commit ff34f3cce278a0982a7b66b1afaed6295141b1fc upstream.
The 'a0' member of 'struct arm_smccc_res' is declared as 'unsigned long',
however the Qualcomm SCM firmware interface driver expects to receive
negative error codes via this field, so ensure that it's cast to 'long'
before comparing to see if it is less than 0.
Cc: <stable@vger.kernel.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Will Deacon <will@kernel.org>
[ Upstream commit 82bcd087029f6056506ea929f11af02622230901 ]
This patch adds a Qualcomm specific quirk to the arm_smccc_smc call.
On Qualcomm ARM64 platforms, the SMC call can return before it has
completed. If this occurs, the call can be restarted, but it requires
using the returned session ID value from the interrupted SMC call.
The quirk stores off the session ID from the interrupted call in the
quirk structure so that it can be used by the caller.
This patch folds in a fix given by Sricharan R:
https://lkml.org/lkml/2016/9/28/272
Signed-off-by: Andy Gross <andy.gross@linaro.org>
Reviewed-by: Will Deacon <will.deacon@arm.com>
PAS command 10 is used to assert and deassert the MSS reset via
TrustZone, expose this as a reset-controller to mimic the direct
access case.
Cc: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
This adds the Peripheral Authentication Service (PAS) interface to the
Qualcomm SCM interface. The API is used to authenticate and boot a range
of external processors in various Qualcomm platforms.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Add an implementation of the SCM interface that works on ARM64 SoCs. This
is used by things like determine if we have HDCP support or not on the
system.
Signed-off-by: Kumar Gala <galak@codeaurora.org>
This patch adds stubs for the SCM functions exposed in the QCOM SCM API.
Signed-off-by: Andy Gross <agross@codeaurora.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
