path: root/drivers/extcon
2014-03-19extcon: Move OF helper function to extcon core and change function nameChanwoo Choi
This patch move simply OF helper function to extcon core and change function name as following: - of_extcon_get_extcon_dev() -> extcon_get_edev_by_phandle() Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Felipe Balbi <balbi@ti.com>
2014-03-19extcon: of: Remove unnecessary function call by using the name of device_nodeChanwoo Choi
This patch remove unnecessary function call in of_extcon_get_extcon_dev() by using the name of device_node structure. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-03-19extcon: gpio: Use SIMPLE_DEV_PM_OPS macroJingoo Han
Use SIMPLE_DEV_PM_OPS macro in order to make the code simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-03-19extcon: palmas: Use SIMPLE_DEV_PM_OPS macroJingoo Han
2014-02-20ASoC: dapm: Add locking to snd_soc_dapm_xxxx_pin functionsCharles Keepax
The snd_soc_dapm_xxxx_pin all require the dapm_mutex to be held when they are called as they edit the dirty list, however very few of the callers do so. This patch adds unlocked versions of all the functions replacing the existing implementations with one that holds the lock internally. We also fix up the places where the lock was actually held on the caller side. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-01-09extcon: gpio: Add power resume supportRongjun Ying
When system on the suspend state, Some SoC can't get gpio interrupt. After system resume, need send extcon uevent to userspace. Signed-off-by: Rongjun Ying <rongjun.ying@csr.com> Reviewed-by: Barry Song <Baohua.Song@csr.com> Acked-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-01-07extcon: max14577: Add extcon-max14577 driver to support MUIC deviceChanwoo Choi
This patch supports Maxim MAX14577 MUIC(Micro USB Interface Controller) device by using EXTCON subsystem to handle various external connectors. The max14577 device uses regmap method for i2c communication and supports irq domain. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2014-01-07extcon: arizona: Add support for headphone detection on wm5110 rev DCharles Keepax
wm5110 rev D is the first chip to use headphone detection IP 2, specify such and make a small correction as the impedance value is actually read in 0.5 ohm increments now. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-01-07extcon: arizona: No need to switch back down HPDET rangesCharles Keepax
No point in revisiting ranges the detection will be no more accurate the second time simply report that the resistance is right on the range boundry. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-01-07extcon: arizona: Fix race with microphone detection and removalCharles Keepax
The microphone detection code is run as delayed work to provide additional debounce, it is possible that the jack could have been removed by the time we process the microphone detection. Turn this case into a no op. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-01-07extcon: arizona: Fix reset of HPDET after race with removalCharles Keepax
We need to make sure we reset back to our starting state, especially making sure that we have disabled poll in the register cache. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-01-07extcon: arizona: Add defines for microphone detection levelsCharles Keepax
Improve readability by creating a define for each microphone detection level. Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-01-07extcon: palmas: Handle ID interrupt properly using USB_ID_INT_SRCGeorge Cherian
Always cross check with the ID state and the source of interrupt. Also add a case in which ID Source is ID_GND but LATCH state is set wrongly. This uses the previous Link stat to determine the new state. Signed-off-by: George Cherian <george.cherian@ti.com> Acked-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-01-07extcon: palmas: Added a new compatible type *ti,palmas-usb-vid*Kishon Vijay Abraham I
The Palmas device contains only a USB VBUS-ID detector, so added a compatible type *ti,palmas-usb-vid*. Didn't remove the existing compatible types for backward compatibility. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-01-07extcon: gpio: Request gpio pin before modifying its stateGuenter Roeck
Commit 338de0ca (extcon: gpio: Use gpio driver/chip debounce if supported) introduced a call to gpio_set_debounce() before actually requesting the respective gpio pin from the gpio subsystem. The gpio subsystem expects that a gpio pin was requested before modifying its state. Not doing so results in a warning from gpiolib, and the gpio pin is auto-requested. This in turn causes the subsequent devm_gpio_request_one() to fail. So devm_gpio_request_one() must be called prior to calling gpio_set_debounce(). Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-11-26extcon: remove freed groups caused the panic or warning in unregister flowWang, Xiaoming
(edev->extcon_dev_type.groups) has been freed before device_unregister. extcon_dev_unregister -> kfree(edev->extcon_dev_type.groups) then device_unregister -> device_del -> device_remove_attrs -> device_remove_groups(dev, type->groups); panic because type->groups has been freed. This patch is move device_unregister ahead of groups free to avoid panic in extcon_dev_unregister. stack [ 22.847226] BUG: unable to handle kernel paging request at 5f39746e [ 22.847234] IP: [<c1387fcd>] sysfs_remove_group+0x2d/0xd0 [ 22.847238] *pdpt = 0000000000000000 *pde = 0000000000000000 [ 22.847241] Oops: 0000 [#1] PREEMPT SMP [ 22.847244] Modules linked in: [ 22.847249] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.16-261140-g6533774 #1 [ 22.847251] task: f3078000 ti: f3072000 task.ti: f3072000 [ 22.847254] EIP: 0060:[<c1387fcd>] EFLAGS: 00010206 CPU: 0 [ 22.847257] EIP is at sysfs_remove_group+0x2d/0xd0 [ 22.847259] EAX: 00000004 EBX: 5f39746e ECX: 00000000 EDX: f2773560 [ 22.847261] ESI: f2653b80 EDI: f2773560 EBP: f3073c90 ESP: f3073c70 [ 22.847263] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 [ 22.847264] CR0: 8005003b CR2: 5f39746e CR3: 020e5000 CR4: 001007f0 [ 22.847266] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 [ 22.847268] DR6: ffff0ff0 DR7: 00000400 [ 22.847269] Stack: [ 22.847276] c13848c9 c1ae3805 f3073c80 f24ddc4c 00000246 f2773e88 f1c44408 f2531340 [ 22.847283] f3073ca0 c16935ca f1c44400 f27d3340 f3073cb4 c1693858 f24ddc44 f1c44400 [ 22.847289] f1c4420c f3073cc8 c1693f76 f1c44400 00000001 00000000 f3073ce8 c1694011 [ 22.847290] Call Trace: [ 22.847295] [<c13848c9>] ? sysfs_hash_and_remove+0x49/0xa0 [ 22.847300] [<c1ae3805>] ? sub_preempt_count+0x55/0xe0 [ 22.847306] [<c16935ca>] device_remove_groups+0x2a/0x40 [ 22.847309] [<c1693858>] device_remove_attrs+0x38/0x60 [ 22.847313] [<c1693f76>] device_del+0xd6/0x150 [ 22.847316] [<c1694011>] device_unregister+0x21/0x60 [ 22.847320] [<c13869e8>] ? sysfs_remove_link+0x18/0x30 [ 22.847323] [<c1697d04>] ? class_compat_remove_link+0x34/0x50 [ 22.847329] [<c18bf5d9>] extcon_dev_unregister+0xf9/0x130 [ 22.847333] [<c18bd21f>] pwrsrc_extcon_dev_reg_callback+0x7f/0xa0 [ 22.847337] [<c1ae36e3>] notifier_call_chain+0x43/0x60 [ 22.847343] [<c12634e1>] __blocking_notifier_call_chain+0x41/0x80 [ 22.847347] [<c126353f>] blocking_notifier_call_chain+0x1f/0x30 [ 22.847351] [<c18bef39>] extcon_dev_notify_add_device+0x19/0x20 [ 22.847354] [<c18bf074>] extcon_dev_register+0x134/0x580 [ 22.847358] [<c1ae3805>] ? sub_preempt_count+0x55/0xe0 [ 22.847363] [<c154b4da>] ? gpiod_request+0x6a/0x1d0 [ 22.847368] [<c132528a>] ? kmem_cache_alloc_trace+0xaa/0x170 [ 22.847372] [<c18c0179>] ? fsa9285_probe+0x99/0x3f0 [ 22.847375] [<c18c00e0>] ? fsa9285_irq_handler+0xf0/0xf0 [ 22.847379] [<c18c019f>] fsa9285_probe+0xbf/0x3f0 [ 22.847383] [<c18c00e0>] ? fsa9285_irq_handler+0xf0/0xf0 [ 22.847388] [<c1828d9e>] i2c_device_probe+0x7e/0xf0 [ 22.847392] [<c1386e52>] ? sysfs_create_link+0x22/0x40 [ 22.847395] [<c1696c62>] ? driver_sysfs_add+0x72/0xa0 [ 22.847399] [<c1697119>] driver_probe_device+0x79/0x360 [ 22.847403] [<c1697491>] __driver_attach+0x91/0xa0 [ 22.847407] [<c1697400>] ? driver_probe_device+0x360/0x360 [ 22.847410] [<c16955a2>] bus_for_each_dev+0x42/0x80 [ 22.847414] [<c1696bee>] driver_attach+0x1e/0x20 [ 22.847417] [<c1697400>] ? driver_probe_device+0x360/0x360 [ 22.847420] [<c169675f>] bus_add_driver+0xef/0x270 [ 22.847425] [<c1828e10>] ? i2c_device_probe+0xf0/0xf0 [ 22.847428] [<c1828e10>] ? i2c_device_probe+0xf0/0xf0 [ 22.847432] [<c1697a8a>] driver_register+0x6a/0x160 [ 22.847436] [<c1addb3d>] ? mutex_unlock+0xd/0x10 [ 22.847440] [<c1438ab2>] ? __create_file+0x122/0x2a0 [ 22.847446] [<c20557d3>] ? extcon_class_init+0x15/0x15 [ 22.847450] [<c1827cbb>] i2c_register_driver+0x2b/0xd0 [ 22.847454] [<c1438d05>] ? debugfs_create_file+0x35/0x40 [ 22.847458] [<c20557d3>] ? extcon_class_init+0x15/0x15 [ 22.847461] [<c20557e4>] fsa9285_extcon_init+0x11/0x29 [ 22.847465] [<c12001aa>] do_one_initcall+0xba/0x170 [ 22.847471] [<c2012b4a>] kernel_init_freeable+0x119/0x1b8 [ 22.847475] [<c20124d3>] ? do_early_param+0x7a/0x7a [ 22.847480] [<c1ac4090>] kernel_init+0x10/0xd0 [ 22.847485] [<c1ae6cf7>] ret_from_kernel_thread+0x1b/0x28 [ 22.847488] [<c1ac4080>] ? rest_init+0x80/0x80 Tested-by: Liu, Chuansheng <chuansheng.liu@intel.com> Reviewed-by: Liu, Chuansheng <chuansheng.liu@intel.com> Signed-off-by: xiaoming wang <xiaoming.wang@intel.com> Signed-off-by: Zhang Dongxing <dongxing.zhang@intel.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-11-26extcon: arizona: Get pdata from arizona structure not deviceCharles Keepax
In the case of a device tree system there will be no pdata attached to the device, causing us to deference a NULL pointer. Better to take the pdata from the Arizona structure as this will always exist and we know will have been populated since it is populated by the MFD device which binds in the extcon driver. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-26Merge tag 'extcon-next-for-3.13' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/chanwoo/extcon into char-misc-next Chanwoo writes: Update extcon for 3.13 This patchset modify extcon core to remove unnecessary allocation sequence for 'dev' instance and change extcon_dev_register() interface. extcon-gpio use gpiolib API to get debounce time and include small fix of extcon core/device driver. Detailed description for patchset: 1. Modify extcon core driver - The extcon-gpio driver use gpio_set_debounce() API provided from gpiolib if gpio driver for SoC support gpio_set_debounce() function and support 'gpio_ activ_low' filed to check whether gpio active state is 1(high) or 0(low). - Change field type of 'dev' in structure extcon_dev and remove the sequence of allocating memory of 'struct dev' on extcon_dev_register() function because extcon device must need 'struct device. - Change extcon_dev_register() prototype to simplify it and remove unnecessary parameter as below: 2. Fix coding style and typo - extcon core : Fix indentation coding style and remove unnecessary casting - extcon-max8997 : Fix checkpatch warning - extcon-max77693 : Fix checkpatch warning - extcon-arizona : Fix typo of comment and modify minor issue - extcon-palmas : Use dev_get_platdata() 3. Modify extcon-arizona driver - Modify minor issue about micbias and comparision statement
2013-09-27extcon: Simplify extcon_dev_register() prototype by removing unnecessary ↵Chanwoo Choi
parameter This patch remove extcon_dev_register()'s second parameter which means the pointer of parent device to simplify prototype of this function. So, if extcon device has the parent device, it should set the pointer of parent device to edev.dev.parent in extcon device driver instead of in extcon_dev_register(). Cc: Graeme Gregory <gg@slimlogic.co.uk> Cc: Kishon Vijay Abraham I <kishon@ti.com> Cc: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-09-27extcon: Change field type of 'dev' in extcon_dev structureChanwoo Choi
The extcon device must always need 'struct device' so this patch change field type of 'dev' instead of allocating memory for 'struct device' on extcon_dev_register() function. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <cw00.choi@samsung.com>
2013-09-27extcon: arizona: Don't require micbias to be shifted in pdataCharles Keepax
Every other pdata field is specified unshifted the patch handles shifting for the MICBIAS from the microphone detection polarity configurations in the extcon driver rather than demanding it in pdata to match other fields. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: arizona: Correct typo in headphone detect range transitionsCharles Keepax
We should move range when the measured value is greater than or equal to the max value not when greater than. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: gpio: Add support for active-low presence to detect pinsGuenter Roeck
This patch add 'gpio_active_low' field to 'struct gpio_extcon_data' to check whether gpio active state is 1(high) or 0(low). Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. This is a cosmetic change to make the code simpler and enhance the readability. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: gpio: Use gpio driver/chip debounce if supportedGuenter Roeck
This patch use gpio_set_debounce() API provided from gpiolib if SoC or device driver with gpio support gpio_set_debounce() function. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: gpio: Do not unnecessarily initialize variablesGuenter Roeck
2013-09-27extcon: Remove casting the return value which is a void pointerJingoo Han
Casting the return value which is a void pointer is redundant. The conversion from void pointer to any other pointer type is guaranteed by the C programming language. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: Fix indentation coding style to improve readabilityChanwoo Choi
2013-09-27extcon: max77693: Fix checkpatch warningSachin Kamat
Fixes the following warning: WARNING: space prohibited before semicolon Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: arizona: Fix a typo in a commentSachin Kamat
Fixes an incomplete comment introduced by commit 9c2ba270 ("extcon: arizona: Simplify HPDET based identification"). Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: arizona: Clear trig_sts bits on all pathsCharles Keepax
We want the trig_sts bits to be cleared in all cases where we consider the jack detection interrupt to have been handled. Specifically, if a duplicate detection event was suppressed these bits were not cleared causing the CODEC to not enter a low power state. This patch clears the bits on the duplicate detection code path. Reported-by: Ryo Tsutsui <ryo.tsutsui@wolfsonmicro.com> Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: max8997: Fix checkpatch warningSachin Kamat
2013-09-26extcon: arizona: Fix up minor coding style to remove unnecessary bracesChanwoo Choi
This fixes up braces coding style issue by using checkpatch script. Cc: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26extcon: class: Remove unnecessary extern declarationChanwoo Choi
This patch remove unnecessary extern declaration (extcon_set_state). checkpatch found this coding style issue. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26extcon: Fix up 80 column coding style issuesChanwoo Choi
This patch fix 80 column coding sytle issues by using checkpatch script. Cc: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-03Merge tag 'driver-core-3.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg KH: "Here's the big driver core pull request for 3.12-rc1. Lots of tiny changes here fixing up the way sysfs attributes are created, to try to make drivers simpler, and fix a whole class race conditions with creations of device attributes after the device was announced to userspace. All the various pieces are acked by the different subsystem maintainers" * tag 'driver-core-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (119 commits) firmware loader: fix pending_fw_head list corruption drivers/base/memory.c: introduce help macro to_memory_block dynamic debug: line queries failing due to uninitialized local variable sysfs: sysfs_create_groups returns a value. debugfs: provide debugfs_create_x64() when disabled rbd: convert bus code to use bus_groups firmware: dcdbas: use binary attribute groups sysfs: add sysfs_create/remove_groups for when SYSFS is not enabled driver core: add #include <linux/sysfs.h> to core files. HID: convert bus code to use dev_groups Input: serio: convert bus code to use drv_groups Input: gameport: convert bus code to use drv_groups driver core: firmware: use __ATTR_RW() driver core: core: use DEVICE_ATTR_RO driver core: bus: use DRIVER_ATTR_WO() driver core: create write-only attribute macros for devices and drivers sysfs: create __ATTR_WO() driver-core: platform: convert bus code to use dev_groups workqueue: convert bus code to use dev_groups MEI: convert bus code to use dev_groups ...
2013-08-05extcon: adc-jack: Use power efficient workqueueMark Brown
The debounce timeout is generally quite long and the work not performance critical so allow the scheduler to run the work anywhere rather than in the normal per-CPU workqueue. Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-08-05extcon: gpio: Use power efficient workqueue for debounceMark Brown
2013-08-05extcon: arizona: Use power efficient workqueueMark Brown
None of the delayed work the driver schedules has particularly short delays and it is not performance sensitive so let the scheduler run it wherever is most efficient rather than in a per CPU workqueue by using the system power efficient workqueue. Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-08-05extcon: palmas: Option to disable ID/VBUS detection based on platformLaxman Dewangan
Based on system design, platform needs to detect the VBUS or ID or both. Provide option to select this through platform data to disable part of cable detection through palmas-usb. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-08-05extcon: palams: add support for suspend/resumeLaxman Dewangan
Add suspend/resume callbacks and support for wakeup from suspend on USB HOST or USB Device cable insertion or removal. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-08-05extcon: palmas: enable ID_GND and ID_FLOAT detection alwaysLaxman Dewangan
When integrating driver with Tegra platform, it is found that the ID pins get detected only once after booting system and further removal and re-insert does not detect the ID pin. Fixing this issue with enabling interrupt on ID_GND and ID_FLOAT always and clearing the status on LATCH register which actually occurred. Also if interrupt occurs with line status as zero then based on previous status, set the cable state. Add debug prints to display the cable state when any cable insertion/removal happen. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-08-05extcon: palmas: remove assigning "edev.name" to palmasKishon Vijay Abraham I
of_extcon_get_extcon_dev() uses dev_name for getting the reference to the extcon device. If the extcon driver assigns a different name other than dev_name, of_extcon_get_extcon_dev() wouldn't be able to find the reference to the extcon device. Since the client drivers of extcon-palmas would be using of_extcon_get_extcon_dev(), removed assigning edev.name in extcon-palmas. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-08-05extcon: Add an API to get extcon device from dt nodeKishon Vijay Abraham I
Added an API of_extcon_get_extcon_dev() to be used by drivers to get extcon device in the case of dt boot (this can be used instead of extcon_get_extcon_dev()). Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-07-25extcon: convert extcon_class to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct class is going away soon, dev_groups should be used instead. This converts the extcon_class code to use the correct field. Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Acked-by: Chanwoo Choi<cw00.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03drivers: avoid format string in dev_set_nameKees Cook
Calling dev_set_name with a single paramter causes it to be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents, including wrappers like device_create*() and bdi_register(). Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-17extcon: Palmas Extcon DriverGraeme Gregory
This is the driver for the USB comparator built into the palmas chip. It handles the various USB OTG events that can be generated by cable insertion/removal. Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Moiz Sonasath <m-sonasath@ti.com> Signed-off-by: Ruchika Kharwar <ruchika@ti.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: George Cherian <george.cherian@ti.com> [kishon@ti.com: adapted palmas usb driver to use the extcon framework] Signed-off-by: Sebastien Guiriec <s-guiriec@ti.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17extcon: add EXPORT_SYMBOL_GPL for exported functionsKishon Vijay Abraham I
Added EXPORT_SYMBOL_GPL() for extcon_register_interest and extcon_register_notifier in order to avoid undefined reference error when building the consumer modules of extcon as _modules_. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17extcon: Change permission 'state' sysfs entry (rw -> r)Chanwoo Choi
This patch change permission from read/write to only read. The specific process in the user-space couldn't change the state of cable when cable is attached or detached. - /sys/class/extcon/[devine name]/state Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-09Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull removal of GENERIC_GPIO from Grant Likely: "GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it is possible to do so which has been causing confusion and breakage. This branch does the work to completely eliminate GENERIC_GPIO." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: gpio: update gpio Chinese documentation Remove GENERIC_GPIO config option Convert selectors of GENERIC_GPIO to GPIOLIB blackfin: force use of gpiolib m68k: coldfire: use gpiolib mips: pnx833x: remove requirement for GENERIC_GPIO openrisc: default GENERIC_GPIO to false avr32: default GENERIC_GPIO to false xtensa: remove explicit selection of GENERIC_GPIO sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB powerpc: remove redundant GENERIC_GPIO selection unicore32: default GENERIC_GPIO to false unicore32: remove unneeded select GENERIC_GPIO arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB arm: remove redundant GENERIC_GPIO selection mips: alchemy: require gpiolib mips: txx9: change GENERIC_GPIO to GPIOLIB mips: loongson: use GPIO driver on CONFIG_GPIOLIB mips: remove redundant GENERIC_GPIO select
