path: root/drivers/firmware
2011-12-21ibft: Fix finding IBFT ACPI table on UEFIYinghai Lu
commit 935a9fee51c945b8942be2d7b4bae069167b4886 upstream. Found one system with UEFI/iBFT, kernel does not detect the iBFT during iscsi_ibft module loading. Root cause: on x86 (UEFI), we are calling of find_ibft_region() much earlier - specifically in setup_arch() before ACPI is enabled. Try to split acpi checking code out and call that later At that time ACPI iBFT already get permanent mapped with ioremap. So isa_virt_to_bus() will get wrong phys from right virt address. We could just skip that phys address printing. For legacy one, print the found address early. -v2: update comments and description according to Konrad. -v3: fix problem about module use case that is found by Konrad. -v4: use acpi_get_table() instead of acpi_table_parse() to handle module use case that is found by Konrad again.. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09firmware: Sigma: Fix endianess issuesLars-Peter Clausen
commit bda63586bc5929e97288cdb371bb6456504867ed upstream. Currently the SigmaDSP firmware loader only works correctly on little-endian systems. Fix this by using the proper endianess conversion functions. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09firmware: Sigma: Skip header during CRC generationLars-Peter Clausen
commit c56935bdc0a8edf50237d3b0205133a5b0adc604 upstream. The firmware header is not part of the CRC, so skip it. Otherwise the firmware will be rejected due to non-matching CRCs. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09firmware: Sigma: Prevent out of bounds memory accessLars-Peter Clausen
commit 4f718a29fe4908c2cea782f751e9805319684e2b upstream. The SigmaDSP firmware loader currently does not perform enough boundary size checks when processing the firmware. As a result it is possible that a malformed firmware can cause an out of bounds memory access. This patch adds checks which ensure that both the action header and the payload are completely inside the firmware data boundaries before processing them. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-04drivers/firmware/sigma.c needs MODULE_LICENSERandy Dunlap
commit 27c46a2546c75c6814562e85b751e3d64c188ad5 upstream. Fix module tainting message: sigma: module license 'unspecified' taints kernel. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-28Merge branch 'driver-core-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: Connector: Correctly set the error code in case of success when dispatching receive callbacks Connector: Set the CN_NETLINK_USERS correctly pti: PTI semantics fix in pti_tty_cleanup. pti: ENXIO error case memory leak PTI fix. pti: double-free security PTI fix drivers:misc: ti-st: fix skipping of change remote baud drivers/base/platform.c: don't mark platform_device_register_resndata() as __init_or_module st_kim: Handle case of no device found for ID 0 firmware: fix GOOGLE_SMI kconfig dependency warning
2011-06-09iscsi_ibft: iscsi_ibft_find unused variable iConnor Hansen
int i is only needed if CONFIG_ACPI is set so move it within a new ifdef so kernels without ACPI don't allocate space for nothing. Fixes warning too. Signed-off-by: Connor Hansen <cmdkhh@gmail.com> Signed-off-by: Peter Jones <pjones@redhat.com> [v2: Fixed warning when CONFIG_ACPI was defined] Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
2011-06-07firmware: fix GOOGLE_SMI kconfig dependency warningRandy Dunlap
Is it meaningful/useful to enable EFI_VARS but not EFI? That's what GOOGLE_SMI does. Make it enable EFI also. Fixes this kconfig dependency warning: warning: (GOOGLE_SMI) selects EFI_VARS which has unmet direct dependencies (EFI) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (44 commits) debugfs: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warning sysfs: remove "last sysfs file:" line from the oops messages drivers/base/memory.c: fix warning due to "memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION" memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION SYSFS: Fix erroneous comments for sysfs_update_group(). driver core: remove the driver-model structures from the documentation driver core: Add the device driver-model structures to kerneldoc Translated Documentation/email-clients.txt RAW driver: Remove call to kobject_put(). reboot: disable usermodehelper to prevent fs access efivars: prevent oops on unload when efi is not enabled Allow setting of number of raw devices as a module parameter Introduce CONFIG_GOOGLE_FIRMWARE driver: Google Memory Console driver: Google EFI SMI x86: Better comments for get_bios_ebda() x86: get_bios_ebda_length() misc: fix ti-st build issues params.c: Use new strtobool function to process boolean inputs debugfs: move to new strtobool ... Fix up trivial conflicts in fs/debugfs/file.c due to the same patch being applied twice, and an unrelated cleanup nearby.
2011-05-19Merge branches 'x86-reboot-for-linus' and 'x86-setup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-reboot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Reorder reboot method preferences * 'x86-setup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, setup: Fix EDD3.0 data verification.
2011-05-19Merge branch 'stable/broadcom.ibft' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6 * 'stable/broadcom.ibft' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6: iscsi_ibft: search for broadcom specific ibft sign (v2)
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-06efivars: prevent oops on unload when efi is not enabledRandy Dunlap
efivars_exit() should check for efi_enabled and not undo allocations when efi is not enabled. Otherwise there is an Oops during module unload: calling efivars_init+0x0/0x1000 [efivars] @ 2810 EFI Variables Facility v0.08 2004-May-17 initcall efivars_init+0x0/0x1000 [efivars] returned 0 after 5120 usecs Oops: 0000 [#1] SMP DEBUG_PAGEALLOC last sysfs file: /sys/module/firmware_class/initstate CPU 1 Modules linked in: efivars(-) af_packet tun nfsd lockd nfs_acl auth_rpcgss sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables ip6t_REJECT xt_tcpudp nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables x_tables ipv6 cpufreq_ondemand acpi_cpufreq freq_table mperf binfmt_misc dm_mirror dm_region_hash dm_log dm_multipath scsi_dh dm_mod snd_hda_codec_analog snd_hda_intel snd_hda_codec snd_hwdep mousedev snd_seq joydev snd_seq_device mac_hid evdev snd_pcm usbkbd usbmouse usbhid snd_timer hid tg3 snd sr_mod pcspkr rtc_cmos soundcore cdrom iTCO_wdt processor sg dcdbas i2c_i801 rtc_core iTCO_vendor_support intel_agp snd_page_alloc thermal_sys rtc_lib intel_gtt 8250_pnp button hwmon unix ide_pci_generic ide_core ata_generic pata_acpi ata_piix sd_mod crc_t10dif ext3 jbd mbcache uhci_hcd ohci_hcd ssb mmc_core pcmcia pcmcia_core firmware_class ehci_hcd usbcore [last unloaded: dell_rbu] Pid: 2812, comm: rmmod Not tainted 2.6.39-rc6 #1 Dell Inc. OptiPlex 745 /0TY565 RIP: 0010:[<ffffffffa06a17f6>] [<ffffffffa06a17f6>] unregister_efivars+0x28/0x12c [efivars] RSP: 0018:ffff88005eedde98 EFLAGS: 00010283 RAX: ffffffffa06a23fc RBX: ffffffffa06a44c0 RCX: ffff88007c227a50 RDX: 0000000000000000 RSI: 00000055ac13db78 RDI: ffffffffa06a44c0 RBP: ffff88005eeddec8 R08: 0000000000000000 R09: ffff88005eeddd78 R10: ffffffffa06a4220 R11: ffff88005eeddd78 R12: fffffffffffff7d0 R13: 00007fff5a3aaec0 R14: 0000000000000000 R15: ffffffffa06a4508 FS: 00007fa8dcc4a6f0(0000) GS:ffff88007c200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000000 CR3: 000000005d148000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rmmod (pid: 2812, threadinfo ffff88005eedc000, task ffff88006754b000) Stack: ffff88005eeddec8 ffffffffa06a4220 0000000000000000 00007fff5a3aaec0 0000000000000000 0000000000000001 ffff88005eedded8 ffffffffa06a2418 ffff88005eeddf78 ffffffff810d3598 ffffffffa06a4220 0000000000000880 Call Trace: [<ffffffffa06a2418>] efivars_exit+0x1c/0xc04 [efivars] [<ffffffff810d3598>] sys_delete_module+0x2d6/0x368 [<ffffffff812d1db9>] ? lockdep_sys_exit_thunk+0x35/0x67 [<ffffffff810fcba1>] ? audit_syscall_entry+0x172/0x1a5 [<ffffffff81575082>] system_call_fastpath+0x16/0x1b Code: 5c c9 c3 55 48 89 e5 41 57 41 56 41 55 41 54 53 48 83 ec 08 0f 1f 44 00 00 4c 8b 67 48 48 89 fb 4c 8d 7f 48 49 81 ec 30 08 00 00 <4d> 8b ac 24 30 08 00 00 49 81 ed 30 08 00 00 eb 59 48 89 df 48 RIP [<ffffffffa06a17f6>] unregister_efivars+0x28/0x12c [efivars] RSP <ffff88005eedde98> CR2: 0000000000000000 ---[ end trace aa99b99090f70baa ]--- Matt apparently removed such a check in 2004 (with no reason given): * 17 May 2004 - Matt Domsch <Matt_Domsch@dell.com> * remove check for efi_enabled in exit but there have been several changes since then. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mike Waychison <mikew@google.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: <matthew.e.tolentino@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-29Introduce CONFIG_GOOGLE_FIRMWAREMike Waychison
In order to keep Google's firmware drivers organized amongst themselves, all Google firmware drivers are gated on CONFIG_GOOGLE_FIRMWARE=y, which defaults to 'n' in the kernel build. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-29driver: Google Memory ConsoleMike Waychison
This patch introduces the 'memconsole' driver. Our firmware gives us access to an in-memory log of the firmware's output. This gives us visibility in a data-center of headless machines as to what the firmware is doing. The memory console is found by the driver by finding a header block in the EBDA. The buffer is then copied out, and is exported to userland in the file /sys/firmware/log. Signed-off-by: San Mehat <san@google.com> Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-29driver: Google EFI SMIMike Waychison
The "gsmi" driver bridges userland with firmware specific routines for accessing hardware. Currently, this driver only supports NVRAM and eventlog information. Deprecated functions have been removed from the driver, though their op-codes are left in place so that they are not re-used. This driver works by trampolining into the firmware via the smi_command outlined in the FADT table. Three protocols are used due to various limitations over time, but all are included herein. This driver should only ever load on Google boards, identified by either a "Google, Inc." board vendor string in DMI, or "GOOGLE" in the OEM strings of the FADT ACPI table. This logic happens in gsmi_system_valid(). Signed-off-by: Duncan Laurie <dlaurie@google.com> Signed-off-by: Aaron Durbin <adurbin@google.com> Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-27x86, setup: Fix EDD3.0 data verification.Gleb Natapov
Check for nonzero path in edd_has_edd30() has no sense. First, it looks at the wrong memory. Device path starts at offset 30 of the info->params structure which is at offset 8 from the beginning of info structure, but code looks at info + 4 instead. This was correct when code was introduced, but around v2.6.4 three more fields were added to edd_info structure (commit 66b61a5c in history.git). Second, even if it will check correct memory it will always succeed since at offset 30 (params->key) there will be non-zero values otherwise previous check would fail. The patch replaces this bogus check with one that verifies checksum. Signed-off-by: Gleb Natapov <gleb@redhat.com> Link: http://lkml.kernel.org/r/20110426082132.GG2265@redhat.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-04-26treewide: cleanup continuations and remove logging message whitespaceJoe Perches
Using C line continuation inside format strings is error prone. Clean up the unintended whitespace introduced by misuse of \. Neaten correctly used line continations as well for consistency. drivers/scsi/arcmsr/arcmsr_hba.c has these errors as well, but arcmsr needs a lot more work and the driver should likely be moved to staging instead. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-19efivars: handle errors from register_efivars()Dan Carpenter
We should unwind and return an error if register_efivars() fails. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19efivars: memory leak on error in create_efivars_bin_attributes()Dan Carpenter
This is a cut and paste bug. We intended to free ->del_var and ->new_var but we only free ->new_var. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14iscsi_ibft: search for broadcom specific ibft sign (v2)Mike Christie
Broadcom iscsi offload firmware uses a non standard ibft sign of "BIFT". When we added support for boot, the anaconda team and I were using older firmware (I guess 4 years old), so boot does not work on current cards. This patch modifies the ibft search code to search for "BIFT" along with the other possible values. Broadcom has tested the patch and reported it works with their firmware. Mike has tested Chelsio and Intel cards. [v2: - Add ACPI_SIG_IBFT to ibft_signs - replace break with goto in find_ibft_in_mem innner loop.] Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Peter Jones <pjones@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
2011-03-22sigma-firmware: loader for Analog Devices' SigmaStudioMike Frysinger
Analog Devices' SigmaStudio can produce firmware blobs for devices with these DSPs embedded (like some audio codecs). Allow these device drivers to easily parse and load them. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-16Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (50 commits) printk: do not mangle valid userspace syslog prefixes efivars: Add Documentation efivars: Expose efivars functionality to external drivers. efivars: Parameterize operations. efivars: Split out variable registration efivars: parameterize efivars efivars: Make efivars bin_attributes dynamic efivars: move efivars globals into struct efivars drivers:misc: ti-st: fix debugging code kref: Fix typo in kref documentation UIO: add PRUSS UIO driver support Fix spelling mistakes in Documentation/zh_CN/SubmittingPatches firmware: Fix unaligned memory accesses in dmi-sysfs firmware: Add documentation for /sys/firmware/dmi firmware: Expose DMI type 15 System Event Log firmware: Break out system_event_log in dmi-sysfs firmware: Basic dmi-sysfs support firmware: Add DMI entry types to the headers Driver core: convert platform_{get,set}_drvdata to static inline functions Translate linux-2.6/Documentation/magic-number.txt into Chinese ...
2011-03-14efivars: Expose efivars functionality to external drivers.Mike Waychison
Signed-off-by: Mike Waychison <mikew@google.com> Cc: Matt Domsch <Matt_Domsch@dell.com>, Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-14efivars: Parameterize operations.Mike Waychison
Instead of letting efivars access struct efi directly when dealing with variables, use an operations structure. This allows a later change to reuse the efivars logic without having to pretend to support everything in struct efi. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Matt Domsch <Matt_Domsch@dell.com>, Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-14efivars: Split out variable registrationMike Waychison
In anticipation of re-using the variable facilities in efivars from elsewhere, split out the registration and unregistration of struct efivars from the rest of the EFI specific sysfs code. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Matt Domsch <Matt_Domsch@dell.com>, Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-14efivars: parameterize efivarsMike Waychison
Now that we all global variable state is encapsulated by struct efivars, parameterize all functions to the efivars local to the control flow rather than at file scope. We do this by removing the variable "efivars" at file scope and move its storage down to the end of the file. Variables get at efivars by storing the efivars pointer within each efivar_entry. The "new_var" and "del_var" binary attribute files get at the efivars through the private pointer. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Matt Domsch <Matt_Domsch@dell.com>, Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-14efivars: Make efivars bin_attributes dynamicMike Waychison
In preparation for encapsulating efivars, we need to have the bin_attributes be dynamically allocated so that we can use their ->private fields to get back to the struct efivars structure. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Matt Domsch <Matt_Domsch@dell.com>, Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-14efivars: move efivars globals into struct efivarsMike Waychison
In preparation for abstracting out efivars to be usable by other similar variable services, move the global lock, list and kset into a structure. Later patches will change the scope of 'efivars' and have it be passed by function argument. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Matt Domsch <Matt_Domsch@dell.com>, Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02dcdbas: force SMI to happen when expectedStuart Hayes
The dcdbas driver can do an I/O write to cause a SMI to occur. The SMI handler looks at certain registers and memory locations, so the SMI needs to happen immediately. On some systems I/O writes are posted, though, causing the SMI to happen well after the "outb" occurred, which causes random failures. Following the "outb" with an "inb" forces the write to go through even if it is posted. Signed-off-by: Stuart Hayes <stuart_hayes@yahoo.com> Acked-by: Doug Warzecha <douglas_warzecha@dell.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-25firmware: Fix unaligned memory accesses in dmi-sysfsMike Waychison
DMI entries are arranged in memory back to back with no alignment guarantees. This means that the struct dmi_header passed to callbacks from dmi_walk() itself isn't byte aligned. This causes problems on architectures that expect aligned data, such as IA64. The dmi-sysfs patchset introduced structure member accesses through this passed in dmi_header. Fix this by memcpy()ing the structures to temporary locations on stack when inspecting/copying them. Signed-off-by: Mike Waychison <mikew@google.com> Tested-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-25firmware: Expose DMI type 15 System Event LogMike Waychison
The System Event Log described by DMI entry type 15 may be backed by either memory or may be indirectly accessed via an IO index/data register pair. In order to get read access to this log, expose it in the "system_event_log" sub-directory of type 15 DMI entries, ie: /sys/firmware/dmi/entries/15-0/system_event_log/raw_event_log. This commit handles both IO accessed and memory access system event logs. OEM specific access and GPNV support is explicitly not handled and we error out in the logs when we do not recognize the access method. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-25firmware: Break out system_event_log in dmi-sysfsMike Waychison
The optional type 15 entry of the DMI table describes a non-volatile storage-backed system event log. In preparation for the next commit which exposes the raw bits of the event log to userland, create a new sub-directory within the dmi entry called "system_event_log" and expose attribute files that describe the event log itself. Currently, only a single child object is permitted within a dmi_sysfs_entry. We simply point at this child from the dmi_sysfs_entry if it exists. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-25firmware: Basic dmi-sysfs supportMike Waychison
Introduce a new module "dmi-sysfs" that exports the broken out entries of the DMI table through sysfs. Entries are enumerated via dmi_walk() on module load, and are populated as kobjects rooted at /sys/firmware/dmi/entries. Entries are named "<type>-<instance>", where: <type> : is the type of the entry, and <instance> : is the ordinal count within the DMI table of that entry type. This instance is used in lieu the DMI entry's handle as no assurances are made by the kernel that handles are unique. All entries export the following attributes: length : The length of the formatted portion of the entry handle : The handle given to this entry by the firmware raw : The raw bytes of the entire entry, including the formatted portion, the unformatted (strings) portion, and the two terminating nul characters. type : The DMI entry type instance : The ordinal instance of this entry given its type. position : The position ordinal of the entry within the table in its entirety. Entries in dmi-sysfs are kobject backed members called "struct dmi_sysfs_entry" and belong to dmi_kset. They are threaded through entry_list (protected by entry_list_lock) so that we can find them at cleanup time. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-15x86, dmi, debug: Log board name (when present) in dmesg/oops outputNaga Chumbalkar
The "Type 2" SMBIOS record that contains Board Name is not strictly required and may be absent in the SMBIOS on some platforms. ( Please note that Type 2 is not listed in Table 3 in Sec 6.2 ("Required Structures and Data") of the SMBIOS v2.7 Specification. ) Use the Manufacturer Name (aka System Vendor) name. Print Board Name only when it is present. Before the fix: (i) dmesg output: DMI: /ProLiant DL380 G6, BIOS P62 01/29/2011 (ii) oops output: Pid: 2170, comm: bash Not tainted 2.6.38-rc4+ #3 /ProLiant DL380 G6 After the fix: (i) dmesg output: DMI: HP ProLiant DL380 G6, BIOS P62 01/29/2011 (ii) oops output: Pid: 2278, comm: bash Not tainted 2.6.38-rc4+ #4 HP ProLiant DL380 G6 Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: <stable@kernel.org> # .3x - good for debugging, please apply as far back as it applies cleanly LKML-Reference: <20110214224423.2182.13929.sendpatchset@nchumbalkar.americas.hpqcorp.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27dmi: log board, system, and BIOS informationBjorn Helgaas
Put basic system information in the dmesg log. There are lots of dmesg logs on the web, and it would be useful if they contained this information for debugging platform problems. "BOARD/PRODUCT" format copied from show_regs_common(), which is used in the oops path. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-14ibft: fix kconfig dependenciesRandy Dunlap
Fix kconfig dependency warning to satisfy dependencies: warning: (BE2ISCSI && SCSI_LOWLEVEL && PCI && SCSI && NET || ISCSI_IBFT && ISCSI_IBFT_FIND && SCSI) selects ISCSI_BOOT_SYSFS which has unmet direct dependencies (SCSI_LOWLEVEL && SCSI) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Peter Jones <pjones@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
2010-08-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (28 commits) [SCSI] qla4xxx: fix compilation warning [SCSI] make error handling more robust in the face of reservations [SCSI] tgt: fix warning [SCSI] drivers/message/fusion: Adjust confusing if indentation [SCSI] Return NEEDS_RETRY for eh commands with status BUSY [SCSI] ibmvfc: Driver version 1.0.9 [SCSI] ibmvfc: Fix terminate_rport_io [SCSI] ibmvfc: Fix rport add/delete race resulting in oops [SCSI] lpfc 8.3.16: Change LPFC driver version to 8.3.16 [SCSI] lpfc 8.3.16: FCoE Discovery and Failover Fixes [SCSI] lpfc 8.3.16: SLI Additions, updates, and code cleanup [SCSI] pm8001: introduce missing kfree [SCSI] qla4xxx: Update driver version to 5.02.00-k3 [SCSI] qla4xxx: Added AER support for ISP82xx [SCSI] qla4xxx: Handle outstanding mbx cmds on hung f/w scenarios [SCSI] qla4xxx: updated mbx_sys_info struct to sync with FW 4.6.x [SCSI] qla4xxx: clear AF_DPC_SCHEDULED flage when exit from do_dpc [SCSI] qla4xxx: Stop firmware before doing init firmware. [SCSI] qla4xxx: Use the correct request queue. [SCSI] qla4xxx: set correct value in sess->recovery_tmo ...
2010-08-13Merge branch 'stable/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6 * 'stable/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6: firmware: ibft depends on SCSI ibft: Kernel oops when rmmoding iscsi_ibft with no iBFT present.
2010-08-11firmware: ibft depends on SCSIRandy Dunlap
Prevent build errors when SCSI is not enabled: iscsi_ibft.c:(.init.text+0x548d): undefined reference to `iscsi_boot_create_initiator' iscsi_ibft.c:(.init.text+0x54a9): undefined reference to `iscsi_boot_create_ethernet' iscsi_ibft.c:(.init.text+0x54c5): undefined reference to `iscsi_boot_create_target' iscsi_ibft.c:(.init.text+0x55ff): undefined reference to `iscsi_boot_destroy_kset' iscsi_ibft.c:(.init.text+0x561e): undefined reference to `iscsi_boot_create_kset' iscsi_ibft.c:(.exit.text+0xe2c): undefined reference to `iscsi_boot_destroy_kset' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Peter Jones <pjones@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
2010-08-11ibft: Kernel oops when rmmoding iscsi_ibft with no iBFT present.Konrad Rzeszutek Wilk
We failed to check to see if actually allocated structures to contain the iBFT structure and went ahead to dereference it. This patch fixes the OOPS. Reported-by: "Jayamohan Kalickal" <jayamohank@serverengines.com>   Tested-by: "Jayamohan Kalickal" <jayamohank@serverengines.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org> Signed-off-by: Peter Jones <pjones@redhat.com>
2010-08-09edd: fix possible memory leak in edd_init() error pathAxel Lin
The error may happen at any iteration of the for loop, this patch properly unregisters already registed edd_devices in error path. [akpm@linux-foundation.org: remove unneeded NULL test] Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-06Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (30 commits) PCI: update for owner removal from struct device_attribute PCI: Fix warnings when CONFIG_DMI unset PCI: Do not run NVidia quirks related to MSI with MSI disabled x86/PCI: use for_each_pci_dev() PCI: use for_each_pci_dev() PCI: MSI: Restore read_msi_msg_desc(); add get_cached_msi_msg_desc() PCI: export SMBIOS provided firmware instance and label to sysfs PCI: Allow read/write access to sysfs I/O port resources x86/PCI: use host bridge _CRS info on ASRock ALiveSATA2-GLAN PCI: remove unused HAVE_ARCH_PCI_SET_DMA_MAX_SEGMENT_{SIZE|BOUNDARY} PCI: disable mmio during bar sizing PCI: MSI: Remove unsafe and unnecessary hardware access PCI: Default PCIe ASPM control to on and require !EMBEDDED to disable PCI: kernel oops on access to pci proc file while hot-removal PCI: pci-sysfs: remove casts from void* ACPI: Disable ASPM if the platform won't provide _OSC control for PCIe PCI hotplug: make sure child bridges are enabled at hotplug time PCI hotplug: shpchp: Removed check for hotplug of display devices PCI hotplug: pciehp: Fixed return value sign for pciehp_unconfigure_device PCI: Don't enable aspm before drivers have had a chance to veto it ...
2010-08-06[SCSI] iscsi boot: mv iscsi_boot_sysfs to drivers/scsiMike Christie
iscsi_boot_sysfs does not depend on firmware. Any iscsi driver can use it. This patch moves iscsi_boot_sysfs to the scsi dir, so that it can be used on any arch with any driver. Signed-off-by: Mike Christie <mchristi@redhat.com> Acked-by: Konrad Rzeszutek Wilk <konrad@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-05dcdbas: remove a redundant smi_data_buf_free in dcdbas_exitAxel Lin
smi_data_buf_free is called twice in current implementation. The second call simply return because smi_data_buf is set to NULL in first call. This patch removes the second smi_data_buf_free call. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
