path: root/drivers/gpio/gpio-sch.c
2014-04-28gpio-sch: set output level after configuration of directionDaniel Krueger
According to the datasheet, writing to the level register has no effect when GPIO is programmed as input. Actually the the level register is read-only when configured as input. Thus presetting the output level before switching to output is _NOT_ possible. Any writes are lost! Hence we set the level after configuring the GPIO as output. But we cannot prevent a short low pulse if direction is set to high and an external pull-up is connected. Signed-off-by: Daniel Krueger <daniel.krueger@systec-electronic.com> Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-20gpio: Don't override the error code in probe error handlingAxel Lin
Otherwise, we return 0 in probe error paths when gpiochip_remove() returns 0. Also show error message if gpiochip_remove() fails. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Tomoya MORINAGA <tomoya.rohm@gmail.com> Cc: Denis Turischev <denis@compulab.co.il> Cc: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-27gpio: gpio-sch.c: fix checkpatch errorLaurent Navet
Fix : gpio/gpio-sch.c:206: ERROR: switch and case should be at the same indent Also remove blank lines Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-27gpio-sch: Allow for more than 8 lines in the resume wellDarren Hart
The E6xx (TunnelCreek) CPUs have 9 GPIO lines in the resume well. Update the resume functions to allow for more than 8 GPIO lines, using the core functions as a template. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-28gpio: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-05gpio-sch: Fix leak of resourceAlan Cox
Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-05-22gpio: Add Intel Centerton support to gpio-schSeth Heasley
This patch adds the Intel Centerton processor device ID for GPIO. The device ID is defined in include/linux/pci_ids.h Signed-off-by: Seth Heasley <seth.heasley@intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-01-02gpio: Convert GPIO drivers to module_platform_driverMark Brown
Where appropriate factor out some boilerplate code for platform device registration into module_platform_driver. Drivers that don't use the standard module_init initcall haven't been converted. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06gpio: reorganize driversGrant Likely
Sort the gpio makefile and enforce the naming convention gpio-*.c for gpio drivers. v2: cleaned up filenames in Kconfig and comment blocks v3: fixup use of BASIC_MMIO to GENERIC_GPIO for mxc Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
