path: root/drivers/firewire/fw-card.c
2009-03-24firewire: core: optimize propagation of BROADCAST_CHANNELStefan Richter
Cache the test result of whether a device implements BROADCAST_CHANNEL. This minimizes traffic on the bus after each bus reset. A majority of devices does not implement BROADCAST_CHANNEL. Remove busy retries; just rely on the hardware to retry requests to busy responders. Remove unnecessary log messages. Rename the flag is_irm to broadcast_channel_allocated to better reflect its meaning. Reset the flag earlier in fw_core_handle_bus_reset. Pass the generation down as a call parameter; that way generation can't be newer than card->broadcast_channel_allocated and device->node_id. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: core: simplify broadcast channel allocationStefan Richter
fw-iso.c has channel allocation code now, use it. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: core: increase bus manager grace periodStefan Richter
Per IEEE 1394 clause 8.4.2.5, bus manager capable nodes which are not incumbent shall wait at least 125ms before trying to establish themselves as bus manager. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: broadcast channel supportJay Fenlason
This patch adds the ISO broadcast channel support that is required of a 1394a IRM. In specific, if the local device the IRM, it allocates ISO channel 31 and sets the broadcast channel register of all devices on the local bus to BROADCAST_CHANNEL_INITIAL | BROADCAST_CHANNEL_VALID to indicate that channel 31 can be use for broadcast messages. One minor complication is that on startup the local device may become IRM before all the devices on the bus have been enumerated by the stack. Therefore we have to keep a "the local device is IRM" flag and possibly set the broadcast channel register of new devices at enumeration time. Signed-off-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: normalize a variable nameStefan Richter
Standardize on if (err) handle_error; and if (ret < 0) handle_error; Don't call a variable err if we store values in it which mean success. Also, offset some return statements by a blank line since this how we do it in drivers/firewire. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: remove line breaks before function namesStefan Richter
type function_name(parameters); is nice to look at but was not used consistently. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-02-01firewire: core: Remove card from list of cards when enable failsPetr Vandrovec
Signed-off-by: Petr Vandrovec <petr@vandrovec.name> After a controller initialization failure, addition of another card got stuck due to card_list corruption. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-01-24firewire: core: optimize card shutdownStefan Richter
This fixes a regression by "firewire: keep highlevel drivers attached during brief connection loss": There were 2 seconds unnecessary waiting added to the shutdown procedure of each controller. We use card->link as status flag to signal the device handler that there is no use to wait for a come-back. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-01-20firewire: unnecessary BM delay after generation rolloverStefan Richter
Noticed by Jarod Wilson: The bus manager work was unnecessarily delayed each time the bus generation counter rolled over. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2009-01-09firewire: core: fix sleep in atomic context due to driver core changeStefan Richter
Due to commit 2831fe6f9cc4e16c103504ee09a47a084297c0f3, "driver core: create a private portion of struct device", device_initialize() can no longer be called from atomic contexts. We now defer it until after config ROM probing. This requires changes to the bus manager code because this may use a device before it was probed. Reported-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-01-04firewire: improve refcounting of fw_cardJay Fenlason
Take a reference to the card whenever fw_card_bm_work() is scheduled on that card and release it when the work is done. This allows us to remove the cancel_delayed_work_sync() in fw_core_remove_card(). Signed-off-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (patch update)
2009-01-04firewire: typo in commentJay Fenlason
2008-10-15firewire: fw_send_request_sync()Jay Fenlason
Share code between fw_send_request + wait_for_completion callers. Signed-off-by: Jay Fenlason <fenlason@redhat.com> Addendum: Removes an unnecessary struct and an ununsed retry loop. Calls it fw_run_transaction() instead of fw_send_request_sync(). Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Kristian Høgsberg <krh@redhat.com>
2008-07-14firewire: warn on unfinished transactions during card removalStefan Richter
After card->done and card->work are completed, any remaining pending request would be a bug. We cannot safely complete a transaction at that point anymore. IOW card users must not drop their last fw_card reference (usually indirect references through fw_device references) before their last outbound transaction through that card was finished. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-07-14firewire: clean up fw_card reference countingStefan Richter
This is a functionally equivalent replacement of the current reference counting of struct fw_card instances. It only converts it to common idioms as suggested by Kristian Høgsberg: - struct kref replaces atomic_t as the counter. - wait_for_completion is used to wait for all card users to complete. BTW, it may make sense to count card->flush_timer and card->work as card users too. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-07-14firewire: remove unused struct membersStefan Richter
2008-07-14firewire: implement broadcast_channel CSR for 1394a complianceStefan Richter
See IEEE 1394a clause 8.3.2.3.11. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: cleanupsAdrian Bunk
This patch contains the following cleanups: - #if 0 the following unused structs: - fw-transaction.c:fw_low_memory_region - fw-transaction.c:fw_private_region - fw-transaction.c:fw_csr_region - fw-transaction.c:fw_unit_space_region - remove the following unused EXPORT_SYMBOL's: - fw-card.c:fw_core_add_descriptor - fw-card.c:fw_core_remove_descriptor - fw-iso.c:fw_iso_context_create - fw-iso.c:fw_iso_context_destroy - fw-iso.c:fw_iso_context_start - fw-iso.c:fw_iso_context_queue - fw-iso.c:fw_iso_context_stop Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: fix synchronization of gap countsStefan Richter
Fix: The fact that nodes had different gap counts would be overlooked if the bus manager code would pick gap count 63 because of beta repeaters or because of very large hop counts. In this case, the bus manager code would miss that it actually has to send the PHY config packet with gap count 63. Related trivial changes: Use bool for an int used as bool, touch up some comments. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: reread config ROM when device reset the busStefan Richter
When a device changes its configuration ROM, it announces this with a bus reset. firewire-core has to check which node initiated a bus reset and whether any unit directories went away or were added on this node. Tested with an IOI FWB-IDE01AB which has its link-on bit set if bus power is available but does not respond to ROM read requests if self power is off. This implements - recognition of the units if self power is switched on after fw-core gave up the initial attempt to read the config ROM, - shutdown of the units when self power is switched off. Also tested with a second PC running Linux/ieee1394. When the eth1394 driver is inserted and removed on that node, fw-core now notices the addition and removal of the IPv4 unit on the ieee1394 node. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: remove superfluous reference countingStefan Richter
The card->kref became obsolete since patch "firewire: fix crash in automatic module unloading" added another counter of card users. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-03-02firewire: fix crash in automatic module unloadingStefan Richter
"modprobe firewire-ohci; sleep .1; modprobe -r firewire-ohci" used to result in crashes like this: BUG: unable to handle kernel paging request at ffffffff8807b455 IP: [<ffffffff8807b455>] PGD 203067 PUD 207063 PMD 7c170067 PTE 0 Oops: 0010 [1] PREEMPT SMP CPU 0 Modules linked in: i915 drm cpufreq_ondemand acpi_cpufreq freq_table applesmc input_polldev led_class coretemp hwmon eeprom snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss button thermal processor sg snd_hda_intel snd_pcm snd_timer snd snd_page_alloc sky2 i2c_i801 rtc [last unloaded: crc_itu_t] Pid: 9, comm: events/0 Not tainted 2.6.25-rc2 #3 RIP: 0010:[<ffffffff8807b455>] [<ffffffff8807b455>] RSP: 0018:ffff81007dcdde88 EFLAGS: 00010246 RAX: ffff81007dc95040 RBX: ffff81007dee5390 RCX: 0000000000005e13 RDX: 0000000000008c8b RSI: 0000000000000001 RDI: ffff81007dee5388 RBP: ffff81007dc5eb40 R08: 0000000000000002 R09: ffffffff8022d05c R10: ffffffff8023b34c R11: ffffffff8041a353 R12: ffff81007dee5388 R13: ffffffff8807b455 R14: ffffffff80593bc0 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffffffff8055a000(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: ffffffff8807b455 CR3: 0000000000201000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process events/0 (pid: 9, threadinfo ffff81007dcdc000, task ffff81007dc95040) Stack: ffffffff8023b396 ffffffff88082524 0000000000000000 ffffffff8807d9ae ffff81007dc5eb40 ffff81007dc9dce0 ffff81007dc5eb40 ffff81007dc5eb80 ffff81007dc9dce0 ffffffffffffffff ffffffff8023be87 0000000000000000 Call Trace: [<ffffffff8023b396>] ? run_workqueue+0xdf/0x1df [<ffffffff8023be87>] ? worker_thread+0xd8/0xe3 [<ffffffff8023e917>] ? autoremove_wake_function+0x0/0x2e [<ffffffff8023bdaf>] ? worker_thread+0x0/0xe3 [<ffffffff8023e813>] ? kthread+0x47/0x74 [<ffffffff804198e0>] ? trace_hardirqs_on_thunk+0x35/0x3a [<ffffffff8020c008>] ? child_rip+0xa/0x12 [<ffffffff8020b6e3>] ? restore_args+0x0/0x3d [<ffffffff8023e68a>] ? kthreadd+0x14c/0x171 [<ffffffff8023e68a>] ? kthreadd+0x14c/0x171 [<ffffffff8023e7cc>] ? kthread+0x0/0x74 [<ffffffff8020bffe>] ? child_rip+0x0/0x12 Code: Bad RIP value. RIP [<ffffffff8807b455>] RSP <ffff81007dcdde88> CR2: ffffffff8807b455 ---[ end trace c7366c6657fe5bed ]--- Note that this crash happened _after_ firewire-core was unloaded. The shared workqueue tried to run firewire-core's device initialization jobs or similar jobs. The fix makes sure that firewire-ohci and hence firewire-core is not unloaded before all device shutdown jobs have been completed. This is determined by the count of device initializations minus device releases. Also skip useless retries in the node initialization job if the node is to be shut down. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-03-02firewire: potentially invalid pointers used in fw_card_bm_workStefan Richter
The bus management workqueue job was in danger to dereference NULL pointers. Also, after having temporarily lifted card->lock, a few node pointers and a device pointer may have become invalid. Add NULL pointer checks and get the necessary references. Also, move card->local_node out of fw_card_bm_work's sight during shutdown of the card. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2007-08-25firewire: fix unloading of fw-ohci while devices are attachedStefan Richter
Fix panic in run_timer_softirq right after "modprobe -r firewire-ohci" if a FireWire disk was attached and firewire-sbp2 loaded. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-07-10firewire: optimize gap count with 1394b leaf nodesStefan Richter
Table-based gap count optimization cannot be used if 1394b repeater PHYs are present. But it does work with 1394b leaf nodes. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2007-05-31firewire: Implement suspend/resume PCI driver hooks.Kristian Høgsberg
It's a low-impact design, that just makes suspend/resume look like a bus reset to the upper level drivers, but it should be sufficient. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-10firewire: Always use parens with sizeof.Kristian Høgsberg
Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-10firewire: Uppercase most macro names.Kristian Høgsberg
2007-05-10firewire: Coding style cleanup: no spaces after function names.Kristian Høgsberg
2007-05-10firewire: Convert card_rwsem to a regular mutex.Kristian Høgsberg
2007-05-10firewire: Clean up comment style.Kristian Høgsberg
Drop filenames from file preamble, drop editor annotations and use standard indent style for block comments. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (fixed typo)
2007-05-10firewire: Use lib/ implementation of CRC ITU-T.Kristian Høgsberg
With the CRC ITU-T implementation available in lib/ we can use that instead. This also fixes a bug in the topology map crc computation. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (fixed Kconfig)
2007-04-17firewire: Don't use subsystem rwsem, it's going away.Kristian Høgsberg
2007-03-28firewire: Add ioctls to add and remove config rom descriptors.Kristian Høgsberg
Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (fixed whitespace)
2007-03-24firewire: Add phy register defines.Marc Butler
Signed-off-by: Marc Butler <marc@adaptivecode.com> Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (added whitespace)
2007-03-09firewire: Implement topology map and fix a couple of loopback bugs.Kristian Høgsberg
2007-03-09firewire: Drop the unused fw_card device.Kristian Høgsberg
2007-03-09firewire: Let an fw_descriptor specify a leading immediate key/value pair.Kristian Høgsberg
This lets us break out "Juju" as the model name in the config rom. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: Use atomic_t's for serial numbers.Kristian Høgsberg
Signed-off-by: Kristian Høgsberg <krh@redhat.com> Use atomic_inc_return. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: Implement proper transaction cancelation.Kristian Høgsberg
Drivers such as fw-sbp2 had no way to properly cancel in-progress transactions, which could leave a pending transaction or an unset packet in the low-level queues after kfree'ing the containing structure. fw_cancel_transaction() lets drivers cancel a submitted transaction. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: use atomic type for fw_device.stateStefan Richter
2007-03-09firewire: Implement compliant bus management.Kristian Høgsberg
2007-03-09firewire: Implement gap count optimization.Kristian Høgsberg
2007-03-09firewire: comma after last enum item or initializerStefan Richter
2007-03-09firewire: whitespace adjustmentsStefan Richter
2007-03-09firewire: mark some structs constStefan Richter
Instances of struct file_operations and struct fw_card_driver can be qualified as "const". Ditto with struct fw_descriptor.data, struct fw_device_id, and predefined instances of struct fw_address_region, at least in the current implementation. Data qualified as const is placed into the .rodata section which won't be mixed with dirty data. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: Add device probing and sysfs integration.Kristian Høgsberg
2007-03-09firewire: Add core firewire stack.Kristian Høgsberg
