path: root/drivers/gpio/Kconfig
2013-11-12Merge tag 'gpio-v3.13-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO changes from Linus Walleij: "Here is the bulk of GPIO changes for the v3.13 development cycle. I've got ACKs for the things that affect other subsystems (or it's my own subsystem, like pinctrl). Most of that pertain to an attempt from my side to consolidate and get rid of custom GPIO implementations in the ARM tree. I will continue doing this. The main change this time is the new GPIO descriptor API, background for this can be found in Corbet's summary from this january in LWN: http://lwn.net/Articles/533632/ Summary: - Merged the GPIO descriptor API from Alexandre Courbot. This is a first step toward trying to get rid of the global GPIO numberspace for the future. - Add an API so that driver can flag that a certain GPIO line is being used by a irqchip backend for generating IRQs, so that we can enforce checks, like not allowing users to switch that line to an output at runtime, since this makes no sense. Implemented corresponding calls in a few select drivers. - ACPI GPIO cleanups, refactorings and switch to using the descriptor-based interface. - Support for the TPS80036 Palmas GPIO variant. - A new driver for the Broadcom Kona GPIO SoC IP block. - Device tree support for the PCF857x driver. - A set of ARM GPIO refactorings with the goal of getting rid of a bunch of custom GPIO implementations from the arch/arm/* tree: * Move the IOP GPIO driver to the GPIO subsystem and fix all users to use the gpiolib API for accessing GPIOs. Delete the old custom GPIO implementation. * Delete the unused custom PXA GPIO implemention. * Convert all users of the IXP4 custom GPIO implementation to use gpiolib and delete the custom implementation. * Delete the custom Gemini GPIO implementation, also completely unused. - Various cleanups and renamings" * tag 'gpio-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (85 commits) gpio: gpio-mxs: Remove unneeded dt checks gpio: pl061: don't depend on CONFIG_ARM gpio: bcm-kona: add missing .owner to struct gpio_chip gpiolib: provide a declaration of seq_file in gpio/driver.h gpiolib: include gpio/consumer.h in of_gpio.h for desc_to_gpio() gpio: provide stubs for devres gpio functions gpiolib: devres: add missing headers gpiolib: make GPIO_DEVRES depend on GPIOLIB gpiolib: devres: fix devm_gpiod_get_index() gpiolib / ACPI: document the GPIO descriptor based interface gpiolib / ACPI: allow passing GPIOF_ACTIVE_LOW for GpioInt resources gpiolib / ACPI: add ACPI support for gpiod_get_index() gpiolib / ACPI: convert to gpiod interfaces gpiolib: add gpiod_get() and gpiod_put() functions gpiolib: port of_ functions to use gpiod gpiolib: export descriptor-based GPIO interface Fixup "MAINTAINERS: GPIO-INTEL-MID: add maintainer" gpio: bcm281xx: Don't print addresses of GPIO area in probe() gpio: tegra: use new gpio_lock_as_irq() API gpio: rcar: Include linux/of.h header ...
2013-11-06gpio: pl061: don't depend on CONFIG_ARMRob Herring
The pl061 driver has no real dependency on ARM, so remove the kconfig dependency. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: linux-gpio@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-29gpiolib: make GPIO_DEVRES depend on GPIOLIBAlexandre Courbot
Current Kconfig allows GPIO_DEVRES to be selected and compiled without GPIOLIB. This does not make sense anymore since GPIOLIB has become the exclusive way to deal with GPIOs. This patch makes GPIO_DEVRES available only if GPIOLIB is selected. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-25gpio: add TB10x GPIO driverChristian Ruppert
The GPIO driver for the Abilis Systems TB10x series of SOCs based on ARC700 CPUs. It supports GPIO control and GPIO interrupt generation. This driver works in conjunction with the TB10x pinctrl driver. Signed-off-by: Sascha Leuenberger <sascha.leuenberger@abilis.com> Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com> Acked-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-11gpio: rename gpio-langwell to gpio-intel-midDavid Cohen
gpio-langwell is a deprecated name. Despite the driver was made initially for Langwell, it supports now other Intel Mid SoC's. This patch does no change beside the file renaming with Kconfig/Makefile update. Signed-off-by: David Cohen <david.a.cohen@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-23Merge branch 'iop-cleanup' into develLinus Walleij
2013-09-20ARM: plat-iop: move the GPIO driver to drivers/gpioLinus Walleij
Move the IOP GPIO driver to live with its siblings in the GPIO subsystem. Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-20gpio: ucb1400: Can be built as a moduleJean Delvare
With the recent code cleanup from Marek Vasut, driver gpio-ucb1400 can be built as a module, so change symbol GPIO_UCB1400 from bool to tristate. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-20gpio: bcm281xx: Add GPIO driverMarkus Mayer
Add the GPIO driver for the Broadcom bcm281xx family of mobile SoCs. These GPIO controllers may contain up to 8 banks where each bank includes 32 pins that can be driven high or low and act as an edge sensitive interrupt. Signed-off-by: Markus Mayer <markus.mayer@linaro.org> Reviewed-by: Christian Daudt <csd@broadcom.com> Reviewed-by: Tim Kryger <tim.kryger@linaro.org> Reviewed-by: Matt Porter <matt.porter@linaro.org> Reviewed-by: Stephen Warren <swarren@nvidia.com> [Added depends on OF_GPIO] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-19emev2: GPIOLIB: Enable support for OFIan Molton
EMEV2 is now a DT platform, however the GPIO driver cannot be used from a DT file since it does not fill out the of_node field in its gpio_chip structure. Signed-off-by: Ian Molton <ian.molton@codethink.co.uk> Reviewed-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-12Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This has been sitting in -next for a while with no objections and all MIPS defconfigs except one are building fine; that one platform got broken by another patch in your tree and I'm going to submit a patch separately. - a handful of fixes that didn't make 3.11 - a few bits of Octeon 3 support with more to come for a later release - platform enhancements for Octeon, ath79, Lantiq, Netlogic and Ralink SOCs - a GPIO driver for the Octeon - some dusting off of the DECstation code - the usual dose of cleanups" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (65 commits) MIPS: DMA: Fix BUG due to smp_processor_id() in preemptible code MIPS: kexec: Fix random crashes while loading crashkernel MIPS: kdump: Skip walking indirection page for crashkernels MIPS: DECstation HRT calibration bug fixes MIPS: Export copy_from_user_page() (needed by lustre) MIPS: Add driver for the built-in PCI controller of the RT3883 SoC MIPS: DMA: For BMIPS5000 cores flush region just like non-coherent R10000 MIPS: ralink: Add support for reset-controller API MIPS: ralink: mt7620: Add cpu-feature-override header MIPS: ralink: mt7620: Add spi clock definition MIPS: ralink: mt7620: Add wdt clock definition MIPS: ralink: mt7620: Improve clock frequency detection MIPS: ralink: mt7620: This SoC has EHCI and OHCI hosts MIPS: ralink: mt7620: Add verbose ram info MIPS: ralink: Probe clocksources from OF MIPS: ralink: Add support for systick timer found on newer ralink SoC MIPS: ralink: Add support for periodic timer irq MIPS: Netlogic: Built-in DTB for XLP2xx SoC boards MIPS: Netlogic: Add support for USB on XLP2xx MIPS: Netlogic: XLP2xx update for I2C controller ...
2013-08-30gpio: add GPIO support for F71882FG and F71889FSimon Guinot
This patch adds support for the GPIOs found on the Fintek super-I/O chips F71882FG and F71889F. A super-I/O is a legacy I/O controller embedded on x86 motherboards. It is used to connect the low-bandwidth devices. Among others functions the F71882FG/F71889F provides: a parallel port, two serial ports, a keyboard controller, an hardware monitoring controller and some GPIO pins. Note that this super-I/Os are embedded on some Atom-based LaCie NASes. The GPIOs are used to control the LEDs and the hard drive power. Changes since v3: - Use request_muxed_region to protect the I/O ports against concurrent accesses. Changes since v2: - Remove useless NULL setters for driver data. Changes since v1: - Enhance the commit message by describing what is a Super-I/O. - Use self-explanatory names for the GPIO register macros. - Add a comment to explain the platform device and driver registration. - Fix gpio_get when GPIO is configured in input mode. I only had the hardware to check this mode recently... Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-26gpio MIPS/OCTEON: Add a driver for OCTEON's on-chip GPIO pins.David Daney
The SOCs in the OCTEON family have 16 (or in some cases 20) on-chip GPIO pins, this driver handles them all. Configuring the pins as interrupt sources is handled elsewhere (OCTEON's irq handling code). Signed-off-by: David Daney <david.daney@cavium.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Cc: linux-gpio@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/5633/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-07-21gpio: Kontron PLD gpio driverGuenter Roeck
Add gpio support for the on-board PLD found on some Kontron embedded modules. Originally-from: Michael Brunner <michael.brunner@kontron.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Kevin Strasser <kevin.strasser@linux.intel.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-20gpio-tz1090: convert to use generic irqchipJames Hogan
Convert gpio-tz1090 driver to use generic irqchips. This allows the irq_ack, irq_mask, and irq_unmask callbacks and associated helper functions to be removed. Also switch to using irq_setup_alt_chip() in the irq_set_type callback instead of using __irq_set_handler_locked(). Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Grant Likely <grant.likely@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-20gpio-tz1090-pdc: add TZ1090 PDC gpio driverJames Hogan
Add a GPIO driver for the low-power Powerdown Controller GPIOs in the TZ1090 SoC. The driver is instantiated by device tree and supports interrupts for the SysWake GPIOs only. Changes in v4: - fix typos in DT bindings compatible properties - reference Documentation/devicetree/bindings/gpio/gpio.txt in gpio-ranges description in DT bindings - fix gpio-ranges examples in DT bindings (it must now have 3 cells) Changes in v3: - separated from irq-imgpdc and removed arch/metag changes to allow these patches to go upstream separately via the pinctrl[/gpio] trees (particularly the pinctrl drivers depend on the new pinconf DT bindings). - some s/unsigned/unsigned int/. - gpio-tz1090*: refer to <dt-bindings/gpio/gpio.h> and <dt-bindings/interrupt-controller/irq.h> flags in bindings. - gpio-tz1090*: move initcall from postcore to subsys. Changes in v2: - gpio-tz1090-pdc: remove references to Linux flags in dt bindings - gpio-tz1090-pdc: make use of BIT() from linux/bitops.h - gpio-tz1090-pdc: make register accessors inline to match pinctrl - gpio-tz1090-pdc: update gpio-ranges to use 3 cells after recent ABI breakage Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Rob Landley <rob@landley.net> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: linux-doc@vger.kernel.org Cc: devicetree-discuss@lists.ozlabs.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-20gpio-tz1090: add TZ1090 gpio driverJames Hogan
Add a GPIO driver for the main GPIOs found in the TZ1090 (Comet) SoC. This doesn't include low-power GPIOs as they're controlled separately via the Powerdown Controller (PDC) registers. The driver is instantiated by device tree and supports interrupts for all GPIOs. Changes in v4: - fix typos in DT bindings compatible properties - reference Documentation/devicetree/bindings/gpio/gpio.txt in gpio-ranges description in DT bindings - fix gpio-ranges examples in DT bindings (it must now have 3 cells) - gpio-tz1090: use of_property_read_u32 instead of of_get_property Changes in v3: - separated from irq-imgpdc and removed arch/metag changes to allow these patches to go upstream separately via the pinctrl[/gpio] trees (particularly the pinctrl drivers depend on the new pinconf DT bindings). - some s/unsigned/unsigned int/. - some s/unsigned int/bool/ and use of BIT(). - gpio-tz1090*: refer to <dt-bindings/gpio/gpio.h> and <dt-bindings/interrupt-controller/irq.h> flags in bindings. - gpio-tz1090*: move initcall from postcore to subsys. - gpio-tz1090: add REG_ prefix to some constants for consistency. - gpio-tz1090: add comment to explain tz1090_gpio_irq_next_edge cunningness. Changes in v2: - gpio-tz1090: remove references to Linux flags in dt bindings - gpio-tz1090: make use of BIT() from linux/bitops.h - gpio-tz1090: make register accessors inline to match pinctrl - gpio-tz1090: update gpio-ranges to use 3 cells after recent ABI breakage Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Rob Landley <rob@landley.net> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: linux-doc@vger.kernel.org Cc: devicetree-discuss@lists.ozlabs.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-03Merge tag 'gpio-for-v3.11-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "Here is a batch of GPIO changes for v3.11. I have agreed with Grant to take care of the pull requests for this development cycle. No special things are happening in the GPIO tree this time (nice with some calm) and I have been extra careful to do regression builds and it's well boiled in -next. GPIO changes for the v3.11 development cycle: - Incremental development for the Langwell (Atom SoC), Xilinx, ICH and RCAR drivers. - Cleanups from Jingoo Han, Axel Lin, Wei Jongjun, Wolfram Sang, Tushar Behera, Sachin Kamat and Yijing Wang" * tag 'gpio-for-v3.11-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (35 commits) Gpio/trivial: replace numeric with standard PM state macros gpiolib: remove warnning of allocations with IRQs disabled gpio: grgpio: Staticize local symbols gpio-langwell: remove Withney point support gpio: ich: add GPO_BLINK support gpio-sta2x11: Convert to use devm_ioremap_resource gpio_msm: Convert to use devm_ioremap_resource gpio-rcar: Use OUTDT when reading GPIOs configured as output gpio-sta2x11: Fix potential NULL pointer dereference gpio/omap: omap_gpio_init_context stub must be inline gpio: msm-v1: Remove errant __devinit to fix compile gpio: devres: make comments proper GPIO: xilinx: Enable driver for Xilinx zynq DT: Add documentation for gpio-xilinx GPIO: xilinx: Use BIT macro GPIO: xilinx: Use __raw_readl/__raw_writel IO functions GPIO: xilinx: Add support for dual channel GPIO: xilinx: Simplify driver probe function gpio: sx150x: convert to use devm_* functions MAINTAINERS: add linux-gpio mailing list ...
2013-07-02Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC specific changes from Arnd Bergmann: "These changes are all to SoC-specific code, a total of 33 branches on 17 platforms were pulled into this. Like last time, Renesas sh-mobile is now the platform with the most changes, followed by OMAP and EXYNOS. Two new platforms, TI Keystone and Rockchips RK3xxx are added in this branch, both containing almost no platform specific code at all, since they are using generic subsystem interfaces for clocks, pinctrl, interrupts etc. The device drivers are getting merged through the respective subsystem maintainer trees. One more SoC (u300) is now multiplatform capable and several others (shmobile, exynos, msm, integrator, kirkwood, clps711x) are moving towards that goal with this series but need more work. Also noteworthy is the work on PCI here, which is traditionally part of the SoC specific code. With the changes done by Thomas Petazzoni, we can now more easily have PCI host controller drivers as loadable modules and keep them separate from the platform code in drivers/pci/host. This has already led to the discovery that three platforms (exynos, spear and imx) are actually using an identical PCIe host controller and will be able to share a driver once support for spear and imx is added." * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (480 commits) ARM: integrator: let pciv3 use mem/premem from device tree ARM: integrator: set local side PCI addresses right ARM: dts: Add pcie controller node for exynos5440-ssdk5440 ARM: dts: Add pcie controller node for Samsung EXYNOS5440 SoC ARM: EXYNOS: Enable PCIe support for Exynos5440 pci: Add PCIe driver for Samsung Exynos ARM: OMAP5: voltagedomain data: remove temporary OMAP4 voltage data ARM: keystone: Move CPU bringup code to dedicated asm file ARM: multiplatform: always pick one CPU type ARM: imx: select syscon for IMX6SL ARM: keystone: select ARM_ERRATA_798181 only for SMP ARM: imx: Synertronixx scb9328 needs to select SOC_IMX1 ARM: OMAP2+: AM43x: resolve SMP related build error dmaengine: edma: enable build for AM33XX ARM: edma: Add EDMA crossbar event mux support ARM: edma: Add DT and runtime PM support to the private EDMA API dmaengine: edma: Add TI EDMA device tree binding arm: add basic support for Rockchip RK3066a boards arm: add debug uarts for rockchip rk29xx and rk3xxx series arm: Add basic clocks for Rockchip rk3066a SoCs ...
2013-06-20Merge tag 'remove-nondt-exynos-3' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc From Kukjin Kim: cleanup and removing dead code for only support DT for exynos - remove board file for exynos - remove legacy files which are not used anymore - decouple ARCH_EXYNOS from PLAT_S5P * tag 'remove-nondt-exynos-3' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (35 commits) ARM: EXYNOS: Remove remaining dead code after non-DT support removal ARM: EXYNOS: Remove legacy L2X0 initialization ARM: EXYNOS: Use exynos_init_io() as map_io callback ARM: EXYNOS: Remove custom init_irq callbacks ARM: EXYNOS: Remove mach/regs-usb-phy.h header thermal: exynos: Support both EXYNOS4X12 SoCs ARM: EXYNOS: Remove unused base addresses from mach/map.h header ARM: EXYNOS: Remove mach/irqs.h header ARM: EXYNOS: Select SPARSE_IRQ for Exynos ARM: SAMSUNG: Make legacy MFC support code depend on SAMSUNG_ATAGS ARM: EXYNOS: Remove mach/regs-gpio.h header ARM: EXYNOS: Remove mach/gpio.h ARM: EXYNOS: Remove setup-i2c0.c ARM: EXYNOS: Do not select legacy Kconfig symbols any more ARM: SAMSUNG: Include most of mach/ headers conditionally ARM: EXYNOS: Decouple ARCH_EXYNOS from PLAT_S5P USB: Check for ARCH_EXYNOS separately platform: Check for ARCH_EXYNOS separately ARM: SAMSUNG: Compile legacy IRQ and GPIO PM code only with ATAGS support ARM: EXYNOS: Provide compatibility stubs for PM code in pm-core.h header ... Conflicts: arch/arm/mach-exynos/Kconfig Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-19ARM: SAMSUNG: Introduce GPIO_SAMSUNG Kconfig entryTomasz Figa
This patch adds Kconfig entry that selects whether legacy Samsung GPIO driver should be built or not. For platforms that support only DT based boot, the new pinctrl driver is used and so the old one is not needed. Cc: Grant Likely <grant.likely@linaro.org> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-06-17GPIO: xilinx: Enable driver for Xilinx zynqMichal Simek
Enable gpio driver for usage on Xilinx ARM zynq platform. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-14Merge tag 'msm-cleanup-for-3.11' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm into next/cleanup From David Brown: Cleanups for MSM for 3.11 These are a handful of cleanups to the MSM tree. The gpio cleanups get us closer to having proper pinmux and gpio support. * tag 'msm-cleanup-for-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm: mfd: ssbi: Use devm_* and simplify code gpio: msm: Add device tree and irqdomain support for gpio-msm-v2 ARM: msm: Remove gpiomux-v2 and re-organize MSM_GPIOMUX configs msm: iomap: Remove unused bases and mappings msm: Remove unused file core.h ARM: msm: Remove init_irq declaration in machine description Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/boot/dts/msm8660-surf.dts arch/arm/boot/dts/msm8960-cdp.dts
2013-06-12gpio: msm: Add device tree and irqdomain support for gpio-msm-v2Rohit Vaswani
This cleans up the gpio-msm-v2 driver of all the global define usage. The number of gpios are now defined in the device tree. This enables adding irqdomain support as well. Signed-off-by: Rohit Vaswani <rvaswani@codeaurora.org> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2013-06-11GPIO: clps711x: Rewrite driver for using generic GPIO codeAlexander Shiyan
This patch provides rewritten driver for CLPS711X GPIO which uses generic GPIO code. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-30gpio: max7300: Fix trivial typo in Kconfig help textAxel Lin
max7301 is controlled through SPI interface which means another driver. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-20gpio: mcp23s08: Fix build error when CONFIG_SPI_MASTER=y && CONFIG_I2C=mAxel Lin
This patch fixes below build error when CONFIG_SPI_MASTER=y && CONFIG_I2C=m && CONFIG_GPIO_MCP23S08=y. LD init/built-in.o drivers/built-in.o: In function `mcp23017_write': clkdev.c:(.text+0x1e14): undefined reference to `i2c_smbus_write_word_data' drivers/built-in.o: In function `mcp23017_read': clkdev.c:(.text+0x1e24): undefined reference to `i2c_smbus_read_word_data' drivers/built-in.o: In function `mcp23008_write': clkdev.c:(.text+0x1e8c): undefined reference to `i2c_smbus_write_byte_data' drivers/built-in.o: In function `mcp23008_read': clkdev.c:(.text+0x1e98): undefined reference to `i2c_smbus_read_byte_data' drivers/built-in.o: In function `mcp23008_read_regs': clkdev.c:(.text+0x1ed0): undefined reference to `i2c_smbus_read_byte_data' drivers/built-in.o: In function `mcp23s08_init': clkdev.c:(.init.text+0x30): undefined reference to `i2c_register_driver' drivers/built-in.o: In function `mcp23s08_exit': clkdev.c:(.exit.text+0x30): undefined reference to `i2c_del_driver' make: *** [vmlinux] Error 1 When CONFIG_I2C=m, meaning we can't build the drivers in with I2C support. Thus don't allow the drivers to be compiled as built-in when CONFIG_I2C=m. The real fix though is to break the driver apart into a SPI part, an I2C part and a common part. But that's something for 3.11 while this is something for 3.10/stable. Signed-off-by: Axel Lin <axel.lin@ingics.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-09Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull removal of GENERIC_GPIO from Grant Likely: "GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it is possible to do so which has been causing confusion and breakage. This branch does the work to completely eliminate GENERIC_GPIO." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: gpio: update gpio Chinese documentation Remove GENERIC_GPIO config option Convert selectors of GENERIC_GPIO to GPIOLIB blackfin: force use of gpiolib m68k: coldfire: use gpiolib mips: pnx833x: remove requirement for GENERIC_GPIO openrisc: default GENERIC_GPIO to false avr32: default GENERIC_GPIO to false xtensa: remove explicit selection of GENERIC_GPIO sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB powerpc: remove redundant GENERIC_GPIO selection unicore32: default GENERIC_GPIO to false unicore32: remove unneeded select GENERIC_GPIO arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB arm: remove redundant GENERIC_GPIO selection mips: alchemy: require gpiolib mips: txx9: change GENERIC_GPIO to GPIOLIB mips: loongson: use GPIO driver on CONFIG_GPIOLIB mips: remove redundant GENERIC_GPIO select
2013-05-07Merge tag 'soc-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates (part 2) from Arnd Bergmann: "These patches are all for Renesas shmobile, and depend on the earlier pinctrl updates. Remarkably, this adds support for three new SoCs: r8a73a4, r8a73a4 and r8a7778. The bulk of the code added for these is for pinctrl (using the new subsystem) and for clocks (not yet using the common clock subsystem). The latter will have to get converted in one of the upcoming releases, but shmobile is not ready for that yet. The series also contains Renesas shmobile board changes, adding one board file for each of the three new SoCs. These boards are using a mix of classic and device-tree based probing, as there is still a lot of infrastructure in shmobile that has not been converted to DT yet. Once those are resolved to the degree that no board specific setup code is needed, they can get folded into the respective SoC setup files." * tag 'soc-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (78 commits) ARM: shmobile: use r8a7790 timer setup code on Lager ARM: shmobile: force enable of r8a7790 arch timer ARM: shmobile: Add second I/O range for r8a7790 PFC ARM: shmobile: bockw: enable network settings on bootargs ARM: shmobile: bockw: add SMSC ethernet support ARM: shmobile: R8A7778: add Ether support ARM: shmobile: bockw: enable SMSC ethernet on defconfig ARM: shmobile: r8a7778: add r8a7778_init_irq_extpin() ARM: shmobile: r8a7778: remove pointless PLATFORM_INFO() ARM: shmobile: mackerel: clean up MMCIF vs. SDHI1 selection ARM: shmobile: mackerel: add interrupt names for SDHI0 ARM: shmobile: mackerel: switch SDHI and MMCIF interfaces to slot-gpio ARM: shmobile: mackerel: remove OCR masks, where regulators are used ARM: shmobile: mackerel: SDHI resources do not have to be numbered ARM: shmobile: Initial r8a7790 Lager board support ARM: shmobile: APE6EVM LAN9220 support ARM: shmobile: APE6EVM PFC support ARM: shmobile: APE6EVM base support ARM: shmobile: kzm9g-reference: add ethernet support ARM: shmobile: add R-Car M1A Bock-W platform support ...
2013-05-06Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull GPIO changes from Grant Likely: "The usual selection of bug fixes and driver updates for GPIO. Nothing really stands out except the addition of the GRGPIO driver and some enhacements to ACPI support" I'm pulling this despite the earlier mess. Let's hope it compiles these days. * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: (46 commits) gpio: grgpio: Add irq support gpio: grgpio: Add device driver for GRGPIO cores gpiolib-acpi: introduce acpi_get_gpio_by_index() helper GPIO: gpio-generic: remove kfree() from bgpio_remove call gpio / ACPI: Handle ACPI events in accordance with the spec gpio: lpc32xx: Fix off-by-one valid range checking for bank gpio: mcp23s08: convert driver to DT gpio/omap: force restore if context loss is not detectable gpio/omap: optimise interrupt service routine gpio/omap: remove extra context restores in *_runtime_resume() gpio/omap: free irq domain in probe() failure paths gpio: gpio-generic: Add 16 and 32 bit big endian byte order support gpio: samsung: Add terminating entry for exynos_pinctrl_ids gpio: mvebu: add dbg_show function MAX7301 GPIO: Do not force SPI speed when using OF Platform gpio: gpio-tps65910.c: fix checkpatch error gpio: gpio-timberdale.c: fix checkpatch error gpio: gpio-tc3589x.c: fix checkpatch errors gpio: gpio-stp-xway.c: fix checkpatch error gpio: gpio-sch.c: fix checkpatch error ...
2013-04-26gpio: grgpio: Add device driver for GRGPIO coresAndreas Larsson
This driver supports GRGPIO gpio cores available in the GRLIB VHDL IP core library from Aeroflex Gaisler. Signed-off-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-16Remove GENERIC_GPIO config optionAlexandre Courbot
GENERIC_GPIO has been made equivalent to GPIOLIB in architecture code and all driver code has been switch to depend on GPIOLIB. It is thus safe to have GENERIC_GPIO removed. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2013-04-04gpio: vt8500: Remove arch-vt8500 gpio driverTony Prisk
With the move to a combined pinctrl/gpio driver, the arch-vt8500 gpio driver is no longer required. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-03gpio: Renesas R-Car GPIO driver V3Magnus Damm
This patch is V3 of a GPIO driver for the R-Car series of SoCs from Renesas. This driver is designed to be reusable between multiple SoCs that share the same basic building block, but so far it has only been used on R-Car H1 (r8a7779). Each driver instance handles 32 GPIOs with individually maskable IRQs. The driver operates on a single I/O memory range and the 32 GPIOs are hooked up a single interrupt. In the case of R-Car H1 either external IRQ pins or GPIOs with interrupts can be used for on-board interupts. For external IRQs 4 pins are supported, and in the case of GPIO there are 202 GPIOS as 202 interrupts hooked up via 6 driver instances and to the GIC and the Cortex-A9 Quad. At this point this driver is interfacing as a regular platform device driver. In the future DT support will be submitted as an incremental feature patch. Signed-off-by: Magnus Damm <damm@opensource.se> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-03-27gpio-lynxpoint: Add X86 dependency and io-port handling header.Mathias Nyman
Lynxpoint gpio driver uses X86 specific io-ports to control gpios Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-26Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull GPIO changes from Grant Likely: "This branch contains the usual set of individual driver improvements and bug fixes, as well as updates to the core code. The more notable changes include: - Internally add new API for referencing GPIOs by gpio_desc instead of number. Eventually this will become a public API - ACPI GPIO binding support" * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: (33 commits) arm64: select ARCH_WANT_OPTIONAL_GPIOLIB gpio: em: Use irq_domain_add_simple() to fix runtime error gpio: using common order: let 'static const' instead of 'const static' gpio/vt8500: memory cleanup missing gpiolib: Fix locking on gpio debugfs files gpiolib: let gpio_chip reference its descriptors gpiolib: use descriptors internally gpiolib: use gpio_chips list in gpiochip_find_base gpiolib: use gpio_chips list in sysfs ops gpiolib: use gpio_chips list in gpiochip_find gpiolib: use gpio_chips list in gpiolib_sysfs_init gpiolib: link all gpio_chips using a list gpio/langwell: cleanup driver gpio/langwell: Add Cloverview ids to pci device table gpio/lynxpoint: add chipset gpio driver. gpiolib: add missing braces in gpio_direction_show gpiolib-acpi: Fix error checks in interrupt requesting gpio: mpc8xxx: don't set IRQ_TYPE_NONE when creating irq mapping gpiolib: remove gpiochip_reserve() arm: pxa: tosa: do not use gpiochip_reserve() ...
2013-02-24Merge tag 'mfd-3.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS updates from Samuel Ortiz: "This is the MFD pull request for the 3.9 merge window. No new drivers this time, but a bunch of fairly big cleanups: - Roger Quadros worked on a OMAP USBHS and TLL platform data consolidation, OMAP5 support and clock management code cleanup. - The first step of a major sync for the ab8500 driver from Lee Jones. In particular, the debugfs and the sysct interfaces got extended and improved. - Peter Ujfalusi sent a nice patchset for cleaning and fixing the twl-core driver, with a much needed module id lookup code improvement. - The regular wm5102 and arizona cleanups and fixes from Mark Brown. - Laxman Dewangan extended the palmas APIs in order to implement the palmas GPIO and rt drivers. - Laxman also added DT support for the tps65090 driver. - The Intel SCH and ICH drivers got a couple fixes from Aaron Sierra and Darren Hart. - Linus Walleij patchset for the ab8500 driver allowed ab8500 and ab9540 based devices to switch to the new abx500 pin-ctrl driver. - The max8925 now has device tree and irqdomain support thanks to Qing Xu. - The recently added rtsx driver got a few cleanups and fixes for a better card detection code path and now also supports the RTS5227 chipset, thanks to Wei Wang and Roger Tseng." * tag 'mfd-3.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (109 commits) mfd: lpc_ich: Use devres API to allocate private data mfd: lpc_ich: Add Device IDs for Intel Wellsburg PCH mfd: lpc_sch: Accomodate partial population of the MFD devices mfd: da9052-i2c: Staticize da9052_i2c_fix() mfd: syscon: Fix sparse warning mfd: twl-core: Fix kernel panic on boot mfd: rtsx: Fix issue that booting OS with SD card inserted mfd: ab8500: Fix compile error mfd: Add missing GENERIC_HARDIRQS dependecies Documentation: Add docs for max8925 dt mfd: max8925: Add dts mfd: max8925: Support dt for backlight mfd: max8925: Fix onkey driver irq base mfd: max8925: Fix mfd device register failure mfd: max8925: Add irqdomain for dt mfd: vexpress: Allow vexpress-sysreg to self-initialise mfd: rtsx: Support RTS5227 mfd: rtsx: Implement driving adjustment to device-dependent callbacks mfd: vexpress: Add pseudo-GPIO based LEDs mfd: ab8500: Rename ab8500 to abx500 for hwmon driver ...
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 update from Martin Schwidefsky: "The most prominent change in this patch set is the software dirty bit patch for s390. It removes __HAVE_ARCH_PAGE_TEST_AND_CLEAR_DIRTY and the page_test_and_clear_dirty primitive which makes the common memory management code a bit less obscure. Heiko fixed most of the PCI related fallout, more often than not missing GENERIC_HARDIRQS dependencies. Notable is one of the 3270 patches which adds an export to tty_io to be able to resize a tty. The rest is the usual bunch of cleanups and bug fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits) s390/module: Add missing R_390_NONE relocation type drivers/gpio: add missing GENERIC_HARDIRQ dependency drivers/input: add couple of missing GENERIC_HARDIRQS dependencies s390/cleanup: rename SPP to LPP s390/mm: implement software dirty bits s390/mm: Fix crst upgrade of mmap with MAP_FIXED s390/linker skript: discard exit.data at runtime drivers/media: add missing GENERIC_HARDIRQS dependency s390/bpf,jit: add vlan tag support drivers/net,AT91RM9200: add missing GENERIC_HARDIRQS dependency iucv: fix kernel panic at reboot s390/Kconfig: sort list of arch selected config options phylib: remove !S390 dependeny from Kconfig uio: remove !S390 dependency from Kconfig dasd: fix sysfs cleanup in dasd_generic_remove s390/pci: fix hotplug module init s390/pci: cleanup clp page allocation s390/pci: cleanup clp inline assembly s390/perf: cpum_cf: fallback to software sampling events s390/mm: provide PAGE_SHARED define ...
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-14drivers/gpio: add missing GENERIC_HARDIRQ dependencyHeiko Carstens
The VIA VX855/VX875 GPIO and RDC R-321x GPIO support drivers select MFD_CORE which itself depends on GENERIC_HARDIRQ support. So add this dependency to these two drivers as well to prevent selection of MFD_CORE. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-14gpio: palmas: Add support for Palmas GPIOLaxman Dewangan
Add gpio driver for TI Palmas series PMIC. This has 8 gpio which can work as input/output. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-05Merge branch 'linusw/devel' of ↵Grant Likely
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio.git into gpio/next Device driver features, cleanups and bug fixes. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-02-05gpio/lynxpoint: add chipset gpio driver.Mathias Nyman
Add gpio support for Intel Lynxpoint chipset. Lynxpoint supports 94 gpio pins which can generate interrupts. Driver will fail requests for pins that are marked as owned by ACPI, or set in an alternate mode (non-gpio). Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-01-30gpio: delete AB8500 driverLinus Walleij
The AB8500 GPIO driver has been marked BROKEN for ages, and we have something better in store: a shiny new pinctrl driver. So let use delete this old driver as the first step. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-22gpio: devm_gpio_* support should not depend on GPIOLIBShawn Guo
Some architectures (e.g. blackfin) provide gpio API without requiring GPIOLIB support (ARCH_WANT_OPTIONAL_GPIOLIB). devm_gpio_* functions should also work for these architectures, since they do not really depend on GPIOLIB. Add a new option GPIO_DEVRES (enabled by default) to control the build of devres.c. It also removes the empty version of devm_gpio_* functions for !GENERIC_GPIO build from linux/gpio.h, and moves the function declarations from asm-generic/gpio.h into linux/gpio.h. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-21drivers/gpio: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-19gpio/mvebu-gpio: Make mvebu-gpio depend on OF_CONFIGGregory CLEMENT
When building without device tree support (for the mv78x00 SoCs for example), the build failed because of_irq_count is undeclared. However mvebu-gpio is not designed to build without device tree support. So make it depends on OF_CONFIG, remove the #ifdef OF_CONFIG line and the platform_device_id. Tested on RD-78x00-mASA, DB-78460-BP, DB-88F6710-BP-DDR3, DB-MV784MP-GP, Mirabox and OpenBlocks AX3. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-12-16Merge tag 'mfd-3.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS update from Samuel Ortiz: "This is the MFD patch set for the 3.8 merge window. We have several new drivers, most of the time coming with their sub devices drivers: - Austria Microsystem's AS3711 - Nano River's viperboard - TI's TPS80031, AM335x TS/ADC, - Realtek's MMC/memstick card reader - Nokia's retu We also got some notable cleanups and improvements: - tps6586x got converted to IRQ domains. - tps65910 and tps65090 moved to the regmap IRQ API. - STMPE is now Device Tree aware. - A general twl6040 and twl-core cleanup, with moves to the regmap I/O and IRQ APIs and a conversion to the recently added PWM framework. - sta2x11 gained regmap support. Then the rest is mostly tiny cleanups and fixes, among which we have Mark's wm5xxx and wm8xxx patchset." Far amount of annoying but largely trivial conflicts. Many due to __devinit/exit removal, others due to one or two of the new drivers also having come in through another tree. * tag 'mfd-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (119 commits) mfd: tps6507x: Convert to devm_kzalloc mfd: stmpe: Update DT support for stmpe driver mfd: wm5102: Add readback of DSP status 3 register mfd: arizona: Log if we fail to create the primary IRQ domain mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQ mfd: tps80031: Add terminating entry for tps80031_id_table mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask() mfd: wm5102: Add tuning for revision B mfd: arizona: Defer patch initialistation until after first device boot mfd: tps65910: Fix wrong ack_base register mfd: tps65910: Remove unused data mfd: stmpe: Get rid of irq_invert_polarity mfd: ab8500-core: Fix invalid free of devm_ allocated data mfd: wm5102: Mark DSP memory regions as volatile mfd: wm5102: Correct default for LDO1_CONTROL_2 mfd: arizona: Register haptics devices mfd: wm8994: Make current device behaviour the default mfd: tps65090: MFD_TPS65090 needs to select REGMAP_IRQ mfd: Fix stmpe.c build when OF is not enabled mfd: jz4740-adc: Use devm_kzalloc ...
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
