path: root/drivers/extcon/extcon-sm5502.c
2017-01-09extcon: Restructure multi-line comments to follow codingstyleSrikant Ritolia
Aligning all block comments in extcon subsystem as per linux coding style. Found using checkpatch.pl script. Signed-off-by: Srikant Ritolia <s.ritolia@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2016-09-13extcon: Use the extcon_set_state_sync() instead of deprecated functionsChanwoo Choi
This patch alters the renamed extcon API to set the state of the external connectors instead of deprecated extcon_set_cable_state_(). Because the patch[1] modifies the function name to maintain the function naming pattern. - extcon_set_cable_state_() -> extcon_set_state_sync() - extcon_get_cable_state_() -> extcon_get_state() [1] https://lkml.org/lkml/2016/8/4/729 - extcon: Rename the extcon_set/get_state() to maintain the function naming pattern Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Roger Quadros <rogerq@ti.com>
2016-01-25extcon: Add the EXTCON_CHG_USB_SDP to support SDP charing portChanwoo Choi
This patch adds the new EXTCON_CHG_USB_SDP connector to support SDP (Standard Downstream Port) USB charging port. The commit 11eecf910bd8 ("extcon: Modify the id and name of external connector") add the new EXTCON_CHG_USB_SDP connector which support the both data transfer and usb charging at the same time. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
2016-01-25extcon: Use to_i2c_client for both rt8973a and sm5502Geliang Tang
Use to_i2c_client() instead of open-coding it. Signed-off-by: Geliang Tang <geliangtang@163.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2015-10-16extcon: Modify the id and name of external connectorChanwoo Choi
This patch modifies the id and name of external connector with the additional prefix to clarify both attribute and meaning of external connector as following: - EXTCON_CHG_* mean the charger connector. - EXTCON_JACK_* mean the jack connector. - EXTCON_DISP_* mean the display port connector. Following table show the new name of external connector with old name: -------------------------------------------------- Old extcon name | New extcon name | -------------------------------------------------- EXTCON_TA | EXTCON_CHG_USB_DCP | EXTCON_CHARGE_DOWNSTREAM| EXTCON_CHG_USB_CDP | EXTCON_FAST_CHARGER | EXTCON_CHG_USB_FAST | EXTCON_SLOW_CHARGER | EXTCON_CHG_USB_SLOW | -------------------------------------------------- EXTCON_MICROPHONE | EXTCON_JACK_MICROPHONE | EXTCON_HEADPHONE | EXTCON_JACK_HEADPHONE | EXTCON_LINE_IN | EXTCON_JACK_LINE_IN | EXTCON_LINE_OUT | EXTCON_JACK_LINE_OUT | EXTCON_VIDEO_IN | EXTCON_JACK_VIDEO_IN | EXTCON_VIDEO_OUT | EXTCON_JACK_VIDEO_OUT | EXTCON_SPDIF_IN | EXTCON_JACK_SPDIF_IN | EXTCON_SPDIF_OUT | EXTCON_JACK_SPDIF_OUT | -------------------------------------------------- EXTCON_HMDI | EXTCON_DISP_HDMI | EXTCON_MHL | EXTCON_DISP_MHL | EXTCON_DVI | EXTCON_DISP_DVI | EXTCON_VGA | EXTCON_DISP_VGA | -------------------------------------------------- And, when altering the name of USB charger connector, EXTCON refers to the "Battery Charging v1.2 Spec and Adopters Agreement"[1] to use the standard name of USB charging port as following. Following name of USB charging port are already used in power_supply subsystem. We chan check it on patch[2]. - EXTCON_CHG_USB_SDP /* Standard Downstream Port */ - EXTCON_CHG_USB_DCP /* Dedicated Charging Port */ - EXTCON_CHG_USB_CDP /* Charging Downstream Port */ - EXTCON_CHG_USB_ACA /* Accessory Charger Adapter */ [1] www.usb.org/developers/docs/devclass_docs/BCv1.2_070312.zip [2] commit 85efc8a18ced ("power_supply: Add types for USB chargers") Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> [ckeepax: For the Arizona changes] Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Reviewed-by: Roger Quadros <rogerq@ti.com>
2015-09-29extcon: sm5502: fix handling regmap_irq_get_virq resultAndrzej Hajda
The function can return negative value. The problem has been detected using proposed semantic patch scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1]. [1]: http://permalink.gmane.org/gmane.linux.kernel/2046107 Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2015-09-29extcon: Export OF module alias information in missing driversJavier Martinez Canillas
The I2C core always reports the MODALIAS uevent as "i2c:<modalias>" regardless of the mechanism that was used to register the device (i.e: OF or board code) and the table that is used later to match the driver with the device (i.e: I2C id table or OF match table). So drivers needs to export the I2C id table and this be built into the module or udev won't have the necessary information to autoload the needed driver module when the device is added. But this means that OF-only drivers needs to have both OF and I2C id tables that have to be kept in sync and also the dev node compatible manufacturer prefix is stripped when reporting the MODALIAS. Which can lead to issues if two vendors use the same I2C device name for example. To avoid the above, the I2C core behavior may be changed in the future to not require an SPI device table for OF-only drivers and report the OF module alias. So, it's better to also export the OF table even when is unused now to prevent breaking module loading when the core changes. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2015-08-10extcon: Drop owner assignment from i2c_driverKrzysztof Kozlowski
i2c_driver does not need to set an owner because i2c_register_driver() will set it. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2015-06-12extcon: Redefine the unique id of supported external connectors without ↵Chanwoo Choi
'enum extcon' type This patch just redefine the unique id of supported external connectors without 'enum extcon' type. Because unique id would be used on devictree file(*.dts) to indicate the specific external connectors like key number of input framework. So, I have the plan to move this definitions to following header file which includes the unique id of supported external connectors. - include/dt-bindings/extcon/extcon.h Fixes: 2a9de9c0f08d ("extcon: Use the unique id for external connector instead of string") Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-22extcon: Use the unique id for external connector instead of stringChanwoo Choi
This patch uses the unique id to identify the type of external connector instead of string name. The string name have the many potential issues. So, this patch defines the 'extcon' enumeration which includes all supported external connector on EXTCON subsystem. If new external connector is necessary, the unique id of new connector have to be added in 'extcon' enumeration. There are current supported external connector in 'enum extcon' as following: enum extcon { EXTCON_NONE = 0x0, /* USB external connector */ EXTCON_USB = 0x1, EXTCON_USB_HOST = 0x2, /* Charger external connector */ EXTCON_TA = 0x10, EXTCON_FAST_CHARGER = 0x11, EXTCON_SLOW_CHARGER = 0x12, EXTCON_CHARGE_DOWNSTREAM = 0x13, /* Audio and video external connector */ EXTCON_LINE_IN = 0x20, EXTCON_LINE_OUT = 0x21, EXTCON_MICROPHONE = 0x22, EXTCON_HEADPHONE = 0x23, EXTCON_HDMI = 0x30, EXTCON_MHL = 0x31, EXTCON_DVI = 0x32, EXTCON_VGA = 0x33, EXTCON_SPDIF_IN = 0x34, EXTCON_SPDIF_OUT = 0x35, EXTCON_VIDEO_IN = 0x36, EXTCON_VIDEO_OUT = 0x37, /* Miscellaneous external connector */ EXTCON_DOCK = 0x50, EXTCON_JIG = 0x51, EXTCON_MECHANICAL = 0x52, EXTCON_END, }; For example in extcon-arizona.c: To use unique id removes the potential issue about handling the inconsistent name of external connector with string. - Previously, use the string to register the type of arizona jack connector static const char *arizona_cable[] = { "Mechanical", "Microphone", "Headphone", "Line-out", }; - Newly, use the unique id to register the type of arizona jack connector static const enum extcon arizona_cable[] = { EXTCON_MECHANICAL, EXTCON_MICROPHONE, EXTCON_HEADPHONE, EXTCON_LINE_OUT, EXTCON_NONE, }; And this patch modify the prototype of extcon_{get|set}_cable_state_() which uses the 'enum extcon id' instead of 'cable_index'. Because although one more extcon drivers support USB cable, each extcon driver might has the differnt 'cable_index' for USB cable. All extcon drivers can use the unique id number for same external connector with modified extcon_{get|set}_cable_state_(). - Previously, use 'cable_index' on these functions: extcon_get_cable_state_(struct extcon_dev*, int cable_index) extcon_set_cable_state_(struct extcon_dev*, int cable_index, bool state) -Newly, use 'enum extcon id' on these functions: extcon_get_cable_state_(struct extcon_dev*, enum extcon id) extcon_set_cable_state_(struct extcon_dev*, enum extcon id, bool state) Cc: Arnd Bergmann <arnd@arndb.de> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Roger Quadros <rogerq@ti.com> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Ramakrishna Pallala <ramakrishna.pallala@intel.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> [arnd: Report the build break about drivers/usb/phy/phy-tahvo.c after using the unique id for external connector insteadf of string] Reported-by: Arnd Bergmann <arnd@arndb.de> [dan.carpenter: Report the build warning of extcon_{set|get}_cable_state_()] Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
2015-05-19extcon: Remove the optional name of extcon deviceChanwoo Choi
This patch removes the optional name of extcon device. Instead, extcon_dev_register() set the device name as 'extcon[number]' naming pattern. - /sys/class/extcon/[hardcoded device name] -> /sys/class/extcon/extcon[number] Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Cc: Graeme Gregory <gg@slimlogic.co.uk> Cc: Kishon Vijay Abraham I <kishon@ti.com> Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: Jaewon Kim <jaewon02.kim@samsung.com>
2015-03-07extcon: Fix the checkpatch warningChanwoo Choi
This patch fixes the checkpatch warning about coding style. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-09-22extcon: sm5502: Drop useless includeJean Delvare
Don't include <linux/input.h> when the driver does not use anything from this header file. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Cc: Chanwoo Choi <cw00.choi@samsung.com> Cc: MyungJoo Ham <myungjoo.ham@samsung.com>
2014-09-22extcon: sm5502: Clean up codes by using checkpatch scriptChanwoo Choi
This patch just clean up codes by using checkpatch script and fix warning message about if statement. - the result of checkpatch script as following: WARNING: void function return statements are not generally useful + return; +} WARNING: quoted string split across lines + dev_err(info->dev, "failed: irq request (IRQ: %d," + " error :%d)\n", muic_irq->irq, ret); - warning message about coding style. drivers/extcon/extcon-sm5502.c:398 sm5502_muic_cable_handler() warn: we tested 'attached' before and it was 'false' Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-09-22extcon: sm5502: Move sm5502.h header file to extcon directoryChanwoo Choi
This patch move sm5502.h header file from 'include/linux/extcon' to 'driver/extcon' because sm5502.h is used for driver/extcon/extcon-sm5502.c. and remove duplicate license description. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-09-22extcon: sm5502: Fix bug to check cable typeChanwoo Choi
This patch fix bug when checking cable type. SM5502 have to use ADC value to get correct cable type. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-07-23extcon: sm5502: Change internal hardware switch according to cable typeChanwoo Choi
This patch changes internal hardware DP_CON/DM_CON switch according to cable type. The SM5502 MUIC device can set hardware switch as following: - OPEN (not connected state) / USB / UART / AUDIO Also, this patch set VBUSIN switch according to cable type. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-07-23extcon: sm5502: Detect cable state after completing platform bootingChanwoo Choi
This patch detect whether cable is connected or not and the cable type after completing kernel/platform booting using system_power_efficient_wq. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-07-23extcon: sm5502: Add support new SM5502 extcon device driverChanwoo Choi
This patch add new SM5502 MUIC(Micro-USB Interface Controller) device by using EXTCON subsystem. The extcon-sm5502 driver is capable of identifying the type of the external power source and attached accessory. An external power sources, such as Deticated Charger or a standard USB port, are able to charge the battery in the smart phone via the connector. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
