path: root/drivers/gpio/gpio-tb10x.c
2015-10-16gpio: replace trivial implementations of request/free with generic oneJonas Gorski
Replace all trivial request/free callbacks that do nothing but call into pinctrl code with the generic versions. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: James Hogan <james.hogan@imgtec.com> Acked-by: Stefan Agner <stefan@agner.ch> Acked-by: Joachim Eastwood <manabian@gmail.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-06-02gpio: tb10x: Drop unneeded free_irq() callAxel Lin
Current code uses devm_request_irq() in .probe, so drop the unneeded free_irq() call in .remove. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Christian Ruppert <christian.ruppert@alitech.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-27gpio: gpio-tb10x: remove incorrect __exit markupDmitry Torokhov
Even if bus is not hot-pluggable, the devices can be unbound from the driver via sysfs, so we should not be using __exit annotations on remove() methods. The only exception is drivers registered with platform_driver_probe() which specifically disables sysfs bind/unbind attributes. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-10-28gpio: gpio-tb10x: remove duplicate check on resourceVarka Bhadram
Sanity check on resource happening with devm_ioremap_resource(). Signed-off-by: Varka Bhadram <varkab@cdac.in> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20gpio: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-22gpio: remove all usage of gpio_remove retval in driver/gpioabdoulaye berthe
Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-02gpio: tb10x: Remove redundant of_match_ptr helperSachin Kamat
'tb10x_gpio_dt_ids' is always compiled in. Hence the helper macro is not needed. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-09Merge tag 'v3.13-rc3' into develLinus Walleij
Linux 3.13-rc3
2013-12-04gpio/pinctrl: make gpio_chip members typed booleanLinus Walleij
This switches the two members of struct gpio_chip that were defined as unsigned foo:1 to bool, because that is indeed what they are. Switch all users in the gpio and pinctrl subsystems to assign these values with true/false instead of 0/1. The users outside these subsystems will survive since true/false is 1/0, atleast we set some kind of more strict typing example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-11-25gpio: tb10x: Set output value before setting direction to outputAxel Lin
Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Christian Ruppert <christian.ruppert@abilis.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-30gpio: tb10x: fix return value check in tb10x_gpio_probe()Wei Yongjun
In case of error, the function devm_ioremap_resource() returns ERR_PTR() and never returns NULL. The NULL test in the return value check should be replaced with IS_ERR(). Also remove the dev_err call to avoid redundant error message. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-30gpio: tb10x: use module_platform_driver to simplify the codeWei Yongjun
module_platform_driver() makes the code simpler by eliminating boilerplate code. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-25gpio: add TB10x GPIO driverChristian Ruppert
The GPIO driver for the Abilis Systems TB10x series of SOCs based on ARC700 CPUs. It supports GPIO control and GPIO interrupt generation. This driver works in conjunction with the TB10x pinctrl driver. Signed-off-by: Sascha Leuenberger <sascha.leuenberger@abilis.com> Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com> Acked-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
