path: root/drivers/gpio/gpio-dwapb.c
2017-06-21gpio: dwapb: fix missing first irq for edgeboth irq typeXiaoguang Chen
dwapb_irq_set_type overwrites polarity register value for IRQ_TYPE_EDGE_BOTH case. If the polarity of one gpio is 0 by default, then it will set falling edge irq trigger. and the gpio may requires rising edge irq for the first time, and it will be missed. Do not overwrite polarity register for IRQ_TYPE_EDGE_BOTH case can solve this issue. Signed-off-by: Xiaoguang Chen <xgchenshy@gmail.com> Tested-by: Jisheng Zhang <jszhang@marvell.com> [Fix some really weird text encoding problem] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-04-24gpio: dwapb: use dwapb_read instead of readl_relaxedJisheng Zhang
Commit 67809b974a07 ("GPIO: gpio-dwapb: Change readl&writel to dwapb_read&dwapb_write") missed this readl_relaxed() usage, I'm not sure the reason, maybe for performance reason? But if we do care the performance, we could use the relaxed io in dwapb_read and dwapb_write. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-03-06gpio: dwapb: Add support for next generation of X-Gene SoCHoan Tran
Next generation of X-Gene SoC's GPIO hardware register map is very similar to DW GPIO. It only differs by a few register addresses. This patch modifies DW GPIO driver to accommodate the difference in a few register addresses. Signed-off-by: Hoan Tran <hotran@apm.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-01-26pinctrl / gpio: Introduce .set_config() callback for GPIO chipsMika Westerberg
Currently we already have two pin configuration related callbacks available for GPIO chips .set_single_ended() and .set_debounce(). In future we expect to have even more, which does not scale well if we need to add yet another callback to the GPIO chip structure for each possible configuration parameter. Better solution is to reuse what we already have available in the generic pinconf. To support this, we introduce a new .set_config() callback for GPIO chips. The callback takes a single packed pin configuration value as parameter. This can then be extended easily beyond what is currently supported by just adding new types to the generic pinconf enum. If the GPIO driver is backed up by a pinctrl driver the GPIO driver can just assign gpiochip_generic_config() (introduced in this patch) to .set_config and that will take care configuration requests are directed to the pinctrl driver. We then convert the existing drivers over .set_config() and finally remove the .set_single_ended() and .set_debounce() callbacks. Suggested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-07-22gpio: dwapb: add missing fwnode_handle_put() in dwapb_gpio_get_pdata()Wei Yongjun
fwnode_handle_put() should be used when terminating device_for_each_child_node() iteration with break or return to prevent stale device node references from being left behind. Generated by Coccinelle. Fixes: 4ba8cfa79f44 ("gpio: dwapb: convert device node to fwnode") Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-05-11gpio: dwapb: Add ACPI device ID for DWAPB GPIO controller on X-Gene platformsDuc Dang
This patch enables DWAPB GPIO controller support on X-Gene platforms in ACPI boot mode. Signed-off-by: Duc Dang <dhdang@apm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-29gpio: dwapb: add gpio-signaled acpi event supportJiang Qiu
This patch adds gpio-signaled acpi event support. It is used for power button on hisilicon D02 board, an arm64 platform. The corresponding DSDT file is defined as follows: Device(GPI0) { Name(_HID, "HISI0181") Name(_ADR, 0) Name(_UID, 0) Name (_CRS, ResourceTemplate () { Memory32Fixed (ReadWrite, 0x802e0000, 0x10000) Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive,,,) {344} }) Device(PRTa) { Name (_DSD, Package () { Package () { Package () {"reg",0}, Package () {"snps,nr-gpios",32}, } }) } Name (_AEI, ResourceTemplate () { GpioInt(Edge, ActiveLow, ExclusiveAndWake, PullUp, , " \\_SB.GPI0") {8} }) Method (_E08, 0x0, NotSerialized) { Notify (\_SB.PWRB, 0x80) } } Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Jiang Qiu <qiujiang@huawei.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-29gpio: dwapb: convert device node to fwnodeJiang Qiu
This patch converts device node to fwnode for dwapb driver, so as to provide a unified fwnode for DT and ACPI bindings. Tested-by: Alan Tull <delicious.quinoa@gmail.com> Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Jiang Qiu <qiujiang@huawei.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-29gpio: dwapb: remove name from dwapb_port_propertyJiang Qiu
This patch removed the name property from dwapb_port_property. The name property is redundant, since we can get this info from dwapb_gpio dev node. Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Jiang Qiu <qiujiang@huawei.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-01-05gpio: generic: factor into gpio_chip structLinus Walleij
The separate struct bgpio_chip has been a pain to handle, both by being confusingly similar in name to struct gpio_chip and for being contained inside a struct so that struct gpio_chip is contained in a struct contained in a struct, making several steps of dereferencing necessary. Make things simpler: include the fields directly into <linux/gpio/driver.h>, #ifdef:ed for CONFIG_GENERIC_GPIO, and get rid of the <linux/basic_mmio_gpio.h> altogether. Prefix some of the member variables with bgpio_* and add proper kerneldoc while we're at it. Modify all users to handle the change and use a struct gpio_chip directly. And while we're at it: replace all container_of() dereferencing by gpiochip_get_data() and registering the gpio_chip with gpiochip_add_data(). Cc: arm@kernel.org Cc: Alexander Shiyan <shc_work@mail.ru> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Kukjin Kim <kgene@kernel.org> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Brian Norris <computersforpeace@gmail.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Olof Johansson <olof@lixom.net> Cc: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Cc: Rabin Vincent <rabin@rab.in> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-omap@vger.kernel.org Cc: linux-samsung-soc@vger.kernel.org Cc: bcm-kernel-feedback-list@broadcom.com Acked-by: Gregory Fong <gregory.0xf0@gmail.com> Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-07-14gpio: Use irq_desc_get_xxx() to avoid redundant lookup of irq_descJiang Liu
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we already have a pointer to corresponding irq_desc. Preparatory patch for the removal of the 'irq' argument from irq flow handlers. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-06-25gpio/dwapb: Fix race in installing chained IRQ handlerThomas Gleixner
Fix a race where a pending interrupt could be received and the handler called before the handler's data has been setup, by converting to irq_set_chained_handler_and_data(). Search and conversion was done with coccinelle: @@ expression E1, E2, E3; @@ ( -if (irq_set_chained_handler(E1, E3) != 0) - BUG(); | -irq_set_chained_handler(E1, E3); ) -irq_set_handler_data(E1, E2); +irq_set_chained_handler_and_data(E1, E3, E2); @@ expression E1, E2, E3; @@ ( -if (irq_set_chained_handler(E1, E3) != 0) - BUG(); ... | -irq_set_chained_handler(E1, E3); ... ) -irq_set_handler_data(E1, E2); +irq_set_chained_handler_and_data(E1, E3, E2); Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: linux-gpio@vger.kernel.org
2015-01-15gpio: dwapb: Convert to use resource managed APIsAxel Lin
Use resource managed APIs to simplify the code a bit. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-10-28gpio: rename gpio_lock_as_irq to gpiochip_lock_as_irqAlexandre Courbot
This function actually operates on a gpio_chip, so its prefix should reflect that fact for consistency with other functions defined in gpio/driver.h. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20gpio: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-24gpio: dwapb: fix pointer to integer castLinus Walleij
The statements BUG_ON(ctx == 0) was implicitly casting a pointer to an integer for comparison. Do this with a bool test instead to get away from sparse warnings. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23GPIO: gpio-dwapb: Suspend & Resume PM enablingWeike Chen
This patch enables suspend and resume mode for the power management, and it is based on Josef Ahmad's previous work. Reviewed-by: Hock Leong Kweh <hock.leong.kweh@intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@intel.com> Signed-off-by: Weike Chen <alvin.chen@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23GPIO: gpio-dwapb: Support DebounceWeike Chen
This patch enables 'debounce' for the designware GPIO, and it is based on Josef Ahmad's previous work. Reviewed-by: Hock Leong Kweh <hock.leong.kweh@intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Weike Chen <alvin.chen@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23GPIO: gpio-dwapb: Change readl&writel to dwapb_read&dwapb_writeWeike Chen
This patch replaces 'readl&writel' with 'dwapb_read&dwapb_write'. Reviewed-by: Shevchenko, Andriy <andriy.shevchenko@intel.com> Signed-off-by: Weike Chen <alvin.chen@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23GPIO: gpio-dwapb: Enable platform driver binding to MFD driverWeike Chen
The Synopsys DesignWare APB GPIO driver only supports open firmware devices. But, like Intel Quark X1000 SOC, which has a single PCI function exporting a GPIO and an I2C controller, it is a Multifunction device. This patch is to enable the current Synopsys DesignWare APB GPIO driver to support the Multifunction device which exports the designware GPIO controller. Reviewed-by: Hock Leong Kweh <hock.leong.kweh@intel.com> Signed-off-by: Weike Chen <alvin.chen@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-22gpio: remove all usage of gpio_remove retval in driver/gpioabdoulaye berthe
Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-27gpio: dwapb: use a second irq chipSebastian Andrzej Siewior
Right new have one irq chip running always in level mode. It would nicer to have two irq chips where one is handling level type interrupts and the other one is doing edge interrupts. So we can have at runtime two users where one is using edge and the other level. Acked-by: Alan Tull <delicious.quinoa@gmail.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-04-28gpio: dwapb: drop irq_setup_generic_chip()Sebastian Andrzej Siewior
The driver calls irq_alloc_domain_generic_chips() which creates a gc and adds it to gc_list. The driver later then calls irq_setup_generic_chip() which also initializes the gc and adds it to the gc_list() and this corrupts the list. Enable LIST_DEBUG and you see the kernel complain. This isn't required, irq_alloc_domain_generic_chips() did the init. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Tested-by: Alan Tull <delicious.quinoa@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-03-18gpio: switch drivers to use new callbackLinus Walleij
This switches all GPIO and pin control drivers with irqchips that were using .startup() and .shutdown() callbacks to lock GPIO lines for IRQ usage over to using the .request_resources() and .release_resources() callbacks just introduced into the irqchip vtable. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jean-Jacques Hiblot <jjhiblot@traphandler.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-03-05gpio: add a driver for the Synopsys DesignWare APB GPIO blockJamie Iles
The Synopsys DesignWare block is used in some ARM devices (picoxcell) and can be configured to provide multiple banks of GPIO pins. v12: - Add irq_startup/shutdown - do irq_create_mapping() in probe, irq_find_mapping() in to_irq() - Adjust mappings to show support for 1 gpio per port. - gpio-cells = <1> v11: - Use NULL when checking existence of 'interrupts' property - Bindings descriptions cleanup v10: - in documentation nr-gpio -> nr-gpios v9: - cleanup in dt bindings doc - use of_get_child_count() v8: - remove socfpga.dtsi changes - minor cleanup in devicetree documentation v7: - use irq_generic_chip - support one irq per gpio line or one irq for many - s/bank/port/ and other cleanup v6: - (atull) squash the set of patches - use linear irq domain - build fixes. Original driver was reviewed on v3.2. - Fix setting irq edge type for 'rising' and 'both'. - Support as a loadable module. - Use bgpio_chip's spinlock during register access. - Clean up register names to match spec - s/bank/port/ because register names use the word 'port' - s/nr-gpio/nr-gpios/ - don't get/put the of_node - remove signoffs/acked-by's because of changes - other cleanup v5: - handle sparse bank population correctly v3: - depend on rather than select IRQ_DOMAIN - split IRQ support into a separate patch v2: - use Rob Herring's irqdomain in generic irq chip patches - use reg property to indicate bank index - support irqs on both edges based on LinusW's u300 driver Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Alan Tull <atull@altera.com> Reviewed-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
