path: root/drivers/eisa
2014-01-17Revert "EISA: Initialize device before its resources"Bjorn Helgaas
This reverts commit 26abfeed4341872364386c6a52b9acef8c81a81a. In the eisa_probe() force_probe path, if we were unable to request slot resources (e.g., [io 0x800-0x8ff]), we skipped the slot with "Cannot allocate resource for EISA slot %d" before reading the EISA signature in eisa_init_device(). Commit 26abfeed4341 moved eisa_init_device() earlier, so we tried to read the EISA signature before requesting the slot resources, and this caused hangs during boot. Link: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1251816 Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.10+ a2080d0c561c: Revert "EISA: Log device resources in dmesg"
2014-01-17Revert "EISA: Log device resources in dmesg"Bjorn Helgaas
This reverts commit a2080d0c561c546d73cb8b296d4b7ca414e6860b. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-12-13EISA: Call put_device() if device_register() failsLevente Kurusa
We need to give up the last reference to edev->dev, so we need to call put_device(). Signed-off-by: Levente Kurusa <levex@linux.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-04-29Merge tag 'pci-v3.10-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v3.10 merge window: PCI device hotplug - Remove ACPI PCI subdrivers (Jiang Liu, Myron Stowe) - Make acpiphp builtin only, not modular (Jiang Liu) - Add acpiphp mutual exclusion (Jiang Liu) Power management - Skip "PME enabled/disabled" messages when not supported (Rafael Wysocki) - Fix fallback to PCI_D0 (Rafael Wysocki) Miscellaneous - Factor quirk_io_region (Yinghai Lu) - Cache MSI capability offsets & cleanup (Gavin Shan, Bjorn Helgaas) - Clean up EISA resource initialization and logging (Bjorn Helgaas) - Fix prototype warnings (Andy Shevchenko, Bjorn Helgaas) - MIPS: Initialize of_node before scanning bus (Gabor Juhos) - Fix pcibios_get_phb_of_node() declaration "weak" annotation (Gabor Juhos) - Add MSI INTX_DISABLE quirks for AR8161/AR8162/etc (Xiong Huang) - Fix aer_inject return values (Prarit Bhargava) - Remove PME/ACPI dependency (Andrew Murray) - Use shared PCI_BUS_NUM() and PCI_DEVID() (Shuah Khan)" * tag 'pci-v3.10-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (63 commits) vfio-pci: Use cached MSI/MSI-X capabilities vfio-pci: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK PCI: Remove "extern" from function declarations PCI: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK PCI: Drop msi_mask_reg() and remove drivers/pci/msi.h PCI: Use msix_table_size() directly, drop multi_msix_capable() PCI: Drop msix_table_offset_reg() and msix_pba_offset_reg() macros PCI: Drop is_64bit_address() and is_mask_bit_support() macros PCI: Drop msi_data_reg() macro PCI: Drop msi_lower_address_reg() and msi_upper_address_reg() macros PCI: Drop msi_control_reg() macro and use PCI_MSI_FLAGS directly PCI: Use cached MSI/MSI-X offsets from dev, not from msi_desc PCI: Clean up MSI/MSI-X capability #defines PCI: Use cached MSI-X cap while enabling MSI-X PCI: Use cached MSI cap while enabling MSI interrupts PCI: Remove MSI/MSI-X cap check in pci_msi_check_device() PCI: Cache MSI/MSI-X capability offsets in struct pci_dev PCI: Use u8, not int, for PM capability offset [SCSI] megaraid_sas: Use correct #define for MSI-X capability PCI: Remove "extern" from function declarations ...
2013-04-15EISA: Log device resources in dmesgBjorn Helgaas
Note the resources consumed by EISA devices in dmesg, similar to what we already do for PCI and PNP devices. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-04-15EISA: Initialize device before its resourcesBjorn Helgaas
Move eisa_init_device() before eisa_request_resources() so the device name is set before we set up its resources. That way we can print better messages. Previously edev->res[i].name was set to NULL in eisa_request_resources(), then filled in by eisa_init_device(). Now it is filled in by eisa_init_device() first, and we don't want to clear it out later in eisa_request_resources(). Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-04-15EISA: Mark vendor ID resource as I/O port spaceBjorn Helgaas
Previously we marked this as merely IORESOURCE_BUSY without indicating the type. Setting the type makes %pR on the resource work better. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-04-15EISA: Use dev_printk() when possibleBjorn Helgaas
Use dev_printk() when possible to make messages more useful. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-04-01EISA/PCI: Init EISA early, before PNPYinghai Lu
Matthew reported kernels fail the pci_eisa probe and are later successful with the virtual_eisa_root_init force probe without slot0. The reason for that is: PNP probing is before pci_eisa_init gets called as pci_eisa_init is called via pci_driver. pnp 00:0f has 0xc80 - 0xc84 reserved. [ 9.700409] pnp 00:0f: [io 0x0c80-0x0c84] so eisa_probe will fail from pci_eisa_init ==>eisa_root_register ==>eisa_probe path. as force_probe is not set in pci_eisa_root, it will bail early when slot0 is not probed and initialized. Try to use subsys_initcall_sync instead, and will keep following sequence: pci_subsys_init pci_eisa_init_early pnpacpi_init/isapnp_init After this patch EISA can be initialized properly, and PNP overlapping resource will not be reserved. [ 10.104434] system 00:0f: [io 0x0c80-0x0c84] could not be reserved Reported-by: Matthew Whitehead <mwhitehe@redhat.com> Tested-by: Matthew Whitehead <mwhitehe@redhat.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: stable@vger.kernel.org
2013-04-01EISA/PCI: Fix bus res referenceYinghai Lu
Matthew found that 3.8.3 is having problems with an old (ancient) PCI-to-EISA bridge, the Intel 82375. It worked with the 3.2 kernel. He identified the 82375, but doesn't assign the struct resource *res pointer inside the struct eisa_root_device, and panics. pci_eisa_init() was using bus->resource[] directly instead of pci_bus_resource_n(). The bus->resource[] array is a PCI-internal implementation detail, and after commit 45ca9e97 (PCI: add helpers for building PCI bus resource lists) and commit 0efd5aab (PCI: add struct pci_host_bridge_window with CPU/bus address offset), bus->resource[] is not used for PCI root buses any more. The 82375 is a subtractive-decode PCI device, so handle it the same way we handle PCI-PCI bridges in subtractive-decode mode in pci_read_bridge_bases(). [bhelgaas: changelog] Reported-by: Matthew Whitehead <mwhitehe@redhat.com> Tested-by: Matthew Whitehead <mwhitehe@redhat.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: stable@vger.kernel.org # v3.3+
2012-11-19eisa: Fix spelling of "asynchronous".Adam Buchbinder
Some device IDs misspell "asynchronous". String change only. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-08-04eisa/pci_eisa.c: fix BUG introduced by 005bdad7b80Arnaud Lacombe
While `pci_eisa_driver' still refer `pci_eisa_init', the .probe() function should not be called after init memory release, as pointed out by commit 74b9a297. The structure is still referenced in the drivers subsystem, and can be accesseed through sysfs, so the modpost warning is a false positive. Mark it as such. In the same time, the warning referenced in 005bdad7b80 did only mention `pci_eisa_driver', not `pci_eisa_pci_tbl', so remove its marking. Broken-by: Arnaud Lacombe <lacombar@gmail.com> (in 005bdad7b80) Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25eisa/pci_eisa.c: fix section mismatchArnaud Lacombe
Fixes WARNING: vmlinux.o(.data+0x15d3ac): Section mismatch in reference from the variable pci_eisa_driver to the function .init.text:pci_eisa_init() The variable pci_eisa_driver references the function __init pci_eisa_init() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06eisa: fix coding style for eisa bus codeThadeu Lima de Souza Cascardo
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16eisa.ids: add Network Peripherals FDDI boardsMaciej W. Rozycki
Add EISA IDs for Network Peripherals FDDI boards. Descriptions taken from the respective EISA configuration files. It's unlikely we'll ever support these cards, the problem being the lack of documentation. Assuming the policy for the EISA ID database is the same as for PCI I'm sending these entries for the sake of completeness. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Marc Zyngier <maz@misterjones.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15eisa: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24eisa: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2009-01-30x86: allow more than 8 cpus to be used on 32-bitYinghai Lu
X86_PC is the only remaining 'sub' architecture, so we dont need it anymore. This also cleans up a few spurious references to X86_PC in the driver space - those certainly should be X86. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-21driver core: remove DEVICE_NAME_SIZE defineKay Sievers
There is no such thing as a "device name size" in the driver core, so remove the define and fix up any users of this odd define in the rest of the kernel. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-14signedness: module_param_array nump argumentAl Viro
... should be unsigned int Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-08virtual_eisa_root_init() should be __initAndrew Morton
WARNING: vmlinux - Section mismatch: reference to .init.text:eisa_root_register from .text between 'virtual_eisa_root_init' (at offset 0xc026b80f) and 'cpufreq_debug_disable_ratelimit' Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27[PATCH] drivers/eisa/pci_eisa.c:pci_eisa_init() should be initAdrian Bunk
WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:eisa_root_register from .text between 'pci_eisa_init' (at offset 0xabf670) and 'virtual_eisa_release' AFAIK a PCI to EISA bridge isn't anything hotpluggable, so pci_eisa_init() can become __init. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-11[PATCH] EISA: handle sysfs errorsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] EISA bus MODALIAS attributes supportMichael Tokarev
Add modalias attribute support for the almost forgotten now EISA bus and (at least some) EISA-aware modules. The modalias entry looks like (for an 3c509 NIC): eisa:sTCM5093 and the in-module alias like: eisa:sTCM5093* The patch moves struct eisa_device_id declaration from include/linux/eisa.h to include/linux/mod_devicetable.h (so that the former now #includes the latter), adds proper MODULE_DEVICE_TABLE(eisa, ...) statements for all drivers with EISA IDs I found (some drivers already have that DEVICE_TABLE declared), and adds recognision of __mod_eisa_device_table to scripts/mod/file2alias.c so that proper modules.alias will be generated. There's no support for /lib/modules/$kver/modules.eisamap, as it's not used by any existing tools, and because with in-kernel modalias mechanism those maps are obsolete anyway. The rationale for this patch is: a) to make EISA bus to act as other busses with modalias support, to unify driver loading b) to foget about EISA finally - with this patch, kernel (who still supports EISA) will be the only one who knows how to choose the necessary drivers for this bus ;) [akpm@osdl.org: fix the kbuild bit] Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Acked-the-net-bits-by: Jeff Garzik <jeff@garzik.org> Acked-the-tulip-bit-by: Valerie Henson <val_henson@linux.intel.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] EISA: Ignore generated file drivers/eisa/devlist.hRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] EISA: tidy-up driver_register() return valueBjorn Helgaas
Remove the assumption that driver_register() returns the number of devices bound to the driver. In fact, it returns zero for success or a negative error value. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Jeff Garzik <jgarzik@pobox.com> Acked-by: Marc Zyngier <maz@misterjones.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] drivers/eisa: kmalloc + memset -> kzalloc conversionDeepak Saxena
Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] Driver Core: drivers/base - drivers/i2c/chips/adm1026.c: update ↵Yani Ioannou
device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
