path: root/drivers/firewire
2014-01-20firewire: Enable remote DMA above 4 GBStefan Richter
This makes all of a machine's memory accessible to remote debugging via FireWire, using the physical response unit (i.e. RDMA) of OHCI-1394 link layer controllers. This requires actual support by the controller. The only ones currently known to support it are Agere/LSI FW643. Most if not all other OHCI-1394 controllers do not implement the optional Physical Upper Bound register. With them, RDMA will continue to be limited to the lowermost 4 GB. firewire-ohci's startup message in the kernel log is augmented to tell whether the controller does expose more than 4 GB to RDMA. While OHCI-1394 allows for a maximum Physical Upper Bound of 0xffff'0000'0000 (near 256 TB), this implementation sets it to 0x8000'0000'0000 (128 TB) in order to avoid interference with applications that require interrupt-served asynchronous request reception at respectively low addresses. Note, this change does not switch remote DMA on. It only increases the range of remote access to all memory (instead of just 4 GB) whenever remote DMA was switched on by other means. The latter is achieved by setting firewire-ohci's remote_dma parameter, or if the physical DMA filter is opened through firewire-sbp2. Derived from patch "firewire: Enable physical DMA above 4GB" by Peter Hurley <peter@hurleysoftware.com> from March 27, 2013. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2014-01-12firewire: ohci: Turn remote DMA support into a module parameterLubomir Rintel
This makes it possible to debug kernel over FireWire without the need to recompile it. [Stefan R: changed description from "...0" to "...N"] Cc: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-12-15firewire: sbp2: bring back WRITE SAME supportStefan Richter
Commit 54b2b50c20a6 "[SCSI] Disable WRITE SAME for RAID and virtual host adapter drivers" disabled WRITE SAME support for all SBP-2 attached targets. But as described in the changelog of commit b0ea5f19d3d8 "firewire: sbp2: allow WRITE SAME and REPORT SUPPORTED OPERATION CODES", it is not required to blacklist WRITE SAME. Bring the feature back by reverting the sbp2.c hunk of commit 54b2b50c20a6. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: stable@kernel.org
2013-11-29[SCSI] Disable WRITE SAME for RAID and virtual host adapter driversMartin K. Petersen
Some host adapters do not pass commands through to the target disk directly. Instead they provide an emulated target which may or may not accurately report its capabilities. In some cases the physical device characteristics are reported even when the host adapter is processing commands on the device's behalf. This can lead to adapter firmware hangs or excessive I/O errors. This patch disables WRITE SAME for devices connected to host adapters that provide an emulated target. Driver writers can disable WRITE SAME by setting the no_write_same flag in the host adapter template. [jejb: fix up rejections due to eh_deadline patch] Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: stable@kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-29firewire: ohci: Fix deadlock at bus resetStephan Gatzka
Put bus_reset_work into its own workqueue. By doing this, forward progress of bus_reset_work() is guaranteed if the work is switched over to a rescuer thread. Switching work to a rescuer thread happens if a new worker thread could not be allocated in certain time (MAYDAY_INITIAL_TIMEOUT, typically 10 ms). This might not be possible under high memory pressure or even on a heavily loaded embedded system running a slow serial console. The former deadlock occured in the following situation: The rescuer thread ran fw_device_init->read_config_rom->read_rom->fw_run_transaction. fw_run_transaction blocked waiting for the completion object. This completion object would have been completed in bus_reset_work, but this work was never executed in the rescuer thread due to its strictly sequential behaviour. [Stefan R.: Removed WQ_NON_REENTRANT flag from allocation because it is no longer needed in current kernels. Add it back if you backport to kernels older than 3.7, i.e. one which does not contain dbf2576e37da "workqueue: make all workqueues non-reentrant". Swapped order of destroy_workqueue and pci_unregister_driver.] Signed-off-by: Stephan Gatzka <stephan.gatzka@gmail.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-08-29firewire: ohci: Change module_pci_driver to module_init/module_exitStephan Gatzka
This is a prerequisite to allocate a per driver self_id workqueue. This reverts the ohci.c part of patch fe2af11c220c7bb3a67f7aec0594811e5c59e019. Signed-off-by: Stephan Gatzka <stephan.gatzka@gmail.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-08-19firewire: ohci: beautify some macro definitionsStefan Richter
a) Sort device IDs by vendor -- device -- revision. b) Write quirk flags in hexadecimal. This affects the user-visible output of "modinfo firewire-ohci". Since more flags have been added recently, it is now easier to cope with them in hexadecimal represen- tation. Besides, the device-specific combination of quirk flags is shown in hexadecimal in the kernel log too. (And firewire-sbp2 presents its own quirk flags in modinfo as hexadecimals as well.) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-08-19firewire: ohci: change confusing name of a struct memberStefan Richter
We have got struct descriptor *descriptors; dma_addr_t descriptors_bus; dma_addr_t buffer_bus; struct descriptor buffer[0]; void *misc_buffer; dma_addr_t misc_buffer_bus; __be32 *config_rom; dma_addr_t config_rom_bus; __be32 *next_config_rom; dma_addr_t next_config_rom_bus; But then we have got __le32 *self_id_cpu; dma_addr_t self_id_bus; Better apply the pattern of xyz vs. xyz_bus to self_id vs. self_id_bus as well. The _cpu suffix looks particularly weird in conversions from little endian to CPU endian. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-07-30firewire: core: typecast from gfp_t to bool more safelyStefan Richter
An idr related patch introduced the following sparse warning: drivers/firewire/core-cdev.c:488:33: warning: incorrect type in initializer (different base types) drivers/firewire/core-cdev.c:488:33: expected bool [unsigned] [usertype] preload drivers/firewire/core-cdev.c:488:33: got restricted gfp_t So let's convert from gfp_t bitfield to Boolean explicitly and safely. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-07-30firewire: WQ_NON_REENTRANT is meaningless and going awayTejun Heo
dbf2576e37 ("workqueue: make all workqueues non-reentrant") made WQ_NON_REENTRANT no-op and the flag is going away. Remove its usages. This patch doesn't introduce any behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-07-27firewire: fix libdc1394/FlyCap2 iso event regressionClemens Ladisch
Commit 18d627113b83 (firewire: prevent dropping of completed iso packet header data) was intended to be an obvious bug fix, but libdc1394 and FlyCap2 depend on the old behaviour by ignoring all returned information and thus not noticing that not all packets have been received yet. The result was that the video frame buffers would be saved before they contained the correct data. Reintroduce the old behaviour for old clients. Tested-by: Stepan Salenikovich <stepan.salenikovich@gmail.com> Tested-by: Josep Bosch <jep250@gmail.com> Cc: <stable@vger.kernel.org> # 3.4+ Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-06-09firewire: remove support of fw_driver.driver.probe and .remove methodsStefan Richter
After all IEEE 1394 high-level drivers being converted to bus-specific .probe/.remove methods, remove support of the obsolete generic methods. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-06-09firewire: introduce fw_driver.probe and .remove methodsStefan Richter
FireWire upper layer drivers are converted from generic struct driver.probe() and .remove() to bus-specific struct fw_driver.probe() and .remove(). The new .probe() adds a const struct ieee1394_device_id *id argument, indicating the entry in the driver's device identifiers table which matched the fw_unit to be probed. This new argument is used by the snd-firewire-speakers driver to look up device-specific parameters and methods. There is at least one other FireWire audio driver currently in development in which this will be useful too. The new .remove() drops the unused error return code. Although all in-tree drivers are being converted to the new methods, support for the old methods is left in place in this commit. This allows public developer trees to merge this commit and then move to the new fw_driver methods. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Clemens Ladisch <clemens@ladisch.de> (for sound/firewire/) Cc: Peter Hurley <peter@hurleysoftware.com> (for drivers/staging/fwserial/)
2013-05-09Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewure updates from Stefan Richter: - fix controller removal when controller is in suspended state - fix video reception on VIA VT6306 with gstreamer, MythTV, and maybe dv4l - fix a startup issue with Agere/LSI FW643-e2 - error logging improvements and other small updates * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: ohci: dump_stack() for PHY regs read/write failures firewire: ohci: Improve bus reset error messages firewire: ohci: Alias dev_* log functions firewire: ohci: Fix 'failed to read phy reg' on FW643 rev8 firewire: ohci: fix VIA VT6306 video reception firewire: ohci: Check LPS before register access on pci removal firewire: ohci: Fix double free_irq() firewire: remove unnecessary alloc/OOM messages firewire: sbp2: replace BUG_ON by WARN_ON firewire: core: remove an always false test firewire: Remove two unneeded checks for macros
2013-04-30firewire: ohci: dump_stack() for PHY regs read/write failuresPeter Hurley
A stack trace is an invaluable tool in determining the basis and cause of PHY regs read/write failures. Include PHY reg addr (and value for writes) in the diagnostic. [Stefan R: changed whitespace] Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-30firewire: ohci: Improve bus reset error messagesPeter Hurley
Many of the error messages possible from bus_reset_work() do not contain enough information to distinguish which error condition occurred nor enough information to evaluate the error afterwards. Differentiate all error conditions in bus_reset_work(); add additional information to make error diagnosis possible. [Stefan R: fixed self-ID endian conversion] Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-30firewire: ohci: Alias dev_* log functionsPeter Hurley
Convert dev_xxxx(ohci->card.device, ...) log functions to ohci_xxxx(ohci, ...). [Stefan R: Peter argues that this increases readability of the code.] [Stefan R: changed whitespace] Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-30firewire: ohci: Fix 'failed to read phy reg' on FW643 rev8Peter Hurley
With the LSI FW643 rev 8 [1], the first commanded bus reset at the conclusion of ohci_enable() has been observed to fail with the following messages: [ 4.884015] firewire_ohci 0000:01:00.0: failed to read phy reg .... [ 5.684012] firewire_ohci 0000:01:00.0: failed to read phy reg With drivers/firewire/ohci.c instrumented, the error condition [2] indicates the PHY arbitration state machine has timed out prior to enabling PHY LCtrl. Furthermore, instrumenting ohci_enable() shows that LPS has been enabled within 1 ms. Test LPS latching every 1 ms rather than every 50ms. [1] lspci -v 01:00.0 FireWire (IEEE 1394): LSI Corporation FW643 [TrueFire] PCIe 1394b Controller (rev 08) (prog-if 10 [OHCI]) Subsystem: LSI Corporation FW643 [TrueFire] PCIe 1394b Controller Flags: bus master, fast devsel, latency 0, IRQ 92 Memory at fbeff000 (64-bit, non-prefetchable) [size=4K] Capabilities: [44] Power Management version 3 Capabilities: [4c] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [60] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [140] Virtual Channel Capabilities: [170] Device Serial Number 08-14-43-82-00-00-41-fc Kernel driver in use: firewire_ohci Kernel modules: firewire-ohci [2] instrumented WARNING in read_phy_reg() [ 4.576010] ------------[ cut here ]------------ [ 4.576035] WARNING: at ./drivers/firewire/ohci.c:570 read_phy_reg+0x93/0xe0 [firewire_ohci]() [ 4.576050] Hardware name: Precision WorkStation T5400 [ 4.576058] failed to read phy reg:1 (phy(5) @ config enhance:19) [ 4.576068] Modules linked in: hid_logitech_dj hid_generic(+) usbhid <...snip...> [ 4.576140] Pid: 61, comm: kworker/2:1 Not tainted 3.8.0-2+fwtest-xeon #2+fwtest [ 4.576149] Call Trace: [ 4.576160] [<ffffffff8105468f>] warn_slowpath_common+0x7f/0xc0 [ 4.576168] [<ffffffff81054786>] warn_slowpath_fmt+0x46/0x50 [ 4.576178] [<ffffffffa00caca3>] read_phy_reg+0x93/0xe0 [firewire_ohci] [ 4.576188] [<ffffffffa00cae19>] ohci_read_phy_reg+0x39/0x60 [firewire_ohci] [ 4.576203] [<ffffffffa00731ff>] fw_send_phy_config+0xbf/0xe0 [firewire_core] [ 4.576214] [<ffffffffa006b2d6>] br_work+0x46/0xb0 [firewire_core] [ 4.576225] [<ffffffff81071e0c>] process_one_work+0x13c/0x500 [ 4.576238] [<ffffffffa006b290>] ? fw_card_initialize+0x180/0x180 [firewire_core] [ 4.576248] [<ffffffff810737ed>] worker_thread+0x16d/0x470 [ 4.576257] [<ffffffff81073680>] ? busy_worker_rebind_fn+0x100/0x100 [ 4.576266] [<ffffffff8107d160>] kthread+0xc0/0xd0 [ 4.576275] [<ffffffff816a0000>] ? pcpu_dump_alloc_info+0x1cb/0x2c4 [ 4.576284] [<ffffffff8107d0a0>] ? kthread_create_on_node+0x130/0x130 [ 4.576297] [<ffffffff816b2f6c>] ret_from_fork+0x7c/0xb0 [ 4.576305] [<ffffffff8107d0a0>] ? kthread_create_on_node+0x130/0x130 [ 4.576313] ---[ end trace cbc940994b300302 ]--- [Stefan R: Peter also reports a change of behavior with LSI FW323. Before the patch, there would often occur a lock transaction failure during firewire-core startup: [ 6.056022] firewire_core 0000:07:06.0: BM lock failed (timeout), making local node (ffc0) root This failure no longer happens after the patch, without an obvious reason for the failure or the fix.] [Stefan R: Added quirk flag, quirk table entry, and comment.] Reported-by: Tim Jordan <tim@insipid.org.uk> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: ohci: fix VIA VT6306 video receptionAndy Leiserson
Add quirk for VT6306 wake bit behavior. VT6306 seems to reread the wrong descriptor when the wake bit is written. work around by putting a copy of the branch address in the first descriptor of the block. [Stefan R: This fixes the known broken video reception via gstreamer on VIA VT6306. 100% repeatable testcase: $ gst-launch-0.10 dv1394src \! dvdemux \! dvdec \! xvimagesink with a camcorder or other DV source connected. Likewise for MPEG2-TS reception via gstreamer, e.g. from TV settop boxes. Perhaps this also fixes dv4l on VT6306, but this is as yet untested. Kino, dvgrab or FFADO had not been affected by this chip quirk. Additional comments from Andy:] I've looked into some problems with the wake bit on a vt6306 family chip (1106:3044, rev 46). I used this firewire card in a mythtv setup (ISO receive MPEG2 stream) with Debian 2.6.32 kernels for ~2 years without problems. Since upgrading to 3.2, I've been having problems with the input stream freezing -- input data stops until I restart mythtv (I expect closing and reopening the device would be sufficient). This happens infrequently, maybe one out of 20 recordings. I eventually determined that the problem is more likely to occur if the system is loaded. I isolated the kernel version as the triggering SW factor and then specifically the change from dualbuffer back to packet-per-buffer DMA mode. The possibility that the controller does not properly respond to the wake bit was suggested in https://bugzilla.redhat.com/show_bug.cgi?id=415841, but not proven. Based on the fact that dualbuffer mode worked while packet-per-buffer has trouble, I guessed that upon seeing the wake bit written, the vt6306 controller only checks the branch address in the first descriptor of the block, even if that is not the correct place to look (because the block has multiple descriptors). This theory seems to be correct. When the ISO reception is hung, I am able to resume it by manually writing the branch address to the first descriptor in the block, and then writing the wake bit. I've had luck so far with the attached patch, so I'm including it. It's probably not a complete solution -- I haven't tested transmit modes to see whether they have a similar issue. I doubt that the quirk test is any cheaper than just writing the extra branch address in all cases, but it does reduce the risk of breaking other hardware. [Stefan R: omitted QUIRK_NO_MSI from VT6306 quirks table entry, changed whitespace] Signed-off-by: Andy Leiserson <andy@leiserson.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: ohci: Check LPS before register access on pci removalPeter Hurley
A pci device can be removed while in its suspended state. If the ohci host controller is suspended, the PHY is also in low-power mode and LPS is disabled. If LPS is disabled, most of the host registers aren't accessible, including IntMaskClear. Furthermore, access to these registers when LPS is disabled can cause hard lockups on some hardware. Since interrupts are already disabled in this mode, further action is unnecessary. Test LPS before attempting to write IntMaskClear to disable interrupts. [Stefan R: whitespace changes] Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: ohci: Fix double free_irq()Peter Hurley
A pci device can be removed while in its suspended state. Because the ohci driver freed the irq to suspend, free_irq() is called twice; once from pci_remove() and again from pci_suspend(), which issues the warning below [1]. Rather than allocate the irq in the .enable() path, move the allocation to .probe(). Consequently, the irq is not reallocated upon pci_resume() and thus is not freed upon pci_suspend(). [1] Warning reported by Mark Einon <mark.einon@gmail.com> when suspending an MSI MS-1727 GT740 laptop on Ubuntu 3.5.0-22-generic WARNING: at ./kernel/irq/manage.c:1198 __free_irq+0xa3/0x1e0() Hardware name: MS-1727 Trying to free already-free IRQ 16 Modules linked in: ip6table_filter ip6_tables ebtable_nat ebtables <...snip...> Pid: 4, comm: kworker/0:0 Tainted: P O 3.5.0-22-generic #34-Ubuntu Call Trace: [<ffffffff81051c1f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff81051d16>] warn_slowpath_fmt+0x46/0x50 [<ffffffff8103fa39>] ? default_spin_lock_flags+0x9/0x10 [<ffffffff810df6b3>] __free_irq+0xa3/0x1e0 [<ffffffff810df844>] free_irq+0x54/0xc0 [<ffffffffa005a27e>] pci_remove+0x6e/0x210 [firewire_ohci] [<ffffffff8135ae7f>] pci_device_remove+0x3f/0x110 [<ffffffff8141fdbc>] __device_release_driver+0x7c/0xe0 [<ffffffff8141fe4c>] device_release_driver+0x2c/0x40 [<ffffffff8141f5f1>] bus_remove_device+0xe1/0x120 [<ffffffff8141cd1a>] device_del+0x12a/0x1c0 [<ffffffff8141cdc6>] device_unregister+0x16/0x30 [<ffffffff81354784>] pci_stop_bus_device+0x94/0xa0 [<ffffffffa0091c67>] acpiphp_disable_slot+0xb7/0x1a0 [acpiphp] [<ffffffffa0090716>] ? get_slot_status+0x46/0xc0 [acpiphp] [<ffffffffa0091d7d>] acpiphp_check_bridge.isra.15+0x2d/0xf0 [acpiphp] [<ffffffffa0092442>] _handle_hotplug_event_bridge+0x372/0x4d0 [acpiphp] [<ffffffff81390f8c>] ? acpi_os_execute_deferred+0x2f/0x34 [<ffffffff8116e22d>] ? kfree+0xed/0x110 [<ffffffff8107086a>] process_one_work+0x12a/0x420 [<ffffffffa00920d0>] ? _handle_hotplug_event_func+0x1d0/0x1d0 [acpiphp] [<ffffffff8107141e>] worker_thread+0x12e/0x2f0 [<ffffffff810712f0>] ? manage_workers.isra.26+0x200/0x200 [<ffffffff81075f13>] kthread+0x93/0xa0 [<ffffffff8168d024>] kernel_thread_helper+0x4/0x10 [<ffffffff81075e80>] ? kthread_freezable_should_stop+0x70/0x70 [<ffffffff8168d020>] ? gs_change+0x13/0x13 Reported-by: Mark Einon <mark.einon@gmail.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: remove unnecessary alloc/OOM messagesStefan Richter
These are redundant to log messages from the mm core. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: sbp2: replace BUG_ON by WARN_ONStefan Richter
No need to crash and burn if S/G element sizes cannot be set to our liking; just leave a message in the log. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: core: remove an always false testStefan Richter
struct fw_cdev_allocate_iso_resource.bandwidth is unsigned. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-04-28firewire: Remove two unneeded checks for macrosPaul Bolle
The old IEEE 1394 driver stack was removed in v2.6.37. That made the checks for two Kconfig (module) macros unneeded, since they will now always evaluate to true. Remove these two checks. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-03-28net: add ETH_P_802_3_MINSimon Horman
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for an 802.3 frame. Frames with a lower value in the ethernet type field are Ethernet II. Also update all the users of this value that David Miller and I could find to use the new constant. Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN should be >= not >. As suggested by Jesse Gross. Compile tested only. Cc: David Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: John W. Linville <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Bart De Schuymer <bart.de.schuymer@pandora.be> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: linux-bluetooth@vger.kernel.org Cc: netfilter-devel@vger.kernel.org Cc: bridge@lists.linux-foundation.org Cc: linux-wireless@vger.kernel.org Cc: linux1394-devel@lists.sourceforge.net Cc: linux-media@vger.kernel.org Cc: netdev@vger.kernel.org Cc: dev@openvswitch.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net, ipv6: IPv6 over Firewire (RFC3146) support.YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net, ipv4 arp: Extend hardware address and remove driver-level ↵YOSHIFUJI Hideaki / 吉藤英明
packet inspection. Inspection of upper layer protocol is considered harmful, especially if it is about ARP or other stateful upper layer protocol; driver cannot (and should not) have full state of them. IPv4 over Firewire module used to inspect ARP (both in sending path and in receiving path), and record peer's GUID, max packet size, max speed and fifo address. This patch removes such inspection by extending our "hardware address" definition to include other information as well: max packet size, max speed and fifo. By doing this, The neighbour module in networking subsystem can cache them. Note: As we have started ignoring sspd and max_rec in ARP/NDP, those information will not be used in the driver when sending. When a packet is being sent, the IP layer fills our pseudo header with the extended "hardware address", including GUID and fifo. The driver can look-up node-id (the real but rather volatile low-level address) by GUID, and then the module can send the packet to the wire using parameters provided in the extendedn hardware address. This approach is realistic because IP over IEEE1394 (RFC2734) and IPv6 over IEEE1394 (RFC3146) share same "hardware address" format in their address resolution protocols. Here, extended "hardware address" is defined as follows: union fwnet_hwaddr { u8 u[16]; struct { __be64 uniq_id; /* EUI-64 */ u8 max_rec; /* max packet size */ u8 sspd; /* max speed */ __be16 fifo_hi; /* hi 16bits of FIFO addr */ __be32 fifo_lo; /* lo 32bits of FIFO addr */ } __packed uc; }; Note that Hardware address is declared as union, so that we can map full IP address into this, when implementing MCAP (Multicast Cannel Allocation Protocol) for IPv6, but IP and ARP subsystem do not need to know this format in detail. One difference between original ARP (RFC826) and 1394 ARP (RFC2734) is that 1394 ARP Request/Reply do not contain the target hardware address field (aka ar$tha). This difference is handled in the ARP subsystem. CC: Stephan Gatzka <stephan.gatzka@gmail.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net: Ignore spd and max_payload advertised by ARP.YOSHIFUJI Hideaki / 吉藤英明
Stefan Richter <stefanr@s5r6.in-berlin.de> says: | As far as I can tell, it would be best to ignore max_rec and sspd from ARP | and NDP but keep using the respective information from firewire-core | instead (handed over by fwnet_probe()). | | Why? As I noted earlier, RFC 2734:1999 and RFC 3146:2001 were apparently | written with a too simplistic notion of IEEE 1394 bus topology, resulting | in max_rec and sspd in ARP-1394 and NDP-1394 to be useless, IMO. | | Consider a bus like this: | | A ---- B ==== C | | A, B, C are all IP-over-1394 capable nodes. ---- is an S400 cable hop, | and ==== is an S800 cable hop. | | In case of unicasts or multicasts in which node A is involved as | transmitter or receiver, as well as in case of broadcasts, the speeds | S100, S200, S400 work and speed S400 is optimal. | | In case of anything else, IOW in case of unicasts or multicasts in which | only nodes B and C are involved, the speeds S100, S200, S400, S800 work | and speed S800 is optimal. | | Clearly, node A should indicate sspd = S400 in its ARP or NDP packets. | But which sspd should nodes B and C set there? Maybe they set S400, which | would work but would waste half of the available bandwidth in the second | case. Or maybe they set S800, which is OK in the second case but would | prohibit any communication with node A if blindly taken for correct. | | On the other hand, firewire-core *always* gives us the correct and optimum | peer-to-peer speed and asynchronous packet payload, no matter how simple | or complex the bus topology is and no matter in which temporal order nodes | join the bus and are discovered. CC: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net: Allocate address handler before registering net_device.YOSHIFUJI Hideaki / 吉藤英明
Allocate FIFO address before registering net_device. This is preparation to change the pseudo hardware address format for firewire devices to include the offset of the FIFO for receipt of unicast datagrams, instead of mangling ARP/NDP messages in the driver layer. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net: Send L2 multicast via GASP.YOSHIFUJI Hideaki / 吉藤英明
Send L2 multicast packet via GASP (Global asynchronous stream packet) by seeing the multicast bit in the L2 hardware address, not by seeing upper- layer protocol address. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26firewire net: Accept IPv4 and ARP only.YOSHIFUJI Hideaki / 吉藤英明
2013-03-13firewire net: Release broadcast/fifo resources on ifdown.YOSHIFUJI Hideaki
Since those resources are allocated on ifup, relsase them on ifdown. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-03-13firewire net: Introduce fwnet_broadcast_stop() to destroy broadcast resources.YOSHIFUJI Hideaki
2013-03-13firewire net: Allocate dev->broadcast_rcv_buffer_ptrs early.YOSHIFUJI Hideaki
2013-03-13firewire net: Fix leakage of kmap for broadcast receive buffer.YOSHIFUJI Hideaki
2013-03-13firewire net: Omit checking dev->broadcast_rcv_context in ↵YOSHIFUJI Hideaki
fwnet_broadcast_start(). dev->broadcast_rcv_context is always non-NULL if dev->broadcast_state is not FWNET_BROADCAST_ERROR. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-03-13firewire net: Clear dev->broadcast_rcv_context and dev->broadcast_state ↵YOSHIFUJI Hideaki
after destruction of context. Clear dev->broadcast_rcv_context to NULL and set dev->broadcast_state to FWNET_BROADCAST_ERROR after descruction of broadcast context. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-03-13firewire net: Fix memory leakage in fwnet_remove().YOSHIFUJI Hideaki
2013-03-13firewire net: Check dev->broadcast_state inside fwnet_broadcast_start().YOSHIFUJI Hideaki
2013-03-13firewire net: Setup broadcast and local fifo independently.YOSHIFUJI Hideaki
2013-03-13firewire net: Introduce fwnet_fifo_{start, stop}() helpers.YOSHIFUJI Hideaki
2013-03-13firewire net: No need to reset dev->local_fifo after failure of ↵YOSHIFUJI Hideaki
fw_core_add_address_handler(). fwnet_broadcast_start() try to register address handler at first if it was not registered yet; dev->local_fifo == FWNET_NO_FIFO_ADDR. Since dev->local_info not changed if fw_core_add_address_hander() has failed, we do not need to set dev->local_info to FWNET_NO_FIFO_ADDR. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2013-02-27firewire: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. v2: Stefan pointed out that add_client_resource() may be called from non-process context. Preload iff @gfp_mask contains __GFP_WAIT. Also updated to include minor upper limit check. [tim.gardner@canonical.com: fix accidentally orphaned 'minor'[ Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27firewire: add minor number range check to fw_device_init()Tejun Heo
fw_device_init() didn't check whether the allocated minor number isn't too large. Fail if it goes overflows MINORBITS. Signed-off-by: Tejun Heo <tj@kernel.org> Suggested-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27firewire: don't use idr_remove_all()Tejun Heo
idr_destroy() can destroy idr by itself and idr_remove_all() is being deprecated. Drop its usage. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-20firewire net: Use LL_RESERVED_SPACE(), HH_DATA_OFF().YOSHIFUJI Hideaki / 吉藤英明
