path: root/drivers/gpio/gpio-langwell.c
2011-10-06gpio: langwell: ensure alternate function is clearedAdrian Hunter
Alternate function must be zero for the pin to act as a GPIO. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-22Merge branch 'gpio/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: (61 commits) gpio/mxc/mxs: fix build error introduced by the irq_gc_ack() renaming mcp23s08: add i2c support mcp23s08: isolate spi specific parts mcp23s08: get rid of setup/teardown callbacks gpio/tegra: dt: add binding for gpio polarity mcp23s08: remove unused work queue gpio/da9052: remove a redundant assignment for gpio->da9052 gpio/mxc: add device tree probe support ARM: mxc: use ARCH_NR_GPIOS to define gpio number gpio/mxc: get rid of the uses of cpu_is_mx() gpio/mxc: add missing initialization of basic_mmio_gpio shadow variables gpio: Move mpc5200 gpio driver to drivers/gpio GPIO: DA9052 GPIO module v3 gpio/tegra: Use engineering names in DT compatible property of/gpio: Add new method for getting gpios under different property names gpio/dt: Refine GPIO device tree binding gpio/ml-ioh: fix off-by-one for displaying variable i in dev_err gpio/pca953x: Deprecate meaningless device-tree bindings gpio/pca953x: Remove dynamic platform data pointer gpio/pca953x: Fix IRQ support. ...
2011-06-06gpio: reorganize driversGrant Likely
Sort the gpio makefile and enforce the naming convention gpio-*.c for gpio drivers. v2: cleaned up filenames in Kconfig and comment blocks v3: fixup use of BASIC_MMIO to GENERIC_GPIO for mxc Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
