path: root/drivers/firmware/pcdp.c
2007-07-16serial: convert early_uart to earlycon for 8250Yinghai Lu
Beacuse SERIAL_PORT_DFNS is removed from include/asm-i386/serial.h and include/asm-x86_64/serial.h. the serial8250_ports need to be probed late in serial initializing stage. the console_init=>serial8250_console_init=> register_console=>serial8250_console_setup will return -ENDEV, and console ttyS0 can not be enabled at that time. need to wait till uart_add_one_port in drivers/serial/serial_core.c to call register_console to get console ttyS0. that is too late. Make early_uart to use early_param, so uart console can be used earlier. Make it to be bootconsole with CON_BOOT flag, so can use console handover feature. and it will switch to corresponding normal serial console automatically. new command line will be: console=uart8250,io,0x3f8,9600n8 console=uart8250,mmio,0xff5e0000,115200n8 or earlycon=uart8250,io,0x3f8,9600n8 earlycon=uart8250,mmio,0xff5e0000,115200n8 it will print in very early stage: Early serial console at I/O port 0x3f8 (options '9600n8') console [uart0] enabled later for console it will print: console handover: boot [uart0] -> real [ttyS0] Signed-off-by: <yinghai.lu@sun.com> Cc: Andi Kleen <ak@suse.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-02ACPICA: Remove duplicate table definitions (non-conflicting), contAlexey Starikovskiy
Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-26[PATCH] EFI: keep physical table addresses in efi structureBjorn Helgaas
Almost all users of the table addresses from the EFI system table want physical addresses. So rather than doing the pa->va->pa conversion, just keep physical addresses in struct efi. This fixes a DMI bug: the efi structure contained the physical SMBIOS address on x86 but the virtual address on ia64, so dmi_scan_machine() used ioremap() on a virtual address on ia64. This is essentially the same as an earlier patch by Matt Tolentino: http://marc.theaimsgroup.com/?l=linux-kernel&m=112130292316281&w=2 except that this changes all table addresses, not just ACPI addresses. Matt's original patch was backed out because it caused MCAs on HP sx1000 systems. That problem is resolved by the ioremap() attribute checking added for ia64. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] PCDP: if PCDP contains parity information, use itBjorn Helgaas
If the PCDP supplies parity, use it (only none/even/odd supported), and don't append parity/stop bit arguments unless baud is present. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[IA64-SGI] pcdp: add PCDP pci interface supportMark Maule
Resend 2 with changes per Bjorn Helgaas comments. Changes from original: + Change globals to vga_console_iobase/vga_console_membase and make them unconditional. + Address style-related comments. Patch to extend the PCDP vga setup code to support PCI io/mem translations for the legacy vga ioport and ram spaces on architectures (e.g. altix) which need them. Summary of the changes: drivers/firmware/pcdp.c drivers/firmware/pcdp.h ----------------------- + add declaration for the spec-defined PCI interface struct (pcdp_if_pci) as well as support macros. + extend setup_vga_console() to know about pcdp_if_pci and add a couple of globals to hold the io and mem translation offsets if present. arch/ia64/kernel/setup.c ------------------------ + tweek early_console_setup() to allow multiple early console setup routines to be called. include/asm-ia64/vga.h ---------------------- + make VGA_MAP_MEM vga_console_membase aware Signed-off-by: Mark Maule <maule@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-23[PATCH] PCDP: handle tables that don't supply baud rateBjorn Helgaas
The HCDP specs (i.e., PCDP revision < 3) allow zero as a default value for baud rate and data bits. So if firmware doesn't supply them, let early_serial_console_init() probe for them rather than telling it the baud rate is zero. Also, update the URL for the PCDP spec. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-31[PATCH] pcdp.c build fixPeter Chubb
In file included from drivers/firmware/pcdp.c:18: drivers/firmware/pcdp.h:48: error: field `addr' has incomplete type drivers/firmware/pcdp.c: In function `setup_serial_console': drivers/firmware/pcdp.c:27: error: `ACPI_ADR_SPACE_SYSTEM_MEMORY' undeclared (first use in this function) Cc: <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
