path: root/drivers/firewire/fw-transaction.c
2009-06-05firewire: rename source filesStefan Richter
The source files of firewire-core, firewire-ohci, firewire-sbp2, i.e. "drivers/firewire/fw-*.c" are renamed to "drivers/firewire/core-*.c", "drivers/firewire/ohci.c", "drivers/firewire/sbp2.c". The old fw- prefix was redundant to the directory name. The new core- prefix distinguishes the files according to which driver they belong to. This change comes a little late, but still before further firewire drivers are added as anticipated RSN. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-06-05firewire: reorganize header filesStefan Richter
The three header files of firewire-core, i.e. "drivers/firewire/fw-device.h", "drivers/firewire/fw-topology.h", "drivers/firewire/fw-transaction.h", are replaced by "drivers/firewire/core.h", "include/linux/firewire.h". The latter includes everything which a firewire high-level driver (like firewire-sbp2) needs besides linux/firewire-constants.h, while core.h contains the rest which is needed by firewire-core itself and by low- level drivers (card drivers) like firewire-ohci. High-level drivers can now also reside outside of drivers/firewire without having to add drivers/firewire to the header file search path in makefiles. At least the firedtv driver will be such a driver. I also considered to spread the contents of core.h over several files, one for each .c file where the respective implementation resides. But it turned out that most core .c files will end up including most of the core .h files. Also, the combined core.h isn't unreasonably big, and it will lose more of its contents to linux/firewire.h anyway soon when more firewire drivers are added. (IP-over-1394, firedtv, and there are plans for one or two more.) Furthermore, fw-ohci.h is renamed to ohci.h. The name of core.h and ohci.h is chosen with regard to name changes of the .c files in a follow-up change. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-06-05firewire: clean up includesStefan Richter
Include required headers which were only indirectly included. Remove unused includes and an unused constant. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: core: drop unused call parameters of close_transactionStefan Richter
All callers inserted NULL and 0 here. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: add closure to async stream ioctlStefan Richter
This changes the as yet unreleased FW_CDEV_IOC_SEND_STREAM_PACKET ioctl to generate an fw_cdev_event_response event just like the other two ioctls for asynchronous request transmission do. This way, clients get feedback on successful or unsuccessful transmission. This also adds input validation for length, tag, channel, sy, speed. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: implement asynchronous stream transmissionJay Fenlason
Allow userspace and other firewire drivers (fw-ipv4 I'm looking at you!) to send Asynchronous Transmit Streams as described in 7.8.3 of release 1.1 of the 1394 Open Host Controller Interface Specification. Signed-off-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (tweaks)
2009-03-24firewire: core: normalize a function argument nameStefan Richter
It's called "payload" rather than "data" almost everywhere in fw-transaction.c. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: remove line breaks before function namesStefan Richter
type function_name(parameters); is nice to look at but was not used consistently. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: standardize a variable nameStefan Richter
"ret" is the new "retval". Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: core: remove obsolete assertionsStefan Richter
This code never changes. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: core: remove outdated commentStefan Richter
2009-03-24firewire: cdev: address handler input validationStefan Richter
Like before my commit 1415d9189e8c59aa9c77a3bba419dcea062c145f, fw_core_add_address_handler() does not align the address region now. Instead the caller is required to pass valid parameters. Since one of the callers of fw_core_add_address_handler() is the cdev userspace interface, we now check for valid input. If the client is buggy, we give it a hint with -EINVAL. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-01-04firewire: fix small memory leak at module removalStefan Richter
2008-12-10firewire: fw-ohci: fix IOMMU resource exhaustionStefan Richter
There is a DMA map/ unmap imbalance whenever a block write request packet is sent and then dequeued with ohci_cancel_packet. The latter may happen frequently if the AR resp tasklet is executed before the AT req tasklet for the same transaction. Add the missing dma_unmap_single. This fixes https://bugzilla.redhat.com/show_bug.cgi?id=475156 Reported-by: Emmanuel Kowalski Tested-by: Emmanuel Kowalski Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-10-15firewire: fw_send_request_sync()Jay Fenlason
Share code between fw_send_request + wait_for_completion callers. Signed-off-by: Jay Fenlason <fenlason@redhat.com> Addendum: Removes an unnecessary struct and an ununsed retry loop. Calls it fw_run_transaction() instead of fw_send_request_sync(). Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Kristian Høgsberg <krh@redhat.com>
2008-07-25firewire: avoid memleak after phy config transmit failureStefan Richter
Use only statically allocated data for PHY config packet transmission. With the previous incarnation, some data wouldn't be freed if the packet transmit callback was never called. A theoretical drawback now is that, in PCs with more than one card, card A may complete() for a waiter on card B. But this is highly unlikely and its impact not serious. Bus manager B may reset bus B before the PHY config went out, but the next phy config on B should be fine. However, with a timeout of 100ms, this situation is close to impossible. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-07-14firewire: small fw_fill_request cleanupStefan Richter
- better name for a function argument - removal of a local variable which became unnecessary after "fully initialize fw_transaction before marking it pending" Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-07-14firewire: fully initialize fw_transaction before marking it pendingStefan Richter
In theory, card->flush_timer could already access a transaction between fw_send_request()'s spin_unlock_irqrestore and the rest of what happens in fw_send_request(). This would happen if the process which sends the request is preempted and put to sleep right after spin_unlock_irqrestore for longer than 100ms. Therefore we fill in everything in struct fw_transaction at which the flush_timer might look at before we lift the lock. To do: Ensure that the timer does not pick up the transaction before the time of the AT request event plus split transaction timeout. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-07-14firewire: don't respond to broadcast write requestsStefan Richter
Contrary to a comment in the source, request->ack of a broadcast write request can be ACK_PENDING. Hence the existing check is insufficient. Debug dmesg before: AR spd 0 tl 00, ffc0 -> ffff, ack_pending , QW req, fffff0000234 = ffffffff AT spd 0 tl 00, ffff -> ffc0, ack_complete, W resp And the requesting node (linux1394) reports an unsolicited response. Debug dmesg after: AR spd 0 tl 00, ffc0 -> ffff, ack_pending , QW req, fffff0000234 = ffffffff Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-07-14firewire: implement broadcast_channel CSR for 1394a complianceStefan Richter
See IEEE 1394a clause 8.3.2.3.11. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-06-19firewire: deadline for PHY config transmissionStefan Richter
If the low-level driver failed to initialize a card properly without noticing it, fw-core was blocked indefinitely when trying to send a PHY config packet. This hung up the events kernel thread, e.g. locked up keyboard input. https://bugzilla.redhat.com/show_bug.cgi?id=444694 https://bugzilla.redhat.com/show_bug.cgi?id=446763 This problem was introduced between 2.6.25 and 2.6.26-rc1 by commit 2a0a2590498be7b92e3e76409c9b8ee722e23c8f "firewire: wait until PHY configuration packet was transmitted (fix bus reset loop)". The solution is to wait with timeout. I tested it with 7 different working controllers and 1 non-working controller. On the working ones, the packet callback complete()s usually --- but not always --- before a timeout of 10ms. Hence I chose a safer timeout of 100ms. On the few tests with the non-working controller ALi M5271, PHY config packet transmission always timed out so far. (Fw-ohci needs to be fixed for this controller independently of this deadline fix. Often the core doesn't even attempt to send a phy config because not even self ID reception works.) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-06-19firewire: don't panic on invalid AR request bufferStefan Richter
BUG() at this place is wrong. (Unless if the low level driver would already do higher-level input validation of incoming request headers.) Invalid incoming requests or bugs in the controller which corrupt the AR-req buffer needlessly crashed the box because this is run in tasklet context. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18drivers: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18firewire: cleanupsAdrian Bunk
This patch contains the following cleanups: - #if 0 the following unused structs: - fw-transaction.c:fw_low_memory_region - fw-transaction.c:fw_private_region - fw-transaction.c:fw_csr_region - fw-transaction.c:fw_unit_space_region - remove the following unused EXPORT_SYMBOL's: - fw-card.c:fw_core_add_descriptor - fw-card.c:fw_core_remove_descriptor - fw-iso.c:fw_iso_context_create - fw-iso.c:fw_iso_context_destroy - fw-iso.c:fw_iso_context_start - fw-iso.c:fw_iso_context_queue - fw-iso.c:fw_iso_context_stop Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: wait until PHY configuration packet was transmitted (fix bus reset ↵Stefan Richter
loop) We now exit fw_send_phy_config /after/ the PHY config packet has been transmitted, instead of before. A subsequent fw_core_initiate_bus_reset will therefore not overlap with the transmission. This is meant to make the send PHY config packet + reset bus routine more deterministic. Fixes bus reset loop and eventual panic with - VIA VT6307 + IOGEAR hub + Unibrain Fire-i camera http://bugzilla.kernel.org/show_bug.cgi?id=10128 - JMicron card Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-04-18firewire: use bitwise and to get reg in handle_registersJarod Wilson
for code efficiency. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: replace more hex values with defined csr constantsJarod Wilson
Trivial change to replace more meaningless (to the untrained eye) hex values with defined CSR constants. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-03-20firewire: fix panic in handle_at_packetStefan Richter
This fixes a use-after-free bug in the handling of split transactions. The AT DMA handler of the request was occasionally executed after the AR DMA handler of the response. The AT DMA handler then accessed an already freed packet. Reported by Johannes Berg. http://bugzilla.kernel.org/show_bug.cgi?id=9617 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-03-14firewire: endianess annotationsStefan Richter
Kills warnings from 'make C=1 CHECKFLAGS="-D__CHECK_ENDIAN__" modules': drivers/firewire/fw-transaction.c:771:10: warning: incorrect type in assignment (different base types) drivers/firewire/fw-transaction.c:771:10: expected unsigned int [unsigned] [usertype] <noident> drivers/firewire/fw-transaction.c:771:10: got restricted unsigned int [usertype] <noident> drivers/firewire/fw-transaction.h:93:10: warning: incorrect type in assignment (different base types) drivers/firewire/fw-transaction.h:93:10: expected unsigned int [unsigned] [usertype] <noident> drivers/firewire/fw-transaction.h:93:10: got restricted unsigned int [usertype] <noident> drivers/firewire/fw-ohci.c:1490:8: warning: restricted degrades to integer drivers/firewire/fw-ohci.c:1490:35: warning: restricted degrades to integer drivers/firewire/fw-ohci.c:1516:5: warning: cast to restricted type Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-01-30firewire: replace subtraction with bitwise andJarod Wilson
Replace an unnecessary subtraction with a bitwise AND when determining the value of ext_tcode in fw_fill_transaction() to save a cpu cycle or two in a somewhat critical path. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-01-30firewire: Fix extraction of source node idRabin Vincent
Fix extraction of the source node id from the packet header. Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-20fix typo "insted" -> "instead"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17firewire: optimize fw_core_add_address_handlerStefan Richter
Potentially avoids unnecessary loop runs. Guarantee quadlet-aligned starts of address regions. Document the return values. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-08-02firewire: fw-core: make two variables staticStefan Richter
2007-07-18firewire: fix memory leak of fw_request instancesStefan Richter
Found and debugged by Jay Fenlason <fenlason@redhat.com>. The bug was especially noticeable with direct I/O over fw-sbp2. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2007-07-18firewire: remove bogus check in fw_core_handle_requestStefan Richter
This check is bogus: - Maximum asynchronous payload size for S800...S3200 is 4096. - The p->payload_length is totally uninteresting. Only the request->length of the subsequently allocated and initialized struct fw_request is of significance. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2007-05-10firewire: Always use parens with sizeof.Kristian Høgsberg
Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-10firewire: Uppercase most macro names.Kristian Høgsberg
2007-05-10firewire: Clean up comment style.Kristian Høgsberg
Drop filenames from file preamble, drop editor annotations and use standard indent style for block comments. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (fixed typo)
2007-03-09firewire: Implement CSR cycle time and bus time registers.Kristian Høgsberg
Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: Implement topology map and fix a couple of loopback bugs.Kristian Høgsberg
2007-03-09firewire: Switch cdev code over to use register_chrdev and keep a list of ↵Kristian Høgsberg
devices. The old mechanism kept a struct cdev for each fw device, but fops->release would reference this struct after the device got freed in some cases. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: Let an fw_descriptor specify a leading immediate key/value pair.Kristian Høgsberg
This lets us break out "Juju" as the model name in the config rom. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: Use correct payload pointer when demarshalling incoming requests.Kristian Høgsberg
2007-03-09firewire: Implement proper transaction cancelation.Kristian Høgsberg
Drivers such as fw-sbp2 had no way to properly cancel in-progress transactions, which could leave a pending transaction or an unset packet in the low-level queues after kfree'ing the containing structure. fw_cancel_transaction() lets drivers cancel a submitted transaction. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: Rework async receive DMA.Kristian Høgsberg
The old DMA program for receiving async packets stops DMA while processing received packets and only expects one packet per interrupt. Stopping DMA can silently drop packets and we need to handle multiple received packets per interrupt. This new version keeps DMA running at all times and just append new pages as buffers fill up, and supports multiple packets per interrupt. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: Fix bit shift typo.Kristian Høgsberg
2007-03-09firewire: Sanitize send error codes.Kristian Høgsberg
Drop the negative errnos and use RCODEs for all error codes in the complete transaction callback. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-09firewire: Handle access to CSR resources on local node.Kristian Høgsberg
2007-03-09firewire: Clean up response handling.Kristian Høgsberg
