Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Change-Id: I082f222945f054b585659cbd65d042d45e3cd225
Reviewed-on: http://git-master/r/269997
Replaced write to GPIO pin with read-modify write as old value was
overwritten.
Original-Change-Id: I679994ba920b70f90a2b1654ee2c0fcc3e08d02e
Reviewed-on: http://git-master/r/14540
Reviewed-by: Amit Kamath <akamath@nvidia.com>
Tested-by: Amit Kamath <akamath@nvidia.com>
Rebase-Id: Rf7e30c62eb580ed8727142b3b5604e2b7990f144
-on reset default direction is in NOT_CONFIGURED (neither input
nor output) mode.
-as tps6586x driver has not implemented direction_input, gpiolib
sysfs only creates a value node not any direction node for
each gpios. so from user space there is no way to set direction
(or to call function tps6586x_update).
-by adding empty function for direction_input solves the above
problem by providing direction node in sysfs.
Original-Change-Id: I608bcfcd4392c20afab39874deacc6dc20f45063
Reviewed-on: http://git-master/r/11340
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Tested-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-by: Peter Zu <pzu@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Re07f62867121955f8f91f0418667923e7795ba5d
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFS update from Samuel Ortiz:
"This is the MFD patch set for the 3.8 merge window.
We have several new drivers, most of the time coming with their sub
devices drivers:
- Austria Microsystem's AS3711
- Nano River's viperboard
- TI's TPS80031, AM335x TS/ADC,
- Realtek's MMC/memstick card reader
- Nokia's retu
We also got some notable cleanups and improvements:
- tps6586x got converted to IRQ domains.
- tps65910 and tps65090 moved to the regmap IRQ API.
- STMPE is now Device Tree aware.
- A general twl6040 and twl-core cleanup, with moves to the regmap
I/O and IRQ APIs and a conversion to the recently added PWM
framework.
- sta2x11 gained regmap support.
Then the rest is mostly tiny cleanups and fixes, among which we have
Mark's wm5xxx and wm8xxx patchset."
Far amount of annoying but largely trivial conflicts. Many due to
__devinit/exit removal, others due to one or two of the new drivers also
having come in through another tree.
* tag 'mfd-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (119 commits)
mfd: tps6507x: Convert to devm_kzalloc
mfd: stmpe: Update DT support for stmpe driver
mfd: wm5102: Add readback of DSP status 3 register
mfd: arizona: Log if we fail to create the primary IRQ domain
mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQ
mfd: tps80031: Add terminating entry for tps80031_id_table
mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask()
mfd: wm5102: Add tuning for revision B
mfd: arizona: Defer patch initialistation until after first device boot
mfd: tps65910: Fix wrong ack_base register
mfd: tps65910: Remove unused data
mfd: stmpe: Get rid of irq_invert_polarity
mfd: ab8500-core: Fix invalid free of devm_ allocated data
mfd: wm5102: Mark DSP memory regions as volatile
mfd: wm5102: Correct default for LDO1_CONTROL_2
mfd: arizona: Register haptics devices
mfd: wm8994: Make current device behaviour the default
mfd: tps65090: MFD_TPS65090 needs to select REGMAP_IRQ
mfd: Fix stmpe.c build when OF is not enabled
mfd: jz4740-adc: Use devm_kzalloc
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Peter Tyser <ptyser@xes-inc.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
The TPS6586x adds the interrupt of this device using
linear mapping on irq domain.
Hence, implement gpio_to_irq to get the irq number
corresponding to TPS6586x GPIOs which is created
dynamically.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Converting the gpio driver of tps6586x to a platform
driver in place of registering the gpio through core
driver.
The motivation of the change is:
- This is inline with the mfd drivers implementation.
- This will move the related gpio support to gpio driver
folder where all gpio related drivers are available.
This will be easy the maintenance and enhancement is
anything done for gpio.
- The gpio functionality can be selected through config
variable.
