path: root/drivers/fmc
2013-10-14treewide: Fix typo in KconfigMasanari Iida
Correct spelling typo in Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-08-12FMC: Staticize local symbolsJingoo Han
This local symbol is used only in this file. Fix the following sparse warnings: drivers/fmc/fmc-write-eeprom.c:106:5: warning: symbol 'fwe_probe' was not declared. Should it be static? drivers/fmc/fmc-write-eeprom.c:147:5: warning: symbol 'fwe_remove' was not declared. Should it be static? Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-24FMC: fix locking in sample chardev driverAlessandro Rubini
The fmc-chardev module was over-locking, by calling misc register/unregister while holding its spinlock. This reported a "scheduling while atomic" error. Since the misc driver already serializes operations internally, this commit downgrades the fmc-chardev lock to just cover its own list. Reported-by: Sasha Levin <sasha.levin@oracle.com> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-24FMC: fix error handling in probe() functionDan Carpenter
The call to kzalloc() wasn't checked. The dev_info() message dereferenced freed memory on error. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-19fmc: avoid readl/writel namespace conflictArnd Bergmann
The use of the 'readl' and 'writel' identifiers here causes build errors on architectures where those are macros. This renames the fields to read32/write32 to avoid the problem. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-19FMC: NULL dereference on allocation failureDan Carpenter
If we don't allocate "arr" then the cleanup path will dereference it and oops. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-18FMC: add a char-device mezzanine driverAlessandro Rubini
This driver exports the memory area associated with the mezzanine card as a misc device, so users can access registers. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Juan David Gonzalez Cobas <dcobas@cern.ch> Acked-by: Emilio G. Cota <cota@braap.org> Acked-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-18FMC: add a driver to write mezzanine EEPROMAlessandro Rubini
This driver allows to reprogram the EEPROM in a mezzanine, to store its own identifiers during manufacturing or to save other useful data. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Juan David Gonzalez Cobas <dcobas@cern.ch> Acked-by: Emilio G. Cota <cota@braap.org> Acked-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-18FMC: add a software mezzanine driverAlessandro Rubini
This simple do-nothing mezzanine driver shows how to write a mezzanine driver, that can also handle interrupts reported by the carrier. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Juan David Gonzalez Cobas <dcobas@cern.ch> Acked-by: Emilio G. Cota <cota@braap.org> Acked-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-18FMC: add a software carrier driverAlessandro Rubini
This fake carrier is designed to help FMC users understand how a carrier driver works, and to experiment the behaviour with EEPROM reprogramming (with a mezzanine driver commited later). This carrier can register up to 4 (fake) mezzanines. We have real carriers (both on PCI-E and VME), but they are bigger things and are not part of this submission. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Juan David Gonzalez Cobas <dcobas@cern.ch> Acked-by: Emilio G. Cota <cota@braap.org> Acked-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-18FMC: add core bus driverAlessandro Rubini
This module offers registration services for both carriers (i.e. devices) and mezzanines (i.e. drivers). The matching for devices and drivers is performed according to the IPMI standard for FRU devices (Field Replaceable Units). The code includes support for parsing an SDB tree if present in the FPGA, and dumping it for diagnostics. SDB is not mandatory. Files in this commit correspond to commit ab23167f in the master branch of the project hosted on ohwr.org. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Juan David Gonzalez Cobas <dcobas@cern.ch> Acked-by: Emilio G. Cota <cota@braap.org> Acked-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17FMC: create drivers/fmc and toplevel Kconfig questionAlessandro Rubini
This commit creates the drivers/fmc directory and puts the necessary hooks for kbuild and kconfig. The code is currently a placeholder that only registers an empty bus. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Juan David Gonzalez Cobas <dcobas@cern.ch> Acked-by: Emilio G. Cota <cota@braap.org> Acked-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
