Replace all trivial request/free callbacks that do nothing but call into
pinctrl code with the generic versions.
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: James Hogan <james.hogan@imgtec.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Acked-by: Joachim Eastwood <manabian@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Adding a BGPIOF_READ_OUTPUT_REG_SET initialization flag to GPIO
generic MMIO driver makes possible to remove a private get() value
function from the driver.
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
This patch converts MOXART GPIO driver to use basic_mmio_gpio
generic library.
Signed-off-by: Kamlakant Patel <kamlakant.patel@linaro.org>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Tested-by: Jonas Jensen <jonas.jensen@gmail.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The site-specific OOM messages are unnecessary, because they
duplicate the MM subsystem generic OOM message.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
moxart_gpio_direction_output() ignored the state passed into it. Fix it.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
Slightly adjust the code to avoid forward declaration as we need to call
moxart_gpio_set() in moxart_gpio_direction_output() to properly set the
output state.
There is a error message within devm_ioremap_resource
already, so remove the dev_err call to avoid redundant
error message.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Add missing .owner of struct gpio_chip. This prevents the
module from being removed from underneath its users.
Renaming "moxart_gpio_base" to "base" allows better fit,
remove line breaks in moxart_gpio_get().
While doing trivial cleanup, also remove fields initialized
with zero in moxart_template_chip.
Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com>
Add GPIO driver for MOXA ART SoCs.
