path: root/drivers/firmware/edd.c
2008-02-03drivers/firmware/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-24Kobject: convert drivers/* from kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: change drivers/firmware/edd.c to use kobject_init_and_addGreg Kroah-Hartman
Stop using kobject_register, as this way we can control the sending of the uevent properly, after everything is properly initialized. Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24firmware: change firmware_kset to firmware_kobjGreg Kroah-Hartman
There is no firmware "subsystem" it's just a directory in /sys that other portions of the kernel want to hook into. So make it a kobject not a kset to help alivate anyone who tries to do some odd kset-like things with this. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert edd to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: rename ktype_edd and ktype_efivarGreg Kroah-Hartman
This makes it a bit more sane when trying to figure out how to clean up the ktype mess. Based on a larger patch from Kay Sievers Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-16edd: switch to pci_get based APIAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-11[PATCH] docbook: add edd firmware interfacesRandy Dunlap
Cleanup kernel-doc notation in drivers/firmware/edd.c. Add edd.c to DocBook/kernel-api.tmpl. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-07[PATCH] drivers/firmware: kmalloc + memset -> kzalloc conversionDeepak Saxena
Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] sysfs: (rest) if show/store is missing return -EIODmitry Torokhov
sysfs: fix the rest of the kernel so if an attribute doesn't implement show or store method read/write will return -EIO instead of 0 or -EINVAL or -EPERM. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
