[ Upstream commit f759921cfbf4847319d197a6ed7c9534d593f8bc ]
When a threaded irq handler is chained attached to one of the gpio
pins when configure for level irq the altera_gpio_irq_leveL_high_handler
does not mask the interrupt while being handled by the chained irq.
This resulting in the threaded irq not getting enough cycles to complete
quickly enough before the irq was disabled as faulty. handle_level_irq
should be used in this situation instead of handle_simple_irq.
In gpiochip_irqchip_add set default handler to handle_bad_irq as
per Documentation/gpio/driver.txt. Then set the correct handler in
the set_type callback.
Signed-off-by: Phil Reid <preid@electromag.com.au>
The state container of the Altera GPIO driver is extracted from
the gpio_chip exploiting the fact that offsetof() the
struct gpio_chip inside the struct of_mm_gpio_chip are both 0, so
the container_of() is in practice a noop. However if a member
is added to struct altera_gpio_chip in front of
struct of_mm_gpio_chip, things will break. Using proper
container_of() avoids this problem.
Semantically this is a noop, the compiler will optimize it away,
but syntactically it makes me happier.
Cc: Tien Hock Loh <thloh@altera.com>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
This driver calls of_mm_gpiochip_add() to add a memory mapped gpio
chip. So, of_mm_gpiochip_remove() should be used when removing it.
The direct call of gpiochip_remove() misses unmapping the register
and freeing the label.
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
Acked-by: Tien Hock Loh <thloh@altera.com>
The remove callback never succeeds, which seems odd.
This patch fixes some issues given by checkpatch. Fixes include
bracket placement, spacing and indenting.
Signed-off-by: Daniel Lockyer <thisisdaniellockyer@gmail.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Adds a new driver for Altera soft GPIO IP. The driver is able to do
read/write and allows GPIO to be a interrupt controller.
Tested on Altera GHRD on interrupt handling and IO.
v10:
- Updated conflicting device tree parameters
- Removed unused headers
- Used macro instead of magic numbers for ngpio
- Code readability cleanup using ?: and temporal variables
- Removed leftover garbage and unnecessary function calls
- Checked bgpio_init but unusable because Altera GPIO may not
be a multiple of 8 bits
v9:
- Removed duplicated initialization on set_type using temporals
to improve code readability in calling generic_handle_irq
- Using ?: ternary to reduce code size
v8:
- Using for_each_set_bit
- Added const for struct definition
- Removed naggy pr_err
- Sort alpha header
- Remove unused macros
- Use fixed width data types instead of unsigned long
- Whitespace issue fixes
- Removed _relaxed function for better compatibility across different
CPU
- Changed irq_create_mapping to platform_get_irq updated implementation
to use gpiochip_irqchip_add
- Reserve interrupt-cells number 2 in device tree binding for future
use
- Remove confusing sections on devicetree bindings
- Added tristate Kconfig help text
v7:
- Used dev_warn instead of pr_warn
- Clean up unnecesarry if else indentation
v6:
- Added irq_startup and irq_shutdown
- Changed bitwise clamping style
- Cleanup bitwise operation to improve readability change naming of
mapped irqs from virq to mapped_irq
v5:
- Dispose irq_domain mapping correctly
- Update optional binding description in binding docs
v4:
- Added vendor prefix to devicetree binding for IP specific properties
using MMIO GPIO helper library instead of manually map PIO to memory
- altera_gpio_chip inline struct documentation to kerneldoc
- Using dev_ print to print a better failure message
v2, v3:
- Do not reference NO_IRQ
- Updated irq_set_type to only allow the hardware configured irq type
Signed-off-by: Tien Hock Loh <thloh@altera.com>
