commit 1b02d9e770cd7087f34c743f85ccf5ea8372b047 upstream.
If the module init function fails after creating the debugs directory,
it's never removed. Add proper cleanup calls to avoid this resource
leak.
Fixes: 9202ba2397d1 ("gpio: mockup: implement event injecting over debugfs")
Cc: <stable@vger.kernel.org>
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
When using single_open() for opening, single_release() should be
used instead of seq_release(), otherwise there is a memory leak.
Fixes: 2a9e27408e12 ("gpio: mockup: rework debugfs interface")
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
When calling debugfs functions, there is no need to ever check the
return value. The function can work or not, but the code logic should
never do something different based on this.
Cc: Bamvor Jian Zhang <bamv2005@gmail.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Cc: linux-gpio@vger.kernel.org
[Bartosz: removed one more check for debugfs return value]
Calling read() for a single byte read will return 2 currently. Use
simple_read_from_buffer() which correctly handles all sizes.
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
The debugfs read callback must advance ppos or users using read() on
the file descriptor will never get the EOL. This wasn't spotted before
as I was using busybox cat for testing which uses sendfile() internally
and only noticed it now when switched to cat from coreutils.
Modify the way the debugfs interface works in gpio-mockup. Introduce
the concept of dummy pull config which will keep the mockup lines in
known state. The pull values can be modified by writing to the debugfs
files corresponding to lines. Lines in input mode always report the
current pull value, lines in output mode change the line value but
it will revert back to the one specified by current pull when released.
The unlocked variants only get called from places where we already have
the pointer to the underlying gpio_mockup_chip structure, so take it
as parameter instead of struct gpio_chip.
This field can never be negative.
User-space tests no longer use it and we're breaking the interface
anyway.
We already support set_multiple(). Implement get_multiple() as well.
While no user reported any race condition problems with gpio-mockup,
let's be on the safe side and use a mutex when performing any changes
on the dummy chip structures.
Suggested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Commit 3edfb7bd76bd ("gpiolib: Show correct direction from the
beginning") fixed an existing issue but broke libgpiod tests by
changing the default direction of dummy lines to output.
We don't break user-space so make gpio-mockup behave as before.
Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl>
Some users want to introduce device tree support to the mockup driver.
Let's make it easier by switching to using generic device properties.
The driver stays compatible with previous use cases and after this
conversion there'll be no need to change the way probing of mockup
GPIO chips works.
Tested with libgpiod test suite.
Use the SPDX license identifier for GPLv2.0 or later and remove the
license boilerplate.
If we failed to create the top debugfs directory, we must not try to
create the child nodes. We currently only check if gpio_mockup_dbg_dir
is not NULL, but it can also contain an errno if debugfs is disabled
in build options. Use IS_ERR_OR_NULL() instead.
Bamvor changed his mail so let's updat his mail address
everywhere.
The return value of platform_device_register_resndata() on error is
an error code converted to pointer with ERR_PTR(), not NULL.
Check the return value correctly.
Fixes: 8a39f597bcfd ("gpio: mockup: rework device probing")
In order to avoid repeating the calculations on every access - add
helpers for gpio base and ngpio components of the ranges array.
This variable holds the number of mockup GPIO ranges so rename it
accordingly.
As discussed with Marc Zyngier: irq_sim_init() and its devres variant
should return the base of the allocated interrupt range on success
rather than 0. This will be modified later - first, change the way
users handle the return value of these routines.
Implement the set_multiple() callback and register it with the gpiolib
framework. This is only meant to also test the internal kernel API.
Minor readability tweak: prefer breaking the lines in a way where the
second part is longer than the first.
Improve the module params sanitization: bail out from init if the user
tries to pass a non-positive number of GPIO lines for any mockup chip.
The debugfs routines returning pointers can return NULL or error codes
embedded with ERR_PTR(). Check the return values with IS_ERR_OR_NULL().
While we're at it: make the error message more specific so it's not
confused with the one emitted when the top-level gpio-mockup debugfs
directory creation fails.
Keep GPIO chip callbacks, event trigger callbacks and mockup chip
setup code visibly separated. We're mostly good - just need to move
the line naming routine below.
GPIO values are universally represented as integers. Change the type
of the variable storing the current line value to int for consistency.
Currently each chip has a dedicated directory in debugfs for event
triggers. We use the chip's label for the directory name, but the user
can't really associate these directories with chip names without
parsing the relevant sysfs entries.
Use chip names for directory names. For backward compatibility: create
links pointing to the actual directories named using the chip labels.
Move the last bits of code dealing with module parameters to the init
function. Add a new variable to platform data, which indicates to the
probe function if it should name the GPIO lines. If we ever want to
make the line naming more fine-grained (e.g. per chip switch) it will
be easier this way.
Now that the probe() function only does what is should, there's no
need to split the chip adding logic into a separate routine. Merge
gpio_mockup_add() into gpio_mockup_probe().
Minor coding style fix.
Visually shrink the pr_err() calls by encapsulating adding the module
name prefix to the message in a macro.
We currently create a single platform device in init and then parse
the configuration passed to us via module parameters in probe() before
creating GPIO chips and registering them with the gpiolib framework.
The relation between platform devices and mockup chips should be 1:1.
Create a separate platform device for each mockup chip using convenient
helpers (platform_device_register_resndata()). Pass a platform data
structure to probe() in which the configuration (GPIO base, number of
lines, chip index) extracted from the module params is stored. Make
probe() create a single mockup chip for every platform device.
This approach has several advantages:
- we only parse the module parameters in init() and can bail out before
attaching any device if the input is invalid (currently we would
have to examine kernel logs),
- we'll get notified by the device framework about errors in probe()
for specific chips,
- probe() gets simplified and only does what it's supposed to.
The number of supported mockup chips is limited. Check this limit when
parsing the module parameters.
Also: make sure that each chip is described with a <base - ngpio> pair.
If the module parameters are invalid, we should bail out from the init
function instead of detecting it during the device probe. That way we
don't even allow the user to load the module if we don't accept the
arguments.
Add the gpio_mockup_ prefix to the remaining symbols that still don't
have it, so that the entire driver code is consistent.
The variable gc is assigned but never read and is redundant. Remove it.
Cleans up clang warning:
drivers/gpio/gpio-mockup.c:169:2: warning: Value stored to 'gc' is never read
Shrink the driver by removing the code dealing with dummy interrupts
and replacing it with calls to the irq_sim API.
Acked-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
When allocating a zeroed array of objects use devm_kcalloc() instead
of manually calculating the required size and using devm_kzalloc().
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Just taking credit for the recent changes and new features. :)
Indicate the error number and make the message a bit more elaborate.
When the requested number of GPIO lines is 0, return -EINVAL, not
-1 which is -EPERM.
We currently shift bits here and there without actually explaining
what we're doing. Add some helper variables with names indicating
their purpose to improve the code readability.
Currently we ignore the last odd range value, since each chip is
described by two values. Be more strict and require the user to
pass an even number of ranges.
Invert the logic of the irq_enabled check and only access the private
data after the input is sanitized.
We're currently only checking the first character of the input to the
debugfs event files, so a string like '0sdfdsf' is valid and indicates
a falling edge event.
Be more strict and only allow '0', '1', '0\n' & '1\n'.
While we're at it: move the sanitization code before the irq_enabled
check so that we indicate an error on invalid input even if nobody is
waiting for events.
Even though this is a testing module, be nice and actually implement
these functions.
When inserting and removing the module repeatedly (e.g. when running
the libgpiod test-suite) the kernel log gets clobbered with messages
reporting successful creation of dummy gpiochips.
Remove this message and only emit logs when something bad happens.
All internal symbols except for the direction enum follow the same
convention and use the gpio_mockup prefix. Add the prefix to the
DIR_IN and DIR_OUT definitions as well for consistency across the
file.
The comment in linux/gpio/driver.h says:
@get_direction: returns direction for signal "offset", 0=out, 1=in
We got those switched at some point. Fix the values.
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.12 kernel cycle.
Core changes:
- Return NULL from gpiod_get_optional() when GPIOLIB is disabled.
This was a much discussed change. It affects use cases where people
write drivers that might or might not be using GPIO resources. I
have decided that this is the lesser evil right now.
- Make gpiod_count() behave consistently across different hardware
descriptions.
- Fix the syntax around open drain/open source to not infer active
high/low semantics.
New drivers:
- A new single-register fixed-direction framework driver for hardware
that have lines controlled by a single register that just work in
one direction (out or in), including IRQ support.
- Support the Fintek F71889A GPIO SuperIO controller.
- Support the National NI 169445 MMIO GPIO.
- Support for the X-Gene derivative of the DWC GPIO controller
- Support for the Rohm BD9571MWV-M PMIC GPIO controller.
- Refactor the Gemini GPIO driver to a generic Faraday FTGPIO driver
and replace both the Gemini and the Moxa ART custom drivers with
this driver.
Driver improvements:
- A whole slew of drivers have their spinlocks chaned to raw
spinlocks as they provide irqchips, and thus we are progressing on
realtime compliance.
- Use devm_irq_alloc_descs() in a slew of drivers, getting managed
resources.
- Support for the embedded PWM controller inside the MVEBU driver.
- Debounce, open source and open drain support for the Aspeed driver.
- Misc smaller fixes like spelling and syntax and whatnot"
* tag 'gpio-v4.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (77 commits)
gpio: f7188x: Add a missing break
gpio: omap: return error if requested debounce time is not possible
gpio: Add ROHM BD9571MWV-M PMIC GPIO driver
gpio: gpio-wcove: fix GPIO IRQ status mask
gpio: DT bindings, move tca9554 from pcf857x to pca953x
gpio: move tca9554 from pcf857x to pca953x
gpio: arizona: Correct check whether the pin is an input
gpio: Add XRA1403 DTS binding documentation
dt-bindings: add exar to vendor prefixes list
gpio: gpio-wcove: fix irq pending status bit width
gpio: dwapb: use dwapb_read instead of readl_relaxed
gpio: aspeed: Add open-source and open-drain support
gpio: aspeed: Add debounce support
gpio: aspeed: dt: Add optional clocks property
gpio: aspeed: dt: Fix description alignment in bindings document
gpio: mvebu: Add limited PWM support
gpio: Use unsigned int for interrupt numbers
gpio: f7188x: Add F71889A GPIO support.
gpio: core: Decouple open drain/source flag with active low/high
gpio: arizona: Correct handling for reading input GPIOs
