xx_edac: Fix compilation Fix sb_edac compilation with 32 bits kernels
2012-03-24Merge tag 'device-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/device.h> avoidance patches from Paul Gortmaker: "Nearly every subsystem has some kind of header with a proto like: void foo(struct device *dev); and yet there is no reason for most of these guys to care about the sub fields within the device struct. This allows us to significantly reduce the scope of headers including headers. For this instance, a reduction of about 40% is achieved by replacing the include with the simple fact that the device is some kind of a struct. Unlike the much larger module.h cleanup, this one is simply two commits. One to fix the implicit <linux/device.h> users, and then one to delete the device.h includes from the linux/include/ dir wherever possible." * tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: device.h: audit and cleanup users in main include dir device.h: cleanup users outside of linux/include (C files)
2012-03-23Merge tag 'amd64-edac-updates-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp Pull AMD64 EDAC fixes from Borislav Petkov: "A bunch of fixes/updates for the AMD side of EDAC including * MCE decoding updates * tree-wide EDAC sweep making pci_device_ids __devinitconst * Scrub rate API correction * two amd64_edac corrections for K8 boxes and sysfs csrow nodes" * tag 'amd64-edac-updates-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: MCE, AMD: Constify error tables MCE, AMD: Correct bank 5 error signatures MCE, AMD: Rework NB MCE signatures MCE, AMD: Correct VB data error description MCE, AMD: Correct ucode patch buffer description MCE, AMD: Correct some MC0 error types EDAC: Make pci_device_id tables __devinitconst. EDAC: Correct scrub rate API amd64_edac: Fix K8 revD and later chip select sizes amd64_edac: Fix missing csrows sysfs nodes
2012-03-21edac: rename channel_info to rank_infoMauro Carvalho Chehab
What it is pointed by a csrow/channel vector is a rank information, and not a channel information. On a traditional architecture, the memory controller directly access the memory ranks, via chip select rows. Different ranks at the same DIMM is selected via different chip select rows. So, typically, one csrow/channel pair means one different DIMM. On FB-DIMMs, there's a microcontroller chip at the DIMM, called Advanced Memory Buffer (AMB) that serves as the interface between the memory controller and the memory chips. The AMB selection is via the DIMM slot, and not via a csrow. It is up to the AMB to talk with the csrows of the DRAM chips. So, the FB-DIMM memory controllers see the DIMM slot, and not the DIMM rank. RAMBUS is similar. Newer memory controllers, like the ones found on Intel Sandy Bridge and Nehalem, even working with normal DDR3 DIMM's, don't use the usual channel A/channel B interleaving schema to provide 128 bits data access. Instead, they have more channels (3 or 4 channels), and they can use several interleaving schemas. Such memory controllers see the DIMMs directly on their registers, instead of the ranks, which is better for the driver, as its main usageis to point to a broken DIMM stick (the Field Repleceable Unit), and not to point to a broken DRAM chip. The drivers that support such such newer memory architecture models currently need to fake information and to abuse on EDAC structures, as the subsystem was conceived with the idea that the csrow would always be visible by the CPU. To make things a little worse, those drivers don't currently fake csrows/channels on a consistent way, as the concepts there don't apply to the memory controllers they're talking with. So, each driver author interpreted the concepts using a different logic. In order to fix it, let's rename the data structure that points into a DIMM rank to "rank_info", in order to be clearer about what's stored there. Latter patches will provide a better way to represent the memory hierarchy for the other types of memory controller. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-21i5400_edac: Avoid calling pci_put_device() twiceMauro Carvalho Chehab
When i5400_edac driver is removed and re-loaded a few times, it causes an OOPS, as it is currently decrementing some PCI device usage two times. When called inside a loop, pci_get_device() will call pci_put_device(). That mangles the error count. In this specific case, it seems easier to just duplicate the call. Also fixes the error logic when pci_get_device fails. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-21edac: i5100 ack error detection register after each readNiklas Söderlund
If I only ack the detection register after a error have been detected I'm unable to reliably detect errors. I have verified this behavior using both an error injection DIMM and software to inject errors. I can't find any documentation supporting this behavior in Intel 5100 Memory Controller Hub Chipset, see 1. So this is all based on experimentation. [1] Intel® 5100 Memory Controller Hub Chipset http://www.intel.com/content/dam/doc/datasheet/5100- memory-controller-hub-chipset-datasheet.pdf Signed-off-by: Niklas Söderlund <niklas.soderlund@ericsson.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-21edac: i5100 fix erroneous define for M1ErrNiklas Söderlund
According to [1] the define for M1Err in the FERR_NF_MEM register is wrong. It should be at position 1 not 0. [1] Intel 5100 Memory Controller Hub Chipset Doc.Nr: 318378 http://www.intel.com/content/dam/doc/datasheet/5100- memory-controller-hub-chipset-datasheet.pdf Reported-by: Ba Thang Nguyen <thang.b.nguyen@dektech.com.au> Signed-off-by: Niklas Söderlund <niklas.soderlund@ericsson.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-21edac: sb_edac: Fix a wrong value setting for the previous valueHui Wang
>From the driver design, the variable limit wants to compare with its previous value, we should set the value of limit instead of the value of tmp_mb to the variable prev. Signed-off-by: Hui Wang <jason77.wang@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-21edac: sb_edac: Fix a INTERLEAVE_MODE() misuseHui Wang
We can identify dram interleave mode from the Dram Rule register rather than Dram Interleave list register. In this context, the reg of INTERLEAVE_MODE(reg) contains the Dram Interleave list register, we can't get interleave mode from the reg, while the variable interleave_mode saves the the mode got from the Dram Rule register, so we use the variable to replace INTERLEAVE_MDDE(reg) here. Signed-off-by: Hui Wang <jason77.wang@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-21edac: sb_edac: Let the driver depend on PCI_MMCONFIGHui Wang
This driver needs to access PCIe Extended Configuration Space Registers (0x100~0xfff), to correctly access those registers, we need to enable PCI_MMCONFIG option. Since this option is not enabled for X86_64 by default, we let the driver depend on it to prevent users forgetting to enable this option. Signed-off-by: Hui Wang <jason77.wang@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-21edac/ppc4xx_edac: Fix compilationMauro Carvalho Chehab
It seems that nobody is cross-compiling for this arch anymore... drivers/edac/ppc4xx_edac.c: In function 'ppc4xx_edac_probe': drivers/edac/ppc4xx_edac.c:188:12: error: storage class specified for parameter 'ppc4xx_edac_remove' ... drivers/edac/ppc4xx_edac.c:1068:19: error: 'match' undeclared (first use in this function) drivers/edac/ppc4xx_edac.c:1068:19: note: each undeclared identifier is reported only once for each function it appears in drivers/edac/ppc4xx_edac.c:1068:36: warning: left-hand operand of comma expression has no effect [-Wunused-value] Acked-by: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-21Fix sb_edac compilation with 32 bits kernelsMauro Carvalho Chehab
As reported by Josh Boyer <jwboyer@redhat.com>: > drivers/edac/sb_edac.c: In function 'get_memory_error_data': > drivers/edac/sb_edac.c:861:2: warning: left shift count >= width of type > [enabled by default] > <snip> > ERROR: "__udivdi3" [drivers/edac/sb_edac.ko] undefined! > make[1]: *** [__modpost] Error 1 > make: *** [modules] Error 2 PS.: compile-tested only Reported-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-20edac: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-19MCE, AMD: Constify error tablesBorislav Petkov
... so that checkpatch can chill out. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Reviewed-by: Andreas Herrmann <andreas.herrmann3@amd.com>
2012-03-19MCE, AMD: Correct bank 5 error signaturesBorislav Petkov
... and remove superfluous ErrorCodeExt check. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Reviewed-by: Andreas Herrmann <andreas.herrmann3@amd.com>
2012-03-19MCE, AMD: Rework NB MCE signaturesBorislav Petkov
Correct their formulation, replace per-family functions with a single, unified lookup table. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Reviewed-by: Andreas Herrmann <andreas.herrmann3@amd.com>
2012-03-19MCE, AMD: Correct VB data error descriptionBorislav Petkov
Sync with latest BKDG error types. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Reviewed-by: Andreas Herrmann <andreas.herrmann3@amd.com>
2012-03-19MCE, AMD: Correct ucode patch buffer descriptionBorislav Petkov
This MC1 error signature is called differently now, fix it. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Reviewed-by: Andreas Herrmann <andreas.herrmann3@amd.com>
2012-03-19MCE, AMD: Correct some MC0 error typesBorislav Petkov
Use "System Read Data Error" as a more general name for MC0 bus errors on F15h and update some error definitions. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Reviewed-by: Andreas Herrmann <andreas.herrmann3@amd.com>
2012-03-19EDAC: Make pci_device_id tables __devinitconst.Lionel Debroux
These const tables are currently marked __devinitdata, but Documentation/PCI/pci.txt says: "o The ID table array should be marked __devinitconst; this is done automatically if the table is declared with DEFINE_PCI_DEVICE_TABLE()." So use DEFINE_PCI_DEVICE_TABLE(x). Based on PaX and earlier work by Andi Kleen. Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2012-03-19EDAC: Correct scrub rate APIBorislav Petkov
The original scrub rate API definition states that if scrub rate accessors are not implemented, a negative value (-1) should be written to the sysfs file (/sys/devices/system/edac/mc/mc<N>/sdram_scrub_rate, where N is the memory controller number on the system). This is counter-intuitive and awkward at the very least because, when setting the scrub rate, userspace has to write to sysfs and then read it back to check error status of the operation. As Tony notes, best it would be to not have the sdram_scrub_rate in sysfs if scrub rate support is not implemented. It is too late about that and a bunch of drivers on a bunch of arches would need to be changed and tested which is not a trivial task ATM. Instead, settle for the next best thing of returning -ENODEV when implementation is missing and -EINVAL when there was an error encountered while setting the scrub rate. Reported-by: Han Pingtian <phan@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Link: http://lkml.kernel.org/r/20110916105856.GA13253@hpt.nay.redhat.com Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2012-03-19amd64_edac: Fix K8 revD and later chip select sizesBorislav Petkov
Fix DRAM chip select sizes calculation for K8, revisions D and E. Reported-by: Niklas Söderlund <niklas.soderlund@ericsson.com Link: http://lkml.kernel.org/r/1320849178-23340-1-git-send-email-niklas.soderlund@ericsson.com Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2012-03-19amd64_edac: Fix missing csrows sysfs nodesAshish Shenoy
While initializing the array of csrow attribute instances, a few csrows were uninitialized. This happened because the module only performed a check for DRAM base ctl register0's and not DRAM base ctl register1's chip select enable bit. There could be systems with DIMMs populated on only single memory channel whereas the module also assumed that a dual channel dimm had double the memory size of a single memory channel instead of checking the memory on each channel. This patch fixes these above issues. Signed-off-by: Ashish Shenoy <ashenoy@riverbed.com> Signed-off-by: Prasanna S. Panchamukhi <ppanchamukhi@riverbed.com> Link: http://lkml.kernel.org/r/4F459CFA.5090604@riverbed.com Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2012-03-11device.h: cleanup users outside of linux/include (C files)Paul Gortmaker
For files that are actively using linux/device.h, make sure that they call it out. This will allow us to clean up some of the implicit uses of linux/device.h within include/* without introducing build regressions. Yes, this was created by "cheating" -- i.e. the headers were cleaned up, and then the fallout was found and fixed, and then the two commits were reordered. This ensures we don't introduce build regressions into the git history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-21asm-generic: architecture independent readq/writeq for 32bit environmentHitoshi Mitake
This provides unified readq()/writeq() helper functions for 32-bit drivers. For some cases, readq/writeq without atomicity is harmful, and order of io access has to be specified explicitly. So in this patch, new two header files which contain non-atomic readq/writeq are added. - <asm-generic/io-64-nonatomic-lo-hi.h> provides non-atomic readq/ writeq with the order of lower address -> higher address - <asm-generic/io-64-nonatomic-hi-lo.h> provides non-atomic readq/ writeq with reversed order This allows us to remove some readq()s that were added drivers when the default non-atomic ones were removed in commit dbee8a0affd5 ("x86: remove 32-bit versions of readq()/writeq()") The drivers which need readq/writeq but can do with the non-atomic ones must add the line: #include <asm-generic/io-64-nonatomic-lo-hi.h> /* or hi-lo.h */ But this will be nop in 64-bit environments, and no other #ifdefs are required. So I believe that this patch can solve the problem of 1. driver-specific readq/writeq 2. atomicity and order of io access This patch is tested with building allyesconfig and allmodconfig as ARCH=x86 and ARCH=i386 on top of tip/master. Cc: Kashyap Desai <Kashyap.Desai@lsi.com> Cc: Len Brown <lenb@kernel.org> Cc: Ravi Anand <ravi.anand@qlogic.com> Cc: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Jason Uhlenkott <juhlenko@akamai.com> Cc: James Bottomley <James.Bottomley@parallels.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Roland Dreier <roland@purestorage.com> Cc: James Bottomley <jbottomley@parallels.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hitoshi Mitake <h.mitake@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-07Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits) arm: fix up some samsung merge sysdev conversion problems firmware: Fix an oops on reading fw_priv->fw in sysfs loading file Drivers:hv: Fix a bug in vmbus_driver_unregister() driver core: remove __must_check from device_create_file debugfs: add missing #ifdef HAS_IOMEM arm: time.h: remove device.h #include driver-core: remove sysdev.h usage. clockevents: remove sysdev.h arm: convert sysdev_class to a regular subsystem arm: leds: convert sysdev_class to a regular subsystem kobject: remove kset_find_obj_hinted() m86k: gpio - convert sysdev_class to a regular subsystem mips: txx9_sram - convert sysdev_class to a regular subsystem mips: 7segled - convert sysdev_class to a regular subsystem sh: dma - convert sysdev_class to a regular subsystem sh: intc - convert sysdev_class to a regular subsystem power: suspend - convert sysdev_class to a regular subsystem power: qe_ic - convert sysdev_class to a regular subsystem power: cmm - convert sysdev_class to a regular subsystem s390: time - convert sysdev_class to a regular subsystem ... Fix up conflicts with 'struct sysdev' removal from various platform drivers that got changed: - arch/arm/mach-exynos/cpu.c - arch/arm/mach-exynos/irq-eint.c - arch/arm/mach-s3c64xx/common.c - arch/arm/mach-s3c64xx/cpu.c - arch/arm/mach-s5p64x0/cpu.c - arch/arm/mach-s5pv210/common.c - arch/arm/plat-samsung/include/plat/cpu.h - arch/powerpc/kernel/sysfs.c and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
2012-01-06Merge branch 'x86-mce-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: add IRQ context simulation in module mce-inject x86, mce, therm_throt: Don't report power limit and package level thermal throttle events in mcelog x86, MCE: Drain mcelog buffer x86, mce: Add wrappers for registering on the decode chain
2012-01-06Merge branch 'driver-core-next' into Linux 3.2Greg Kroah-Hartman
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file, and it fixes the build error in the arch/x86/kernel/microcode_core.c file, that the merge did not catch. The microcode_core.c patch was provided by Stephen Rothwell <sfr@canb.auug.org.au> who was invaluable in the merge issues involved with the large sysdev removal process in the driver-core tree. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21x86: Simplify code by removing a !SMP #ifdefs from 'struct cpuinfo_x86'Kevin Winchester
Several fields in struct cpuinfo_x86 were not defined for the !SMP case, likely to save space. However, those fields still have some meaning for UP, and keeping them allows some #ifdef removal from other files. The additional size of the UP kernel from this change is not significant enough to worry about keeping up the distinction: text data bss dec hex filename 4737168 506459 972040 6215667 5ed7f3 vmlinux.o.before 4737444 506459 972040 6215943 5ed907 vmlinux.o.after for a difference of 276 bytes for an example UP config. If someone wants those 276 bytes back badly then it should be implemented in a cleaner way. Signed-off-by: Kevin Winchester <kjwinchester@gmail.com> Cc: Steffen Persvold <sp@numascale.com> Link: http://lkml.kernel.org/r/1324428742-12498-1-git-send-email-kjwinchester@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-14edac: convert sysdev_class to a regular subsystemKay Sievers
After all sysdev classes are ported to regular driver core entities, the sysdev implementation will be entirely removed from the kernel. Cc: Doug Thompson <dougthompson@xmission.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-14x86, mce: Add wrappers for registering on the decode chainBorislav Petkov
No functionality change, this is done so that in a follow-on patch all queued-up MCEs can be decoded after registering on the chain. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-12-02treewide: Fix typos in various parts of the kernel, and fix some comments.Justin P. Mattock
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments. Please let me know if I missed anything, and I will try to get it changed and resent. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-24drivers/edac/mpc85xx_edac.c: fix memory controller compatible for edacShaohui Xie
compatible in dts has been changed, so the driver needs to be updated accordingly. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-13Merge branch 'master' into for-nextJiri Kosina
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver in the config and Makefile") as I have patch depending on that one.
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits) powerpc/p3060qds: Add support for P3060QDS board powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX powerpc/85xx: Make kexec to interate over online cpus powerpc/fsl_booke: Fix comment in head_fsl_booke.S powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver powerpc/86xx: Correct Gianfar support for GE boards powerpc/cpm: Clear muram before it is in use. drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager powerpc/fsl_msi: add support for "msi-address-64" property powerpc/85xx: Setup secondary cores PIR with hard SMP id powerpc/fsl-booke: Fix settlbcam for 64-bit powerpc/85xx: Adding DCSR node to dtsi device trees powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards powerpc/85xx: fix PHYS_64BIT selection for P1022DS powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map powerpc: respect mem= setting for early memory limit setup powerpc: Update corenet64_smp_defconfig powerpc: Update mpc85xx/corenet 32-bit defconfigs ... Fix up trivial conflicts in: - arch/powerpc/configs/40x/hcu4_defconfig removed stale file, edited elsewhere - arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c: added opal and gelic drivers vs added ePAPR driver - drivers/tty/serial/8250.c moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
2011-11-03edac: Only build sb_edac on 64-bitJosh Boyer
The sb_edac driver is marginally useful on a 32-bit kernel, and currently has 64-bit divide compile errors when building that config. For now, make this build on only for 64-bit kernels. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02Merge branch 'linux_next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac * 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac: (21 commits) MAINTAINERS: add an entry for Edac Sandy Bridge driver edac: tag sb_edac as EXPERIMENTAL, as it requires more testing EDAC: Fix incorrect edac mode reporting in sb_edac edac: sb_edac: Add it to the building system edac: Add an experimental new driver to support Sandy Bridge CPU's i7300_edac: Fix error cleanup logic i7core_edac: Initialize memory name with cpu, channel, bank i7core_edac: Fix compilation on 32 bits arch i7core_edac: scrubbing fixups EDAC: Correct Kconfig dependencies i7core_edac: return -ENODEV if no MC is found i7core_edac: use edac's own way to print errors MAINTAINERS: remove dropped edac_mce.* from the file i7core_edac: Drop the edac_mce facility x86, MCE: Use notifier chain only for MCE decoding EDAC i7core: Use mce socketid for better compatibility i7core_edac: Don't enable memory scrubbing for Xeon 35xx i7core_edac: Add scrubbing support edac: Move edac main structs to include/linux/edac.h i7core_edac: Fix oops when trying to inject errors ...
2011-11-01edac: tag sb_edac as EXPERIMENTAL, as it requires more testingMauro Carvalho Chehab
2011-11-01EDAC: Fix incorrect edac mode reporting in sb_edacMark A. Grondona
The edac driver for Sandy Bridge was found to be reporting "FPM" for edac_mode, which clearly doesn't make sense. It was found that sb_edac.c:get_dimm_config was reusing a variable for both mem_type and edac_type, and thus was overwriting the value after setting it correctly. This patch fixes that issue. Before the patch: /sys/devices/system/edac/mc/mc0/csrow0/edac_mode:FPM /sys/devices/system/edac/mc/mc0/csrow1/edac_mode:FPM /sys/devices/system/edac/mc/mc0/csrow2/edac_mode:FPM /sys/devices/system/edac/mc/mc0/csrow3/edac_mode:FPM After: /sys/devices/system/edac/mc/mc0/csrow0/edac_mode:S4ECD4ED /sys/devices/system/edac/mc/mc0/csrow1/edac_mode:S4ECD4ED /sys/devices/system/edac/mc/mc0/csrow2/edac_mode:S4ECD4ED /sys/devices/system/edac/mc/mc0/csrow3/edac_mode:S4ECD4ED Signed-off-by: Mark A. Grondona <mgrondona@llnl.gov> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
