commit d5653f2b7304f05eeb45d84f123cf02f840b8537 upstream.
Fix NULL pointer exceptions when platform data is not supplied.
Trace of one exception:
Unable to handle kernel NULL pointer dereference at virtual address 00000008
pgd = c0004000
[00000008] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 2 PID: 1 Comm: swapper/0 Not tainted 3.14.0-12045-gead5dd4687a6-dirty #1628
task: eea80000 ti: eea88000 task.ti: eea88000
PC is at max77693_muic_probe+0x27c/0x528
LR is at regmap_write+0x50/0x60
pc : [<c041d1c8>] lr : [<c02eba60>] psr: 20000113
sp : eea89e38 ip : 00000000 fp : c098a834
r10: ee1a5a10 r9 : 00000005 r8 : c098a83c
r7 : 0000000a r6 : c098a774 r5 : 00000005 r4 : eeb006d0
r3 : c0697bd8 r2 : 00000000 r1 : 00000001 r0 : 00000000
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 4000404a DAC: 00000015
Process swapper/0 (pid: 1, stack limit = 0xeea88240)
Stack: (0xeea89e38 to 0xeea8a000)
9e20: c08499fc eeb006d0
9e40: 00000000 00000000 c0915f98 00000001 00000000 ee1a5a10 c098a730 c09a88b8
9e60: 00000000 c098a730 c0915f98 00000000 00000000 c02d6aa0 c02d6a88 ee1a5a10
9e80: c0a712c8 c02d54e4 00001204 c0628b00 ee1a5a10 c098a730 ee1a5a44 00000000
9ea0: eea88000 c02d57b4 00000000 c098a730 c02d5728 c02d3a24 ee813e5c eeb9d534
9ec0: c098a730 ee22f700 c097c720 c02d4b14 c08174ec c098a730 00000006 c098a730
9ee0: 00000006 c092fd30 c09b8500 c02d5df8 00000000 c093cbb8 00000006 c0008928
9f00: 000000c3 ef7fc785 00000000 ef7fc794 00000000 c08af968 00000072 eea89f30
9f20: ef7fc85e c065f198 000000c3 c003e87c 00000003 00000000 c092fd3c 00000000
9f40: c08af618 c0826d58 00000006 00000006 c0956f58 c093cbb8 00000006 c092fd30
9f60: c09b8500 000000c3 c092fd3c c08e8510 00000000 c08e8bb0 00000006 00000006
9f80: c08e8510 c0c0c0c0 00000000 c0628fac 00000000 00000000 00000000 00000000
9fa0: 00000000 c0628fb4 00000000 c000f038 00000000 00000000 00000000 00000000
9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 c0c0c0c0 c0c0c0c0
[<c041d1c8>] (max77693_muic_probe) from [<c02d6aa0>] (platform_drv_probe+0x18/0x48)
[<c02d6aa0>] (platform_drv_probe) from [<c02d54e4>] (driver_probe_device+0x140/0x384)
[<c02d54e4>] (driver_probe_device) from [<c02d57b4>] (__driver_attach+0x8c/0x90)
[<c02d57b4>] (__driver_attach) from [<c02d3a24>] (bus_for_each_dev+0x54/0x88)
[<c02d3a24>] (bus_for_each_dev) from [<c02d4b14>] (bus_add_driver+0xe8/0x204)
[<c02d4b14>] (bus_add_driver) from [<c02d5df8>] (driver_register+0x78/0xf4)
[<c02d5df8>] (driver_register) from [<c0008928>] (do_one_initcall+0xc4/0x174)
[<c0008928>] (do_one_initcall) from [<c08e8bb0>] (kernel_init_freeable+0xfc/0x1c8)
[<c08e8bb0>] (kernel_init_freeable) from [<c0628fb4>] (kernel_init+0x8/0xec)
[<c0628fb4>] (kernel_init) from [<c000f038>] (ret_from_fork+0x14/0x3c)
Code: caffffe7 e59d200c e3550001 b3a05001 (e5923008)
---[ end trace 85db969ce011bde7 ]---
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 190d7cfc8632
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
commit dfee4111febf3d9ef3a640b2cd6205c75f4e7e3d upstream.
Fix NULL pointer exception when platform data is not supplied. The
driver dereferenced pdata pointer where it could be NULL.
Fixes: 810d601f07c
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
GENERIC_GPIO is now equivalent to GPIOLIB and features that depended on
GENERIC_GPIO can now depend on GPIOLIB to allow removal of this option.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/chanwoo/extcon into char-misc-next
Chanwoo writes:
This is small fixes for extcon driver.
MAX77693 extcon driver
- Add 'static' keryword to internal data structure
- Fix return value using 'ret' instead of hardcoding
MAX8997 extcon driver
- Use dev_err() instead of pr_err()
Return the value obtained from the function instead of hardcoding.
Fixes the following warnings:
drivers/extcon/extcon-max8997.c:235 max8997_muic_set_path() info:
why not propagate 'ret' from max8997_update_reg() instead of (-11)?
drivers/extcon/extcon-max8997.c:248 max8997_muic_set_path() info:
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
Silences the following warnings:
drivers/extcon/extcon-max77693.c:297 max77693_muic_set_path()
info: why not propagate 'ret' from max77693_update_reg() instead of (-11)?
drivers/extcon/extcon-max77693.c:310 max77693_muic_set_path()
dev_err() is more preferred than pr_err().
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Commit 0ec83bd246 ("extcon: max77693: Initialize register of MUIC
device to bring up it without platform data") added this structure
but forgot to make it static. Without this patch we get the following
warning:
drivers/extcon/extcon-max77693.c:41:26: warning:
symbol 'default_init_data' was not declared. Should it be static?
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/misc into char-misc-next
Mark writes:
extcon: arizona: Updates for v3.10
There's a bunch of different things in this series, I can split them out
if need be:
- Support for configuring the button detection circuit to reflect the
accessories supplied with the system.
- Improvements in the HPDET based detection scheme.
- Additional robustness against more pathological use cases.
- A few small standalone fixes.
Help mitigate against mechanical bounce during the initial detection by
allowing the configuration of an additional debounce on top of that the
hardware does during the initial phase of microphone detection operation.
If the user moves directly from one button to another then we won't get a
no buttons pressed event and will therefore end up reporting that two
buttons are simultaneously pressed which isn't supported by the hardware.
Make sure we clear any existing button reports before reporting any new
ones.
In pathological cases the microphone detection may fail to report, for
example due to a failure to get a stable measurement. Provide a timeout
to cover such cases.
Rather than measuring both HP channels we can simply directly measure the
microphone impedance and then rely on MICDET for final confirmation of the
presence of a suitable microphone. This improves the overall performance
of the identification process.
This extra check makes the procedure take longer and is of marginal use
in identification so do not execute it.
Sometimes we can trigger measurements early if contacts are shorted during
a slow insertion. As well as debouncing add further robustness by retrying
if we get a high impedance measurement for headphones as this can indicate
that the headphones were not yet connected.
Occasionally we can trigger an interrupt before we have completed
impedance measurement, although the valid bit will still be set. This
patch spins reading the impedance value until a valid value is seen.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
In cases where we see a brief (dis)connection of the jack detection signals
we may see a noop jack insertion or removal where the jack has returned to
the original state by the time the interrupt is serviced. Suppress these
events in order to save work and avoid confusing the rest of the code.
Ensure greater reliability by increasing the minimum threashold for
identifying a microphone.
In some designs an external pull won't be needed.
There is no need to do this as HPDET identification will cause MICBIAS to
be powered down again.
The Arizona button detection circuit is configurable, allowing the system
integrator to program a range of thresholds for the buttons supported on
the accessory but currently the driver uses the default button ranges and
does not provide any flexibility in how this is exposed to the application
layer.
Provide platform data allowing the user to control this and to map
the buttons to keys in the input subsystem.
In some pathological use cases users may insert an accessory very slowly
causing multiple indeterminate measurements. Handle this by retrying many
measurements before we give up and declare a headphone.
This picks up the MEI fixes that we need in this branch now.
Running HPDET while the headphone outputs are enabled can disrupt the
operation of HPDET. In order to avoid this HPDET needs to disable the
headphone outputs and ASoC needs to not enable them while HPDET is
running.
For extcon instead of checking if the headphone output is enabled when
doing magic application unconditionally disable the output and restore
the state which ASoC wants set when undoing the magic.
We have a very similar sequence doing magic writes in several places
(one of which missed an update to interlock with the CODEC driver) so
factor it out into a function.
platform data
This patch set default value of MUIC register to bring up MUIC device.
If user don't set some initial value for MUIC device through platform data,
extcon-max77693 driver use 'default_init_data' to bring up base operation
of MAX77693 MUIC device.
This patch fix wrong pointer of platform data. If each machine set
platform data for h/w path or delay time of workqueue, this driver
happen kernel panic related to null pointer.
error
This patch check the pointer of platform data to protect
kernel panic when platform data is not used and code clean.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver patches from Greg Kroah-Hartman:
"Here's the big char/misc driver patches for 3.9-rc1.
Nothing major here, just lots of different driver updates (mei,
hyperv, ipack, extcon, vmci, etc.).
All of these have been in the linux-next tree for a while."
* tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits)
w1: w1_therm: Add force-pullup option for "broken" sensors
w1: ds2482: Added 1-Wire pull-up support to the driver
vme: add missing put_device() after device_register() fails
extcon: max8997: Use workqueue to check cable state after completing boot of platform
extcon: max8997: Set default UART/USB path on probe
extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type
extcon: max8997: Set default of ADC debounce time during initialization
extcon: max8997: Remove duplicate code related to set H/W line path
extcon: max8997: Move defined constant to header file
extcon: max77693: Make max77693_extcon_cable static
extcon: max8997: Remove unreachable code
extcon: max8997: Make max8997_extcon_cable static
extcon: max77693: Remove unnecessary goto statement to improve readability
extcon: max77693: Convert to devm_input_allocate_device()
extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style
CREDITS: update email and address of Harald Hoyer
extcon: arizona: Use MICDET for final microphone identification
extcon: arizona: Always take the first HPDET reading as the final one
extcon: arizona: Clear _trig_sts bits after jack detection
extcon: arizona: Don't HPDET magic when headphones are enabled
platform
This patch use delayed workqueue to check cable state after a certain
time. If extcon-max8997 driver check cable state during booting of
platform, this couldn't send the correct notification of cable state
to extcon consumer. Alwasys, this driver should check cable state
after the completion of platform initialization
This patch set default H/W line path according to platfomr data.
The MAX8997 MUIC device can possibly set UART/USB or UART_AUX
/USB_AUX to internal H/W line path of MUIC device. Namely, only
one H/W line is used for two operation.
For example,
if H/W line path of MAX8997 device set UART/USB, micro usb cable
is connected to AP(Application Processor) and if H/W line path
set UART_AUX/USB_AUX, micro usb cable is connected to CP(Coprocessor).
This patch make max8997_muic_get_cable_type() function to remove
duplicate code for checking ADC/Charger cable type because almost
internal function need to read adc/chg_type value of MUIC register.
Also, remove *_detach() function, extcon-max8997 driver treat
attach/detach operation of cable in max8997_*_handler() function.
Lastly, this patch move defined constant in header file(include/
linux/mfd/max8997.h, max8997-private.h) because defined constant
is only used in the 'extcon-max8997.c'.
This patch set default of ADC Debounce Time(25ms) during probe step.
Also, can possible change ADC Debounce Time according to H/W situation
by using max8997_set_adc_debounce_time()
This patch move defined constants to header file(max77693-private.h)
because of mask/unmask selectively interrupt of MUIC device according
to attribute of H/W board.
'max77693_extcon_cable' is used only in this file. Hence
make it static.
'break' after 'return' is never executed and hence can be deleted.
'max8997_extcon_cable' is used only in this file. Hence make it static.
Mark writes:
extcon: arizona: Updates for v3.9
More updates for v3.9, a mix of fixes for the code that's already there
and a few new features.
When using HPDET to identify the accessory still run MICDET before we
report a microphone in order to ensure that the accessory identified is
compatible with the MICDET detection ranges after having confirmed that
the device is not using a headphone.
This should always be the most accurate reading for supported accessory
configurations.
It is important to clear the wake trigger status bits otherwise DCVDD
will be held high independent of the state of the LDOENA line.
The magic is already done as part of enabling the headphone output so
does not need to be done when the headphone outputs are enabled. We hold
the DAPM lock so the headphone status can't be changed underneath us.
The HPDET identification method does not have the same natural debounce
built into it that the standard MICDET method does so add some extra on
top of what the jack detection does in hardware to make sure we get a
robust result.
